H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
54-MPLS Configuration Guide
54-MPLS Configuration Guide 623.27 KB
Table of Contents
1 MPLS Configuration Guide· 1-1
Network Diagram·· 1-1
Networking and Configuration Requirements· 1-1
Applicable Product Matrix· 1-1
Configuration Procedure· 1-1
Complete Configuration· 1-5
Configuration Guidelines· 1-6
2 MPLS L2VPN Configuration Guide· 2-1
Guide for Configuring a Remote CCC Connection· 2-1
Network Diagram·· 2-1
Networking and Configuration Requirements· 2-1
Applicable Product Matrix· 2-1
Configuration Procedure· 2-1
Complete Configuration· 2-4
Configuration Guidelines· 2-5
Configuring SVC MPLS L2VPN· 2-6
Network Diagram·· 2-6
Networking and Configuration Requirements· 2-6
Applicable Product Matrix· 2-6
Configuration Procedure· 2-6
Complete Configuration· 2-10
Configuration Guidelines· 2-12
Configuring Martini MPLS L2VPN· 2-12
Network Diagram·· 2-12
Networking and Configuration Requirements· 2-12
Applicable Product Matrix· 2-12
Configuration Procedure· 2-12
Complete Configuration· 2-16
Configuration Guidelines· 2-18
Configuring Kompella MPLS L2VPN· 2-18
Network Diagram·· 2-18
Networking and Configuration Requirements· 2-18
Applicable Product Matrix· 2-19
Configuration Procedure· 2-19
Complete Configuration· 2-21
Configuration Guidelines· 2-23
3 MPLS L3VPN Configuration Guide· 3-1
Configuring MPLS L3VPNs· 3-1
Network Diagram·· 3-1
Networking and Configuration Requirements· 3-1
Applicable Product Matrix· 3-2
Configuration Procedure· 3-2
Complete Configuration· 3-8
Configuration Guidelines· 3-12
Configuring Inter-Provider VPN Option A· 3-12
Network Diagram·· 3-12
Networking and Configuration Requirements· 3-13
Applicable Product Matrix· 3-13
Configuration Procedure· 3-13
Complete Configuration· 3-17
Configuration Guidelines· 3-22
Configuring Inter-Provider VPN Option B· 3-22
Network Diagram·· 3-22
Networking and Configuration Requirements· 3-22
Applicable Product Matrix· 3-23
Configuration Procedure· 3-23
Complete Configuration· 3-27
Configuration Guidelines· 3-31
Configuring Inter-Provider VPN Option C· 3-31
Network Diagram·· 3-31
Networking and Configuration Requirements· 3-31
Applicable Product Matrix· 3-31
Configuration Procedure· 3-32
Complete Configuration· 3-37
Configuration Guidelines· 3-40
Configuring Carrier’s Carrier 3-41
Network Diagram·· 3-41
Networking and Configuration Requirements· 3-41
Applicable Product Matrix· 3-41
Configuration Procedure· 3-42
Complete Configuration· 3-49
Configuration Guidelines· 3-53
Configuring Nested VPN· 3-54
Network Diagram·· 3-54
Networking and Configuration Requirements· 3-54
Applicable Product Matrix· 3-55
Configuration Procedure· 3-55
Complete Configuration· 3-65
Configuration Guidelines· 3-69
Configuring OSPF Sham Links· 3-69
Network Diagram·· 3-69
Networking and Configuration Requirements· 3-70
Applicable Product Matrix· 3-70
Configuration Procedure· 3-70
Complete Configuration· 3-74
Configuration Guidelines· 3-77
Configuring BGP AS Number Substitution· 3-77
Network Diagram·· 3-77
Networking and Configuration Requirements· 3-77
Applicable Product Matrix· 3-77
Configuration Procedure· 3-78
Complete Configuration· 3-80
Configuration Guidelines· 3-82
Network Diagram
Figure 1-1 Network diagram for configuring LDP sessions
l          Switch A, Switch B, and Switch C all support MPLS. Configure them to run OSPF.
l          Two local LDP sessions are established. One is between Switch A and Switch B, and the other is between Switch B and Switch C.
l          A remote LDP session is established between Switch A and Switch C.
l          The three switches establish an LSP using the local LDP sessions.
Product series
Software version
Hardware version
S7500E Series Ethernet Switches
Release 6300
LSQ1SRP1CB SRPU(s), or exclusively EA series LPUs
1)            Configure the IP addresses of the interfaces
Configure the IP addresses and masks of the interfaces including the VLAN interfaces and loopback interfaces as required in Figure 1-1. The detailed configuration procedure is omitted here.
2)            Configure the routes for OSPF to advertise
# Configure Switch A.
[Sysname] sysname SwitchA
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[SwitchA-ospf-1] quit
# Configure Switch B.
[Sysname] sysname SwitchB
[SwitchB] ospf
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[SwitchB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SwitchB-ospf-1] quit
# Configure Switch C.
[Sysname] sysname SwitchC
[SwitchC] ospf
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[SwitchC-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SwitchC-ospf-1] quit
After completing the above configurations, you will see that every switch has learned the routes to other switches if you execute the display ip routing-table command. The following takes Switch A as an example:
Routing Tables: Public
         Destinations : 9        Routes : 9
Destination/Mask  Proto  Pre  Cost     NextHop      Interface
      1.1.1.9/32  Direct 0    0        127.0.0.1    InLoop0
      2.2.2.9/32  OSPF   10   1563     10.1.1.2     Vlan1
      3.3.3.9/32  OSPF   10   3125     10.1.1.2     Vlan1
     10.1.1.0/24  Direct 0    0        10.1.1.1     Vlan1
     10.1.1.1/32  Direct 0    0        127.0.0.1    InLoop0
     10.1.1.2/32  Direct 0    0        10.1.1.2     Vlan1
     20.1.1.0/24  OSPF   10   3124     10.1.1.2     Vlan1
    127.0.0.0/8   Direct 0    0        127.0.0.1    InLoop0
    127.0.0.1/32  Direct 0    0        127.0.0.1    InLoop0
Now, OSPF adjacency should have been established between Switch A and Switch B and between Switch B and Switch C respectively. If you execute the display ospf peer verbose command, you will find that the neighbors are in the state of Full. The following takes Switch A as an example:
[SwitchA] display ospf peer verbose
          OSPF Process 1 with Switch ID 1.1.1.9
                  Neighbors
 Area 0.0.0.0 interface 10.1.1.1(Vlan-interface1)'s neighbors
 Router ID: 2.2.2.9      Address: 10.1.1.2        GR State: Normal
   State: Full  Mode:Nbr is  Master  Priority: 1
   DR: None   BDR: None   MTU: 1500
   Dead timer due in 39  sec
   Neighbor is up for 00:02:13
3)            Configure MPLS basic capability and enable LDP
[SwitchA] mpls lsr-id 1.1.1.9
[SwitchA] mpls
[SwitchA-mpls] quit
[SwitchA] mpls ldp
[SwitchA-mpls-ldp] quit
[SwitchA-Vlan-interface1] mpls
[SwitchA-Vlan-interface1] mpls ldp
[SwitchB] mpls lsr-id 2.2.2.9
[SwitchB] mpls
[SwitchB-mpls] quit
[SwitchB] mpls ldp
[SwitchB-mpls-ldp] quit
[SwitchB] interface vlan-interface 1
[SwitchB-Vlan-interface1] mpls
[SwitchB-Vlan-interface1] mpls ldp
[SwitchB-Vlan-interface1] quit
[SwitchB-Vlan-interface2] mpls
[SwitchB-Vlan-interface2] mpls ldp
[SwitchC] mpls lsr-id 1.1.1.9
[SwitchC] mpls
[SwitchC-mpls] quit
[SwitchC] mpls ldp
[SwitchC-mpls-ldp] quit
[SwitchC] interface vlan-interface 1
[SwitchC-Vlan-interface1] mpls
[SwitchC-Vlan-interface1] mpls ldp
[SwitchC-Vlan-interface1] quit
After completing the above configurations, local sessions should have been established between Switch A and Switch B and between Switch B and Switch C. You can execute the display mpls ldp session command to check whether the local sessions have been established, or use the display mpls ldp peer command to check the peers. The following takes Switch A as an example:
[SwitchA] display mpls ldp session
               LDP Session(s) in Public Network
Total number of sessions: 1
 Peer-ID       Status        LAM  SsnRole  FT   MD5  KA-Sent/Rcv
 2.2.2.9:0     Operational   DU   Passive  Off  Off  5/5
 LAM : Label Advertisement Mode         FT  : Fault Tolerance
[SwitchA] display mpls ldp peer
         LDP Peer Information in Public network
Total number of peers: 1
 Peer-ID                Transport-Address  Discovery-Source
 2.2.2.9:0              2.2.2.9            Vlan-interface1
4)            Configure the remote LDP session
[SwitchA] mpls ldp remote-peer peerc
[SwitchA-mpls-ldp-remote-peerc] remote-ip 3.3.3.9
[SwitchA-mpls-ldp-remote-peerc] quit
[SwitchC] mpls ldp remote-peer peera
[SwitchC-mpls-ldp-remote-peera] remote-ip 1.1.1.9
[SwitchC-mpls-ldp-remote-peera] quit
After completing the above configurations, you will find by issuing the following commands on Switch A that the remote LDP session with Switch C is already established:
Total number of sessions: 2
 2.2.2.9:0     Operational   DU   Passive  Off  Off  35/35
 3.3.3.9:0     Operational   DU   Passive  Off  Off  8/8
Total number of peers: 2
 3.3.3.9:0              3.3.3.9            Remote Peer : peerc
# Configure the LSP establishment triggering policy as all, that is, allowing any static route or IGP route to trigger LDP to establish an LSP.
l          On Switch A.
[SwitchA] mpls
[SwitchA-mpls] lsp-trigger all
[SwitchA-mpls] return
l          On Switch B.
[SwitchB] mpls
[SwitchB-mpls] lsp-trigger all
[SwitchB-mpls] quit
l          On Switch C.
[SwitchC] mpls
[SwitchC-mpls] lsp-trigger all
[SwitchC-mpls] quit
l          Configuration on Switch A
 mpls lsr-id 1.1.1.9
mpls
  lsp-trigger all
mpls ldp
 remote-ip 3.3.3.9
interface Vlan-interface1
 mpls
 mpls ldp
ospf 1
 area 0.0.0.0
l          Configuration on Switch B
 mpls lsr-id 2.2.2.9
mpls
 lsp-trigger all
mpls ldp
 mpls
 mpls ldp
interface Vlan-interface2
 mpls
 mpls ldp
ospf 1
 area 0.0.0.0
l          Configuration on Switch C
 mpls lsr-id 3.3.3.9
mpls
 lsp-trigger all
mpls ldp
 remote-ip 1.1.1.9
 mpls
 mpls ldp
ospf 1
 area 0.0.0.0
l          When an MPLS label stack is inserted between the header and payload of a frame, the frame may exceed the allowed length of the data link layer and cannot be forwarded. Therefore, if you enable MPLS for a VLAN interface, you are recommended to enable forwarding of jumbo frames for ports in the VLAN and specify a proper frame length according to the application and the number of label layers. For example, if you need to encapsulate two layers of MPLS labels for FTP packets, you need to configure the allowed jumbo frame length on the ports as 1544 bytes: 1518 bytes for the FTP packet + 4 bytes × 2 for MPLS labels + 4 bytes for the VLAN tag + 14 bytes for the Ethernet frame header. For details about forwarding of jumbo frames, refer to Ethernet Interface Configuration in the Access Volume.
l          If you disable the LDP capability of an interface, all LDP sessions on the interface will be disconnected, and thus all LSPs based on the sessions will be removed.
l          If a local adjacency exists between two peers, no remote adjacency can be established between them. If a remote adjacency exists between two peers, you can configure local adjacency for them. However, the local adjacency can be established only when the transport address and keepalive settings of the two peers match respectively, in which case the remote adjacency will be removed. That is, only one remote session or local session can exist between two LSRs, and the local session takes precedence over the remote session.
l          The remote peer IP address to be configured must be different from all existing remote peer IP addresses. Otherwise, the configuration fails.
Network Diagram
Figure 2-1 Network Diagram for caonfiguring a remote CCC conection
Device
IP address
Device
IP address
CE 1
Vlan-int10
100.1.1.1/24
P
Loop0
10.0.0.2/32
PE 1
Loop0
10.0.0.1/32
Vlan-int20
10.2.2.2/24
Vlan-int30
10.1.1.1/24
Vlan-int30
10.1.1.2/24
CE 2
Vlan-int10
100.1.1.2/24
PE 2
Loop0
10.0.0.3/32
Vlan-int20
10.2.2.1/24
l          The CEs are connected to the PEs through VLAN interfaces.
l          A remote CCC connection is created between CE 1 and CE 2.
Product series
Software version
Hardware version
Release 6300,
The main steps for configuring a remote CCC connection are:
l          Create remote CCC connections on the PEs. No static LSP is required on the PEs.
l          Configure two static LSPs on the P device for packets to be transferred in both directions.
1)        Configure CE 1
[Sysname] sysname CE1
[CE1] interface vlan-interface 10
[CE1-Vlan-interface10] ip address 100.1.1.1 24
2)        Configure PE 1
# Configure the LSR ID and enable MPLS globally.
[Sysname] sysname PE1
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 10.0.0.1 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 10.0.0.1
[PE1] mpls
[PE1-mpls] quit
# Enable MPLS L2VPN globally.
[PE1] mpls l2vpn
# Create interface VLAN-interface 10.
[PE1] interface Vlan-interface 10
[PE1-Vlan-interface10] quit
# Configure interface VLAN-interface 30 and enable MPLS.
[PE1] interface vlan-interface 30
[PE1-Vlan-interface30] ip address 10.1.1.1 24
[PE1-Vlan-interface30] mpls
[PE1-Vlan-interface30] quit
# Create a remote connection from CE 1 to CE 2, using the interface connecting CE 1 as the incoming interface and that connecting the P device as the outgoing interface, setting the incoming label to 100 and the outgoing label to 200.
[PE1] ccc ce1-ce2 interface vlan-interface 10 in-label 100 out-label 200 next-hop 10.1.1.2
3)            Configure the P device
[Sysname] sysname P
[P] interface loopback 0
[P-LoopBack0] ip address 10.0.0.2 32
[P-LoopBack0] quit
[P] mpls lsr-id 10.0.0.2
[P] mpls
[P-mpls] quit
[P] interface vlan-interface 30
[P-Vlan-interface30] ip address 10.1.1.2 24
[P-Vlan-interface30] mpls
[P-Vlan-interface30] quit
# Configure interface VLAN-interface 20 and enable MPLS.
[P] interface vlan-interface 20
[P-Vlan-interface20] ip address 10.2.2.2 24
[P-Vlan-interface20] mpls
[P-Vlan-interface20] quit
# Create a static LSP for forwarding packets from PE 1 to PE 2.
[P] static-lsp transit pe1_pe2 incoming-interface vlan-interface 10 in-label 200 next-hop 10.2.2.1 out-label 201
# Create a static LSP for forwarding packets from PE 2 to PE 1.
[P] static-lsp transit pe2_pe1 incoming-interface vlan-interface 20 in-label 101 next-hop 10.1.1.1 out-label 100
4)            Configure PE 2
[Sysname] sysname PE2
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 10.0.0.3 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 10.0.0.3
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls l2vpn
# Configure interface VLAN-interface 10.
[PE2] interface vlan-interface 10
[PE2-Vlan-interface20] quit
[PE2] interface vlan-interface 20
[PE2-Vlan-interface20] ip address 10.2.2.1 24
[PE2-Vlan-interface20] mpls
# Create a remote connection from CE 2 to CE 1, using the interface connecting CE 2 as the incoming interface and that connecting the P device as the outgoing interface, setting the incoming label to 201 and the outgoing label to 101.
