H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
16-IPv6 Routing Configuration Guide
16-IPv6 Routing Configuration Guide 402.85 KB
Table of Contents
1 IPv6 Routing Configuration Guide· 1-1
Configuring an IPv6 Static Route· 1-1
Network Diagram·· 1-1
Networking and Configuration Requirements· 1-1
Applicable Product Matrix· 1-1
Configuration Procedure· 1-2
Complete Configuration· 1-3
Configuration Guidelines· 1-4
Configuring IPv6 RIPng· 1-4
Network Diagram·· 1-4
Networking and Configuration Requirements· 1-4
Applicable Product Matrix· 1-4
Configuration Procedure· 1-5
Complete Configuration· 1-7
Configuration Guidelines· 1-9
Configuring RIPng Route Redistribution· 1-9
Network Diagram·· 1-9
Networking and Configuration Requirements· 1-9
Applicable Product Matrix· 1-9
Configuration Procedure· 1-9
Complete Configuration· 1-11
Configuration Guidelines· 1-13
Configuring IPv6 RIPng over IPv4 Tunnel 1-13
Network Diagram·· 1-13
Networking and Configuration Requirements· 1-13
Applicable Product Matrix· 1-13
Configuration Procedure· 1-14
Complete Configuration· 1-15
Configuration Guidelines· 1-17
Configuring an OSPFv3 Area· 1-17
Network Diagram·· 1-17
Networking and Configuration Requirements· 1-18
Applicable Product Matrix· 1-18
Configuration Procedure· 1-18
Complete Configuration· 1-21
Configuration Guidelines· 1-23
Configuring OSPFv3 Route Redistribution· 1-24
Network Diagram·· 1-24
Networking and Configuration Requirements· 1-24
Applicable Product Matrix· 1-24
Configuration Procedure· 1-24
Complete Configuration· 1-27
Configuration Guidelines· 1-28
Configure OSPFv3 DR Election· 1-29
Network Diagram·· 1-29
Networking and Configuration Requirements· 1-29
Applicable Product Matrix· 1-29
Configuration Procedure· 1-29
Complete Configuration· 1-32
Configuration Guidelines· 1-33
Configuring IPv6 IS-IS· 1-33
Network Diagram·· 1-34
Networking and Configuration Requirements· 1-34
Applicable Product Matrix· 1-34
Configuration Procedure· 1-34
Complete Configuration· 1-35
Configuration Guidelines· 1-37
Configuring IPv6 BGP· 1-37
Network Diagram·· 1-38
Networking and Configuration Requirements· 1-38
Applicable Product Matrix· 1-38
Configuration Procedure· 1-38
Complete Configuration· 1-40
Configuration Guidelines· 1-42
Configuring IPv6 BGP Route Reflector 1-42
Network Diagram·· 1-42
Networking and Configuration Requirements· 1-42
Applicable Product Matrix· 1-43
Configuration Procedure· 1-43
Complete Configuration· 1-44
Configuration Guidelines· 1-45
Configuring Route Policy Application in IPv6 Route Redistribution· 1-46
Network Diagram·· 1-46
Networking and Configuration Requirements· 1-46
Applicable Product Matrix· 1-46
Configuration Procedure· 1-47
Complete Configuration· 1-48
Configuration Guidelines· 1-49
Static routes are manually configured. They work well in simple networks. Configuring and using them properly can improve the performance of networks and guarantee enough bandwidth for important applications.
However, static routes also have shortcomings: any topology changes could result in unavailable routes, requiring the network administrator to manually configure and modify the static routes.
Network Diagram
Figure 1-1 Network diagram for IPv6 static route configuration
With IPv6 static routes configured, all hosts and switches can communicate with each other.
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5510 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions, except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100
Release 6300
All versions
1)        Configure the IPv6 addresses of all VLAN interfaces (omitted)
2)        Configure IPv6 static routes.
# Configure the default IPv6 static route on Switch A.
[SwitchA] ipv6
[SwitchA] ipv6 route-static :: 0 4::2
# Configure two IPv6 static routes on Switch B.
[SwitchB] ipv6
[SwitchB] ipv6 route-static 1:: 64 4::1
[SwitchB] ipv6 route-static 3:: 64 5::1
# Configure the default IPv6 static route on Switch C.
[SwitchC] ipv6
[SwitchC] ipv6 route-static :: 0 5::2
3)        Configure the IPv6 addresses of hosts and gateways.
Configure the IPv6 addresses of all the hosts based upon the network diagram, configure the default gateway of Host A as 1::1, that of Host B as 2::1, and that of Host C as 3::1.
4)        Display configuration information
# Display the IPv6 routing table of Switch A.
[SwitchA] display ipv6 routing-table
Routing Table :
         Destinations : 7        Routes : 7
Destination: ::/0                                        Protocol  : Static
NextHop    : 4::2                                        Preference: 60
Interface  : Vlan200                                     Cost      : 0
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 1::/64                                      Protocol  : Direct
NextHop    : 1::1                                        Preference: 0
Interface  : Vlan100                                     Cost      : 0
Destination: 1::1/128                                    Protocol  : Direct
Destination: 4::/64                                      Protocol  : Direct
NextHop    : 4::1                                        Preference: 0
Destination: 4::1/128                                    Protocol  : Direct
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
Interface  : NULL0                                       Cost      : 0
# Verify the connectivity with the ping command.
[SwitchA] ping ipv6 3::1
  PING 3::1 : 56  data bytes, press CTRL_C to break
    Reply from 3::1
    bytes=56 Sequence=1 hop limit=254  time = 63 ms
    Reply from 3::1
    bytes=56 Sequence=2 hop limit=254  time = 62 ms
    Reply from 3::1
    bytes=56 Sequence=3 hop limit=254  time = 62 ms
    Reply from 3::1
    bytes=56 Sequence=4 hop limit=254  time = 63 ms
    Reply from 3::1
    bytes=56 Sequence=5 hop limit=254  time = 63 ms
  --- 3::1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 62/62/63 ms
l          Configure Switch A.
 ipv6
l          Configure Switch B.
 ipv6
l          Configure Switch C.
 ipv6
When configuring a static route, you can specify the output interface. If the output interface is a VLAN interface, the next hop address must be specified.
