H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
38-VRRP Configuration Guide
38-VRRP Configuration Guide 182.67 KB
Table of Contents
1 IPv4-Based VRRP Configuration Guide· 1-1
Configuring Single VRRP Group· 1-1
Network Diagram·· 1-1
Networking and Configuration Requirements· 1-1
Applicable Product Matrix· 1-2
Configuration Procedure· 1-2
Complete Configuration· 1-3
Configuration Guidelines· 1-3
Configuring VRRP Interface Tracking· 1-4
Network Diagram·· 1-4
Networking and Configuration Requirements· 1-4
Applicable Product Matrix· 1-5
Configuration Procedure· 1-5
Complete Configuration· 1-6
Configuration Guidelines· 1-6
Configuring Multiple VRRP Groups· 1-6
Network Diagram·· 1-7
Networking and Configuration Requirements· 1-7
Applicable Product Matrix· 1-7
Configuration Procedure· 1-7
Complete Configuration· 1-9
Configuration Guidelines· 1-9
2 IPv6-Based VRRP Configuration Guide· 2-1
Configuring Single VRRP Group· 2-1
Network Diagram·· 2-1
Networking and Configuration Requirements· 2-1
Applicable Product Matrix· 2-1
Configuration Procedure· 2-2
Complete Configuration· 2-3
Configuration Guidelines· 2-4
Configuring VRRP Interface Tracking· 2-4
Network Diagram·· 2-4
Networking and Configuration Requirements· 2-4
Applicable Product Matrix· 2-5
Configuration Procedure· 2-5
Complete Configuration· 2-6
Configuration Guidelines· 2-7
Configuring Multiple VRRP Groups· 2-7
Network Diagram·· 2-7
Networking and Configuration Requirements· 2-7
Applicable Product Matrix· 2-8
Configuration Procedure· 2-8
Complete Configuration· 2-9
Configuration Guidelines· 2-10
Virtual Router Redundancy Protocol (VRRP) is an error-tolerant protocol. Deploying it on multicast and broadcast LANs such as Ethernet, you can ensure that the system can still provide highly reliable default links without changing configurations (such as dynamic routing protocols, route discovery protocols) when a device fails. Backup links facilitate network security and prevent network interruption due to a single link failure.
You can add two or more switches into one VRRP group, which can provide two or more reliable links to the external networks, therefore avoiding communication interruption resulting from single or multi-point failure.
Network Diagram
Figure 1-1 Network diagram for single VRRP group configuration
l          Host A needs to access Host B on the Internet, using 202.38.160.111/24 as its default gateway.
l          If Switch A operates normally, packets sent from Host A to Host B are forwarded by Switch A; if Switch A fails, packets sent from Host A to Host B are forwarded by Switch B.
VRRP group settings:
l          VRRP group number: 1
l          Virtual router IP address of the VRRP group: 202.38.160.111
l          Switch A acts as the master
l          Switch B acts as the backup, and works in the preemptive mode
Table 1-1 Networking description
Switch
Ethernet port connected with Host A
IP address of the VLAN interface
Switch priority in the VRRP group
Working mode
Switch A
Ethernet 1/0/6
202.38.160.1/24
110
Preemptive mode
Switch B
Ethernet 1/0/5
202.38.160.2/24
100 (default)
Preemptive mode
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301 Release 5303
All versions
S5510 Series Ethernet Switches
All versions
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100 Release 6300
All versions
l          Configure Switch A
# Configure VLAN 2.
<Switch A> system-view
[Switch A] vlan 2
[Switch A-vlan2] port Ethernet1/0/6
[Switch A-vlan2] quit
[Switch A] interface Vlan-interface 2
[Switch A-Vlan-interface2] ip address 202.38.160.1 255.255.255.0
# Create a VRRP group.
[Switch A-Vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.111
# Set the priority of Switch A in the VRRP group to 110.
[Switch A-Vlan-interface2] vrrp vrid 1 priority 110
# Set Switch A to work in preemptive mode. The preemption delay is five seconds.
[Switch A-Vlan-interface2] vrrp vrid 1 preempt-mode timer delay 5
A VRRP group works in preemptive mode and the preemption delay is 0 seconds by default.
l          Configure Switch B
# Configure VLAN 2.
<Switch B> system-view
[Switch B] vlan 2
[Switch B-Vlan2] port Ethernet1/0/5
[Switch B-Vlan2] quit
[Switch B] interface Vlan-interface 2
[Switch B-Vlan-interface2] ip address 202.38.160.2 255.255.255.0
[Switch B-Vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.111
# Set Switch B to work in preemptive mode. The preemption delay is five seconds.
[Switch B-Vlan-interface2] vrrp vrid 1 preempt-mode timer delay 5
After the configuration, you can use the display vrrp command to verify the configuration.
