H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
06-QinQ Configuration Guide
Configuring QinQ
Network diagram
Figure 1-1 Network diagram for QinQ configuration
Networking and Configuration Requirements
l          Provider A and Provider B are service provider network access devices.
l          Customer A, Customer B and Customer C are customer network access devices.
l          Provider A and Provider B are interconnected through a trunk port. Provider A belongs to service provider VLAN (SVLAN) 1000, and Provider B belongs to SVLAN 2000.
l          Third-party devices are deployed between Provider A and Provider B, with a TPID value of 0x8200.
By default, H3C series switches adopt the TPID value 0x8100.
Configure the network to satisfy the following requirements:
l          Frames of VLAN 10 of Customer A and frames of VLAN 10 of Customer B can be forwarded to each other through SVLAN 1000;
l          Frames of VLAN 20 of Customer A and frames of VLAN 20 of Customer C can be forwarded to each other through SVLAN 2000.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301, Release 5303
All versions
S5510 Series Ethernet Switches
Release 5301, Rlease 5303
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
Configuration Procedure
This example assumes that the SVLANs can pass through the devices inside the network of the service provider.
1)        Configuration on Provider A
# Create VLAN 1000 and VLAN 2000.
<ProviderA> system-view
[ProviderA] vlan 1000
[ProviderA-vlan1000] quit
[ProviderA] vlan 2000
[ProviderA-vlan2000] quit
l          Configuration on GigabitEthernet 1/0/1
# Configure GigabitEthernet 1/0/1 as a hybrid port and assign it to VLAN 1000 and VLAN 2000 in untagged mode.
[ProviderA] interface GigabitEthernet 1/0/1
[ProviderA-GigabitEthernet1/0/1] port link-type hybrid
[ProviderA-GigabitEthernet1/0/1] port hybrid vlan 1000 2000 untagged
l          If your switch is an S3610 or S5510 switch using Release 5301 software version, you must also assign GigabitEthernet 1/0/1 to VLAN 10 and VLAN 20 in untagged mode using the port hybrid vlan 10 20 1000 2000 untagged command.
l          If your switch is an an S3610 or S5510 switch using Release 5303 software version, you can disable VLAN check using the vlan-check disable command in interface view. In this way, you do not need to configure GigabitEthernet 1/0/1 to permit VLAN 10 and VLAN 20.
# Configure the port to tag frames from VLAN 10 with an outer tag with the VLAN ID of 1000.
[ProviderA-GigabitEthernet1/0/1] qinq vid 1000
[ProviderA-GigabitEthernet1/0/1-vid-1000] raw-vlan-id inbound 10
[ProviderA-GigabitEthernet1/0/1-vid-1000] quit
# Configure the port to tag frames from VLAN 20 with an outer tag with the VLAN ID of 2000.
[ProviderA-GigabitEthernet1/0/1] qinq vid 2000
[ProviderA-GigabitEthernet1/0/1-vid-2000] raw-vlan-id inbound 20
[ProviderA-GigabitEthernet1/0/1-vid-2000] quit
[ProviderA-GigabitEthernet1/0/1] quit
l          Configuration on GigabitEthernet 1/0/2
# Configure GigabitEthernet 1/0/2 as an access port and assign it to VLAN 1000.
[ProviderA] interface GigabitEthernet 1/0/2
[ProviderA-GigabitEthernet1/0/2] port access vlan 1000
# Enable basic QinQ so that the port tags frames from VLAN 10 with an outer tag with the VLAN ID of 1000.
[ProviderA-GigabitEthernet1/0/2] qinq enable
[ProviderA-GigabitEthernet1/0/2] quit
l          Configuration on GigabitEthernet 1/0/3.
# Configure GigabitEthernet 1/0/3 as a trunk port, and assign it to VLAN 1000 and VLAN 2000.
[ProviderA] interface GigabitEthernet 1/0/3
[ProviderA-GigabitEthernet1/0/3] port link-type trunk
[ProviderA-GigabitEthernet1/0/3] port trunk permit vlan 1000 2000
# To enable interoperability with the third-party devices in the public network, set the TPID value to be carried in VLAN tags to 0x8200.