[PE2] ccc ce2-ce1 interface vlan-interface 10 in-label 201 out-label 101  next-hop 10.2.2.2
5)            Configure CE 2
[Sysname] sysname CE2
[CE2] interface vlan-interface 10
[CE2-Vlan-interface10] ip address 100.1.1.2 24
6)        Verify your configuration
After completing the above configurations, you can display CCC connection information on PE 1. There should be one local CCC connection established. CE 1 and CE 2 should be able to ping each other.
# Display CCC connection information on PE 1.
[PE1] display ccc
    Total  ccc vc          : 1
    Local  ccc vc          : 0,  0 up
    Remote ccc vc          : 1,  1 up
 ***Name                   : ce1-ce2
    Type                   : remote
    State                  : up
    Intf                   : Vlan-interface10 (up)
    In-label               : 100
    Out-label              : 200
    Nexthop                : 10.1.1.2
# Ping CE 2 from CE 1.
[CE1] ping 100.1.1.2
  PING 100.1.1.2: 56  data bytes, press CTRL_C to break
    Reply from 100.1.1.2: bytes=56 Sequence=1 ttl=255 time=180 ms
    Reply from 100.1.1.2: bytes=56 Sequence=2 ttl=255 time=60 ms
    Reply from 100.1.1.2: bytes=56 Sequence=3 ttl=255 time=10 ms
    Reply from 100.1.1.2: bytes=56 Sequence=4 ttl=255 time=70 ms
    Reply from 100.1.1.2: bytes=56 Sequence=5 ttl=255 time=60 ms
  --- 100.1.1.2 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 10/76/180 ms
l          Configuration on CE 1
interface Vlan-interface10
 ip address 100.1.1.1 255.255.255.0
l          Configuration on PE 1
mpls
mpls l2vpn
interface LoopBack0
 ip address 10.0.0.1 255.255.255.255
interface Vlan-interface30
 mpls
 ccc ce1-ce2 interface Vlan-interface10 in-label 100 out-label 200 nexthop 10.1.1.2
mpls
interface Vlan-interface20
 ip address 10.2.2.2 255.255.255.0
 mpls
 mpls
 static-lsp transit pe1_pe2 incoming-interface Vlan-interface30 in-label 200 nexthop 10.2.2.1 out-label 201
 static-lsp transit pe2_pe1 incoming-interface Vlan-interface20 in-label 101 nexthop 10.1.1.1 out-label 100
l          Configuration on PE 2
mpls
mpls l2vpn
interface LoopBack0
 ip address 10.0.0.3 255.255.255.255
 ip address 10.2.2.1 255.255.255.0
 mpls
l          Configuration on CE 2
 ip address 100.1.1.2 255.255.255.0
l          You do not need to configure two LSPs for each remote CCC connection on a PE. Instead, you just need to configure an incoming label and outgoing label for a remote CCC connection. The incoming label is for the CCC connection exclusively, which therefore equals the configuration of static LSPs.
l          On each P device between two PEs, you need to configure two static LSPs in opposite directions (bi-directional LSP) for transmitting data of CCC connections.
Network Diagram
Device
IP address
Device
IP address
CE 1
Vlan-int10
100.1.1.1/24
P
Loop0
192.4.4.4/32
PE 1
Loop0
192.2.2.2/32
Vlan-int30
10.2.2.2/24
Vlan-int20
10.1.1.1/24
Vlan-int20
10.1.1.2/24
CE 2
Vlan-int10
100.1.1.2/24
PE 2
Loop0
192.3.3.3/32
Vlan-int30
10.2.2.1/24
Figure 2-2 Network diagram for configuring SVC MPLS L2VPN
l          CEs are connected to PEs through VLAN interfaces.
l          An SVC MPLS L2VPN is established between CE 1 and CE 2.
Product series
Software version
Hardware version
Release 6300,
The main steps are the following two:
l          Configure MPLS basic forwarding capability on the PEs and P device. This includes configuring the LSR ID, enabling MPLS and LDP, and running IGP (OSPF in this example) between PE 1, the P device, and PE 2 to establish LSPs.
l          Establish an SVC MPLS L2VPN connection. This includes enabling MPLS L2VPN on PE 1 and PE 2 and establishing an SVC connection and specifying the VC labels.
1)            Configure CE 1
2)            Configure PE 1
[PE1-LoopBack0] ip address 192.2.2.2 32
[PE1] mpls lsr-id 192.2.2.2
[PE1] mpls
# Configure the LSP establishment triggering policy.
[PE1-mpls] lsp-trigger all
[PE1-mpls] quit
# Enable MPLS L2VPN and LDP globally.
[PE1] mpls l2vpn
[PE1] mpls ldp
[PE1-mpls-ldp] quit
# Configure the interface connected with the P device, namely VLAN-interface 20, and enable LDP on the interface.
[PE1] interface vlan-interface 20
[PE1-Vlan-interface20] ip address 10.1.1.1 24
[PE1-Vlan-interface20] mpls
[PE1-Vlan-interface20] mpls ldp
[PE1-Vlan-interface20] quit
# Configure OSPF on PE 1 for establishing LSPs.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.1 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 192.2.2.2 0.0.0.0
[PE1-ospf-1] quit
# On the interface connecting CE 1, namely VLAN-interface 10, create an SVC MPLS L2VPN connection. The interface requires no IP address.
[PE1] interface vlan-interface 10
[PE1-Vlan-interface10] mpls static-l2vc destination 192.3.3.3 transmit-vpn-label 100 receive-vpn-label 200
[Sysname] sysname P
[P-LoopBack0] ip address 192.4.4.4 32
[P-LoopBack0] quit
[P] mpls lsr-id 192.4.4.4
[P] mpls
[P-mpls] lsp-trigger all
[P-mpls] quit
# Enable LDP globally.
[P] mpls ldp
[P-mpls-ldp] quit
# Configure the interface connected with PE 1, namely VLAN-interface 20, and enable LDP on the interface.
[P-Vlan-interface20] ip address 10.1.1.2 24
[P-Vlan-interface20] mpls ldp
# Configure the interface connected with PE 2, namely VLAN-interface 30, and enable LDP on the interface.
[P-Vlan-interface30] link-protocol ppp
[P-Vlan-interface30] ip address 10.2.2.2 24
[P-Vlan-interface30] mpls ldp
# Configure OSPF on the P device for establishing LSPs.
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.2 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.2.2.2 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 192.4.4.4 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
4)            Configure PE 2
[PE2-LoopBack0] ip address 192.3.3.3 32
[PE2] mpls lsr-id 192.3.3.3
[PE2] mpls
[PE2-mpls] lsp-trigger all
[PE2-mpls] quit
[PE2] mpls l2vpn
[PE2] mpls ldp
[PE2-mpls-ldp] quit
# Configure the interface connected with the P device, namely VLAN-interface 30, and enable LDP on the interface.
[PE2] interface vlan-interface 30
[PE2-Vlan-interface30] ip address 10.2.2.1 24
[PE2-Vlan-interface30] mpls
[PE2-Vlan-interface30] mpls ldp
[PE2-Vlan-interface30] quit
# Configure OSPF on PE 2 for establishing LSPs.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.2.2.1 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 192.3.3.3 0.0.0.0
[PE2-ospf-1] quit
# On the interface connecting CE 2, namely VLAN-interface 10, create an SVC MPLS L2VPN connection. The interface requires no IP address.
[PE2-Vlan-interface10] mpls static-l2vc destination 192.2.2.2 transmit-vpn-label 200 receive-vpn-label 100
[PE2-Vlan-interface10] quit
5)            Configure CE 2
After completing the above configurations, you can display SVC L2VPN connection information on PE 1 or PE 2. There should be one L2VPN connection established. CE 1 and CE 2 should be able to ping each other.
# Display SVC L2VPN connection information on PE 1.
[PE1] display mpls static-l2vc
total connections:  1,  1 up,  0 down
ce-intf             state destination     tr-label  rcv-label tnl-policy
Vlan10               up    192.3.3.3       100       200       default
# Display SVC L2VPN connection information on PE 2.
[PE2] display mpls static-l2vc
Vlan20               up    192.2.2.2       200       100       default
    Reply from 100.1.1.2: bytes=56 Sequence=1 ttl=255 time=150 ms
    Reply from 100.1.1.2: bytes=56 Sequence=2 ttl=255 time=130 ms
    Reply from 100.1.1.2: bytes=56 Sequence=3 ttl=255 time=130 ms
    Reply from 100.1.1.2: bytes=56 Sequence=4 ttl=255 time=140 ms
    Reply from 100.1.1.2: bytes=56 Sequence=5 ttl=255 time=80 ms
    0.00% packet loss
    round-trip min/avg/max = 80/126/150 ms
mpls
 lsp-trigger all
mpls l2vpn
mpls ldp
interface LoopBack0
 ip address 192.2.2.2 255.255.255.255
 mpls
 mpls ldp
ospf 1
 area 0
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 ip address 192.4.4.4 255.255.255.255
 mpls
 mpls ldp
 mpls
 mpls ldp
ospf 1
 area 0
l          Configuration on PE2
mpls
 lsp-trigger all
mpls l2vpn
mpls ldp
interface LoopBack0
 ip address 192.3.3.3 255.255.255.255
 mpls
 mpls ldp
ospf 1
 area 0
l          Configuration on CE2
None
Network Diagram
Device
IP address
Device
IP address
CE 1
Vlan-int10
100.1.1.1/24
P
Loop0
192.4.4.4/32
PE 1
Loop0
192.2.2.2/32
Vlan-int20
10.1.1.2/24
Vlan-int20
10.1.1.1/24
Vlan-int30
10.2.2.2/24
CE 2
Vlan-int10
100.1.1.2/24
PE 2
Loop0
192.3.3.3/32
Vlan-int30
10.2.2.1/24
Figure 2-3 Network diagram for configuring Martini MPLS L2VPN
l          A Martini MPLS L2VPN is established between CE 1 and CE 2.
Product series
Software version
Hardware version
Release 6300,
1)        Configure CE 1
2)        Configure PE 1
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls l2vpn
[PE1] mpls ldp
[PE1-mpls-ldp] quit
# Establish a remote session between PE 1 and PE 2.
[PE1] mpls ldp remote-peer 1
[PE1-mpls-ldp-remote-1] remote-ip 192.3.3.3
[PE1-mpls-ldp-remote-1] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# On the interface connecting CE 1, namely VLAN-interface 10, create a Martini MPLS L2VPN connection. The interface requires no IP address.
[PE1-Vlan-interface10] mpls l2vc 192.3.3.3 101
[Sysname] sysname P
[P-LoopBack0] quit
[P] mpls
[P-mpls] quit
[P] mpls ldp
[P-mpls-ldp] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
4)        Configure PE 2
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls l2vpn
[PE2] mpls ldp
[PE2-mpls-ldp] quit
# Configure an LDP remote session between PE 2 and PE 1.
[PE2] mpls ldp remote-peer 2
[PE2-mpls-ldp-remote-2] remote-ip 192.2.2.2
[PE2-mpls-ldp-remote-2] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.2.2.0 0.0.0.255
[PE2-ospf-1] quit
# On the interface connecting CE 2, namely VLAN-interface 10, create a L2VPN connection. The interface requires no IP address.
[PE2-Vlan-interface10] mpls l2vc 192.2.2.2 101
5)        Configure CE 2
After completing the above configurations, you can display L2VPN connection information on PE 1 or PE 2. There should be one L2VC established. CE 1 and CE 2 should be able to ping each other.
# Display L2VPN connection information on PE 1.
[PE1] display mpls l2vc
total ldp vc : 1     1 up       0 down
Transport  Client                   VC      Local      Remote     Tunnel
VC ID      Intf                     State   VC Label   VC Label   Policy
101        Vlan10                    up      8193       8192       default
# Display L2VPN connection information on PE 2.
[PE2] display mpls l2vc
101        Vlan10                    up      8192       8193       default
    Reply from 100.1.1.2: bytes=56 Sequence=1 ttl=255 time=30 ms
    Reply from 100.1.1.2: bytes=56 Sequence=3 ttl=255 time=50 ms
    Reply from 100.1.1.2: bytes=56 Sequence=4 ttl=255 time=40 ms
    Reply from 100.1.1.2: bytes=56 Sequence=5 ttl=255 time=70 ms
    0.00% packet loss
    round-trip min/avg/max = 30/50/70 ms
mpls
 lsp-trigger all
mpls l2vpn
mpls ldp
 remote-ip 192.3.3.3
interface LoopBack0
 mpls
 mpls ldp
ospf 1
 area 0
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 mpls
 mpls ldp
 mpls
 mpls ldp
ospf 1
 area 0
mpls
 lsp-trigger all
mpls l2vpn
mpls ldp
 remote-ip 192.2.2.2
interface LoopBack0
 mpls
 mpls ldp
ospf 1
 area 0
None
Network Diagram
Figure 2-4 Network diagram for configuring Kompella MPLS L2VPN
Device
IP address
Device
IP address
CE 1
Vlan-int10
100.1.1.1/24
P
Loop0
3.3.3.3/32
PE 1
Loop0
2.2.2.2/32
Vlan-int20
10.1.1.2/24
Vlan-int20
10.1.1.1/24
Vlan-int30
10.2.2.2/24
CE 2
Vlan-int10
100.1.1.2/24
PE 2
Loop0
4.4.4.4/32
Vlan-int30
10.2.2.1/24
l          A Kompella MPLS L2VPN is established between CE 1 and CE 2.
Product series
Software version
Hardware version
Release 6300,
1)        Configure IGP on the MPLS backbone
This example uses OSPF. The detailed configuration steps are omitted.
After configuration, issuing the display ip routing-table command on each LSR, you should see that it has learned the routes to the LSR IDs of the other LSRs. Issuing the display ospf peer command, you should see that OSPF adjacencies have been established and reached the state of Full.
2)        Configure MPLS basic capability and LDP to establish LDP LSPs
After configuration, you can issue the display mpls ldp session and display mpls ldp peer commands to view the LDP sessions and peer relationship established, or the display mpls lsp command to view the LSPs established.