RIP next generation (RIPng) is an extension of RIP-2 for IPv4. Most RIP concepts are applicable in RIPng.
RIPng for IPv6 made the following changes to RIP:
l          UDP port number: RIPng uses UDP port 521 for sending and receiving routing information.
l          Multicast address: RIPng uses FF02:9 as the link-local multicast address.
l          Destination Prefix: 128-bit destination address prefix.
l          Next hop: 128-bit IPv6 address.
l          Source address: RIPng uses FE80::/10 as the link-local source address
Network Diagram
Figure 1-2 Network diagram for RIPng configuration
As shown in the figure above, all switches run RIPng. Configure Switch B to filter the route (3::/64) learned from Switch C so that the route will not be added to the routing table of Switch B and Switch B will not forward it to Switch A.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
1)        Configure the IPv6 address for each interface (omitted)
2)        Configure basic RIPng functions.
# Configure Switch A.
[SwitchA] ipv6
[SwitchA] ripng 1
[SwitchA-ripng-1] quit
[SwitchA-Vlan-interface100] ripng 1 enable
[SwitchA] interface vlan-interface 400
[SwitchA-Vlan-interface400] ripng 1 enable
[SwitchA-Vlan-interface400] quit
# Configure Switch B.
[SwitchB] ipv6
[SwitchB] ripng 1
[SwitchB-ripng-1] quit
[SwitchB-Vlan-interface200] ripng 1 enable
[SwitchB-Vlan-interface100] ripng 1 enable
# Configure Switch C.
[SwitchC] ipv6
[SwitchC] ripng 1
[SwitchC-ripng-1] quit
[SwitchC-Vlan-interface200] ripng 1 enable
[SwitchC] interface vlan-interface 500
[SwitchC-Vlan-interface500] ripng 1 enable
[SwitchC-Vlan-interface500] quit
[SwitchC] interface vlan-interface 600
[SwitchC-Vlan-interface600] ripng 1 enable
[SwitchC-Vlan-interface600] quit
# Display the routing table of Switch B.
[SwitchB] display ripng 1 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
 Peer FE80::20F:E2FF:FE23:82F5  on Vlan-interface100
 Dest 1::/64,
     via FE80::20F:E2FF:FE23:82F5, cost  1, tag 0, A, 6 Sec
 Dest 2::/64,
 Peer FE80::20F:E2FF:FE00:100  on Vlan-interface200
 Dest 3::/64,
     via FE80::20F:E2FF:FE00:100, cost  1, tag 0, A, 11 Sec
 Dest 4::/64,
 Dest 5::/64,
# Display the RIPng routing table of Switch A.
[SwitchA] display ripng 1 route
 Peer FE80::200:2FF:FE64:8904  on Vlan-interface100
 Dest 1::/64,
     via FE80::200:2FF:FE64:8904, cost  1, tag 0, A, 31 Sec
 Dest 4::/64,
     via FE80::200:2FF:FE64:8904, cost  2, tag 0, A, 31 Sec
 Dest 5::/64,
 Dest 3::/64,
3)        Configure Switch B to filter incoming and outgoing routes.
[SwitchB] acl ipv6 number 2000
[SwitchB-acl6-basic-2000] rule deny source 3::/64
[SwitchB-acl6-basic-2000] rule permit
[SwitchB-acl6-basic-2000] quit
[SwitchB] ripng 1
[SwitchB-ripng-1] filter-policy 2000 import
[SwitchB-ripng-1] filter-policy 2000 export
# Display RIPng routing tables of Switch B and Switch A.
 Dest 1::/64,
     via FE80::20F:E2FF:FE23:82F5, cost  1, tag 0, A, 2 Sec
 Dest 2::/64,
 Dest 4::/64,
     via FE80::20F:E2FF:FE00:100, cost  1, tag 0, A, 5 Sec
 Dest 5::/64,
 Peer FE80::20F:E2FF:FE00:1235  on Vlan-interface100
 Dest 1::/64,
     via FE80::20F:E2FF:FE00:1235, cost  1, tag 0, A, 2 Sec
 Dest 4::/64,
     via FE80::20F:E2FF:FE00:1235, cost  2, tag 0, A, 2 Sec
 Dest 5::/64,
 ipv6
vlan 100
vlan 400
interface Vlan-interface100
 ipv6 address 1::1/64
 ripng 1 enable
interface Vlan-interface400
 ipv6 address 2::1/64
 ripng 1 enable
ripng 1
 ipv6
vlan 100
vlan 200
 rule 0 deny source 3::/64
 rule 5 permit
 ipv6 address 1::2/64
 ripng 1 enable
interface Vlan-interface200
 ipv6 address 3::1/64
 ripng 1 enable
ripng 1
 ipv6
vlan 200
vlan 500
vlan 600
 ipv6 address 3::2/64
 ripng 1 enable
interface Vlan-interface500
 ipv6 address 5::1/64
 ripng 1 enable
interface Vlan-interface600
 ipv6 address 4::1/64
 ripng 1 enable
ripng 1
If RIPng is not enabled on an interface, the interface will not send and receive any RIPng route.
Network Diagram
Figure 1-3 Network diagram for RIPng route redistribution
As shown in Figure 1-3, two RIPng processes are running on Switch B, which communicates with Switch A through RIPng 100 and with Switch C through RIPng 200.
Configure route redistribution on Switch B, letting the two RIPng processes redistribute routes from each other. Set the default cost of redistributed routes from RIPng 200 to 3.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 6100
Release 6300
All versions
1)        Configure IPv6 addresses for the interfaces (omitted).