[ProviderA-GigabitEthernet1/0/3] quit
[ProviderA] qinq ethernet-type service-tag 8200
l          The TPID configuration command on an S3610, S5510, or S5500-SI series switch is different from that on an S5500-EI series switch. For details, refer to the corresponding operation manual.
l          On the S5500-EI and S5500-SI series switches, selective QinQ configuration can coexist with basic QinQ configuration but enjoys a higher priority, that is, a received frame will be tagged with an outer VLAN ID based on basic QinQ only after it fails to match the match criteria defined in the traffic class. On the S3610 and S5510 series switches, basic QinQ and selective QinQ are mutually exclusive.
2)        Configuration on Provider B
<ProviderB> system-view
[ProviderB] vlan 1000
[ProviderB-vlan1000] quit
[ProviderB] vlan 2000
[ProviderB-vlan2000] quit
# Configure GigabitEthernet 1/0/1 as a trunk port, and assign it to VLAN 1000 and VLAN 2000.
[ProviderB] interface GigabitEthernet 1/0/1
[ProviderB-GigabitEthernet1/0/1] port link-type trunk
[ProviderB-GigabitEthernet1/0/1] port trunk permit vlan 1000 2000
[ProviderB-GigabitEthernet1/0/1] quit
[ProviderB] qinq ethernet-type service-tag 8200
# Configure GigabitEthernet 1/0/2 as an access port and assign it to VLAN 2000.
[ProviderB] interface GigabitEthernet 1/0/2
[ProviderB-GigabitEthernet1/0/2] port access vlan 2000
# Enable basic QinQ so as to tag frames from VLAN 20 with an outer tag with the VLAN ID of 2000.
[ProviderB-GigabitEthernet1/0/2] qinq enable
3)        Configuration on the devices on the public network
As third-party devices are deployed between Provider A and Provider B, only the basic configurations that should be made on the devices are discussed here. Configure that device connecting with GigabitEthernet 1/0/3 of Provider A and the device connecting with GigabitEthernet 1/0/1 of Provider B so that the involved ports on them send tagged frames of VLAN 1000 and VLAN 2000. The configuration steps are omitted here.
Complete Configuration
l          Configuration on ProviderA
vlan 1000
vlan 2000
 port hybrid vlan 1 1000 2000 untagged
 qinq vid 1000
 qinq vid 2000
 qinq enable
 port trunk permit vlan 1 1000 2000
l          Configuration on DeviceB
vlan 1000
vlan 2000
 qinq enable
Configuration Guidelines
An inner VLAN tag corresponds to only one outer VLAN tag. If you want to change an outer VLAN tag, you must delete the old outer VLAN tag configuration and configure a new outer VLAN tag.
Configuring Flow-Based Selective QinQ
Network Diagram
Figure 1-2 Network diagram for flow-based selective QinQ configuration
l          Customer A, Customer B, Customer C, and Customer D are customer network access devices.
l          Provider A and Provider B are interconnected through a trunk port, which permits the frames of SVLAN 1000, SVLAN 2000, and SVLAN 3000 to pass through.
l          VLAN 10 of Customer A and VLAN 10 of Customer B can intercommunicate across SVLAN 1000.
l          VLAN 20 of Customer A and VLAN 20 of Customer C can intercommunicate across SVLAN 2000.
l          Frames of the VLANs other than VLAN 10 and VLAN 20 of Customer A can be forwarded to Customer D across SVLAN 3000.