Normally, Switch A functions as the gateway. When Switch A is turned off or fails, Switch B takes charge of Switch A and functions as the gateway.
Since Switch A works in the preemptive mode, it can become the master again after it resumes to work and function as the gateway.
l          Configuration on Switch A
interface Vlan-interface2
interface Ethernet1/0/6
 port access vlan 2
l          Configuration on Switch B
interface Ethernet1/0/5
 port access vlan 2
Follow these guidelines when configuring single VRRP group:
l          Only when the configured virtual IP address and the interface IP address are legal host addresses and belong to the same segment can the VRRP group operate normally. The virtual IP address of the VRRP group cannot be 0.0.0.0, 255.255.255.255, loopback addresses, non class A/B/C addresses or other illegal IP addresses such as 0.0.0.1.
l          Ensure that the configurations are consistent in a VRRP group in terms of number of virtual IP addresses, virtual IP address, advertisement interval and authentication mode.
l          Excessive traffic or different timer setting on routers can cause the backup timer to time out abnormally and trigger a change of the state. To solve this problem, you can prolong the time interval to send VRRP packets and configure a preemption delay.
The interface tracking function expands the backup functionality of VRRP. It provides backup not only when the interface to which a VRRP group is assigned fails but also when other interfaces on the switch become unavailable. When a monitored interface goes down, the priority of the switch where the interface resides is automatically decreased by a specified value, allowing a higher priority switch in the VRRP group to become the master.
Network Diagram
Figure 1-2 Network diagram for VRRP interface tracking
Configure the interface tracking function to realize the following:
Although Switch A works normally, if its interface connecting with the Internet is not available, Switch B will act as the gateway by using another link to the external networks.
For the ease of explanation, set the number of the VRRP group to 1.
l          Switch A and Switch B belong to VRRP group 1 with the virtual IP address of 202.38.160.111.
l          If Switch A operates normally, packets sent from Host A to Host B are forwarded by Switch A; if VLAN-interface 3 through which Switch A connects to the Internet is not available, packets sent from Host A to Host B are forwarded by Switch B.
Product series
Software version
Hardware version
All versions
All versions
Release 2102
All versions
All versions
l          Configure Switch A.
# Configure VLAN 2.
[Switch A] vlan 2
# Configure the priority of Switch A in the VRRP group as 110.
# Set the interface to be tracked.
[Switch A-Vlan-interface2] vrrp vrid 1 track interface Vlan-interface 3 reduced 30
l          Configure Switch B.
# Configure VLAN 2.
[Switch B] vlan 2
[Switch B-vlan2] port Ethernet1/0/5
[Switch B-vlan2] quit
Normally, Switch A acts as the gateway. If VLAN-interface 3 on Switch A is unavailable, the priority of Switch A will be decreased by 30, making the priority of Switch A lower than that of Switch B. Therefore, Switch B will become the master and function as the gateway.
When VLAN-interface 3 resumes to work, Switch A becomes the master again and functions as the gateway.
 vrrp vrid 1 track interface Vlan-interface3 reduced 30
 port access vlan 2
 port access vlan 2
Follow these guidelines when configuring VRRP interface tracking:
l          Interface tracking is not configurable on an IP address owner.
l          When configuring VRRP interface tracking, you are recommended to configure the uplink trunk port to deny the VLAN that corresponds to the tracked interface.
l          If the state of the interface under tracking changes from down to up, the priority of the device where the interface resides is restored automatically.
l          When configuring the priority decreasing value, ensure that after the priority of the switch is automatically decreased, the priority is lower than that of any switch in the VRRP group, allowing a higher priority switch to become the master.
Multiple VRRP groups can implement link backup and load balancing functions, which can avoid communication interruption resulting from switch failure or traffic overburden on a link.