3)        Configure BGP L2VPN capability
# Configure PE 1.
[PE1] mpls l2vpn
[PE1] bgp 100
[PE1-bgp] peer 4.4.4.4 as-number 100
[PE1-bgp] peer 4.4.4.4 connect-interface loopback 0
[PE1-bgp] l2vpn-family
[PE1-bgp-af-l2vpn] policy vpn-target
[PE1-bgp-af-l2vpn] peer 4.4.4.4 enable
[PE1-bgp-af-l2vpn] quit
[PE1-bgp] quit
# Configure PE 2.
[PE2] mpls l2vpn
[PE2] bgp 100
[PE2-bgp] peer 2.2.2.2 as-number 100
[PE2-bgp] peer 2.2.2.2 connect-interface loopback 0
[PE2-bgp] l2vpn-family
[PE2-bgp-af-l2vpn] policy vpn-target
[PE2-bgp-af-l2vpn] peer 2.2.2.2 enable
[PE2-bgp-af-l2vpn] quit
[PE2-bgp] quit
After completing the above configurations, you can issue the display bgp l2vpn peer command on PE 1 and PE 2 to view the peer relationship established between the PEs. The status should be Established. The following takes PE 1 as an example:
[PE1] display bgp l2vpn peer
BGP local router ID : 2.2.2.2
 Local AS number : 100
 Total number of peers : 1                 Peers in established state : 1
  Peer      V   AS   MsgRcvd   MsgSent  OutQ PrefRcv Up/Down  State
  4.4.4.4   4   100        2        5     0       0  00:01:07 Established
4)            Configure the L2VPN and the CE connection
# Configure PE 1. The configurations of the VLAN interfaces are similar to those for Martini MPLS L2VPN and are omitted.
[PE1] mpls l2vpn vpn1 encapsulation vlan
[PE1-mpls-l2vpn-vpn1] route-distinguisher 100:1
[PE1-mpls-l2vpn-vpn1] vpn-target 1:1
[PE1-mpls-l2vpn-vpn1] ce ce1 id 1 range 10
[PE1-mpls-l2vpn-ce-vpn1-ce1] connection ce-offset 2 interface vlan-interface 10
[PE1-mpls-l2vpn-ce-vpn1-ce1] quit
[PE1-mpls-l2vpn-vpn1] quit
# Configure PE 2.
[PE2] mpls l2vpn vpn1 encapsulation vlan
[PE2-mpls-l2vpn-vpn1] route-distinguisher 100:1
[PE2-mpls-l2vpn-vpn1] vpn-target 1:1
[PE2-mpls-l2vpn-vpn1] ce ce2 id 2 range 10
[PE2-mpls-l2vpn-ce-vpn1-ce2] connection ce-offset 1 interface vlan-interface 10
[PE2-mpls-l2vpn-ce-vpn1-ce2] quit
[PE2-mpls-l2vpn-vpn1] quit
5)        Verify your configuration
After completing the above configurations, you can issue the display mpls l2vpn connection command on the PEs. You should see that an L2VPN connection is established between the PEs and the connection is up. CE 1 and CE 2 should be able to ping each other. The following takes PE 1 as an example:
# Display the MPLS L2VPN connection information on PE 1.
[PE1] display mpls l2vpn connection
1 total connections,
connections: 1 up, 0 down, 0 local, 1 remote, 0 unknown
VPN name: vpn1,
  CE name: ce1, id: 1,
  Rid type status peer-id         route-distinguisher   intf
  2   rmt  up     4.4.4.4         100:1                 Vlan10
    Reply from 100.1.1.2: bytes=56 Sequence=1 ttl=255 time=90 ms
    Reply from 100.1.1.2: bytes=56 Sequence=2 ttl=255 time=77 ms
    Reply from 100.1.1.2: bytes=56 Sequence=3 ttl=255 time=34 ms
    Reply from 100.1.1.2: bytes=56 Sequence=4 ttl=255 time=46 ms
    Reply from 100.1.1.2: bytes=56 Sequence=5 ttl=255 time=94 ms
    0.00% packet loss
    round-trip min/avg/max = 34/68/94 ms
mpls lsr-id 2.2.2.2
mpls
 lsp-trigger all
mpls l2vpn
mpls ldp
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 mpls
 mpls ldp
ospf 1
 area 0
network 2.2.2.2 0.0.0.0
bgp 100
 undo synchronization
 peer 4.4.4.4 connect-interface LoopBack0
 l2vpn-family
  peer 4.4.4.4 enable
  vpn-target 1:1 import-extcommunity
  vpn-target 1:1 export-extcommunity
  ce ce1 id 1 range 10 default-offset 0
   connection ce-offset 2 interface Vlan-interface10
mpls lsr-id 3.3.3.3
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 mpls
 mpls ldp
 mpls
 mpls ldp
ospf 1
 area 0
network 3.3.3.3 0.0.0.0
mpls lsr-id 4.4.4.4
mpls
 lsp-trigger all
mpls l2vpn
mpls ldp
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 mpls
 mpls ldp
ospf 1
 area 0
network 4.4.4.4 0.0.0.0
bgp 100
 peer 2.2.2.2 connect-interface LoopBack0
 l2vpn-family
  peer 2.2.2.2 enable
  ce ce2 id 2 range 10 default-offset 0
   connection ce-offset 1 interface Vlan-interface10
l          To configure Kompella MPLS L2VPN, on a PE, you need to configure an L2VPN instance respectively for each VPN that a directly connected CE belongs to. When configuring an L2VPN, you need to specify the same encapsulation type as that on the CE-side interface.
l          The functions of the VPN targets and Route Distinguishers (RDs) configured above in MPLS-L2VPN view are the same as those configured in MPLS L3VPN. For a Kompella L2VPN, you must configure an RD. You cannot change an RD directly; you can only delete the VPN instance, re-create the VPN instance, and then configure a new RD.
Network Diagram
Figure 3-1 Configure MPLS L3VPNs
Device
IP address
Device
IP address
CE 1
Vlan-int1
10.1.1.1/24
P
Loop0
2.2.2.9/32
PE 1
Loop0
1.1.1.9/32
Vlan-int1
172.2.1.1/24
Vlan-int1
10.1.1.2/24
Vlan-int3
172.1.1.2/24
Vlan-int3
172.1.1.1/24
PE 2
Loop0
3.3.3.9/32
Vlan-int2
10.2.1.2/24
Vlan-int1
172.2.1.2/24
CE 2
Vlan-int1
10.2.1.1/24
Vlan-int2
10.3.1.2/24
CE 3
Vlan-int1
10.3.1.1/24
Vlan-int3
10.4.1.2/24
CE 4
Vlan-int1
10.4.1.1/24
l          CE 1 and CE 3 belong to VPN 1, while CE 2 and CE 4 belong to VPN 2.
l          VPN 1 uses VPN target attributes 111:1, while VPN 2 uses VPN target attributes 222:2. Users of different VPNs cannot access each other.
l          PEs and the P device support MPLS.
Product series
Software version
Hardware version
Release 6300,
1)        Configure IGP on the MPLS backbone, enabling the PEs and the P device to communicate
# Configure PE 1.
<PE1> system-view
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-Vlan-interface3] ip address 172.1.1.1 24
[PE1-Vlan-interface3] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure the P device.
<P> system-view
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P-Vlan-interface3] ip address 172.1.1.2 24
[P-Vlan-interface3] quit
[P] interface vlan-interface 1
[P-Vlan-interface1] ip address 172.2.1.1 24
[P-Vlan-interface1] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1] quit
# Configure PE 2.
<PE2> system-view
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-Vlan-interface1] ip address 172.2.1.2 24
[PE2-Vlan-interface1] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
After you complete the above configurations, OSPF adjacency should be established between PE 1, P, and PE 2. Issuing the display ospf peer command, you can see that the adjacency status is Full. Issuing the display ip routing-table command, you can see that the PEs have learned the loopback route of each other. The following takes PE 1 as an example:
[PE1] display ip routing-table
2.2.2.9/32        OSPF   10   1        172.1.1.2       Vlan3
3.3.3.9/32        OSPF   10   2        172.1.1.2       Vlan3
172.1.1.0/24      Direct 0    0        172.1.1.1       Vlan3
172.1.1.1/32      Direct 0    0        127.0.0.1       InLoop0
172.1.1.2/32      Direct 0    0        172.1.1.2       Vlan3
172.2.1.0/24      OSPF   10   1        172.1.1.2       Vlan3
[PE1] display ospf peer verbose
          OSPF Process 1 with Router ID 1.1.1.9
                  Neighbors
 Area 0.0.0.0 interface 172.1.1.1(Vlan-interface3)'s neighbors
 Router ID: 172.1.1.2        Address: 172.1.1.2        GR State: Normal
   Dead timer due in 38  sec
   Neighbor is up for 00:02:44
   Neighbor state change count: 5
2)        Configure MPLS basic capability and MPLS LDP on the MPLS backbone to establish LDP LSPs
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1-Vlan-interface3] mpls
[PE1-Vlan-interface3] mpls ldp
[P] mpls lsr-id 2.2.2.9
[P] mpls
[P-mpls] quit
[P] mpls ldp
[P-mpls-ldp] quit
[P-Vlan-interface3] mpls
[P-Vlan-interface3] mpls ldp
[P-Vlan-interface1] mpls
[P-Vlan0interface1] mpls ldp
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2-Vlan-interface1] mpls
[PE2-Vlan-interface1] mpls ldp
After you complete the above configurations, LDP sessions should be established between PE 1, P, and PE 2. Issuing the display mpls ldp session command, you can see that the Session State field has a value of Operational. Issuing the display mpls ldp lsp command, you can see that the LSPs established by LDP. The following takes PE 1 as an example:
[PE1] display mpls ldp session
[PE1] display mpls ldp lsp
                              LDP LSP Information
 SN  DestAddress/Mask   In/OutLabel  Next-Hop     In/Out-Interface
 1   1.1.1.9/32         3/NULL       127.0.0.1     Vlan-interface3/InLoop0
 2   2.2.2.9/32         NULL/3       172.1.1.2     -------/Vlan-interface3
 3   3.3.3.9/32         NULL/1024    172.1.1.2     -------/Vlan-interface3
 A '*' before an LSP means the LSP is not established
 A '*' before a Label means the USCB or DSCB is stale
3)        Configure VPN instances on PEs to allow CEs to access
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 222:2
[PE1-vpn-instance-vpn2] quit
[PE1-Vlan-interface1] ip binding vpn-instance vpn1
[PE1-Vlan-interface1] ip address 10.1.1.2 24
[PE1-Vlan-interface1] quit
[PE1-Vlan-interface2] ip binding vpn-instance vpn2
[PE1-Vlan-interface2] ip address 10.2.1.2 24
[PE1-Vlan-interface2] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 200:2
[PE2-vpn-instance-vpn2] vpn-target 222:2
[PE2-vpn-instance-vpn2] quit
[PE2-Vlan-interface2] ip binding vpn-instance vpn1
[PE2-Vlan-interface2] ip address 10.3.1.2 24
[PE2-Vlan-interface2] quit
[PE2-Vlan-interface3] ip binding vpn-instance vpn2
[PE2-Vlan-interface3] ip address 10.4.1.2 24
[PE2-Vlan-interface3] quit
# Configure IP addresses for the CEs as required in Figure 3-1. The detailed configuration steps are omitted.
After completing the above configurations, you can issue the display ip vpn-instance command on the PEs to view the configuration of the VPN instance. The PEs should be capable of pinging their respective CEs. The following takes PE 1 and CE 1 as an example:
[PE1] display ip vpn-instance
  Total VPN-Instances configured : 2
  VPN-Instance Name      RD          Create Time
  vpn1                  100:1        2006/08/13 09:32:45
  vpn2                  100:2        2006/08/13 09:42:59
[PE1] ping -vpn-instance vpn1 10.1.1.1
  PING 10.1.1.1: 56  data bytes, press CTRL_C to break
    Reply from 10.1.1.1: bytes=56 Sequence=1 ttl=255 time=56 ms
    Reply from 10.1.1.1: bytes=56 Sequence=2 ttl=255 time=4 ms
    Reply from 10.1.1.1: bytes=56 Sequence=3 ttl=255 time=4 ms
    Reply from 10.1.1.1: bytes=56 Sequence=4 ttl=255 time=52 ms
    Reply from 10.1.1.1: bytes=56 Sequence=5 ttl=255 time=3 ms
  --- 10.1.1.1 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 3/23/56 ms
4)        Establish EBGP peer relationship between PEs and CEs to allow VPN routes to be injected
# Configure CE 1.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp] peer 10.1.1.2 as-number 100
[CE1-bgp] import-route direct
[CE1-bgp] quit
The configurations for the other three CEs are similar to the above. The detailed configuration steps are omitted.
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp] ipv4-family vpn-instance vpn1
[PE1-bgp-vpn1] peer 10.1.1.1 as-number 65410
[PE1-bgp-vpn1] import-route direct
[PE1-bgp-vpn1] quit
[PE1-bgp] ipv4-family vpn-instance vpn2
[PE1-bgp-vpn2] peer 10.2.1.1 as-number 65420
[PE1-bgp-vpn2] import-route direct
[PE1-bgp-vpn2] quit
[PE1-bgp] quit
The configurations for PE 2 are similar to those for PE 1. The detailed configuration steps are omitted.
After completing the above configuration, if you issue the display bgp vpnv4 vpn-instance peer command on the PEs, you should see that BGP peer relationship has been established between PE and CE, and has reached the state of Established. The following takes PE 1 and CE 1 as an example:
[PE1] display bgp vpnv4 vpn-instance vpn1 peer
 BGP local router ID : 1.1.1.9
  10.1.1.1 4 65410     11        9     0        1   00:06:37   Established
5)        Configure MP-IBGP peers between PEs
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp] peer 3.3.3.9 as-number 100
[PE1-bgp] peer 3.3.3.9 connect-interface loopback 0
[PE1-bgp] ipv4-family vpnv4
[PE1-bgp-af-vpnv4] peer 3.3.3.9 enable
[PE1-bgp-af-vpnv4] quit
[PE1-bgp] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp] peer 1.1.1.9 as-number 100
[PE2-bgp] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp] ipv4-family vpnv4
[PE2-bgp-af-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-af-vpnv4] quit
[PE2-bgp] quit
After completing the above configuration, if you issue the display bgp peer command or the display bgp vpnv4 all peer command on the PEs, you should see that BGP peer relationship has been established between the PEs, and has reached the state of Established.