# Enable RIPng 100 on Switch A.
[SwitchA] ripng 100
[SwitchA-ripng-100] quit
[SwitchA-Vlan-interface100] ripng 100 enable
[SwitchA-Vlan-interface200] ripng 100 enable
# Enable RIP 100 and RIP 200 on Switch B.
[SwitchB] ripng 100
[SwitchB-ripng-100] quit
[SwitchB-Vlan-interface100] ripng 100 enable
[SwitchB] ripng 200
[SwitchB-ripng-200] quit
[SwitchB] interface vlan-interface 300
[SwitchA-Vlan-interface300] ripng 200 enable
# Enable RIPng 200 on Switch C.
[SwitchC] ripng 200
[SwitchC-Vlan-interface300] ripng 200 enable
[SwitchC-Vlan-interface300] quit
[SwitchC] interface vlan-interface 400
[SwitchC-Vlan-interface400] ripng 200 enable
[SwitchC-Vlan-interface400] quit
# # Display the IPv6 routing table of Switch A.
Routing Table :
         Destinations : 6        Routes : 6
Destination: 2::/64                                      Protocol  : Direct
NextHop    : 2::1                                        Preference: 0
Destination: 2::1/128                                    Protocol  : Direct
2)        Configure RIPng route redistribution.
# Configure route redistribution between the two RIPng processes on Switch B.
[SwitchB] ripng 100
[SwitchB-ripng-100] default cost 3
[SwitchB-ripng-100] import-route ripng 200
[SwitchB] ripng 200
[SwitchB-ripng-200] import-route ripng 100
Routing Table :
Destination: 4::/64                                      Protocol  : RIPng
NextHop    : FE80::200:BFF:FE01:1C02                     Preference: 100
Interface  : Vlan100                                     Cost      : 4
 ipv6
vlan 100
vlan 200
 ripng 100 enable
 ripng 100 enable
ripng 200
 ipv6
vlan 100
vlan 300
 ripng 100 enable
interface Vlan-interface300
 ripng 200 enable
ripng 100
 default cost 3
ripng 200
 ipv6
vlan 300
vlan 400
 ripng 200 enable
 ripng 200 enable
ripng 200
l          The S5500-EI series Ethernet switches of Release 2102 support only RIPng single process.
l          The S5500-SI series Ethernet switches of Release 1207 or Release 1301 support only RIPng single process.
Network Diagram
Figure 1-4 Network diagram for IPv6 RIPng over IPv4 tunnel configuration
As shown in Figure 1-4, two IPv6 networks are connected to the IPv4 network respectively through Switch A and Switch B, which are reachable to each other. It is required to configure an IPv6 manual tunnel between Switch A and Switch B so that the two IPv6 networks can communicate with each other through RIPng.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 2102
All versions
Release 6100
Release 6300
All versions
1)        Configure IPv6 and IPv4 addresses for the interfaces (omitted)
2)        Configure Switch A.
# Enable IPv6.
[SwitchA] ipv6
# Configure an IPv6 manual tunnel.
[SwitchA] interface tunnel 0
[SwitchA-Tunnel0] ipv6 address 3001::1:1 64
[SwitchA-Tunnel0] source vlan-interface 101
[SwitchA-Tunnel0] destination 10.1.1.2
[SwitchA-Tunnel0] tunnel-protocol ipv6-ipv4
[SwitchA-Tunnel0] quit
# Configure RIPng basic functions.
[SwitchA] ripng 1
[SwitchA-Tunnel0] ripng 1 enable
3)        Configure Switch B.
# Enable IPv6.
[SwitchB] ipv6
[SwitchB] interface tunnel 0
[SwitchB-Tunnel0] ipv6 address 3001::1:2 64
[SwitchB-Tunnel0] source vlan-interface 101
[SwitchB-Tunnel0] destination 172.13.1.1
[SwitchB-Tunnel0] tunnel-protocol ipv6-ipv4
[SwitchB-Tunnel0] quit
[SwitchA] ripng 1
4)        Configure Switch C.
# Enable IPv6.
[SwitchC] ipv6
[SwitchC] ripng 1
[SwitchC-Vlan-interface100] ripng 1 enable
5)        Configure Switch D.
# Enable IPv6.
<SwitchD> system-view
[SwitchD] ipv6
[SwitchD] ripng 1
[SwitchD-ripng-1] quit
[SwitchD] interface vlan-interface 100
[SwitchD-Vlan-interface100] ripng 1 enable
[SwitchD-Vlan-interface100] quit
Use the display ipv6 routing-table command on Switch C and Switch D respectively. You can see that Switch C has learned the network 2002:3::/64 and Switch D has learned the network 2002:1::/64.
 ipv6
vlan 100 to 101
 ipv6 address 2002:1::1/64
 ripng 1 enable
interface Vlan-interface101
 ip address 172.13.1.1 255.255.255.0
interface Tunnel0
 ipv6 address 3001::1:1/64
 ripng 1 enable
 source Vlan-interface101
ripng 1
 ipv6
vlan 100
vlan 101
 ipv6 address 2002:3::1/64
 ripng 1 enable
interface Tunnel0
 ipv6 address 3001::1:2/64
 ripng 1 enable
ripng 1
 ipv6
vlan 100
 ipv6 address 2002:1::2/64
 ripng 1 enable
ripng 1
l          Configure Switch D.
 ipv6
vlan 100
 ipv6 address 2002:3::2/64
 ripng 1 enable
ripng 1
l          If the addresses of the tunnel interfaces at the two ends of a tunnel are not in the same network segment, a forwarding route through the tunnel to the peer must be configured so that the encapsulated packets can be forwarded normally. You can configure static or dynamic routing.
l          To configure dynamic routing, you must enable the dynamic routing protocol on the tunnel interfaces at both ends of the tunnel.
l          For distributed switches, such as the S7500E series, the tunnel interface number is in the A/B/C format, where A, B, and C represent the slot number of a card, the slot number of a sub-card, and the tunnel interface number respectively.
l          When you create a tunnel interface on a distributed switch, such as an S7500E switch, the slot number of the tunnel interface should be that of the source interface, namely, the interface sending packets. In this way, the forwarding efficiency can be improved.
Open Shortest Path First version 3 supports IPv6 and complies with RFC2740 (OSPF for IPv6).