Product series
Software version
Hardware version
S7500E Series Ethernet Switches
Release 6100, Release 6300
All versions
# Create VLAN 1000, VLAN 2000, and VLAN 3000.
[ProviderA] vlan 3000
[ProviderA-vlan3000] quit
l          Configuration on Ethernet 2/0/1
# Configure Ethernet 2/0/1 as a hybrid port and assign it to VLAN 1000, VLAN 2000, and VLAN 3000 in untagged mode.
[ProviderA] interface ethernet 2/0/1
[ProviderA-Ethernet2/0/1] port link-type hybrid
[ProviderA-Ethernet2/0/1] port hybrid vlan 1000 2000 3000 untagged
# Configure VLAN 3000 as the default VLAN of Ethernet 2/0/1, and enable basic QinQ on Ethernet 2/0/1. As a result, the frames received on the port are tagged with the outer VLAN tag 3000.
[ProviderA-Ethernet2/0/1] port hybrid pvid vlan 3000
[ProviderA-Ethernet2/0/1] qinq enable
[ProviderA-Ethernet2/0/1] quit
# Create a class A10 to match frames of VLAN 10 of Customer A.
[ProviderA] traffic classifier A10
[ProviderA-classifier-A10] if-match customer-vlan-id 10
[ProviderA-classifier-A10] quit
# Create a traffic behavior P1000 and configure the action of tagging frames with the outer VLAN tag 1000 for the traffic behavior.
[ProviderA] traffic behavior P1000
[ProviderA-behavior-P1000] nest top-most vlan-id 1000
[ProviderA-behavior-P1000] quit
# Create a class A20 to match frames of VLAN 20 of Customer A. Create a traffic behavior P2000 and configure the action of tagging frames with the outer VLAN tag 2000 for the traffic behavior.
[ProviderA] traffic classifier A20
[ProviderA-classifier-A20] if-match customer-vlan-id 20
[ProviderA-classifier-A20] quit
[ProviderA] traffic behavior P2000
[ProviderA-behavior-P2000] nest top-most vlan-id 2000
[ProviderA-behavior-P2000] quit
# Create a QoS policy qinq. Associate the class A10 with the traffic behavior P1000, and associate the class A20 with the traffic behavior P2000 in the QoS policy qinq.
[ProviderA] qos policy qinq
[ProviderA-qospolicy-qinq] classifier A10 behavior P1000
[ProviderA-qospolicy-qinq] classifier A20 behavior P2000
[ProviderA-qospolicy-qinq] quit
# Apply the QoS policy qinq in the inbound direction of Ethernet 2/0/1.
[ProviderA] interface Ethernet 2/0/1
[ProviderA-Ethernet2/0/1] qos apply policy qinq inbound
l          Configuration on Ethernet 2/0/2
# Configure VLAN 1000 as the default VLAN of Ethernet 2/0/2.
[ProviderA] interface ethernet 2/0/2
[ProviderA-Ethernet2/0/2] port access vlan 1000
# Enable basic QinQ. Tag frames from VLAN 10 with the outer VLAN tag 1000.
[ProviderA-Ethernet2/0/2] qinq enable
[ProviderA-Ethernet2/0/2] quit
l          Configuration on Ethernet 2/0/3.
# Configure Ethernet 2/0/3 as a trunk port, and assign it to VLAN 1000 and VLAN 2000.
[ProviderA] interface ethernet 2/0/3
[ProviderA-Ethernet2/0/3] port link-type trunk
[ProviderA-Ethernet2/0/3] port trunk permit vlan 1000 2000
# To enable interoperability with the third-party devices in the public network, set the TPID of the SVLAN tags to 0x8200. Therefore, the port tags the frames with the outer VLAN tag whose TPID is 0x8200.
[ProviderA-Ethernet2/0/3] qinq ethernet-type service-tag 8200
# Configure Ethernet 2/0/1 as a trunk port, and assign it to VLAN 1000、VLAN 2000 and VLAN 3000.
[ProviderB] interface ethernet 2/0/1
[ProviderB-Ethernet2/0/1] port link-type trunk
[ProviderB-Ethernet2/0/1] port trunk permit vlan 1000 2000 3000
# To enable interoperability with the third-party devices in the public network, set the TPID of the SVLAN tags to 0x8200. Therefore, the port tags the received frames with the outer VLAN tag whose TPID is 0x8200.