[PE1] display bgp peer
  3.3.3.9  4  100        2        6     0          0  00:00:12 Established
6)        Verify your configurations
Issuing the display ip routing-table vpn-instance command on the PEs, you should see the routes to the CEs. The following takes PE 1 as an example:
[PE1] display ip routing-table vpn-instance vpn1
Routing Tables: vpn1
         Destinations : 3        Routes : 3
10.1.1.0/24       Direct 0    0        10.1.1.2        Vlan1
10.1.1.2/32       Direct 0    0        127.0.0.1       InLoop0
10.3.1.0/24       BGP    255  0        3.3.3.9         NULL0
[PE1] display ip routing-table vpn-instance vpn2
Routing Tables: vpn2
10.2.1.0/24       Direct 0    0         10.2.1.2        Vlan2
10.2.1.2/32       Direct 0    0         127.0.0.1       InLoop0
10.4.1.0/24       BGP    255  0         3.3.3.9         NULL0
CEs of the same VPN should be capable of pinging each other, whereas those of different VPNs should not. For example, CE 1 should be capable of pinging CE 3 (10.3.1.1), but should not be capable of pinging CE 4 (10.4.1.1):
[CE1] ping 10.3.1.1
  PING 10.3.1.1: 56  data bytes, press CTRL_C to break
    Reply from 10.3.1.1: bytes=56 Sequence=1 ttl=253 time=72 ms
    Reply from 10.3.1.1: bytes=56 Sequence=2 ttl=253 time=34 ms
    Reply from 10.3.1.1: bytes=56 Sequence=3 ttl=253 time=50 ms
    Reply from 10.3.1.1: bytes=56 Sequence=4 ttl=253 time=50 ms
    Reply from 10.3.1.1: bytes=56 Sequence=5 ttl=253 time=34 ms
  --- 10.3.1.1 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 34/48/72 ms
[CE1] ping 10.4.1.1
  PING 10.4.1.1: 56  data bytes, press CTRL_C to break
    Request time out
    Request time out
    Request time out
    Request time out
    Request time out
  --- 10.4.1.1 ping statistics ---
    0 packet(s) received
    100.00% packet loss
bgp 65410
 import-route direct
 ip address 10.2.1.1 255.255.255.0
bgp 65420
 peer 10.2.1.2 as-number 100
 import-route direct
mpls lsr-id 1.1.1.9
 vpn-target 111:1 export-extcommunity
 vpn-target 111:1 import-extcommunity
 vpn-target 222:1 export-extcommunity
 vpn-target 222:1 import-extcommunity
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 ip address 1.1.1.9 255.255.255.255
 ip address 10.2.1.2 255.255.255.0
 ip address 172.1.1.1 255.255.255.0
 mpls
 mpls ldp
ospf 1
 area 0
bgp 100
 peer 3.3.3.9 connect-interface LoopBack0
  import-route direct
  import-route direct
 ipv4-family vpnv4
peer 3.3.3.9 enable
mpls lsr-id 2.2.2.9
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 ip address 2.2.2.9 255.255.255.255
 ip address 172.2.1.1 255.255.255.0
 mpls
 mpls ldp
 ip address 172.1.1.2 255.255.255.0
 mpls
 mpls ldp
ospf 1
 area 0
mpls lsr-id 3.3.3.9
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 ip address 3.3.3.9 255.255.255.255
 ip address 172.2.1.2 255.255.255.0
 ip address 10.3.1.2 255.255.255.0
 ip address 10.4.1.2 255.255.255.0
ospf 1
 area 0
bgp 100
 peer 1.1.1.9 connect-interface LoopBack0
  peer 10.1.1.1 as-number 65430
  import-route direct
  peer 10.2.1.1 as-number 65440
  import-route direct
 ipv4-family vpnv4
peer 1.1.1.9 enable
l          Configuration on CE 3
 ip address 10.3.1.1 255.255.255.0
bgp 65430
 peer 10.3.1.2 as-number 100
 import-route direct
l          Configuration on CE 4
 ip address 10.4.1.1 255.255.255.0
bgp 65440
 peer 10.4.1.2 as-number 100
 import-route direct
If you execute the ip binding vpn-instance command on an interface, the IP address configured for the interface will be removed. Therefore, you need to re-configure the IP address for the interface.
Network Diagram
Figure 3-2 Configure inter-provider VPN option A
Device
IP address
Device
IP address
CE 1
Vlan-int1
10.1.1.1/24
CE 2
Vlan-int1
10.2.1.1/24
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
4.4.4.9/32
Vlan-int1
10.1.1.2/24
Vlan-int1
10.2.1.2/24
Vlan-int2
172.1.1.2/24
Vlan-int2
162.1.1.2/24
ASBR-PE 1
Loop0
2.2.2.9/32
ASBR-PE 2
Loop0
3.3.3.9/32
Vlan-int1
172.1.1.1/24
Vlan-int1
162.1.1.1/24
Vlan-int2
192.1.1.1/24
Vlan-int2
192.1.1.2/24
l          CE 1 and CE 2 belong to the same VPN. CE 1 accesses the network through PE 1 in AS 100 and CE 2 accesses the network through PE 2 in AS 200.
l          Inter-provider MPLS L3VPN is implemented using option A. That is, the VRF-to-VRF method is used to manage VPN routes.
l          The MPLS backbone in each AS runs OSPF.
Product series
Software version
Hardware version
Release 6300,
1)        Configure IGP on the MPLS backbone, implementing the connectivity in the backbone
The 32-bit loopback interface address used as the LSR ID needs to be advertised by OSPF.
After you complete the above configurations, each ASBR PE and the PE in the same AS should be able to establish OSPF adjacencies. Issuing the display ospf peer command, you can see that the adjacencies reach the state of Full, and that PEs can learn the loopback addresses of each other.
Each ASBR PE and the PE in the same AS should be able to ping each other.
# Configure MPLS basic capability on PE 1 and enable MPLS LDP on the interface connected to ASBR PE 1.
<PE1> system-view
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1-Vlan-interface1] mpls
[PE1-Vlan-interface1] mpls ldp
# Configure MPLS basic capability on ASBR PE 1 and enable MPLS LDP on the interface connected to PE 1.
<ASBR-PE1> system-view
[ASBR-PE1] mpls lsr-id 2.2.2.9
[ASBR-PE1] mpls
[ASBR-PE1-mpls] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-mpls-ldp] quit
[ASBR-PE1] interface vlan-interface 1
[ASBR-PE1-Vlan-interface1] mpls
[ASBR-PE1-Vlan-interface1] mpls ldp
[ASBR-PE1-Vlan-interface1] quit
# Configure MPLS basic capability on ASBR PE 2 and enable MPLS LDP on the interface connected to PE 2.
<ASBR-PE2> system-view
[ASBR-PE2] mpls lsr-id 3.3.3.9
[ASBR-PE2] mpls
[ASBR-PE2-mpls] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-mpls-ldp] quit
[ASBR-PE2] interface vlan-interface 1
[ASBR-PE2-Vlan-interface1] mpls
[ASBR-PE2-Vlan-interface1] mpls ldp
[ASBR-PE2-Vlan-interface1] quit
# Configure MPLS basic capability on PE 2 and enable MPLS LDP on the interface connected to ASBR PE 2.
<PE2> system-view
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2-Vlan-interface2] mpls
[PE2-Vlan-interface2] mpls ldp
After you complete the above configurations, each PE and the ASBR PE in the same AS should be able to establish neighbor relationship. Issuing the display mpls ldp session command on the devices, you can see that the Session State field has a value of Operational in the output information.
The VPN targets for the VPN instances of the PEs must match those for the VPN instances of the ASBR-PEs in the same AS. It is not required for PEs in different ASs.
# Configure CE 1.
<CE1> system-view
[CE1-Vlan-interface1] ip address 10.1.1.1 24
[CE1-Vlan-interface1] quit
# Configure PE 1.
[PE1-vpn-instance-vpn1] vpn-target 100:1 both
# Configure CE 2.
<CE2> system-view
[CE2-Vlan-interface1] ip address 10.2.1.1 24
[CE2-Vlan-interface1] quit
# Configure PE 2.
[PE2-vpn-instance] route-distinguisher 200:2
[PE2-vpn-instance] vpn-target 100:1 both
[PE2-vpn-instance] quit
[PE2-Vlan-interface1] ip binding vpn-instance vpn1
[PE2-Vlan-interface1] ip address 10.2.1.2 24
# Configure ASBR PE 1, creating a VPN instance and binding the instance to the interface connected with ASBR PE 2. Note that ASBR PE 1 considers ASBR PE 2 its CE.
[ASBR-PE1] ip vpn-instance vpn1
[ASBR-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[ASBR-PE1-vpn-instance-vpn1] vpn-target 100:1 both
[ASBR-PE1-vpn-instance-vpn1] quit
[ASBR-PE1] interface vlan-interface 2
[ASBR-PE1-Vlan-interface2] ip binding vpn-instance vpn1
[ASBR-PE1-Vlan-interface2] ip address 192.1.1.1 24
[ASBR-PE1-Vlan-interface2] quit
# Configure ASBR PE 2, creating a VPN instance and binding the instance to the interface connected with ASBR PE 1. Note that ASBR PE 2 considers ASBR PE 1 its CE.
[ASBR-PE2] ip vpn-instance vpn1
[ASBR-PE2-vpn-vpn-vpn1] route-distinguisher 200:1
[ASBR-PE2-vpn-vpn-vpn1] vpn-target 100:1 both
[ASBR-PE2-vpn-vpn-vpn1] quit
[ASBR-PE2] interface vlan-interface 2
[ASBR-PE2-Vlan-interface2] ip binding vpn-instance vpn1
[ASBR-PE2-Vlan-interface2] ip address 192.1.1.2 24
[ASBR-PE2-Vlan-interface2] quit
After completing the above configurations, you should see the VPN instance configurations by issuing the display ip vpn-instance command.
The PEs should be able to ping the CEs and the ASBR PEs should be able to ping each other.
# Configure CE 1.
[CE1] bgp 65001
[CE1-bgp] quit
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-vpn1] peer 10.1.1.1 as-number 65001
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
# Configure CE 2.
[CE2] bgp 65002
[CE2-bgp] peer 10.2.1.2 as-number 200
[CE2-bgp] import-route direct
[CE2-bgp] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp] ipv4-family vpn-instance vpn1
[PE2-bgp-vpn1] peer 10.2.1.1 as-number 65002
[PE2-bgp-vpn1] import-route direct
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
5)        Establish IBGP peer relationship between each PE and the ASBR PE in the same AS and EBGP peer relationship between the ASBR PEs
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp] peer 2.2.2.9 as-number 100
[PE1-bgp] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-af-vpnv4] peer 2.2.2.9 enable
[PE1-bgp-af-vpnv4] peer 2.2.2.9 next-hop-local
[PE1-bgp] quit
# Configure ASBR PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp] ipv4-family vpn-instance vpn1
[ASBR-PE1-bgp-vpn1] peer 192.1.1.2 as-number 200
[ASBR-PE1-bgp-vpn1] quit
[ASBR-PE1-bgp] peer 1.1.1.9 as-number 100
[ASBR-PE1-bgp] peer 1.1.1.9 connect-interface loopback 0
[ASBR-PE1-bgp] ipv4-family vpnv4
[ASBR-PE1-bgp-af-vpnv4] peer 1.1.1.9 enable
[ASBR-PE1-bgp-af-vpnv4] peer 1.1.1.9 next-hop-local
[ASBR-PE1-bgp-af-vpnv4] quit
[ASBR-PE1-bgp] quit
# Configure ASBR PE 2.
[ASBR-PE2] bgp 200
[ASBR-PE2-bgp] ipv4-family vpn-instance vpn1
[ASBR-PE2-bgp-vpn1] peer 192.1.1.1 as-number 100
[ASBR-PE2-bgp-vpn1] quit
[ASBR-PE2-bgp] peer 4.4.4.9 as-number 200
[ASBR-PE2-bgp] peer 4.4.4.9 connect-interface loopback 0
[ASBR-PE2-bgp] ipv4-family vpnv4
[ASBR-PE2-bgp-af-vpnv4] peer 4.4.4.9 enable
[ASBR-PE2-bgp-af-vpnv4] peer 4.4.4.9 next-hop-local
[ASBR-PE2-bgp-af-vpnv4] quit
[ASBR-PE2-bgp] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp] peer 3.3.3.9 as-number 200
[PE2-bgp] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-af-vpnv4] peer 3.3.3.9 enable
[PE2-bgp-af-vpnv4] peer 3.3.3.9 next-hop-local
[PE2-bgp] quit
After you complete the above configurations, the CEs should be able to learn the interface routes from each other and ping each other.
bgp 65001
 import-route direct
mpls lsr-id 1.1.1.9
 vpn-target 100:1 export-extcommunity
 vpn-target 100:1 import-extcommunity
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 mpls
 mpls ldp
 mpls
 mpls ldp
ospf 1
 area 0
bgp 100
 peer 2.2.2.9 connect-interface LoopBack0
  import-route direct
ipv4-family vpnv4
peer 2.2.2.9 enable
l          Configuration on ASBR-PE 1
mpls lsr-id 2.2.2.9
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 mpls
 mpls ldp
 ip address 192.1.1.1 255.255.255.0
 mpls
 mpls ldp
ospf 1
 area 0
network 192.1.1.0 0.0.0.255
bgp 100
  import-route direct
ipv4-family vpnv4
peer 1.1.1.9 enable
l          Configuration on ASBR-PE 2
mpls lsr-id 3.3.3.9
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 ip address 162.1.1.1 255.255.255.0
 mpls
 mpls ldp
 ip address 192.1.1.2 255.255.255.0
 mpls
 mpls ldp
ospf 1
 area 0
network 162.1.1.0 0.0.0.255
bgp 200
 peer 4.4.4.9 connect-interface LoopBack0
  import-route direct
ipv4-family vpnv4
peer 4.4.4.9 enable
mpls lsr-id 4.4.4.9
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 ip address 4.4.4.9 255.255.255.255
 mpls
 mpls ldp
 ip address 162.1.1.2 255.255.255.0
 mpls
 mpls ldp
ospf 1
 area 0
network 10.2.1.0 0.0.0.255
network 4.4.4.9 0.0.0.0
bgp 200
  import-route direct
ipv4-family vpnv4
peer 3.3.3.9 enable
bgp 65002
 import-route direct
In the inter-provider VPN option A solution, for the same VPN, the VPN targets for the VPN instances of the PEs must match those for the VPN instances of the ASBR-PEs in the same AS. It is not required for PEs in different ASs.
Network Diagram
Figure 3-3 Configure inter-provider VPN option B
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
Vlan-int1
30.0.0.1/8
Vlan-int1
20.0.0.1/8
Vlan-int2
1.1.1.2/8
Vlan-int2
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
Vlan-int1
1.1.1.1/8
Vlan-int1
9.1.1.1/8
Vlan-int2
11.0.0.2/8
Vlan-int2
11.0.0.1/8
l          Site 1 and Site 2 belong to the same VPN. CE 1 of Site 1 accesses the network through PE 1 in AS 100 and CE 2 of Site 2 accesses the network through PE 2 in AS 600.
l          PEs in the same AS runs IS-IS between them.
l          PE 1 and ASBR-PE 1 exchange labeled IPv4 routes by MP-IBGP.
l          PE 2 and ASBR-PE 2 exchange labeled IPv4 routes by MP-IBGP.
l          ASBR-PE 1 and ASBR-PE 2 exchange labeled IPv4 routes by MP-EBGP.
l          ASBRs do not perform VPN target filtering of received VPN-IPv4 routes.
Product series
Software version
Hardware version
Release 6300,
In the inter-provider VPN option B solution, configurations on CEs are similar to those in the inter-provider VPN option A solution. The configuration steps on CEs are omitted.