OSPFv3 and OSPFv2 have the following in common:
l          32-bit router ID and area ID
l          Packets: Hello, DD (Data Description), LSR (Link State Request), LSU (Link State Update), LSAck (Link State Acknowledgment)
l          Mechanisms for finding neighbors and establishing adjacencies
l          Mechanisms for LSA flooding and aging
Differences between OSPFv3 and OSPFv2 are as follows:
l          OSPFv3 now runs on a per-link basis, instead of on a per-IP-subnet basis.
l          OSPFv3 supports multiple instances per link.
l          OSPFv3 identifies neighbors by Router ID, while OSPFv2 by IP address.
Network Diagram
Figure 1-5 Network diagram for OSPFv3 area configuration
l          In the figure above, all switches run OSPFv3. The AS is split into three areas, in which, Switch B and Switch C act as ABRs to forward routing information between areas.
l          It is required to configure Area 2 as a stub area, reducing LSAs into the area without affecting route reachability.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 2102
All versions
Release 6100
Release 6300
All versions
1)        Configure IPv6 addresses for interfaces (omitted)
2)        Configure OSPFv3 basic functions
[SwitchA] ipv6
[SwitchA] ospfv3
[SwitchA-ospfv3-1] router-id 1.1.1.1
[SwitchA-ospfv3-1] quit
[SwitchA] interface vlan-interface 300
[SwitchA-Vlan-interface300] ospfv3 1 area 1
[SwitchA-Vlan-interface300] quit
[SwitchA-Vlan-interface200] ospfv3 1 area 1
[SwitchB] ipv6
[SwitchB] ospfv3
[SwitchB-ospf-1] router-id 2.2.2.2
[SwitchB-ospf-1] quit
[SwitchB-Vlan-interface100] ospfv3 1 area 0
[SwitchB-Vlan-interface200] ospfv3 1 area 1
[SwitchC] ipv6
[SwitchC] ospfv3
[SwitchC-ospfv3-1] router-id 3.3.3.3
[SwitchC-ospfv3-1] quit
[SwitchC-Vlan-interface100] ospfv3 1 area 0
[SwitchC-Vlan-interface400] ospfv3 1 area 2
# Configure Switch D.
[SwitchD] ipv6
[SwitchD] ospfv3
[SwitchD-ospfv3-1] router-id 4.4.4.4
[SwitchD-ospfv3-1] quit
[SwitchD-Vlan-interface400] ospfv3 1 area 2
# Display OSPFv3 neighbor information on Switch B.
[SwitchB] display ospfv3 peer
            OSPFv3 Area ID 0.0.0.0 (Process 1)
Neighbor ID    Pri   State          Dead Time   Interface      Instance ID
3.3.3.3        1     Full/DR        00:00:39    Vlan100        0
            OSPFv3 Area ID 0.0.0.1 (Process 1)
1.1.1.1         1     Full/Backup   00:00:38    Vlan200        0
# Display OSPFv3 neighbor information on Switch C.
[SwitchC] display ospfv3 peer
2.2.2.2        1     Full/Backup    00:00:39    Vlan100        0
            OSPFv3 Area ID 0.0.0.2 (Process 1)
4.4.4.4         1     Full/DR       00:00:38    Vlan400        0
# Display OSPFv3 routing table information on Switch D.
[SwitchD] display ospfv3 routing
E1 - Type 1 external route,    IA - Inter area route,    I  - Intra area route
E2 - Type 2 external route,    *  - Seleted route
            OSPFv3 Router with ID (4.4.4.4) (Process 1)
 *Destination: 2001::/64
  Type       : IA                                       Cost     : 2
  NextHop    : FE80::F40D:0:93D0:1                      Interface: Vlan400
 *Destination: 2001:1::/64
  Type       : IA                                       Cost     : 3
 *Destination: 2001:2::/64
  Type       : I                                        Cost     : 1
  NextHop    : directly-connected                       Interface: Vlan400
 *Destination: 2001:3::/64
  Type       : IA                                       Cost     : 4
3)        Configure Area 2 as a stub area
# ConfigureSwitch D.
[SwitchD] ospfv3
[SwitchD-ospfv3-1] area 2
[SwitchD-ospfv3-1-area-0.0.0.2] stub
# Configure Switch C, and specify the cost of the default route sent to the stub area as 10.
[SwitchC] ospfv3
[SwitchC-ospfv3-1] area 2
[SwitchC-ospfv3-1-area-0.0.0.2] stub
[SwitchC-ospfv3-1-area-0.0.0.2] default-cost 10
# Display OSPFv3 routing table information on Switch D. You can find a default route is added, whose cost is the cost of the directly connected route plus the configured cost.
 *Destination: ::/0
  Type       : IA                                       Cost     : 11
  Type       : IA                                       Cost     : 2
  Type       : IA                                       Cost     : 3
  Type       : I                                        Cost     : 1
  Type       : IA                                       Cost     : 4
4)        Configure Area 2 as a totally stub area to reduce the stub area routing table size.
# Configure Area 2 as a totally stub area on Router C.
[SwitchC-ospfv3-1-area-0.0.0.2] stub no-summary
# Display OSPFv3 routing table information on Switch D. You can find route entries are reduced. All non direct routes are removed except the default route.
 *Destination: ::/0
  Type       : IA                                       Cost     : 11
  Type       : I                                        Cost     : 1
 ipv6
vlan 200
vlan 300
 ipv6 address 2001:1::2/64
 ospfv3 1 area 0.0.0.1
 ipv6 address 2001:3::1/64
ospfv3 1
 router-id 1.1.1.1
 ipv6
vlan 100
vlan 200
 ipv6 address 2001::1/64
 ospfv3 1 area 0.0.0.0
 ipv6 address 2001:1::1/64
ospfv3 1
 router-id 2.2.2.2
 ipv6
vlan 100
vlan 400
 ipv6 address 2001::2/64
 ipv6 address 2001:2::1/64
 ospfv3 1 area 0.0.0.2
ospfv3 1
 router-id 3.3.3.3
 area 0.0.0.2
  stub no-summary
  default-cost 10
 ipv6
vlan 400
 ipv6 address 2001:2::2/64
ospfv3 1
 router-id 4.4.4.4
 area 0.0.0.2
  stub
l          You cannot delete an OSPFv3 area directly. Only when you remove all configurations in area view and all interfaces attached to the area become down can the area be removed automatically.
l          All routers attached to a stub area must be configured with the stub command. The keyword no-summary is only available on the ABR.
l          If you use the stub command with the keyword no-summary on an ABR, the ABR distributes a default summary LSA into the area rather than generating an AS-external-LSA or Inter-Area-Prefix-LSA. The stub area of this kind is also known as totally stub area.
l          To enable an OSPFv3 process on a router, you need to enable the OSPFv3 process globally, assign the OSPFv3 process a router ID, and enable the OSPFv3 process on related interfaces.
l          A router ID uniquely identifies a router within an AS. Therefore, you need to specify a unique router ID for each OSPFv3 router within the AS to ensure normal operation. Note that if a router runs multiple OSPFv3 processes, you need to specify a unique router ID for each process.