[ProviderB-Ethernet2/0/1] qinq ethernet-type service-tag 8200
[ProviderB-Ethernet2/0/1] quit
# Configure VLAN 2000 as the default VLAN.
[ProviderB] interface ethernet 2/0/2
[ProviderB-Ethernet2/0/2] port access vlan 2000
# Enable basic QinQ. Tag frames from VLAN 20 with the outer VLAN tag 2000.
[ProviderB-Ethernet2/0/2] qinq enable
[ProviderB-Ethernet2/0/2] quit
# Configure VLAN 3000 as the default VLAN of Ethernet 2/0/3.
[ProviderB] interface ethernet 2/0/3
[ProviderB-Ethernet2/0/3] port access vlan 3000
# Enable basic QinQ to tag frames of all customer VLANs (CVLANs) with the outer VLAN tag 3000.
[ProviderB-Ethernet2/0/3] qinq enable
3)        Configuration on devices on the public network
As third-party devices are deployed between Provider A and Provider B, only the basic configurations that should be made on the devices are discussed here. Configure that device connecting with Ethernet 2/0/3 of Provider A and the device connecting with Ethernet 2/0/1 of Provider B so that the involved ports on them send tagged frames of VLAN 1000, VLAN 2000 and VLAN 3000. The configuration steps are omitted here.
vlan 1000
vlan 2000
vlan 3000
traffic classifier A10 operator and
traffic classifier A20 operator and
qos policy qinq
interface Ethernet2/0/1
 port hybrid vlan 1 100 1000 2000 3000 untagged
 qinq enable
interface Ethernet2/0/2
 qinq enable
interface Ethernet2/0/3
 port trunk permit vlan 1 100 2000 3000
l          Configuration on ProviderB
vlan 1000
vlan 2000
vlan 3000
interface GigabitEthernet2/0/1
 port trunk permit vlan 1 1000 2000 3000
interface GigabitEthernet2/0/2
 qinq enable
interface GigabitEthernet2/0/3
 qinq enable
l          Before enabling selective QinQ on a port, enable basic QinQ on the port first. Selective QinQ enjoys higher priority than basic QinQ. Therefore, a received frame will be tagged with an outer VLAN ID based on basic QinQ only after it fails to match the match criteria defined in the traffic class.
l          On the S7500E series switches, selective QinQ is achieved through QoS policies. For detailed information about QoS policies, refer to the part talking about QoS.
Configuring One-to-One VLAN Mapping
Network Diagram
Figure 1-3 Network diagram for one-to-one VLAN mapping
For a home, different types of traffic (PC, IPTV, and VoIP) are transmitted in different VLANs.
For a traffic type, packets from different users are isolated from each other.