1)        Configure PE 1
# Run IS-IS on PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] network-entity 10.111.111.111.111.00
[PE1-isis-1] quit
# Configure LSR ID, enable MPLS and LDP.
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls
[PE1-mpls] label advertise non-null
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
# Configure interface VLAN-interface 2, start IS-IS and enable MPLS and LDP on the interface.
[PE1-Vlan-interface2] ip address 1.1.1.2 255.0.0.0
[PE1-Vlan-interface2] isis enable 1
[PE1-Vlan-interface2] mpls
[PE1-Vlan-interface2] mpls ldp
# Configure interface Loopback 0 and start IS-IS on it.
[PE1-LoopBack0] ip address 2.2.2.9 32
[PE1-LoopBack0] isis enable 1
# Create VPN instance vpn1 and configure the RD and VPN target attributes.
# Bind the interface connected with CE 1 to the created VPN instance.
[PE1-Vlan-interface1] ip address 30.0.0.1 8
# Start BGP on PE 1.
[PE1] bgp 100
# Configure IBGP peer 3.3.3.9 as a VPNv4 peer.
# Specify to inject direct routes to the VPN routing table of vpn1.
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
2)        Configure ASBR-PE 1
# Start IS-IS on ASBR-PE 1.
[ASBR-PE1] isis 1
[ASBR-PE1-isis-1] network-entity 10.222.222.222.222.00
[ASBR-PE1-isis-1] quit
[ASBR-PE1] mpls
[ASBR-PE1-mpls] label advertise non-null
[ASBR-PE1] mpls ldp
# Configure interface VLAN-interface 1, start IS-IS and enable MPLS and LDP on the interface.
[ASBR-PE1-Vlan-interface1] ip address 1.1.1.1 255.0.0.0
[ASBR-PE1-Vlan-interface1] isis enable 1
# Configure interface VLAN-interface 2 and enable MPLS on it.
[ASBR-PE1-Vlan-interface2] ip address 11.0.0.2 255.0.0.0
[ASBR-PE1-Vlan-interface2] mpls
[ASBR-PE1-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack0] isis enable 1
[ASBR-PE1-LoopBack0] quit
# Start BGP on ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp] peer 2.2.2.9 as-number 100
[ASBR-PE1-bgp] peer 2.2.2.9 connect-interface loopback 0
[ASBR-PE1-bgp] peer 11.0.0.1 as-number 600
[ASBR-PE1-bgp] peer 11.0.0.1 connect-interface vlan-interface 2
# Specify not to filter the received VPNv4 routes using the import target attribute.
[ASBR-PE1-bgp-af-vpnv4] undo policy vpn-target
# Configure both IBGP peer 2.2.2.0 and EBGP peer 11.0.0.1 as VPNv4 peers.
[ASBR-PE1-bgp-af-vpnv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-af-vpnv4] peer 2.2.2.9 enable
3)        Configure ASBR-PE 2
# Start IS-IS on ASBR-PE 2.
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.222.222.222.222.00
[ASBR-PE2-isis-1] quit
[ASBR-PE2] mpls
[ASBR-PE2-mpls] label advertise non-null
[ASBR-PE2] mpls ldp
[ASBR-PE2-Vlan-interface1] ip address 9.1.1.1 255.0.0.0
[ASBR-PE2-Vlan-interface1] isis enable 1
[ASBR-PE2-Vlan-interface2] ip address 11.0.0.1 255.0.0.0
[ASBR-PE2-Vlan-interface2] mpls
[ASBR-PE2] interface loopback 0
[ASBR-PE2-LoopBack0] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack0] isis enable 1
[ASBR-PE2-LoopBack0] quit
# Start BGP on ASBR-PE 2.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp] peer 11.0.0.2 as-number 100
[ASBR-PE2-bgp] peer 11.0.0.2 connect-interface vlan-interface 2
[ASBR-PE2-bgp] peer 5.5.5.9 as-number 600
[ASBR-PE2-bgp] peer 5.5.5.9 connect-interface loopback 0
[ASBR-PE2-bgp-af-vpnv4] undo policy vpn-target
# Configure both IBGP peer 5.5.5.9 and EBGP peer 11.0.0.2 as VPNv4 peers.
[ASBR-PE2-bgp-af-vpnv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-af-vpnv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp] quit
4)        Configure PE 2
# Start IS-IS on PE 2.
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] network-entity 10.111.111.111.111.00
[PE2-isis-1] quit
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls
[PE2-mpls] label advertise non-null
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2-Vlan-interface2] ip address 9.1.1.2 255.0.0.0
[PE2-Vlan-interface2] isis enable 1
[PE2-LoopBack0] ip address 5.5.5.9 32
[PE2-LoopBack0] isis enable 1
[PE2-vpn-instance-vpn1] route-distinguisher 12:12
# Bind the interface connected with CE 2 to the created VPN instance.
[PE2-Vlan-interface1] ip address 20.0.0.1 8
# Start BGP on PE 2.
[PE2] bgp 600
# Configure IBGP peer 4.4.4.9 as a VPNv4 peer.
[PE2-bgp] peer 4.4.4.9 as-number 600
[PE2-bgp] peer 4.4.4.9 connect-interface loopback 0
[PE2-bgp-af-vpnv4] peer 4.4.4.9 enable
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
5)        Verify your configurations
After you complete the above configurations, PE 1 and PE 2 should be able to ping each other.
mpls lsr-id 2.2.2.9
mpls
 lsp-trigger all
mpls ldp
isis 1
 network-entity 10.1111.1111.1111.00
interface LoopBack0
 isis enable 1
 ip address 30.0.0.1 255.0.0.0
 isis enable 1
 mpls
 mpls ldp
bgp 100
  import-route direct
ipv4-family vpnv4
peer 3.3.3.9 enable
mpls lsr-id 3.3.3.9
mpls
 lsp-trigger all
mpls ldp
isis 1
 network-entity 10.2222.2222.2222.00
interface LoopBack0
 isis enable 1
 isis enable 1
 mpls
 mpls ldp
 mpls
bgp 100
 peer 11.0.0.1 connect-interface Vlan-interface 2
ipv4-family vpnv4
peer 2.2.2.9 enable
mpls lsr-id 4.4.4.9
mpls
 lsp-trigger all
mpls ldp
isis 1
interface LoopBack0
 isis enable 1
 isis enable 1
 mpls
 mpls ldp
 mpls
bgp 600
 peer 5.5.5.9 connect-interface LoopBack0
 peer 11.0.0.2 connect-interface Vlan-interface 2
ipv4-family vpnv4
peer 5.5.5.9 enable
mpls lsr-id 5.5.5.9
mpls
 lsp-trigger all
mpls ldp
isis 1
interface LoopBack0
 ip address 5.5.5.9 255.255.255.255
 isis enable 1
 ip address 20.0.0.1 255.0.0.0
 isis enable 1
 mpls
 mpls ldp
bgp 600
  import-route direct
ipv4-family vpnv4
peer 4.4.4.9 enable
In the inter-provider VPN option B solution, for the same VPN, the VPN targets for the VPN instances of the PEs must match those for the VPN instances of the ASBR-PEs in the same AS. This is also true for PEs in different ASs.
Network Diagram
Figure 3-4 Configure inter-provider VPN option C
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
Loop1
30.0.0.1/32
Loop1
20.0.0.1/32
Vlan-int1
1.1.1.2/8
Vlan-int1
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
Vlan-int1
1.1.1.1/8
Vlan-int1
9.1.1.1/8
Vlan-int2
11.0.0.2/8
Vlan-int2
11.0.0.1/8
l          Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100 and Site 2 accesses the network through PE 2 in AS 600.
l          PE 1 and PE 2 are MP-EBGP peers.
l          ASBR-PE 1 and ASBR-PE 2 use their respective routing policies and label the routes received from each other.
l          ASBR-PE 1 and ASBR-PE 2 use MP-EBGP to exchange labeled IPv4 routes.
Product series
Software version
Hardware version
Release 6300,
1)        Configure PE 1
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] quit
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1-Vlan-interface1] ip address 1.1.1.2 255.0.0.0
[PE1-Vlan-interface1] isis enable 1
# Configure interface Loopback 1 and bind the interface to VPN instance vpn1.
[PE1] interface loopback 1
[PE1-LoopBack1] ip binding vpn-instance vpn1
[PE1-LoopBack1] ip address 30.0.0.1 32
[PE1-LoopBack1] quit
[PE1] bgp 100
# Configure the capability to advertise labeled routes to IBGP peer 3.3.3.9 and to receive labeled routes from the peer.
[PE1-bgp] peer 3.3.3.9 label-route-capability
# Configure the maximum hop count from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp] peer 5.5.5.9 as-number 600
[PE1-bgp] peer 5.5.5.9 connect-interface loopback 0
[PE1-bgp] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv4 peer.
[PE1-bgp-af-vpnv4] peer 5.5.5.9 enable
# Specify to inject direct routes to the routing table of vpn1.
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
[ASBR-PE1] isis 1
[ASBR-PE1] mpls
[ASBR-PE1] mpls ldp
# Create routing policies.
[ASBR-PE1] route-policy policy1 permit node 1
[ASBR-PE1-route-policy1] apply mpls-label
[ASBR-PE1-route-policy1] quit
[ASBR-PE1] route-policy policy2 permit node 1
[ASBR-PE1-route-policy2] if-match mpls-label
[ASBR-PE1-route-policy2] apply mpls-label
[ASBR-PE1-route-policy2] quit
# Start BGP on ASBR-PE 1 and specify to inject routes of IS-IS process 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp] import-route isis 1
# Specify to use routing policy policy2 to filter routes advertised from IBGP peer 2.2.2.9.
[ASBR-PE1-bgp] peer 2.2.2.9 route-policy policy2 export
# Configure the capability to advertise labeled routes to IBGP peer 2.2.2.9 and to receive labeled routes from the peer.
[ASBR-PE1-bgp] peer 2.2.2.9 label-route-capability
# Specify to use routing policy policy1 to filter routes advertised from EBGP peer 11.0.0.1.
[ASBR-PE1-bgp] peer 11.0.0.1 route-policy policy1 export
# Configure the capability to advertise labeled routes to EBGP peer 11.0.0.1 and to receive labeled routes from the peer.
[ASBR-PE1-bgp] peer 11.0.0.1 label-route-capability
[ASBR-PE1-bgp] quit
[ASBR-PE2] isis 1
[ASBR-PE2] mpls
[ASBR-PE2] mpls ldp
[ASBR-PE2] route-policy policy1 permit node 1
New Sequence of this List
[ASBR-PE2-route-policy1] apply mpls-label
[ASBR-PE2-route-policy1] quit
[ASBR-PE2] route-policy policy2 permit node 1
[ASBR-PE2-route-policy2] if-match mpls-label
[ASBR-PE2-route-policy2] apply mpls-label
[ASBR-PE2-route-policy2] quit
# Start BGP on ASBR-PE 2 and specify to inject routes of IS-IS process 1.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp] import-route isis 1
# Configure the capability to advertise labeled routes to IBGP peer 5.5.5.9 and to receive labeled routes from the peer.
[ASBR-PE2-bgp] peer 5.5.5.9 connect-interface loopback 1
[ASBR-PE2-bgp] peer 5.5.5.9 label-route-capability
# Specify to use routing policy policy2 to filter routes advertised from IBGP peer 5.5.5.9.
[ASBR-PE2-bgp] peer 5.5.5.9 route-policy policy2 export
# Specify to use routing policy policy1 to filter routes advertised from EBGP peer 11.0.0.2.
[ASBR-PE2-bgp] peer 11.0.0.2 route-policy policy1 export
# Configure the capability to advertise labeled routes to EBGP peer 11.0.0.2 and to receive labeled routes from the peer.
[ASBR-PE2-bgp] peer 11.0.0.2 label-route-capability
[ASBR-PE2-bgp] quit
4)        Configure PE 2
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2-Vlan-interface1] ip address 9.1.1.2 255.0.0.0
[PE2-Vlan-interface1] isis enable 1
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
[PE2] interface loopback 1
[PE2-LoopBack1] ip binding vpn-instance vpn1
[PE2-LoopBack1] ip address 20.0.0.1 32
[PE2-LoopBack1] quit
[PE2] bgp 600
# Configure the capability to advertise labeled routes to IBGP peer 4.4.4.9 and to receive labeled routes from the peer.
[PE2-bgp] peer 4.4.4.9 connect-interface loopback 1
[PE2-bgp] peer 4.4.4.9 label-route-capability
# Configure the maximum hop count from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp] peer 2.2.2.9 as-number 100
[PE2-bgp] peer 2.2.2.9 connect-interface loopback 1
[PE2-bgp] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv4 peer.
[PE2-bgp-af-vpnv4] peer 2.2.2.9 enable
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
After you complete the above configurations, PE 1 and PE 2 should be able to ping each other:
[PE2] ping –vpn-instance vpn1 30.0.0.1
[PE1] ping –vpn-instance vpn1 20.0.0.1
mpls lsr-id 2.2.2.9
mpls
 lsp-trigger all
mpls ldp
isis 1
interface LoopBack0
 isis enable 1
interfaceLoopBack1
 ip address 30.0.0.1 255.255.255.255
 isis enable 1
 mpls
 mpls ldp
bgp 100
  import-route direct
ipv4-family vpnv4
peer 5.5.5.9 enable
mpls lsr-id 3.3.3.9
mpls
 lsp-trigger all
mpls ldp
isis 1
interface LoopBack0
 isis enable 1
 isis enable 1
 mpls
 mpls ldp
 mpls
bgp 100
 import-route isis 1
 apply mpls-label
 if-match mpls-label
 apply mpls-label
mpls lsr-id 4.4.4.9
mpls
 lsp-trigger all
mpls ldp
isis 1
interface LoopBack0
 isis enable 1
 isis enable 1
 mpls
 mpls ldp
 mpls
bgp 600
 import-route isis 1
 peer 5.5.5.9 connect-interface LoopBack1
 apply mpls-label
 if-match mpls-label
 apply mpls-label
mpls lsr-id 5.5.5.9
mpls
 lsp-trigger all
mpls ldp
isis 1
interface LoopBack0
 isis enable 1
interfaceLoopBack1
 ip address 20.0.0.1 255.255.255.255
 isis enable 1
 mpls
 mpls ldp
bgp 600
 peer 4.4.4.9 connect-interface LoopBack1
 peer 2.2.2.9 connect-interface LoopBack1
  import-route direct
ipv4-family vpnv4
peer 2.2.2.9 enable
Configuration Guidelines
None
Configuring Carrier’s Carrier
Network Diagram
Figure 3-5 Configure carrier’s carrier
Device
IP address
Device
IP address
CE 3
Vlan-int1
100.1.1.1/24
CE 4
Vlan-int1
120.1.1.1/24
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
Vlan-int1
100.1.1.2/24
Vlan-int1
120.1.1.2/24
Vlan-int2
10.1.1.1/24
Vlan-int2
20.1.1.2/24
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
Vlan-int2
10.1.1.2/24
Vlan-int1
21.1.1.2/24
Vlan-int1
11.1.1.1/24
Vlan-int2
20.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
Vlan-int1
11.1.1.2/24
Vlan-int2
30.1.1.2/24
Vlan-int2
30.1.1.1/24
Vlan-int1
21.1.1.1/24
Networking and Configuration Requirements
The Level 2 carrier provides MPLS L3VPN services to customers.
