H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
41-Port Isolation Configuration Guide
41-Port Isolation Configuration Guide 39 KB
Port Isolation
To isolate packets, you can add different ports to different VLANs. However, this will consume the limited VLAN resources. You can use the port isolation feature to isolate ports in the same VLAN. With port isolation, you can isolate ports within the same VLAN by assigning them to isolation groups. The port isolation function provides more secure and more flexible networking schemes.
Configuring Port Isolation
Network Diagram
Figure 1-1 Networking diagram for port isolation configuration
l          As shown in Figure 1-1, users Host A, Host B, and Host C are connected to GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 of Device.
l          Device is connected to the Internet through GigabitEthernet 1/0/4.
l          GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, GigabitEthernet 1/0/3, and GigabitEthernet 1/0/4 belong to the same VLAN. It is desired that Host A, Host B, and Host C cannot communicate with each other, but can access the Internet.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 series Ethernet switches
Release 5301
Release 5303
All versions
S5510 series Ethernet switches
Release 5301
Release 5303
All versions
S5500-SI series Ethernet switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI series Ethernet switches
Release 2102
All versions
S7500E series Ethernet switches
Release 6100
Release 6300
All versions
Configuration Procedure
# Add ports GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to the isolation group.
[Device] interface GigabitEthernet1/0/1
[Device-GigabitEthernet1/0/1] port-isolate enable
[Device] interface GigabitEthernet1/0/2
[Device-GigabitEthernet1/0/2] port-isolate enable
[Device] interface GigabitEthernet1/0/3
[Device-GigabitEthernet1/0/3] port-isolate enable
# Display the information about the isolation group.
<Device> display port-isolate group
 Port-isolate group information:
 Uplink port support: NO
 Group ID: 1
    GigabitEthernet1/0/1     GigabitEthernet1/0/2     GigabitEthernet1/0/3
Complete Configuration
 port-isolate enable
 port-isolate enable
 port-isolate enable
Configuration Guidelines
1)        Currently some devices support only one isolation group that is created automatically by the system as isolation group 1. You can neither remove the isolation group nor create other isolation groups on such devices.
2)        There is no restriction on the number of ports to be assigned to an isolation group.
3)        Bidirectional data transmission between a port within the isolation group and another port outside the isolation group is supported, provided that the two ports belong to the same VLAN, but that between ports within the isolation group is not supported.
4)        The port isolation feature supported on Ethernet switches of the S5500-SI and the S5500-EI series can isolate both Layer 2 and Layer 3 packets, but switches of other series listed in 102650  Applicable Product Matrix can only isolate Layer 2 packets.