Product series
Software version
Hardware version
Release 6100
All versions
1)        Configuration on Switch A
# Create CVLANs and SVLANs.
[SwitchA] vlan 2 to 3
[SwitchA] vlan 101 to 102
[SwitchA] vlan 201 to 202
[SwitchA] vlan 301 to 302
# Configure uplink policies to map the CVLANs to the SVLANs.
[SwitchA] traffic classifier c1
[SwitchA-classifier-c1] if-match customer-vlan-id 1
[SwitchA-classifier-c1] traffic classifier c2
[SwitchA-classifier-c2] if-match customer-vlan-id 2
[SwitchA-classifier-c2] traffic classifier c3
[SwitchA-classifier-c3] if-match customer-vlan-id 3
[SwitchA-classifier-c3] quit
[SwitchA] traffic behavior b1
[SwitchA-behavior-b1] remark service-vlan-id 101
[SwitchA-behavior-b1] traffic behavior b2
[SwitchA-behavior-b2] remark service-vlan-id 201
[SwitchA-behavior-b2] traffic behavior b3
[SwitchA-behavior-b3] remark service-vlan-id 301
[SwitchA-behavior-b3] traffic behavior b4
[SwitchA-behavior-b4] remark service-vlan-id 102
[SwitchA-behavior-b4] traffic behavior b5
[SwitchA-behavior-b5] remark service-vlan-id 202
[SwitchA-behavior-b5] traffic behavior b6
[SwitchA-behavior-b6] remark service-vlan-id 302
[SwitchA-behavior-b6] quit
[SwitchA] qos policy p1
[SwitchA-policy-p1] classifier c1 behavior b1
[SwitchA-policy-p1] classifier c2 behavior b2
[SwitchA-policy-p1] classifier c3 behavior b3
[SwitchA-policy-p1] quit
[SwitchA] qos policy p2
[SwitchA-policy-p2] classifier c1 behavior b4
[SwitchA-policy-p2] classifier c2 behavior b5
[SwitchA-policy-p2] classifier c3 behavior b6
[SwitchA-policy-p2] quit
# Configure downlink policies to map the SVLANs to the original CVLANs.
[SwitchA] traffic classifier c11
[SwitchA-classifier-c11] if-match service-vlan-id 101
[SwitchA-classifier-c11] traffic classifier c22
[SwitchA-classifier-c22] if-match service-vlan-id 201
[SwitchA-classifier-c22] traffic classifier c33
[SwitchA-classifier-c33] if-match service-vlan-id 301
[SwitchA-classifier-c33] traffic classifier c44
[SwitchA-classifier-c44] if-match service-vlan-id 102
[SwitchA-classifier-c44] traffic classifier c55
[SwitchA-classifier-c55] if-match service-vlan-id 202
[SwitchA-classifier-c55] traffic classifier c66
[SwitchA-classifier-c66] if-match service-vlan-id 302
[SwitchA-classifier-c66] quit
[SwitchA] traffic behavior b11
[SwitchA-behavior-b11] remark customer-vlan-id 1
[SwitchA-behavior-b11] traffic behavior b22
[SwitchA-behavior-b22] remark customer-vlan-id 2
[SwitchA-behavior-b22] traffic behavior b33
[SwitchA-behavior-b33] remark customer-vlan-id 3
[SwitchA-behavior-b33] quit
[SwitchA] qos policy p11
[SwitchA-policy-p11] classifier c11 behavior b11
[SwitchA-policy-p11] classifier c22 behavior b22
[SwitchA-policy-p11] classifier c33 behavior b33
[SwitchA-policy-p11] quit
[SwitchA] qos policy p22
[SwitchA-policy-p22] classifier c44 behavior b11
[SwitchA-policy-p22] classifier c55 behavior b22
[SwitchA-policy-p22] classifier c66 behavior b33
[SwitchA-policy-p22] quit
# Configure GigabitEthernet 2/0/1 as a trunk port and assign it to the specified CVLANs and SVLANs.
[SwitchA] interface GigabitEthernet 2/0/1
[SwitchA-GigabitEthernet2/0/1] port link-type trunk
[SwitchA-GigabitEthernet2/0/1] port trunk permit vlan 1 2 3 101 201 301
# Enable basic QinQ on GigabitEthernet 2/0/1.
[SwitchA-GigabitEthernet2/0/1] qinq enable