Network Diagram
Figure 1-6 Network diagram for OSPFv3 route redistribution configuration
l          Switch A, Switch B, and Switch C are in Area 2.
l          OSPFv3 process 1 and OSPFv3 process 2 are enabled on Switch B. Switch B communicates with Switch A and Switch C through OSPFv3 process 1 and OSPFv3 process 2 respectively.
l          Configure OSPFv3 process 2 to redistribute direct routes and the routes from OSPFv3 process 1 on Switch B and set the default metric for redistributed routes to 3. Thus, Switch C can learn the routes destined for 1::0/64 and 2::0/64, while Switch A cannot learn the routes destined for 3::0/64 or 4::0/64.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 6100
Release 6300
All versions
# # Enable OSPFv3 process 1 on Switch A.
[SwitchA] ipv6
[SwitchA] ospfv3 1
[SwitchA] interface Vlan-interface 100
[SwitchA-Vlan-interface100] ospfv3 1 area 2
[SwitchA] interface Vlan-interface 200
[SwitchA-Vlan-interface200] ospfv3 1 area 2
# Enable OSPFv3 process 1 and OSPFv3 process 2 on Switch B.
[SwitchB] ipv6
[SwitchB] ospfv3 1
[SwitchB-ospfv3-1] router-id 2.2.2.2
[SwitchB-ospfv3-1] quit
[SwitchB] interface Vlan-interface 100
[SwitchB-Vlan-interface100] ospfv3 1 area 2
[SwitchB] ospfv3 2
[SwitchB-ospfv3-2] router-id 3.3.3.3
[SwitchB-ospfv3-2] quit
[SwitchB] interface Vlan-interface 300
[SwitchB-Vlan-interface300] ospfv3 2 area 2
[SwitchB-Vlan-interface300] quit
# Enable OSPFv3 process 2 on Switch C.
[SwitchC] ipv6
[SwitchC] ospfv3 2
[SwitchC-ospfv3-2] router-id 4.4.4.4
[SwitchC-ospfv3-2] quit
[SwitchC] interface Vlan-interface 300
[SwitchC-Vlan-interface300] ospfv3 2 area 2
[SwitchC] interface Vlan-interface 400
[SwitchC-Vlan-interface400] ospfv3 2 area 2
# Display the routing table of Switch C.
[SwitchB] display ipv6 routing-table
Routing Table :
Destination: 3::/64                                      Protocol  : Direct
NextHop    : 3::2                                        Preference: 0
Interface  : Vlan300                                     Cost      : 0
Destination: 3::2/128                                    Protocol  : Direct
Interface  : Vlan400                                     Cost      : 0
2)        Configure OSPFv3 route redistribution
# Configure OSPFv3 process 2 to redistribute direct routes and the routes from OSPFv3 process 1 on Switch B.
[SwitchB] ospfv3 2
[SwitchB-ospfv3-2] default cost 3
[SwitchB-ospfv3-2] import-route ospfv3 1
[SwitchB-ospfv3-2] import-route direct
[SwitchC] display ipv6 routing-table
Routing Table :
         Destinations : 8        Routes : 8
Destination: 1::/64                                      Protocol  : OSPFv3
NextHop    : FE80::200:CFF:FE01:1C03                     Preference: 150
Interface  : Vlan300                                     Cost      : 3
Destination: 2::/64                                      Protocol  : OSPFv3
 ipv6
vlan 100
vlan 200
ospfv3 1
 router-id 1.1.1.1
 ipv6
vlan 100
vlan 300
 ospfv3 2 area 0.0.0.2
ospfv3 1
 router-id 2.2.2.2
ospfv3 2
 router-id 3.3.3.3
 default cost 3
 import-route direct
 ipv6
vlan 300
vlan 400
ospfv3 2
 router-id 4.4.4.4
l          The S5500-EI series Ethernet switches of Release 2102 support only OSPFv3 single process.
Network Diagram
Figure 1-7 Network diagram for OSPFv3 DR selection configuration
l          The priority of Switch A is 100, the highest priority on the network, so it will be the DR.
l          The priority of Switch C is 2, the second highest priority on the network, so it will be the BDR.
l          The priority of Switch B is 0, so it cannot become the DR.
l          Switch D has the default priority 1.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 2102
All versions
Release 6100
Release 6300
All versions
[SwitchA] ipv6
[SwitchA] ospfv3
[SwitchA-Vlan-interface100] ospfv3 1 area 0
[SwitchB] ipv6
[SwitchB] ospfv3
[SwitchB-Vlan-interface200] ospfv3 1 area 0
[SwitchC] ipv6
[SwitchC] ospfv3
[SwitchD] ipv6
[SwitchD] ospfv3
[SwitchD] interface vlan-interface 200
[SwitchD-Vlan-interface200] ospfv3 1 area 0
[SwitchD-Vlan-interface200] quit
# Display neighbor information on Switch A. You can find the switches have the same default DR priority 1. In this case, the switch with the highest Router ID is elected as the DR. Therefore, Switch D is the DR, and Switch C is the BDR.