As shown in Figure 3-5,
l          PE 1 and PE 2 are PEs of the Level 1 carrier backbone.
l          CE 1 and CE 2 are devices of the Level 2 carrier and work as CE to access the Level 1 carrier backbone.
l          PE 3 and PE 4 are devices of the Level 2 carrier and work as PE to provide access service for the customers of the Level 2 carrier.
l          CE 3 and CE 4 are customers of the Level 2 carrier.
Applicable Product Matrix
Product series
Software version
Hardware version
S7500E Series Ethernet Switches
Release 6300,
LSQ1SRP1CB SRPU(s), or exclusively EA series LPUs
Configuration Procedure
The key of the carrier’s carrier configuration lies in the exchange process of two kinds of routes:
l          The exchange of the internal Level 2 carrier VPN routes on the Level 1 carrier backbone. In this process, the Level 2 carrier accesses the Level 1 carrier backbone as CE.
l          The exchange of customer VPN routes of the Level 2 carrier between PEs of the Level 2 carrier. In this process, MP-IBGP peer relationship must be established between the PEs of the Level 2 carrier (that is, between PE 3 and PE 4).
1)        Configure MPLS L3VPN on the Level 1 carrier backbone: start IS-IS as the IGP, enable LDP between PE 1 and PE 2, and establish MP-IBGP peer relationship between the PEs
# Configure PE 1.
<PE1> system-view
[PE1-LoopBack0] ip address 3.3.3.9 32
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE1-isis-1] quit
[PE1-Vlan-interface2] ip address 30.1.1.1 24
[PE1-Vlan-interface2] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp] peer 4.4.4.9 as-number 100
[PE1-bgp] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp-af-vpnv4] peer 4.4.4.9 enable
[PE1-bgp] quit
After completing the above configurations, you should see that the LDP session has been established successfully by issuing the display mpls ldp session command on PE 1 or PE 2. Issuing the display bgp peer command, you should see that the BGP peer relationship has been established and has reached the state of Established. Issuing the display isis peer command, you should see that the IS-IS neighbor relationship has been set up. Take PE 1 as an example:
 4.4.4.9:0      Operational   DU   Active   Off  Off  378/378
 BGP local router ID : 3.3.3.9
  4.4.4.9     4 100      162      145     0        0  02:12:47 Established
[PE1] display isis peer
                          Peer information for ISIS(1)
  System Id    Interface        Circuit Id  State HoldTime  Type   PRI
0000.0000.0005 Vlan-interface2  001         Up     29s      L1L2   --
2)        Configure the Level 2 carrier network: start IS-IS as the IGP and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2 respectively
# Configure PE 3.
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 1.1.1.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 1.1.1.9
[PE3] mpls
[PE3-mpls] quit
[PE3] mpls ldp
[PE3-mpls-ldp] quit
[PE3] isis 2
[PE3-isis-2] network-entity 10.0000.0000.0000.0001.00
[PE3-isis-2] quit
[PE3-LoopBack0] isis enable 2
[PE3] interface vlan-interface 2
[PE3-Vlan-interface2] ip address 10.1.1.1 24
[PE3-Vlan-interface2] isis enable 2
[PE3-Vlan-interface2] mpls
[PE3-Vlan-interface2] mpls ldp
[PE3-Vlan-interface2] mpls ldp transport-address interface
[PE3-Vlan-interface2] quit
# Configure CE 1.
<CE1> system-view
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 2.2.2.9 32
[CE1-LoopBack0] quit
[CE1] mpls lsr-id 2.2.2.9
[CE1] mpls
[CE1-mpls] quit
[CE1] mpls ldp
[CE1-mpls-ldp] quit
[CE1] isis 2
[CE1-isis-2] network-entity 10.0000.0000.0000.0002.00
[CE1-isis-2] quit
[CE1-LoopBack0] isis enable 2
[CE1] interface vlan-interface 2
[CE1-Vlan-interface2] ip address 10.1.1.2 24
[CE1-Vlan-interface2] isis enable 2
[CE1-Vlan-interface2] mpls
[CE1-Vlan-interface2] mpls ldp
[CE1-Vlan-interface2] mpls ldp transport-address interface
[CE1-Vlan-interface2] quit
After you complete the above configurations, PE 3 and CE 1 should be able to establish the LDP session and IS-IS neighbor relationship between them.
The configurations for PE 4 and CE 2 are similar to those for PE 3 and CE 1. The detailed configuration steps are omitted.
3)        Perform configuration to allow CEs of the Level 2 carrier to access PEs of the Level 1 carrier
# Configure PE 1 and inject IS-IS routes.
[PE1-vpn-instance-vpn1] route-distinguisher 200:1
[PE1] mpls ldp vpn-instance vpn1
[PE1-mpls-ldp-vpn-instance-vpn1] quit
[PE1] isis 2 vpn-instance vpn1
[PE1-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE1-isis-2] import-route bgp
[PE1-isis-2] quit
[PE1-Vlan-interface1] ip address 11.1.1.2 24
[PE1-Vlan-interface1] isis enable 2
[PE1-Vlan-interface1] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp-vpn1] import isis 2
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
# Configure CE 1.
[CE1-Vlan-interface1] ip address 11.1.1.1 24
[CE1-Vlan-interface1] isis enable 2
[CE1-Vlan-interface1] mpls
[CE1-Vlan-interface1] mpls ldp
[CE1-Vlan-interface1] mpls ldp transport-address interface
After you complete the above configurations, PE 1 and CE 1 should be able to establish the LDP session and IS-IS neighbor relationship between them.
The configurations for PE 2 and CE 2 are similar to those for PE 1 and CE 1. The detailed configuration steps are omitted.
4)        Perform configuration to allow the CEs of the Level 2 carrier to access the PEs
# Configure CE 3.
<CE3> system-view
[CE3] interface vlan-interface 1
[CE3-Vlan-interface1] ip address 100.1.1.1 24
[CE3-Vlan-interface1] quit
[CE3] bgp 65410
[CE3-bgp] peer 100.1.1.2 as-number 100
[CE3-bgp] import-route direct
[CE3-bgp] quit
# Configure PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 1:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface vlan-interface 1
[PE3-Vlan-interface1] ip binding vpn-instance vpn1
[PE3-Vlan-interface1] ip address 100.1.1.2 24
[PE3-Vlan-interface1] quit
[PE3] bgp 100
[PE3-bgp] ipv4-family vpn-instance vpn1
[PE3-bgp-vpn1] peer 100.1.1.1 as-number 65410
[PE3-bgp-vpn1] import-route direct
[PE3-bgp-vpn1] quit
[PE3-bgp] quit
The configurations for PE 4 and CE 4 are similar to those for PE 3 and CE 3. The detailed configuration steps are omitted.
5)        Configure MP-IBGP peer relationship between PEs of the Level 2 carrier to exchange the VPN routes of the Level 2 carrier customers
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp] peer 6.6.6.9 as-number 100
[PE3-bgp] peer 6.6.6.9 connect-interface loopback 0
[PE3-bgp] ipv4-family vpnv4
[PE3-bgp-af-vpnv4] peer 6.6.6.9 enable
[PE3-bgp-af-vpnv4] quit
[PE3-bgp] quit
The configurations for PE 4 are similar to those for PE 3. The detailed configuration steps are omitted.
After completing all the above configurations, you can issue the display ip routing-table command on PE 1 and PE 2. You should see that only routes of the Level 1 carrier network are present in the public network routing table of PE 1 and PE 2. Takes PE 1 as an example:
Routing Tables: Public
         Destinations : 7        Routes : 7
Destination/Mask    Proto  Pre  Cost    NextHop      Interface
3.3.3.9/32          Direct 0    0       127.0.0.1    InLoop0
4.4.4.9/32          ISIS   15   10      30.1.1.2     Vlan2
30.1.1.0/24         Direct 0    0       30.1.1.1     Vlan2
30.1.1.1/32         Direct 0    0       127.0.0.1    InLoop0
30.1.1.2/32         Direct 0    0       30.1.1.2     Vlan2
127.0.0.0/8         Direct 0    0       127.0.0.1    InLoop0
127.0.0.1/32        Direct 0    0       127.0.0.1    InLoop0
Issuing the display ip routing-table vpn-instance command on PE 1 and PE 2, you should see that the internal routes of the Level 2 carrier network are present in the VPN routing tables, but the VPN routes that the Level 2 carrier maintains are not. Takes PE 1 as an example:
         Destinations : 11        Routes : 11
1.1.1.9/32          ISIS   15   20      11.1.1.1      Vlan1
2.2.2.9/32          ISIS   15   10      11.1.1.1      Vlan1
5.5.5.9/32          BGP    255  0       4.4.4.9       NULL0
6.6.6.9/32          BGP    255  0       4.4.4.9       NULL0
10.1.1.0/24         ISIS   15   20      11.1.1.1      Vlan1
11.1.1.0/24         Direct 0    0       11.1.1.1      Vlan1
11.1.1.1/32         Direct 0    0       127.0.0.1     InLoop0
11.1.1.2/32         Direct 0    0       11.1.1.2      Vlan1
20.1.1.0/24         BGP    255  0       4.4.4.9       NULL0
21.1.1.0/24         BGP    255  0       4.4.4.9       NULL0
21.1.1.2/32         BGP    255  0       4.4.4.9       NULL0
Issuing the display ip routing-table command on CE 1 and CE 2, you should see that the internal routes of the Level 2 carrier network are present in the public network routing tables, but the VPN routes that the Level 2 carrier maintains are not. Takes CE 1 as an example:
[CE1] display ip routing-table
         Destinations : 16       Routes : 16
1.1.1.9/32          ISIS   15   10     10.1.1.2        Vlan2
2.2.2.9/32          Direct 0    0      127.0.0.1       InLoop0
5.5.5.9/32          ISIS   15   74     11.1.1.2        Vlan1
6.6.6.9/32          ISIS   15   74     11.1.1.2        Vlan1
10.1.1.0/24         Direct 0    0      10.1.1.2        Vlan2
10.1.1.1/32         Direct 0    0      10.1.1.1        Vlan2
20.1.1.0/24         ISIS   15   74     11.1.1.2        Vlan1
21.1.1.0/24         ISIS   15   74     11.1.1.2        Vlan1
21.1.1.2/32         ISIS   15   74     11.1.1.2        Vlan1
Issuing the display ip routing-table command on PE 3 and PE 4, you should see that the internal routes of the Level 2 carrier network are present in the public network routing tables. Takes PE 3 as an example:
[PE3] display ip routing-table
1.1.1.9/32          Direct 0    0      127.0.0.1       InLoop0
2.2.2.9/32          ISIS   15   10     10.1.1.2        Vlan2
5.5.5.9/32          ISIS   15   84     10.1.1.2        Vlan2
6.6.6.9/32          ISIS   15   84     10.1.1.2        Vlan2
10.1.1.0/24         Direct 0    0      10.1.1.1        Vlan2
10.1.1.1/32         Direct 0    0      127.0.0.1       InLoop0
10.1.1.2/32         Direct 0    0      10.1.1.2        Vlan2
11.1.1.0/24         ISIS   15   20     10.1.1.2        Vlan2
20.1.1.0/24         ISIS   15   84     10.1.1.2        Vlan2
21.1.1.0/24         ISIS   15   84     10.1.1.2        Vlan2
21.1.1.2/32         ISIS   15   84     10.1.1.2        Vlan2
Issuing the display ip routing-table vpn-instance command on PE 3 and PE 4, you should see that the routes of the remote VPN customers are present in the VPN routing tables. Takes PE 3 as an example:
[PE3] display ip routing-table vpn-instance vpn1
100.1.1.0/24        Direct 0    0       100.1.1.2      Vlan1
100.1.1.2/32        Direct 0    0       127.0.0.1      InLoop0
120.1.1.0/24        BGP    255  0       6.6.6.9        NULL0
PE 3 and PE 4 should be able to ping each other:
[PE3] ping 20.1.1.2
  PING 20.1.1.2: 56  data bytes, press CTRL_C to break
    Reply from 20.1.1.2: bytes=56 Sequence=1 ttl=252 time=127 ms
    Reply from 20.1.1.2: bytes=56 Sequence=2 ttl=252 time=97 ms
    Reply from 20.1.1.2: bytes=56 Sequence=3 ttl=252 time=83 ms
    Reply from 20.1.1.2: bytes=56 Sequence=4 ttl=252 time=70 ms
    Reply from 20.1.1.2: bytes=56 Sequence=5 ttl=252 time=60 ms
  --- 20.1.1.2 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 60/87/127 ms
CE 3 and CE 4 should be able to ping each other:
[CE3] ping 120.1.1.1
  PING 120.1.1.1: 56  data bytes, press CTRL_C to break
    Reply from 120.1.1.1: bytes=56 Sequence=1 ttl=252 time=102 ms
    Reply from 120.1.1.1: bytes=56 Sequence=2 ttl=252 time=69 ms
    Reply from 120.1.1.1: bytes=56 Sequence=3 ttl=252 time=105 ms
    Reply from 120.1.1.1: bytes=56 Sequence=4 ttl=252 time=88 ms
    Reply from 120.1.1.1: bytes=56 Sequence=5 ttl=252 time=87 ms
  --- 120.1.1.1 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 69/90/105 ms
Complete Configuration
mpls lsr-id 3.3.3.9
mpls
 lsp-trigger all
mpls ldp
isis 1
 import-route bgp
interface LoopBack0
 isis enable 1
 ip address 11.1.1.2 255.255.255.0
 isis enable 2
 mpls
 mpls ldp
 ip address 30.1.1.1 255.255.255.0
 isis enable 1
 mpls
 mpls ldp
bgp 100
import-route isis 2
ipv4-family vpnv4
peer 4.4.4.9 enable
mpls lsr-id 4.4.4.9
mpls
 lsp-trigger all
mpls ldp
isis 1
 import-route bgp
interface LoopBack0
 isis enable 1
 ip address 21.1.1.1 255.255.255.0
 isis enable 2
 mpls
 mpls ldp
 ip address 30.1.1.2 255.255.255.0
 isis enable 1
 mpls
 mpls ldp
bgp 100
import-route isis 2
ipv4-family vpnv4
peer 3.3.3.9 enable
mpls lsr-id 2.2.2.9
mpls
 lsp-trigger all
mpls ldp
isis 2
interface LoopBack0
 isis enable 2
 ip address 11.1.1.1 255.255.255.0
 isis enable 2
 mpls
 mpls ldp
 isis enable 2
 mpls
 mpls ldp
The complete configuration on CE 2 is similar to that on CE 1 expect the interface IP addresses and the route advertisement segments.
l          Configuration on PE 3
mpls lsr-id 1.1.1.9
mpls
 lsp-trigger all
mpls ldp
isis 2
interface LoopBack0
 isis enable 2
 isis enable 2
 mpls
 mpls ldp
bgp 100
 peer 6.6.6.9 connect-interface LoopBack0
import-route direct
ipv4-family vpnv4
peer 6.6.6.9 enable
l          Configuration on PE 4
The complete configuration on PE 4 is similar to that on PE 3 expect the interface IP addresses and the route advertisement segments.
 ip address 100.1.1.1 255.255.255.0
bgp 65410
 import-route direct
 ip address 120.1.1.1 255.255.255.0
bgp 65420
 peer 120.1.1.2 as-number 100
 import-route direct
None
Configuring Nested VPN
Network Diagram
Figure 3-6 Configure nested VPN
Device
IP address
Device
IP address
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
Vlan-int2
10.1.1.2/24
Vlan-int1
21.1.1.2/24
Vlan-int1
11.1.1.1/24
Vlan-int2
20.1.1.1/24
CE 3
Vlan-int1
100.1.1.1/24
CE 4
Vlan-int1
120.1.1.1/24
CE 5
Vlan-int3
110.1.1.1/24
CE 6
Vlan-int3
130.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
Vlan-int1
11.1.1.2/24
Vlan-int1
21.1.1.1/24
Vlan-int2
30.1.1.1/24
Vlan-int2
30.1.1.2/24
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
Vlan-int1
100.1.1.2/24
Vlan-int1
120.1.1.2/24
Vlan-int2
10.1.1.1/24
Vlan-int2
20.1.1.2/24
Vlan-int3
110.1.1.2/24
Vlan-int3
130.1.1.2/24
The service provider provides nested VPN services for users, as shown in Figure 3-6, where:
l          PE 1 and PE 2 are PE devices on the service provider backbone. Both of them support the nested VPN function.
l          CE 1 and CE 2 are connected to the service provider backbone. Both of them support VPNv4 routes.
l          PE 3 and PE 4 are PE devices of the customer VPN. Both of them support MPLS L3VPN.
l          CE 3 through CE 6 are CE devices of the sub-VPNs for the customer VPN.