Network Diagram
Figure 1-3 Network diagram for multiple VRRP group configuration
l          Hosts in VLAN 2 use 202.38.160.100/25 as their default gateway and hosts in VLAN 3 use 202.38.160.200/25 as their default gateway.
l          Switch A and Switch B belong to both VRRP group 1 and VRRP group 2. The virtual IP address of VRRP group 1 is 202.38.160.100/25, and that of VRRP group 2 is 202.38.160.200/25.
l          In VRRP group 1, Switch A has a higher priority than Switch B. In VRRP group 2, Switch B has a higher priority than Switch A. In this case, hosts in VLAN 2 and VLAN 3 can communicate with the outside through Switch A and Switch B respectively, and if Switch A or Switch B fails, the hosts can use the other switch to communicate with the outside, so as to avoid communication interruption.
Product series
Software version
Hardware version
All versions
All versions
Release 2102
All versions
All versions
# Configure VLAN 2.
[Switch A] vlan 2
[Switch A-vlan2] port Ethernet1/0/5
[Switch A-Vlan-interface2] ip address 202.38.160.1 255.255.255.128
# Create VRRP group 1 and set its virtual IP address to 202.38.160.100.
[Switch A-Vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.100
# Configure the priority of Switch A in VRRP group 1 as 110.
[Switch A-Vlan-interface2] quit
# Configure VLAN 3.
[Switch A] vlan 3
[Switch A-vlan3] port Ethernet 1/0/6
[Switch A-vlan3] quit
[Switch A] interface vlan-interface 3
[Switch A-Vlan-interface3] ip address 202.38.160.130 255.255.255.128
# Create VRRP group 2 and set its virtual IP address to 202.38.160.200.
[Switch A-Vlan-interface3] vrrp vrid 2 virtual-ip 202.38.160.200
# Configure VLAN 2.
[Switch B] vlan 2
[Switch B-Vlan-interface2] ip address 202.38.160.2 255.255.255.128
[Switch B-Vlan-interface2] vrrp vrid 1 virtual-ip 202.38.160.100
[Switch B-Vlan-interface2] quit
# Configure VLAN 3.
[Switch B] vlan 3
[Switch B-vlan3] port Ethernet 1/0/6
[Switch B-vlan3] quit
[Switch B] interface vlan-interface 3
[Switch B-Vlan-interface3] ip address 202.38.160.131 255.255.255.128
[Switch B-Vlan-interface3] vrrp vrid 2 virtual-ip 202.38.160.200
# Configure the priority of Switch B in VRRP group 2 as 110.
[Switch B-Vlan-interface3] vrrp vrid 2 priority 110
In VRRP group 1 Switch A is the master, Switch B is the backup and hosts with the default gateway of 202.38.160.100/25 access the Internet through Switch A; in VRRP group 2 Switch A is the backup, Switch B is the master and hosts with the default gateway of 202.38.160.200/25 access the Internet through Switch B.
 port access vlan 2
 port access vlan 3
 port access vlan 2
 port access vlan 3
l          Ensure that the configurations are consistent in a VRRP group in terms of number of virtual IP addresses, virtual IP address, advertisement interval and authentication.
There are two VRRP versions: VRRPv2 and VRRPv3. VRRPv2 is based on IPv4, while VRRPv3 is based on IPv6. The two versions implement the same functions but provide different commands.
Network Diagram
Figure 2-1 Network diagram for single VRRP group configuration
l          Host A needs to access Host B on the Internet, using FE80::10 as its default gateway.
l          Switch A and Switch B belong to VRRP group 1 with the virtual IP address of FE80::10.
Product series
Software version
Hardware version
All versions
All versions
Release 2102
All versions
All versions
Before enabling IPv6 on an S3610/S5510 series Ethernet switch, you need to configure the device to operate in the IPv4/IPv6 dual-stack mode by using the switch-mode dual-ipv4-ipv6 command. Otherwise, IPv6 packets cannot be forwarded on the device even if IPv6 is enabled. The switch-mode command takes effect after the device is rebooted.
# Configure VLAN 2.
[Switch A] ipv6
[Switch A] vlan 2
[Switch A-Vlan-interface2] ipv6 address fe80::1 link-local
[Switch A-Vlan-interface2] ipv6 address 1::1 64
[Switch A-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip fe80::10 link-local
# Set the priority of Switch A in the VRRP group.
[Switch A-Vlan-interface2] vrrp ipv6 vrid 1 priority 110
[Switch A-Vlan-interface2] vrrp ipv6 vrid 1 preempt-mode
# Enable Switch A to send RA messages.
[Switch A-Vlan-interface2] undo ipv6 nd ra halt
# Configure VLAN 2.
[Switch B] ipv6
[Switch B] vlan 2
[Switch B-Vlan-interface2] ipv6 address fe80::2 link-local
[Switch B-Vlan-interface2] ipv6 address 1::2 64
# Create VRRP group 1.
[Switch B-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip fe80::10 link-local
# Enable Switch B to send RA messages.
[Switch B-Vlan-interface2] undo ipv6 nd ra halt
After the configuration, Host B can be pinged on Host A. You can use the display vrrp ipv6 command to verify the configuration.