[SwitchA] display ospfv3 peer
2.2.2.2        1     2-Way/DROther   00:00:36    Vlan200        0
3.3.3.3        1     Full/Backup     00:00:35    Vlan100        0
4.4.4.4        1     Full/DR         00:00:33    Vlan200        0
# Display neighbor information on Switch D. You can find the neighbor states are all Full.
[SwitchD] display ospfv3 peer
1.1.1.1        1     Full/DROther    00:00:30    Vlan100        0
2.2.2.2        1     Full/DROther    00:00:37    Vlan200        0
3.3.3.3        1     Full/Backup     00:00:31    Vlan100        0
3)        Configure DR priorities for interfaces.
# Configure the DR priority of VLAN-interface 100 as 100 on Switch A
[SwitchA-Vlan-interface100] ospfv3 dr-priority 100
# Configure the DR priority of VLAN-interface 200 as 0 on Switch B.
[SwitchB-Vlan-interface200] ospfv3 dr-priority 0
# Configure the DR priority of VLAN-interface 100 of Switch C as 2.
[SwitchC-Vlan-interface100] ospfv3 dr-priority 2
# Display neighbor information on Switch A. You can find DR priorities have been updated, but the DR and BDR are not changed.
2.2.2.2        0     2-Way/DROther   00:00:38    Vlan200        0
3.3.3.3        2     Full/Backup     00:00:32    Vlan100        0
4.4.4.4        1     Full/DR         00:00:36    Vlan200        0
# Display neighbor information on Switch D. You can find Switch D is still the DR.
1.1.1.1        100   Full/DROther    00:00:33    Vlan100        0
2.2.2.2        0     Full/DROther    00:00:36    Vlan200        0
3.3.3.3        2     Full/Backup     00:00:40    Vlan100        0
4)        Restart DR/BDR election
# Use the shutdown and undo shutdown commands on interfaces to restart DR/BDR election (omitted).
# Display neighbor information on Switch A. You can find Switch C becomes the BDR.
2.2.2.2        0     Full/DROther    00:00:31    Vlan200        0
3.3.3.3        2     Full/Backup     00:00:39    Vlan100        0
4.4.4.4        1     Full/DROther    00:00:37    Vlan200        0
# Display neighbor information on Switch D. You can find Switch A becomes the DR.
1.1.1.1        100   Full/DR         00:00:34    Vlan100        0
2.2.2.2        0     2-Way/DROther   00:00:34    Vlan200        0
 ipv6
vlan 100
ospfv3 1
 router-id 1.1.1.1
 ipv6
vlan 200
ospfv3 1
 router-id 2.2.2.2
 ipv6
vlan 100
 ipv6 address 2001::3/64
ospfv3 1
 router-id 3.3.3.3
 ipv6
vlan 200
 ipv6 address 2001::4/64
ospfv3 1
 router-id 4.4.4.4
The IS-IS routing protocol (Intermediate System-to-Intermediate System intra-domain routing information exchange protocol) supports multiple network protocols, including IPv6. IS-IS with IPv6 support is called IPv6 IS-IS dynamic routing protocol. The international engineer task force (IETF) defines two type-length-values (TLVs) and a new network layer protocol identifier (NLPID) to enable IPv6 support for IS-IS.
TLV is a variable field in the link state PDU or link state packet (LSP). The two TLVs are:
l          IPv6 Reachability: Defines the prefix, metric of routing information to indicate the network reachability, with a type value of 236 (0xEC).
l          IPv6 Interface Address: Similar with the “IP Interface Address” TLV of IPv4, it transforms the 32-bit IPv4 address to the 128-bit IPv6 address.
NLPID is an 8-bit field with a value of 142 (0x8E), which indicates the network layer protocol packet. If the IS-IS router supports IPv6, the advertised routing information must be marked with the NLPID.
Network Diagram
Figure 1-8 Network diagram for IPv6 IS-IS configuration
As shown in figure above, Switch A, Switch B, Switch C and Switch D reside in the same autonomous system, and all are enabled with IPv6.
Switch A and Switch B are Level-1 switches, Switch D is a Level-2 switch, and Switch C is a Level-1-2 switch. Switch A, Switch B, and Switch C are in area 10, while Switch D is in area 20.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 2102
All versions
Release 6100
Release 6300
All versions
2)        Configure IPv6 IS-IS
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.0000.0000.0001.00
[SwitchA-isis-1] ipv6 enable
[SwitchA-isis-1] quit
[SwitchA-Vlan-interface100] isis ipv6 enable 1
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.0000.0000.0002.00
[SwitchB-isis-1] ipv6 enable
[SwitchB-isis-1] quit
[SwitchB-Vlan-interface200] isis ipv6 enable 1
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 10.0000.0000.0003.00
[SwitchC-isis-1] ipv6 enable
[SwitchC-isis-1] quit
[SwitchC-Vlan-interface100] isis ipv6 enable 1
[SwitchC-Vlan-interface200] isis ipv6 enable 1
[SwitchC-Vlan-interface300] isis ipv6 enable 1
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.0000.0000.0004.00
[SwitchD-isis-1] ipv6 enable
[SwitchD-isis-1] quit
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] isis ipv6 enable 1
[SwitchD-Vlan-interface300] quit
[SwitchD] interface vlan-interface 301
[SwitchD-Vlan-interface301] isis ipv6 enable 1
[SwitchD-Vlan-interface301] quit
 ipv6
vlan 100
isis 1
 is-level level-1
  ipv6 enable
 isis ipv6 enable 1
 ipv6
vlan 200
isis 1
 is-level level-1
  ipv6 enable
 isis ipv6 enable 1
 ipv6
vlan 100
vlan 200
vlan 300
isis 1
  ipv6 enable
 isis ipv6 enable 1
 isis ipv6 enable 1
 isis ipv6 enable 1
 ipv6
vlan 300 to 301
isis 1
 is-level level-2
  ipv6 enable
 ipv6 address 2001:3::2/64
 isis ipv6 enable 1
interface Vlan-interface301
 ipv6 address 2001:4::1/64
 isis ipv6 enable 1
None
BGP-4 manages only IPv4 routing information, thus other network layer protocols such as IPv6 are not supported.
To support multiple network layer protocols, IETF extended BGP-4 by introducing IPv6 BGP that is defined in RFC 2858 (multiprotocol extensions for BGP-4).