The key of nested VPN configuration is to understand the processing of routes of sub-VPNs on the service provider PEs, which is described as follows:
l          When receiving a VPNv4 route from a CE (CE 1 or CE 2 in this example), a service provider PE replaces the RD of the VPNv4 route with the RD of the MPLS VPN on the service provider network where the CE resides, adds the export target attribute of the MPLS VPN on the service provider network to the extended community attribute list, and then forwards the VPNv4 route as usual.
l          To implement exchange of sub-VPN routes between customer PEs and service provider PEs, MP-EBGP peers should be established between service provider PEs and customer CEs.
Product series
Software version
Hardware version
Release 6300,
1)        Configure MPLS L3VPN on the service provider backbone, using IS-IS as the IGP protocol, and enabling LDP and establishing MP-IBGP peer relationship between PE 1 and PE 2.
# Configure PE 1.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] quit
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] interface vlan-interface 2
[PE1] bgp 100
[PE1-bgp] quit
Configurations on PE 2 are similar to those on PE 1, and are thus omitted here.
After completing the configurations above, you can execute commands display mpls ldp session, display bgp peer and display isis peer respectively on either PE 1 or PE 2. You should see that the LDP session is established, the BGP peer relationship is established and in the Established state, and the IS-IS neighbor relationship is established and up.
The following takes PE 1 for illustration.
               LDP Session(s) in Public Network
 Peer-ID        Status        LAM  SsnRole  FT   MD5  KA-Sent/Rcv
 LAM : Label Advertisement Mode         FT  : Fault Tolerance
2)        Configure the customer VPN, using IS-IS as the IGP protocol and enabling LDP between PE 3 and CE 1, and between PE 4 and CE 2.
# Configure PE 3.
<PE3> system-view
[PE3] mpls
[PE3-mpls] quit
[PE3] mpls ldp
[PE3-mpls-ldp] quit
[PE3] isis 2
[PE3-isis-2] quit
# Configure CE 1.
<CE1> system-view
[CE1] mpls
[CE1-mpls] quit
[CE1] mpls ldp
[CE1-mpls-ldp] quit
[CE1] isis 2
[CE1-isis-2] quit
After the configurations above, LDP and IS-IS neighbor relationship can be established between PE 3 and CE 1.
Configurations on PE 4 and CE 2 are similar to those on PE 3 and CE 1 respectively, and are thus omitted here.
3)        Connect CE 1 and CE 2 to service provider PEs.
# Configure PE 1.
[PE1] interface vlan-interface1
[PE1] bgp 100
[PE1-bgp-vpn1] peer 11.1.1.1 as-number 200
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
# Configure CE 1.
[CE1] interface vlan-interface 1
[CE1] bgp 200
[CE1-bgp] peer 11.1.1.2 as-number 100
[CE1-bgp] import isis 2
[CE1-bgp] quit
Configurations on PE 2 and CE 2 are similar to those on PE 1 and CE 1 respectively, and are thus omitted here.
4)        Connect sub-VPN CEs to the customer VPN PEs
# Configure CE 3.
<CE3> system-view
[CE3] interface vlan-interface1
[CE3] bgp 65410
[CE3-bgp] peer 100.1.1.2 as-number 200
[CE3-bgp] quit
# Configure CE5.
<CE5> system-view
[CE5] interface vlan-interface 3
[CE5-Vlan-interface3] ip address 110.1.1.1 24
[CE5-Vlan-interface3] quit
[CE5] bgp 65411
[CE5-bgp] peer 110.1.1.2 as-number 200
[CE5-bgp] import-route direct
[CE5-bgp] quit
# Configure PE 3.
[PE3] ip vpn-instance SUB_VPN1
[PE3-vpn-instance-SUB_VPN1] route-distinguisher 100:1
[PE3-vpn-instance-SUB_VPN1] vpn-target 2:1
[PE3-vpn-instance-SUB_VPN1] quit
[PE3-Vlan-interface1] ip binding vpn-instance SUB_VPN1
[PE3] ip vpn-instance SUB_VPN2
[PE3-vpn-instance-SUB_VPN2] route-distinguisher 101:1
[PE3-vpn-instance-SUB_VPN2] vpn-target 2:2
[PE3-vpn-instance-SUB_VPN2] quit
[PE3] interface vlan-interface 3
[PE3-Vlan-interface3] ip binding vpn-instance SUB_VPN2
[PE3-Vlan-interface3] ip address 110.1.1.2 24
[PE3-Vlan-interface3] quit
[PE3] bgp 200
[PE3-bgp] ipv4-family vpn-instance SUB_VPN1
[PE3-bgp-SUB_VPN1] peer 100.1.1.1 as-number 65410
[PE3-bgp-SUB_VPN1] import-route direct
[PE3-bgp-SUB_VPN1] quit
[PE3-bgp] ipv4-family vpn-instance SUB_VPN2
[PE3-bgp-SUB_VPN2] peer 100.1.1.1 as-number 65411
[PE3-bgp-SUB_VPN2] import-route direct
[PE3-bgp-SUB_VPN2] quit
[PE3-bgp] quit
Configurations on PE 4, CE 4 and CE6 are similar to those on PE 3, CE 3 and CE5 respectively, and are thus omitted here.
5)        Establish MP-EBGP peer relationship between service provider PEs and their CEs to exchange user VPNv4 routes.
# Configure PE 1, enabling nested VPN.
[PE1] bgp 100
[PE1-bgp-af-vpnv4] nesting-vpn
[PE1-bgp-af-vpnv4] peer 11.1.1.1 vpn-instance vpn1 enable
[PE1-bgp] quit
# Configure CE 1, enabling VPNv4 capability and establishing VPNv4 neighbor relationship between CE 1 and PE 1.
[CE1] bgp 200
[CE1-bgp] ipv4-family vpnv4
[CE1-bgp-af-vpnv4] peer 11.1.1.2 enable
# Specify to allow the local AS number to appear in the AS-PATH attribute of the routes received.
[CE1-bgp-af-vpnv4] peer 11.1.1.2 allow-as-loop 2
# Specify to receive all VPNv4 routes.
[CE1-bgp-af-vpnv4] undo policy vpn-target
[CE1-bgp-af-vpnv4] quit
[CE1-bgp] quit
6)        Establish MP-IBGP peer relationship between sub-VPN PEs and CEs of the customer VPN to exchange VPNv4 routes of sub-VPNs.
# Configure PE 3.
[PE3] bgp 200
[PE3-bgp] peer 2.2.2.9 as-number 200
[PE3-bgp] peer 2.2.2.9 connect-interface loopback 0
[PE3-bgp-af-vpnv4] peer 2.2.2.9 enable
[PE3-bgp-af-vpnv4] peer 2.2.2.9 allow-as-loop 2
[PE3-bgp] quit
# Configure CE 1.
[CE1] bgp 200
[CE1-bgp] peer 1.1.1.9 as-number 200
[CE1-bgp] peer 1.1.1.9 connect-interface loopback 0
[CE1-bgp-af-vpnv4] peer 1.1.1.9 enable
[CE1-bgp] quit
7)        Verify the configurations.
After completing all the configurations above, execute the display ip routing-table comand on PE 1 and PE 2 to verify that the public routing tables contain only routes on the service provider network. The following takes PE 1 for illustration.
Execute the display ip routing-table vpn-instance command on PE 1 and PE 2 to verify that the VPN routing tables contain sub-VPN routes. The following takes PE 1 for illustration.
         Destinations : 9        Routes : 9
100.1.1.0/24        BGP    255  0            11.1.1.1        NULL0
110.1.1.0/24        BGP    255  0            11.1.1.1        NULL0
120.1.1.0/24        BGP    255  0            4.4.4.9         NULL0
130.1.1.0/24        BGP    255  0            4.4.4.9         NULL0
Execute the display bgp vpnv4 all routing-table command on CE 1 and CE 2 to verify that the VPNv4 routing tables on the customer VPN contain internal sub-VPN routes. The following takes CE 1 for illustration.
[CE1] display bgp vpnv4 all routing-table
BGP Local router ID is 11.11.11.11
 Status codes: * - valid, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? - incomplete
 Total number of routes from all PE: 4
 Route Distinguisher: 100:1
    Network            NextHop         In/Out Label     MED        LocPrf
*>  100.1.1.0/24       1.1.1.9         1024/1024
Route Distinguisher: 101:1
*>  110.1.1.0/24       1.1.1.9         1025/1025
 Route Distinguisher: 200:1
*>  120.1.1.0/24       11.1.1.2        1026/1027
Route Distinguisher: 201:1
*>  130.1.1.0/24       11.1.1.2        1027/1028
Execute the display ip routing-table vpn-instance SUB_VPN1 command on PE 3 and PE 4 to verify that the VPN routing tables contain routes sent by the provider PE to user sub-VPN. The following takes PE 3 for illustration.
[PE3] display ip routing-table vpn-instance SUB_VPN1
Routing Tables: SUB_VPN1
         Destinations : 5        Routes : 5
120.1.1.0/24        BGP    255  0            2.2.2.9         NULL0
Execute the display ip routing-table command on CE 3 and CE 4 to verify that the routing tables contain routes of remote sub-VPNs. The following takes CE 3 for illustration.
[CE3] display ip routing-table
100.1.1.0/24        Direct 0    0            100.1.1.1       Vlan1
100.1.1.1/32        Direct 0    0            127.0.0.1       InLoop0
120.1.1.0/24        BGP    255  0            100.1.1.2       Vlan1
Execute the display ip routing-table command on CE5 and CE6 to verify that the routing tables contain routes of remote sub-VPNs. The following takes CE5 for illustration.
[CE5] display ip routing-table
110.1.1.0/24        Direct 0    0            110.1.1.1       Vlan1
110.1.1.1/32        Direct 0    0            127.0.0.1       InLoop0
130.1.1.0/24        BGP    255  0            110.1.1.2       Vlan1
CE 3 and CE 4 can ping each other successfully.
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
CE5 and CE6 can ping each other successfully.
[CE5] ping 130.1.1.1
  PING 130.1.1.1: 56  data bytes, press CTRL_C to break
    Reply from 130.1.1.1: bytes=56 Sequence=1 ttl=252 time=102 ms
    Reply from 130.1.1.1: bytes=56 Sequence=2 ttl=252 time=69 ms
    Reply from 130.1.1.1: bytes=56 Sequence=3 ttl=252 time=105 ms
    Reply from 130.1.1.1: bytes=56 Sequence=4 ttl=252 time=88 ms
    Reply from 130.1.1.1: bytes=56 Sequence=5 ttl=252 time=87 ms
  --- 130.1.1.1 ping statistics ---
    0.00% packet loss
CE 3 and CE6 cannot ping each other.
[CE3] ping 130.1.1.1
    Request time out
    Request time out
    Request time out
    Request time out
    Request time out
    100.00% packet loss
l          Configuration on PE 1
mpls lsr-id 3.3.3.9
mpls
 lsp-trigger all
mpls ldp
isis 1
interface LoopBack0
 isis enable 1
 mpls
interface Vlan-interface2
 isis enable 1
 mpls
 mpls ldp
bgp 100
ipv4-family vpnv4
peer 4.4.4.9 enable
nesting-vpn
l          Configuration on CE 1
mpls lsr-id 2.2.2.9
mpls
 lsp-trigger all
mpls ldp
isis 2
interface LoopBack0
 isis enable 2
 mpls
 isis enable 2
 mpls
 mpls ldp
bgp 200
 import-route isis 2
 ipv4-family vpnv4
peer 1.1.1.9 enable
mpls lsr-id 1.1.1.9
 vpn-target 2:1 export-extcommunity
 vpn-target 2:1 import-extcommunity
 vpn-target 2:2 export-extcommunity
 vpn-target 2:2 import-extcommunity
mpls
 lsp-trigger all
mpls ldp
isis 2
interface LoopBack0
 isis enable 2
 ip address 100.1.1.2 255.255.255.0
 isis enable 2
 mpls
 mpls ldp
interface Vlan-interface3
 ip address 110.1.1.2 255.255.255.0
bgp 200
  import-route direct
  import-route direct
 ipv4-family vpnv4
  peer 2.2.2.9 enable
bgp 65410
 import-route direct
l          Configuration on CE 5
 ip address 110.1.1.1 255.255.255.0
bgp 65411
 import-route direct
l          Configuration on PE 2
mpls lsr-id 4.4.4.9
mpls
 lsp-trigger all
mpls ldp
isis 1
 network-entity 10.0000.0000.0000.0005.00
interface LoopBack0
 isis enable 1
 ip address 21.1.1.2 255.255.255.0
 mpls
 isis enable 1
 mpls
 mpls ldp
bgp 100
peer 11.1.1.2 as-number 200
ipv4-family vpnv4
peer 3.3.3.9 enable
nesting-vpn
peer 11.1.1.2 vpn-instance vpn1 enable
CE 2, PE 4, CE 4, and CE 6 are respectively in the similar positions as CE 1, PE 3, CE 3, and CE 5 in the network and each pair of them needs the similar configuration. The only differences are the interface IP addresses and the route advertisement segments.
l          The address ranges for sub-VPNs of a user VPN cannot overlap.
l          It is not recommended to give nested VPN peers addresses that public network peers use.
l          Before specifying a nested VPN peer or peer group, be sure to configure the corresponding CE peer or peer group in BGP VPN instance view.
l          At present, nested VPN does not support multi-hop EBGP networking. Therefore, a service provider PE and its peer must use the addresses of the directly connected interfaces to establish neighbor relationship.
l          If a CE of a sub-VPN is directly connected to a service provider’s PE, policy routing must be configured on the PE to allow mutual access between the sub-VPN and the carrier VPN.