# Apply the uplink policy p1 to the inbound direction of GigabitEthernet 2/0/1.
[SwitchA-GigabitEthernet2/0/1] qos apply policy p1 inbound
# Apply the downlink policy p11 to the outbound direction of GigabitEthernet 2/0/1.
[SwitchA-GigabitEthernet2/0/1] qos apply policy p11 outbound
[SwitchA-GigabitEthernet2/0/1] quit
# Configure GigabitEthernet 2/0/2 as a trunk port and assign it to the specified CVLANs and SVLANs.
[SwitchA] interface GigabitEthernet 2/0/2
[SwitchA-GigabitEthernet2/0/2] port link-type trunk
[SwitchA-GigabitEthernet2/0/2] port trunk permit vlan 1 2 3 102 202 302
# Enable basic QinQ on GigabitEthernet 2/0/2.
[SwitchA-GigabitEthernet2/0/2] qinq enable
# Apply the uplink policy p2 to the inbound direction of GigabitEthernet 1/2.
[SwitchA-GigabitEthernet2/0/2] qos apply policy p2 inbound
# Apply the downlink policy p22 to the outbound direction of GigabitEthernet 1/2.
[SwitchA-GigabitEthernet2/0/2] qos apply policy p22 outbound
[SwitchA-GigabitEthernet2/0/2] quit
# Configure GigabitEthernet 2/0/3 as a trunk port and assign it to the specified SVLANs.
[SwitchA] interface GigabitEthernet 2/0/3
[SwitchA-GigabitEthernet2/0/3] port link-type trunk
[SwitchA-GigabitEthernet2/0/3] port trunk permit vlan 101 201 301 102 202 302
2)        Configuration on Switch B
[SwitchB] vlan 2 to 3
[SwitchB] vlan 111 to 112
[SwitchB] vlan 211 to 212
[SwitchB] vlan 311 to 312
[SwitchB] traffic classifier c1
[SwitchB-classifier-c1] if-match customer-vlan-id 1
[SwitchB-classifier-c1] traffic classifier c2
[SwitchB-classifier-c2] if-match customer-vlan-id 2
[SwitchB-classifier-c2] traffic classifier c3
[SwitchB-classifier-c3] if-match customer-vlan-id 3
[SwitchB-classifier-c3] quit
[SwitchB] traffic behavior b1
[SwitchB-behavior-b1] remark service-vlan-id 111
[SwitchB-behavior-b1] traffic behavior b2
[SwitchB-behavior-b2] remark service-vlan-id 211
[SwitchB-behavior-b2] traffic behavior b3
[SwitchB-behavior-b3] remark service-vlan-id 311
[SwitchB-behavior-b3] traffic behavior b4
[SwitchB-behavior-b4] remark service-vlan-id 112
[SwitchB-behavior-b4] traffic behavior b5
[SwitchB-behavior-b5] remark service-vlan-id 212
[SwitchB-behavior-b5] traffic behavior b6
[SwitchB-behavior-b6] remark service-vlan-id 312
[SwitchB-behavior-b6] quit
[SwitchB] qos policy p1
[SwitchB-policy-p1] classifier c1 behavior b1
[SwitchB-policy-p1] classifier c2 behavior b2
[SwitchB-policy-p1] classifier c3 behavior b3
[SwitchB-policy-p1] quit
[SwitchB] qos policy p2
[SwitchB-policy-p2] classifier c1 behavior b4
[SwitchB-policy-p2] classifier c2 behavior b5
[SwitchB-policy-p2] classifier c3 behavior b6
[SwitchB-policy-p2] quit
[SwitchB] traffic classifier c11
[SwitchB-classifier-c11] if-match service-vlan-id 111
[SwitchB-classifier-c11] traffic classifier c22
[SwitchB-classifier-c22] if-match service-vlan-id 211
[SwitchB-classifier-c22] traffic classifier c33
[SwitchB-classifier-c33] if-match service-vlan-id 311
[SwitchB-classifier-c33] traffic classifier c44
[SwitchB-classifier-c44] if-match service-vlan-id 112
[SwitchB-classifier-c44] traffic classifier c55
[SwitchB-classifier-c55] if-match service-vlan-id 212
[SwitchB-classifier-c55] traffic classifier c66
[SwitchB-classifier-c66] if-match service-vlan-id 312
[SwitchB-classifier-c66] quit
[SwitchB] traffic behavior b11
[SwitchB-behavior-b11] remark customer-vlan-id 1
[SwitchB-behavior-b11] traffic behavior b22
[SwitchB-behavior-b22] remark customer-vlan-id 2