To implement IPv6 support, IPv6 BGP puts IPv6 network layer information into the attributes of network layer reachable information (NLRI) and NEXT_HOP.
NLRI attribute of IPv6 BGP involves:
l          MP_REACH_NLRI: Multiprotocol Reachable NLRI, for advertisement of next hop information of reachable routes.
l          MP_UNREACH_NLRI: Multiprotocol Unreachable NLRI, for withdrawal of unreachable routes.
The NEXT_HOP attribute of IPv6 BGP is identified by an IPv6 unicast address or IPv6 local link address.
IPv6 BGP utilizes BGP multiprotocol extensions for application in IPv6 networks. The original messaging and routing mechanisms of BGP are not changed.
Network Diagram
Figure 1-9 Network diagram for IPv6 BGP basic configuration
In the figure above are all IPv6 BGP switches. Between Switch A and Switch B is an EBGP connection. Switch B, Switch C and Switch D are iBGP fully meshed.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 2102
All versions
Release 6100
Release 6300
All versions
2)        Configure iBGP connections
[SwitchB] ipv6
[SwitchB] bgp 65009
[SwitchB-bgp] router-id 2.2.2.2
[SwitchB-bgp] ipv6-family
[SwitchB-bgp-af-ipv6] peer 9:1::2 as-number 65009
[SwitchB-bgp-af-ipv6] peer 9:3::2 as-number 65009
[SwitchB-bgp-af-ipv6] quit
[SwitchB-bgp] quit
[SwitchC] ipv6
[SwitchC] bgp 65009
[SwitchC-bgp] router-id 3.3.3.3
[SwitchC-bgp] ipv6-family
[SwitchC-bgp-af-ipv6] peer 9:3::1 as-number 65009
[SwitchC-bgp-af-ipv6] peer 9:2::2 as-number 65009
[SwitchC-bgp-af-ipv6] quit
[SwitchC-bgp] quit
[SwitchD] ipv6
[SwitchD] bgp 65009
[SwitchD-bgp] router-id 4.4.4.4
[SwitchD-bgp] ipv6-family
[SwitchD-bgp-af-ipv6] peer 9:1::1 as-number 65009
[SwitchD-bgp-af-ipv6] peer 9:2::1 as-number 65009
[SwitchD-bgp-af-ipv6] quit
[SwitchD-bgp] quit
3)        Configure the eBGP connection
[SwitchA] ipv6
[SwitchA] bgp 65008
[SwitchA-bgp] router-id 1.1.1.1
[SwitchA-bgp] ipv6-family
[SwitchA-bgp-af-ipv6] peer 10::1 as-number 65009
[SwitchA-bgp-af-ipv6] quit
[SwitchA-bgp] quit
[SwitchB] bgp 65009
[SwitchB-bgp-af-ipv6] peer 10::2 as-number 65008
# Display IPv6 peer information on Switch B.
[SwitchB] display bgp ipv6 peer
 BGP local router ID : 2.2.2.2
 Local AS number : 65009
 Total number of peers : 3                 Peers in established state : 3
  Peer       V    AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  10::2      4 65008        3        3     0       0 00:01:16 Established
  9:3::2     4 65009        2        3     0       0 00:00:40 Established
  9:1::2     4 65009        2        4     0       0 00:00:19 Established
# Display IPv6 peer information on Switch C.
[SwitchC] display bgp ipv6 peer
 BGP local router ID : 3.3.3.3
 Total number of peers : 2                 Peers in established state : 2
  9:3::1     4 65009        4        4     0       0 00:02:18 Established
  9:2::2     4 65009        4        5     0       0 00:01:52 Established
Switch A and B established an eBGP connection; Switch B, C and D established iBGP connections with each other.
 ipv6
vlan 400
 ipv6 address 10::2/64
bgp 65008
 router-id 1.1.1.1
 ipv6-family
 ipv6
vlan 100
vlan 300
vlan 400
 ipv6 address 9:1::1/64
 ipv6 address 9:3::1/64
 ipv6 address 10::1/64
bgp 65009
 router-id 2.2.2.2
 ipv6-family
 ipv6
vlan 200
vlan 300
 ipv6 address 9:2::1/64
 ipv6 address 9:3::2/64
bgp 65009
 router-id 3.3.3.3
 ipv6-family
 ipv6
vlan 100
vlan 200
 ipv6 address 9:1::2/64
 ipv6 address 9:2::2/64
bgp 65009
 router-id 4.4.4.4
 ipv6-family
l          To improve stability and reliability, you can specify a loopback interface as the source interface for establishing TCP connections to a BGP peer. By doing so, a connection failure upon redundancy availability will not affect TCP connection establishment.
l          To establish multiple BGP connections to a BGP router, you need to specify on the local router the respective source interfaces for establishing TCP connections to the peers on the peering BGP router; otherwise, the local BGP router may fail to establish TCP connections to the peers when using the outbound interfaces of the best routes as the source interfaces.
l          In general, direct links should be available between eBGP peers. If not, you can use the peer ebgp-max-hop command to establish a multi-hop TCP connection in between. However, you need not use this command for direct EBGP connection with loopback interfaces.
Network Diagram
Figure 1-10 Network diagram for IPv6 BGP route reflector configuration
Switch B receives an EBGP update and sends it to Switch C, which is configured as a route reflector with two clients: Switch B and Switch D.
Switch B and Switch D need not establish an IBGP connection because Switch C reflects updates between them.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 2102
All versions
Release 6100
Release 6300
All versions
1)        Configure IPv6 addresses for VLAN interfaces (omitted)
2)        Configure IPv6 BGP basic functions
[SwitchA] ipv6
[SwitchA] bgp 100
[SwitchA-bgp-af-ipv6] peer 100::2 as-number 200
[SwitchA-bgp-af-ipv6] network 1:: 64
#Configure Switch B.