 ipv6
 port access vlan 2
 ipv6
 port access vlan 2
Network Diagram
Figure 2-2 Network diagram for VRRP interface tracking
Although Switch A works normally, if its interface connecting with the Internet is not available, Switch B will act as the gateway by using another link to the outside.
For the ease of explanation, set the number of the backup group to 1.
Product series
Software version
Hardware version
All versions
All versions
Release 2102
All versions
All versions
# Configure VLAN 2.
[Switch A] ipv6
[Switch A] vlan 2
# Set the priority of Switch A in VRRP group 1
[Switch A-Vlan-interface2] vrrp ipv6 vrid 1 preempt-mode timer delay 5
[Switch A-Vlan-interface2] vrrp ipv6 vrid 1 track interface Vlan-interface 3 reduced 30
# Configure VLAN 2.
[Switch B] ipv6
[Switch B] vlan 2
[SwitchB-Vlan-interface2] vrrp ipv6 vrid 1 preempt-mode timer delay 5
After the configuration, you can use the display vrrp ipv6 command to verify the configuration.
 ipv6
 vrrp ipv6 vrid 1 track interface Vlan-interface3 reduced 30
 port access vlan 2
 ipv6
 port access vlan 2
l          If the state of the interface under tracking changes from down to up, the priority of the device corresponding to the interface is restored automatically.
Network Diagram
Figure 2-3 Network diagram for multiple VRRP group configuration
l          Hosts in VLAN 2 use FE80::10 as their default gateway and hosts in VLAN 3 use FE90::10 as their default gateway.
l          Switch A and Switch B belong to both VRRP group 1 and VRRP group 2. The virtual IPv6 address of VRRP group 1 is FE80::10, and that of VRRP group 2 is FE90::10.
l          In VRRP group 1, Switch A has a higher priority than Switch B. In VRRP group 2, Switch B has a higher priority than Switch A. In this case, hosts in VLAN 1 and VLAN 3 can communicate with the outside through Switch A and Switch B respectively, and if Switch A or Switch B fails, the hosts can use the other switch to communicate with the outside, so as to avoid communication interruption.
Product series
Software version
Hardware version
All versions
All versions
Release 2102
All versions
All versions
# Configure VLAN 2.
[Switch A] ipv6
[Switch A] vlan 2
# Create VRRP group 1 and set its virtual IPv6 address to FE80::10.
# Set the priority of Switch A in VRRP group 1 to 110.
# Configure VLAN 3.
[Switch A] vlan 3
[Switch A-Vlan-interface3] ipv6 address fe90::1 link-local
[Switch A-Vlan-interface3] ipv6 address 2::1 64
# Create VRRP group 2 and set its virtual IPv6 address to FE90::10.
[Switch A-Vlan-interface3] vrrp ipv6 vrid 2 virtual-ip fe90::10 link-local
# Configure VLAN 2.
[Switch A] ipv6
[Switch B] vlan 2
# Configure VLAN 3.
[Switch B] vlan 3
[Switch B-Vlan-interface3] ipv6 address fe90::2 link-local
[Switch B-Vlan-interface3] ipv6 address 2::2 64
[Switch B-Vlan-interface3] vrrp ipv6 vrid 2 virtual-ip fe90::10 link-local
# Set the priority of Switch B in VRRP group 2 to 110.
[Switch B-Vlan-interface3] vrrp ipv6 vrid 2 priority 110
In VRRP group 1 Switch A is the master, Switch B is the backup and hosts with the default gateway of FE80::10 accesses the Internet through Switch A; in VRRP group 2 Switch A is the backup, Switch B is the master and hosts with the default gateway of FE90::10 accesses the Internet through Switch B.
 ipv6
 port access vlan 2
 port access vlan 3
 ipv6
 vrrp ipv6 vrid 2 virtual-ip fe80::20 link-local
 port access vlan 2
 port access vlan 3
l          In an IPv6 network, to implement load balancing among multiple VRRP groups, you need to manually configure the default gateway for hosts.