[SwitchB-behavior-b22] traffic behavior b33
[SwitchB-behavior-b33] remark customer-vlan-id 3
[SwitchB-behavior-b33] quit
[SwitchB] qos policy p11
[SwitchB-policy-p11] classifier c11 behavior b11
[SwitchB-policy-p11] classifier c22 behavior b22
[SwitchB-policy-p11] classifier c33 behavior b33
[SwitchB-policy-p11] quit
[SwitchB] qos policy p22
[SwitchB-policy-p22] classifier c44 behavior b11
[SwitchB-policy-p22] classifier c55 behavior b22
[SwitchB-policy-p22] classifier c66 behavior b33
[SwitchB-policy-p22] quit
[SwitchB] interface GigabitEthernet 2/0/1
[SwitchB-GigabitEthernet2/0/1] port link-type trunk
[SwitchB-GigabitEthernet2/0/1] port trunk permit vlan 1 2 3 111 211 311
[SwitchB-GigabitEthernet2/0/1] qos apply policy p1 inbound
[SwitchB-GigabitEthernet2/0/1] qos apply policy p11 outbound
[SwitchB-GigabitEthernet2/0/1] quit
[SwitchB] interface GigabitEthernet 2/0/2
[SwitchB-GigabitEthernet2/0/2] port link-type trunk
[SwitchB-GigabitEthernet2/0/2] port trunk permit vlan 1 2 3 112 212 312
[SwitchB-GigabitEthernet2/0/2] qos apply policy p2 inbound
[SwitchB-GigabitEthernet2/0/2] qos apply policy p22 outbound
[SwitchB-GigabitEthernet2/0/2] quit
[SwitchB] interface GigabitEthernet 2/0/3
[SwitchB-GigabitEthernet2/0/3] port link-type trunk
[SwitchB-GigabitEthernet2/0/3] port trunk permit vlan 111 211 311 112 212 312
Configuration on Switch A:
vlan 1
vlan 2 to 3
vlan 101 to 102
vlan 201 to 202
vlan 301 to 302
traffic classifier c2 operator and
traffic classifier c3 operator and
traffic classifier c1 operator and
traffic classifier c11 operator and
traffic classifier c22 operator and
traffic classifier c33 operator and
traffic classifier c44 operator and
traffic classifier c55 operator and
traffic classifier c66 operator and
traffic behavior b6
traffic behavior b4
traffic behavior b2
traffic behavior b5
traffic behavior b3
traffic behavior b1
qos policy p11
qos policy p22
qos policy p2
qos policy p1
 port trunk permit vlan 1 to 3 101 201 301
 port trunk permit vlan 1 to 3 102 202 302
 port trunk permit vlan 1 101 to 102 201 to 202 301 to 302
Configuration on Switch B:
vlan 1
vlan 2 to 3
vlan 111 to 112
vlan 211 to 212
vlan 311 to 312
traffic behavior b6
traffic behavior b4
traffic behavior b2
traffic behavior b5
traffic behavior b3
traffic behavior b1
qos policy p11
qos policy p22
qos policy p2
qos policy p1
 port trunk permit vlan 1 to 3 111 211 311
 port trunk permit vlan 1 to 3 112 212 312
 port trunk permit vlan 1 111 to 112 211 to 212 311 to 312
Note that:
l          Of the VLAN mapping types, only one-to-one VLAN mapping is supported on the S7500E switches.
l          On S7500E switches, refer to the corresponding operation and command manuals for support for the inbound and outbound keywords of the qos policy apply command.
l          Before configuring one-to-one VLAN mapping, design the CVLAN-SVLAN mapping relationships first.
l          To use QoS policies for implementing one-to-one VLAN mapping in the outbound direction of an SA or EA board, you must use the if-match customer-vlan-id command for traffic classification in an uplink policy, and use the remark customer-vlan-id command in the traffic behavior of a downlink policy; additionally, you must enable basic QinQ on a port before applying a QoS policy to the port.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