[SwitchB] ipv6
[SwitchB] bgp 200
[SwitchB-bgp-af-ipv6] peer 100::1 as-number 100
[SwitchB-bgp-af-ipv6] peer 101::1 as-number 200
[SwitchB-bgp-af-ipv6] peer 101::1 next-hop-local
[SwitchC] ipv6
[SwitchC] bgp 200
[SwitchC-bgp-af-ipv6] peer 101::2 as-number 200
[SwitchC-bgp-af-ipv6] peer 102::2 as-number 200
[SwitchD] ipv6
[SwitchD] bgp 200
[SwitchD-bgp-af-ipv6] peer 102::1 as-number 200
3)        Configure route reflector
# Configure Switch C as a route reflector, Switch B and Switch D as its clients.
[SwitchC-bgp-af-ipv6] peer 101::2 reflect-client
[SwitchC-bgp-af-ipv6] peer 102::2 reflect-client
Use the display bgp ipv6 routing-table command on Switch B and Switch D respectively. You can find both of them have learned the network 1::/64.
 ipv6
vlan 200
 ipv6 address 100::1/96
bgp 100
 router-id 1.1.1.1
 ipv6-family
  network 1:: 64
 ipv6
vlan 200
vlan 300
 ipv6 address 100::2/96
 ipv6 address 101::2/96
bgp 200
 router-id 2.2.2.2
 ipv6-family
 ipv6
vlan 100
vlan 300
 ipv6 address 102::1/96
 ipv6 address 101::1/96
bgp 200
 router-id 3.3.3.3
 ipv6-family
 ipv6
vlan 100
 ipv6 address 102::2/96
bgp 200
 router-id 4.4.4.4
 ipv6-family
l          In general, since the route reflector forwards routing information between clients, it is not required to make clients of a route reflector fully meshed. If clients are fully meshed, it is recommended to disable route reflection between clients to reduce routing costs.
l          If a cluster has multiple route reflectors, you need to specify the same cluster ID for these route reflectors to avoid routing loops.
A routing policy is used on the router for route inspection, filtering, attributes modifying when routes are received, advertised, or redistributed.
When distributing or receiving routing information, a router can use a routing policy to filter routing information. For example, a router receives or advertises only routing information that matches the criteria of a routing policy; a routing protocol redistributes routes from another protocol only routes matching the criteria of a routing policy and modifies some attributes of these routes to satisfy its needs using the routing policy.
To implement a routing policy, you need to define a set of match criteria according to attributes in routing information, such as destination address, advertising router’s address and so on. The match criteria can be set beforehand and then apply them to a routing policy for route distribution, reception and redistribution.
Network Diagram
Figure 1-11 Network diagram for route policy application in IPv6 route redistribution
l          Enable RIPng on Switch A and Switch B.
l          Configure three static routes on Switch A and apply a routing policy when redistributing static routes, making routes 20::0/32 and 40::0/32 pass, routes in 30::0/32 filtered out.
l          Display RIPng routing table information on Switch B to verify the configuration.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
1)        Configure Switch A
# Configure IPv6 addresses for VLAN-interface 100 and VLAN-interface 200.
[SwitchA] ipv6
[SwitchA-Vlan-interface100] ipv6 address 10::1 32
[SwitchA-Vlan-interface200] ipv6 address 11::1 32
# Enable RIPng on VLAN-interface 100.
# Configure three static routes.
[SwitchA] ipv6 route-static 20:: 32 11::2
[SwitchA] ipv6 route-static 30:: 32 11::2
[SwitchA] ipv6 route-static 40:: 32 11::2
# Configure a routing policy.
[SwitchA] ip ipv6-prefix a index 10 permit 30:: 32
[SwitchA] route-policy static2ripng deny node 0
[SwitchA-route-policy] if-match ipv6 address prefix-list a
[SwitchA-route-policy] quit
[SwitchA] route-policy static2ripng permit node 10
# Enable RIPng and redistribute static routes.
[SwitchA] ripng
[SwitchA-ripng-1] import-route static route-policy static2ripng
2)        Configure Switch B.
# Configure the IPv6 address for VLAN-interface 100.
[SwitchB] ipv6
[SwitchB-Vlan-interface100] ipv6 address 10::2 32
# Enable RIPng.
[SwitchB] ripng
# Display RIPng routing table information.
[SwitchB-ripng-1] display ripng 1 route
 Peer FE80::7D58:0:CA03:1  on Vlan-interface 100
 Dest 10::/32,
     via FE80::7D58:0:CA03:1, cost  1, tag 0, A, 18 Sec
 Dest 20::/32,
     via FE80::7D58:0:CA03:1, cost  1, tag 0, A, 8 Sec
 Dest 40::/32,
     via FE80::7D58:0:CA03:1, cost  1, tag 0, A, 3 Sec
 ipv6
vlan 1
vlan 100
vlan 200
 ipv6 address 10::1/32
 ripng 1 enable
 ipv6 address 11::1/32
ripng 1
 ipv6
vlan 100
 ipv6 address 10::2/32
 ripng 1 enable
ripng 1
l          If all items are set to the deny mode, no routes can pass the IPv6 prefix list. Therefore, you need to define the permit :: 0 less-equal 128 item following multiple deny mode items to allow other IPv6 routing information to pass.
l          If a node has the permit keyword specified, routing information meeting the node’s conditions will be handled using the apply clauses of this node, without needing to match against the next node. If routing information does not meet the node’s conditions, it will go to the next node for a match.
l          If a node is specified as deny, the apply clauses of the node will not be executed. When routing information matches all if-match clauses of the node, it can neither pass the node, nor go to the next node. If route information cannot match any if-match clause of the node, it will go to the next node for a match.
l          When a routing policy is defined with more than one node, at least one node should be configured with the permit keyword. If the routing policy is used to filter routing information, routing information that does not meet any node’s conditions cannot pass the routing policy. If all nodes of the routing policy are set using the deny keyword, no routing information can pass it.
l          The if-match clauses of a route-policy are in logic AND relationship, namely, routing information has to satisfy all if-match clauses before being executed with apply clauses.
l          You can specify no or multiple if-match clauses for a routing policy. If no if-match clause is specified, and the routing policy is in permit mode, all routing information can pass the node; if in deny mode, no routing information can pass.