Configuring OSPF Sham Links
Network Diagram
Figure 3-7 Configure an OSPF sham link
Device
IP address
Device
IP address
CE 1
Vlan-int1
100.1.1.1/24
CE 2
Vlan-int1
120.1.1.1/24
Vlan-int2
20.1.1.1/24
Vlan-int2
30.1.1.2/24
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
2.2.2.9/32
Loop1
3.3.3.3/32
Loop1
5.5.5.5/32
Vlan-int1
100.1.1.2/24
Vlan-int1
120.1.1.2/24
Vlan-int2
10.1.1.1/24
Vlan-int2
10.1.1.2/24
Switch A
Vlan-int1
20.1.1.2/24
Vlan-int2
30.1.1.1/24
l          CE 1 and CE 2 belong to VPN 1 and are respectively connected to PE 1 and PE 2.
l          CE 1 and CE 2 are in the same OSPF area.
l          VPN traffic between CE 1 and CE 2 is required to be forwarded through the MPLS backbone, instead of any route in the OSPF area.
Product series
Software version
Hardware version
Release 6300,
1)        Configure OSPF on the customer networks
Configure conventional OSPF on CE 1, Switch A, and CE 2 to advertise segment addresses of the interfaces as shown in Figure 3-7. The detailed configuration steps are omitted.
After completing the configurations, CE 1 and CE 2 should be able to learn the OSPF route to the VLAN interface 1 of each other. The following takes CE 1 as an example:
<CE1> display ip routing-table
20.1.1.0/24       Direct 0    0        20.1.1.1        Vlan2
20.1.1.1/32       Direct 0    0        127.0.0.1       InLoop0
20.1.1.2/32       Direct 0    0        20.1.1.2        Vlan2
30.1.1.0/24       OSPF   10   3124     20.1.1.2        Vlan2
120.1.1.0/24      OSPF   10   3125     20.1.1.2        Vlan2
2)        Configure MPLS L3VPN on the backbone
# Configure MPLS basic capability and MPLS LDP on PE 1 to establish LDP LSPs.
<PE1> system-view
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1-Vlan-interface2] ip address 10.1.1.1 24
# Configure PE 1 to take PE 2 as the MP-IBGP peer.
[PE1] bgp 100
[PE1-bgp] quit
# Configure OSPF on PE 1.
[PE1] ospf 1
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure MPLS basic capability and MPLS LDP on PE 2 to establish LDP LSPs.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.9
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface vlan-interface 2
[PE2-Vlan-interface2] ip address 10.1.1.2 24
# Configure PE 2 to take PE 1 as the MP-IBGP peer.
[PE2] bgp 100
[PE2-bgp] quit
# Configure OSPF on PE 2.
[PE2]ospf 1
[PE2-ospf-1]area 0
[PE2-ospf-1-area-0.0.0.0]network 2.2.2.9 0.0.0.0
[PE2-ospf-1-area-0.0.0.0]network 10.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0]quit
[PE2-ospf-1]quit
3)        Configure PEs to allow CEs to access the network
# Configure PE 1 to allow CE 1 to access the network.
[PE1] interface vlan-interface 1
[PE1-Vlan-interface1] ip address 100.1.1.2 24
[PE1] ospf 100 vpn-instance vpn1
[PE1-ospf-100] domain-id 10
[PE1-ospf-100] area 1
[PE1-ospf-100-area-0.0.0.1] network 100.1.1.0 0.0.0.255
[PE1-ospf-100-area-0.0.0.1] quit
[PE1-ospf-100] quit
[PE2] bgp 100
[PE1-bgp-vpn1] import-route ospf 100
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
# Configure PE 2 to allow CE 2 to access the network.
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2] interface vlan-interface 1
[PE2-Vlan-interface1] ip address 120.1.1.2 24
[PE2] ospf 100 vpn-instance vpn1
[PE2-ospf-100] domain-id 10
[PE2-ospf-100] area 1
[PE2-ospf-100-area-0.0.0.1] network 120.1.1.0 0.0.0.255
[PE2-ospf-100-area-0.0.0.1] quit
[PE2-ospf-100] quit
[PE2] bgp 100
[PE2-bgp-vpn1] import-route ospf 100
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
After completing the above configurations, if you issue the display ip routing-table vpn-instance command on the PEs, you should see that the path to the peer CE is along the OSPF route across the customer networks, instead of the BGP route across the backbone. Take PE 1 as an example:
20.1.1.0/24       OSPF   10   1563     100.1.1.1     Vlan1
30.1.1.0/24       OSPF   10   3125     100.1.1.1     Vlan1
120.1.1.0/24      OSPF   10   3126     100.1.1.1     Vlan1
4)        Configure a sham link
# Configure PE 1.
[PE1-LoopBack1] ip address 3.3.3.3 32
[PE1] ospf 100
[PE1-ospf-100-area-0.0.0.1] sham-link 3.3.3.3 5.5.5.5 cost 10
[PE1-ospf-100] quit
# Configure PE 2.
[PE2-LoopBack1] ip address 5.5.5.5 32
[PE2] ospf 100
[PE2-ospf-100-area-0.0.0.1] sham-link 5.5.5.5 3.3.3.3 cost 10
[PE2-ospf-100] quit
After completing the above configurations, if you issue the display ip routing-table vpn-instance command again on the PEs, you should see that the path to the peer CE is now along the BGP route across the backbone, and that a route to the sham link destination address is present. Take PE 1 as an example:
         Destinations : 6        Routes : 6
3.3.3.3/32        Direct 0    0        127.0.0.1      InLoop0
5.5.5.5/32        BGP    255  0        2.2.2.9        NULL0
Issuing the display ip routing-table command on the CEs, you should see that the cost of the OSPF route to the peer CE is now 10 (the cost configured for the sham link), and that the next hop is now the VLAN interface 1 connected to the PE. This means that VPN traffic to the peer will be forwarded over the backbone. Takes CE 1 as an example:
30.1.1.0/24       OSPF   10   1574      100.1.1.2      Vlan1
120.1.1.0/24      OSPF   10   12        100.1.1.2      Vlan1
Issuing the display ospf sham-link command on the PEs, you should see the established sham link. Takes PE 1 as an example:
[PE1] display ospf sham-link
           OSPF Process 100 with Router ID 100.1.1.2
 Sham Link:
 Area        RouterId     Source-IP     Destination-IP  State Cost
 0.0.0.1     100.1.1.2    3.3.3.3       5.5.5.5         P-2-P 10
Issuing the display ospf sham-link area command, you should see that the status of the peer is Full:
[PE1] display ospf sham-link area 1
  Sham-Link: 3.3.3.3 --> 5.5.5.5
  Neighbour State: Full
  Area: 0.0.0.1
  Cost: 10  State: P-2-P, Type: Sham
  Timers: Hello 10 , Dead 40 , Retransmit 5 , Transmit Delay 1
mpls lsr-id 1.1.1.9
 vpn-target 1:1 export-extcommunity
 vpn-target 1:1 import-extcommunity
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
interface LoopBack1
 ip address 3.3.3.3 255.255.255.255
interface Vlan-interface1
 mpls
 mpls ldp
bgp 100
 undo synchronization
ipv4-family vpnv4
peer 2.2.2.9 enable
ospf 1
 area 0.0.0.0
  network 1.1.1.9 0.0.0.0
 domain-id 0.0.0.10
 area 0.0.0.1
mpls lsr-id 2.2.2.9
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
interface LoopBack1
 ip address 5.5.5.5 255.255.255.255
 ip address 120.1.1.2 255.255.255.0
 mpls
 mpls ldp
bgp 100
ipv4-family vpnv4
peer 1.1.1.9 enable
ospf 1
 area 0.0.0.0
 domain-id 0.0.0.10
 area 0.0.0.1
On CE 1, Switch A, and CE 2, you just need to perform common OSPF configurations and advertise the network segment addresses of the interfaces as illustrated in Figure 3-7.
None
Configuring BGP AS Number Substitution
Network Diagram
Figure 3-8 Configure BGP AS number substitution
Device
IP address
Device
IP address
CE 1
Vlan-int1
10.1.1.1/24
P
Loop0
2.2.2.9/32
Vlan-int2
100.1.1.1/24
Vlan-int1
30.1.1.1/24
PE 1
Loop0
1.1.1.9/32
Vlan-int2
20.1.1.2/24
Vlan-int1
10.1.1.2/24
PE 2
Loop0
3.3.3.9/32
Vlan-int2
20.1.1.1/24
Vlan-int1
30.1.1.2/24
CE 2
Vlan-int1
10.2.1.1/24
Vlan-int2
10.2.1.2/24
Vlan-int2
200.1.1.1/24
As shown in Figure 3-8, CE 1 and CE 2 belong to VPN 1 and are connected to PE 1 and PE 2 respectively. In addition, they use the same AS number 600.
Product series
Software version
Hardware version
Release 6300,
1)            Configuring basic MPLS L3VPN
l          Configure OSPF on the MPLS backbone to allow the PEs and P device to learn the routes of the loopback interfaces from each other.
l          Configure MPLS basic capability and MPLS LDP on the MPLS backbone to establish LDP LSPs.
l          Establish MP-IBGP peer relationship between the PEs to advertise VPN IPv4 routes.
l          Configure the VPN instance of VPN 1 on PE 2 to allow CE 2 to access the network.
l          Configure the VPN instance of VPN 1 on PE 1 to allow CE 1 to access the network.
l          Configure BGP between PE 1 and CE 1, and between PE 2 and CE 2 to inject routes of CEs into PEs.
After completing the above configurations, if you issue the display ip routing-table command on CE 2, you should see that CE 2 has learned the route to network segment 10.1.1.0/24, where the interface used by CE 1 to access PE 1 resides; but has not learned the route to the VPN (100.1.1.0/24) behind CE 1. You should see the similar situation on CE 1.
<CE2> display ip routing-table
         Destinations : 8        Routes : 8
10.1.1.0/24         BGP    255  0          10.2.1.2        Vlan1
10.1.1.1/32         BGP    255  0          10.2.1.2        Vlan1
10.2.1.0/24         Direct 0    0          10.2.1.1        Vlan1
10.2.1.1/32         Direct 0    0          127.0.0.1       InLoop0
10.2.1.2/32         Direct 0    0          10.2.1.2        Vlan1
200.1.1.0/24        Direct 0    0          200.1.1.1       InLoop0
200.1.1.1/32        Direct 0    0          127.0.0.1       InLoop0
Issuing the display ip routing-table vpn-instance command on the PEs, you should see the route to the VPN behind the peer CE. Takes PE 2 as an example:
<PE2> display ip routing-table vpn-instance vpn1
10.1.1.0/24         BGP    255  0          1.1.1.9         NULL0
10.1.1.1/32         BGP    255  0          1.1.1.9         NULL0
10.2.1.0/24         Direct 0    0          10.2.1.2        Vlan1
10.2.1.1/32         Direct 0    0          10.2.1.1        Vlan1
100.1.1.1/32        BGP    255  0          1.1.1.9         NULL0
200.1.1.1/32        BGP    255  0          10.2.1.1        Vlan1
Enabling BGP update packet debugging on PE 2, you should see that PE 2 advertises the route to 100.1.1.1/32, and the AS_PATH is 100 600.
<PE2> terminal monitor
<PE2> terminal debugging
<PE2> debugging bgp update vpn-instance vpn1 verbose
<PE2> refresh bgp vpn-instance vpn1 all export
*0.4402392 PE2 RM/7/RMDEBUG:
         BGP.vpn1: Send UPDATE to 10.2.1.1 for following destinations :
         Origin    : Incomplete
         AS Path   : 100 600
         Next Hop  : 10.2.1.2
         100.1.1.1/32,
Issuing the display bgp routing-table peer received-routes command on CE 2, you should see that CE 2 did not receive the route to 100.1.1.1/32.
<CE2> display bgp routing-table peer 10.2.1.2 received-routes
 Total Number of Routes: 4
 BGP Local router ID is 10.2.1.1
      Network          NextHop        MED     LocPrf    PrefVal Path/Ogn
 *>   10.1.1.0/24      10.2.1.2                           0      100?
 *>   10.1.1.1/32      10.2.1.2                           0      100?
 *    10.2.1.0/24      10.2.1.2        0                  0      100?
 *    10.2.1.1/32      10.2.1.2        0                  0      100?
2)            Configure BGP AS number substitution
# Configure BGP AS number substitution on PE 2.
<PE2> system-view
[PE2] bgp 100
[PE2-bgp-vpn1] peer 10.2.1.1 substitute-as
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
You should see that among the routes advertised by PE 2 to CE 2, the AS_PATH of 100.1.1.1/32 has changed from 100 600 to 100 100:
*0.13498737 PE2 RM/7/RMDEBUG:
         Origin    : Incomplete
         AS Path   : 100 100
         Next Hop  : 10.2.1.2
         100.1.1.1/32
Display again the routing information that CE 2 receives and the routing table:
 Total Number of Routes: 5
 *>   100.1.1.1/32     10.2.1.2                           0      100 100?
100.1.1.1/32        BGP    255  0          10.2.1.2        Vlan1
After configuring BGP AS substitution on PE 1 too, the VLAN interfaces of CE 1 and CE 2 should be able to ping each other:
<CE1> ping –a 100.1.1.1 200.1.1.1
  PING 200.1.1.1: 56  data bytes, press CTRL_C to break
    Reply from 200.1.1.1: bytes=56 Sequence=1 ttl=253 time=109 ms
    Reply from 200.1.1.1: bytes=56 Sequence=2 ttl=253 time=67 ms
    Reply from 200.1.1.1: bytes=56 Sequence=3 ttl=253 time=66 ms
    Reply from 200.1.1.1: bytes=56 Sequence=4 ttl=253 time=85 ms
    Reply from 200.1.1.1: bytes=56 Sequence=5 ttl=253 time=70 ms
  --- 200.1.1.1 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 66/79/109 ms
mpls lsr-id 1.1.1.9
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
ip address 20.1.1.1 255.255.255.0
mpls
 mpls ldp
bgp 100
 peer 3.3.3.9 as-number 100
peer 10.1.1.1 substitute-as
import-route bgp 600
ipv4-family vpnv4
peer 3.3.3.9 enable
mpls lsr-id 3.3.3.9
mpls
 lsp-trigger all
mpls ldp
interface LoopBack0
 mpls
 mpls ldp
bgp 100
ipv4-family vpnv4
peer 1.1.1.9 enable
None
