H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
10-Link Aggregation Configuration Guide
10-Link Aggregation Configuration Guide 47.99 KB
Configuring Link Aggregation
Link aggregation aggregates multiple physical Ethernet ports into one logical link, also called an aggregation group. It allows you to increase bandwidth by distributing traffic across the member ports in the aggregation group. In addition, it provides reliable connectivity because these member ports can dynamically back up each other.
Network Diagram
Figure 1-1 Network diagram for link aggregation configuration
Networking and Configuration Requirements
Switch A aggregates ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to form one link connected to Switch B and performs load sharing among these ports.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 series Ethernet switches
Release 5301, Release 5303
All versions
S5510 series Ethernet switches
All versions
S5500-SI series Ethernet switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI series Ethernet switches
Release 2102
All versions
S7500E series Ethernet switches
Release 6100, Release 6300
All versions
Configuration Procedure
This configuration example only provides the configuration procedure on Switch A. You must perform the same configuration on Switch B for link aggregation to work.
Configure an aggregation group to implement load balancing on the ports in either manual aggregation mode or static LACP aggregation mode:
1)        Manual aggregation mode
# Create manual link aggregation group 1.
[SwitchA] link-aggregation group 1 mode manual
# Add ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to link aggregation group 1.
[SwitchA] interface GigabitEthernet 1/0/1
[SwitchA-GigabitEthernet1/0/1] port link-aggregation group 1
[SwitchA-GigabitEthernet1/0/1] interface GigabitEthernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] port link-aggregation group 1
[SwitchA-GigabitEthernet1/0/2] interface GigabitEthernet 1/0/3
[SwitchA-GigabitEthernet1/0/3] port link-aggregation group 1
2)        Static LACP aggregation mode
# Create static link aggregation group 1.
[SwitchA] link-aggregation group 1 mode static
Link aggregation support of release 6300 of the S7500E series Ethernet switches differs slightly. The aggregation group configuration procedure is as follows:
l              Static aggregation mode
# Create Layer-2 aggregate interface Bridge-Aggregation 1.
[SwitchA] interface bridge-aggregation 1
[SwitchA-Bridge-Aggregation1] quit
# Assign Ethernet ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to aggregation group 1.
l              Dynamic aggregation mode
# Create a Layer-2 aggregate interface Bridge-Aggregation 1, and configure the interface to operate in dynamic aggregation mode.
[SwitchA-Bridge-Aggregation1] link-aggregation mode dynamic
Complete Configuration
1)        Manual aggregation mode:
2)        Static LACP aggregation mode:
interface Bridge-Aggregation1
Configuration Guidelines
l          Compatibility problems may occur when devices are connected to one another through static aggregation in different software, since the implementation approach of static aggregation varies with software. You can use the display version command to view the software version information.
l          An RRPP-configured port, a static MAC address or blackhole MAC address-configured port, a voice VLAN-enabled port, and an 802.1x-enabled port cannot be added to an aggregation group.
