H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
21-MAC Authentication Configuration Guide
21-MAC Authentication Configuration Guide 99.89 KB
MAC Authentication Overview
MAC authentication provides a way for authenticating users based on ports and MAC addresses, without requiring any client software to be installed on the hosts. Once detecting a new MAC address, it initiates the authentication process without requiring any username or password.
Currently, the device supports two MAC authentication modes:
l          Remote Authentication Dial-In User Service (RADIUS) based MAC authentication
l          Local MAC authentication
For detailed information about RADIUS authentication and local authentication, refer to AAA RADIUS HWTACACS Configuration.
After determining the authentication mode to be used, you can choose the username and password type for MAC authentication, which can be:
l          MAC address: The MAC address of a user serves as both the username and password for authentication.
l          Fixed username: All users use the same preconfigured username and password for authentication, regardless of their MAC addresses.
Configuring Local MAC Authentication
Network Diagram
Figure 1-1 Network diagram for local MAC authentication configuration
Networking and Configuration Requirements
As illustrated in Figure 1-1, a host is connected to the switch through port GigabitEthernet 2/0/1.
l          Local MAC authentication is required on every port to control user access to the Internet.
l          All users belong to domain aabbcc.net.
l          Set the offline detect timer to 180 seconds and the quiet timer to 3 minutes.
l          A local user uses aaa as the username and 123456 as the password for authentication.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301, Release 5303
All versions
S5510 Series Ethernet Switches
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100, Release 6300
All versions
Configuration Procedure
1)        Configure MAC authentication on the switch.
# Add a local user.
<Switch> system-view
[Switch] local-user aaa
[Switch-luser-aaa] password simple 123456
[Switch-luser-aaa] service-type lan-access
[Switch-luser-aaa] quit
# Configure ISP domain aabbcc.net, and specify to perform local authentication.
[Switch] domain aabbcc.net
[Switch-isp-aabbcc.net] authentication lan-access local
[Switch-isp-aabbcc.net] quit
# Enable MAC authentication globally.
[Switch] mac-authentication
# Enable MAC authentication for port GigabitEthernet 2/0/1.
[Switch] mac-authentication interface GigabitEthernet 2/0/1
# Specify the ISP domain for MAC authentication.
[Switch] mac-authentication domain aabbcc.net
# Set the MAC authentication timers.
[Switch] mac-authentication timer offline-detect 180
[Switch] mac-authentication timer quiet 180
# Specify the MAC authentication to use fixed username aaa and password 123456 to authenticate supplicants.
[Switch] mac-authentication user-name-format fixed account aaa password simple 123456
Complete Configuration
 local-user aaa
domain aabbcc.net
mac-authentication
interface GigabitEthernet2/0/1
 mac-authentication
Configuration Guidelines
You need to specify the service type as lan-access for local users.
Configuring RADIUS Based MAC Authentication
Network Diagram
Figure 1-2 Network diagram for RADIUS based MAC authentication configuration
As illustrated in Figure 1-2, a host is connected to the switch through port Ethernet 2/0/1. The switch authenticates the host through the RADIUS server.
l          MAC authentication is required on each port to control user access to the Internet.
Product series
Software version
Hardware version
All versions
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
All versions
# Configure the IP addresses of the interfaces. (Omitted)
# Configure a RADIUS scheme.
[Switch] radius scheme 2000
[Switch-radius-2000] primary authentication 10.1.1.1 1812
[Switch-radius-2000] primary accounting 10.1.1.2 1813
[Switch-radius-2000] key authentication abc
[Switch-radius-2000] key accounting abc
[Switch-radius-2000] user-name-format without-domain
[Switch-radius-2000] quit
# Create domain 2000 and specify the AAA schemes for the ISP domain.
[Switch] domain 2000
[Switch-isp-2000] authentication default radius-scheme 2000
[Switch-isp-2000] authorization  default radius-scheme 2000
[Switch-isp-2000] accounting default radius-scheme 2000
[Switch-isp-2000] quit
# Enable MAC authentication for port Ethernet 2/0/1.
[Switch] mac-authentication interface Ethernet 2/0/1
[Switch] mac-authentication domain 2000
radius scheme 2000
 key accounting abc
domain 2000
mac-authentication
interface Ethernet2/0/1
 mac-authentication
l          The username and password configured on the RADIUS server must be consistent with those configured on the switch for MAC authentication.
l          The authentication and accounting keys configured on the RADIUS server must be consistent with those configured on the switch. Otherwise, authentication will fail.
Configuring ACL Assignment
Network Diagram
Figure 1-3 Network diagram for ACL assignment configuration
As shown in Figure 1-3, a host is connected to port Ethernet 2/0/1 of the switch and must pass MAC authentication to access the Internet. An RADIUS server cluster takes the responsibility of authentication. An FTP server with the IP address 10.0.0.1 is on the Internet.
l          On port Ethernet 2/0/1 of the switch, enable MAC authentication and configure ACL 3000.
l          Configure the authentication server to assign ACL 3000 to the switch as the authorization ACL after the host passes authentication, so that the host can access the Internet but cannot access the FTP server.
Product series
Software version
Hardware version
All versions
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
All versions
# Configure the RADIUS scheme.
# Create an ISP domain and specify the AAA schemes for the ISP domain.
# Configure ACL 3000 to deny packets destined for 10.0.0.1.
[Switch] acl number 3000
[Switch-acl-adv-3000] rule 0 deny ip destination 10.0.0.1 0
[Switch-acl-adv-3000] quit
# Specify MAC authentication to use a MAC address with hyphen as the username and password to authenticate supplicants.
[Switch] mac-authentication user-name-format mac-address with-hyphen
radius scheme 2000
 key accounting abc
domain 2000
acl number 3000
mac-authentication
 mac-authentication
l          The authentication and accounting keys configured on the RADIUS server must be consistent with those configured on the switch. Otherwise, the MAC authentication will fail.
l          The username and password type configured on the RADIUS server must be consistent with that configured on the switch for MAC authentication.
l          The letters in the MAC address that serves as the authentication username and password must be in lowercase.
