H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
51-Track Configuration Guide
51-Track Configuration Guide 96.5 KB
Configuring VRRP-Track-NQA Collaboration
The Track module is used to implement collaboration between different modules.
The collaboration here involves three parts: the application modules, the Track module, and the detection modules. These modules collaborate with one another through collaboration objects. That is, the detection modules trigger the application modules to perform certain operations through the Track module. More specifically, the detection modules probe the link status, network performance and so on, and inform the application modules of the detection result through the Track module. After the application modules are aware of the changes of network status, they deal with the changes accordingly to avoid communication interruption and network performance degradation.
The Track module works between the application modules and the detection modules and is mainly used to obscure the difference of various detection modules to provide a unified interface for application modules.
Network Diagram
Figure 1-1 Network diagram for VRRP-Track-NQA collaboration configuration
Networking and Configuration Requirements
l          Host A needs to access Host B on the Internet. The default gateway of Host A is 10.1.1.10/24;
l          Switch A and Switch B belong to VRRP group 1, whose virtual IP address is 10.1.1.10;
l          When Switch A works normally, packets from Host A to Host B are forwarded through Switch A; configure VRRP-track-NQA collaboration, so that when a fault occurs on the upper link of Switch A, packets from Host A to Host B can be forwarded by Switch B automatically.
Applicable Product Matrix
Product series
Software version
Hardware version
S5500-SI Series Ethernet Switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6300
All versions
Configuration Procedure
1)        Configure the IP address of each interface, as shown in Figure 1-1. The configuration procedure is omitted here.
2)        Configure an NQA test group on Switch A.
# Create an NQA test group with the administrator name admin and the operation tag test.
[SwitchA] nqa entry admin test
# Configure the test type as ICMP echo.
[SwitchA-nqa-admin-test] type icmp-echo
# Configure the destination address as 10.1.2.2.
[SwitchA-nqa-admin-test-icmp-echo] destination ip 10.1.2.2
# Set the test frequency to 100 ms.
[SwitchA-nqa-admin-test-icmp-echo] frequency 100
# Configure Reaction entry 1, specifying that five consecutive probe failures trigger the Track-NQA collaboration.
[SwitchA-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[SwitchA-nqa-admin-test-icmp-echo] quit
# Start NQA probes.
[SwitchA] nqa schedule admin test start-time now lifetime forever
3)        Configure a Track object on Switch A.
# Configure Track object 1, and associate it with Reaction entry 1 of the NQA test group (with the administrator admin, and the operation tag test).
[SwitchA] track 1 nqa entry admin test reaction 1
4)        Configure VRRP on Switch A.
# Create VRRP group 1, and configure the virtual IP address 10.1.1.10 for the group.
[SwitchA-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.10
# Set the priority of Switch A in VRRP group 1 to 110.
[SwitchA-Vlan-interface2] vrrp vrid 1 priority 110
# Set the authentication mode of VRRP group 1 to simple, and the authentication key to hello.
[SwitchA-Vlan-interface2] vrrp vrid 1 authentication-mode simple hello
# Configure the master to send VRRP advertisements at an interval of five seconds.
[SwitchA-Vlan-interface2] vrrp vrid 1 timer advertise 5
# Configure Switch A to work in preemptive mode, and set the preemption delay to five seconds.
[SwitchA-Vlan-interface2] vrrp vrid 1 preempt-mode timer delay 5
# Configure to monitor Track object 1 and specify the priority decrement to 30.
[SwitchA-Vlan-interface2] vrrp vrid 1 track 1 reduced 30
5)        Configure VRRP on Switch B.
[SwitchB-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.10
[SwitchB-Vlan-interface2] vrrp vrid 1 authentication-mode simple hello
[SwitchB-Vlan-interface2] vrrp vrid 1 timer advertise 5
# Configure Switch B to work in preemptive mode, and set the preemption delay to five seconds.
[SwitchB-Vlan-interface2] vrrp vrid 1 preempt-mode timer delay 5
6)        Verify the configuration
After configuration, ping Host B on Host A, and you can see that Host B is reachable. Use the display vrrp command to view the configuration result.
# Display detailed information about VRRP group 1 on Switch A.
[SwitchA-Vlan-interface2] display vrrp verbose
 IPv4 Standby Information:
 Run Method      : VIRTUAL-MAC
 Virtual IP Ping : Enable
 Interface       : Vlan-interface2
 VRID            : 1                    Adver. Timer    : 5
 Admin Status    : UP                   State           : Master
 Config Pri      : 110                  Run Pri         : 110
 Preempt Mode    : YES                  Delay Time      : 5
 Auth Type       : SIMPLE TEXT          Key             : hello
 Track Object    : 1                    Pri Reduced     : 0
 Virtual IP      : 10.1.1.10
 Virtual MAC     : 0000-5e00-0101
 Master IP       : 10.1.1.1
# Display detailed information about VRRP group 1 on Switch B.
[SwitchB-Vlan-interface2] display vrrp verbose
 Admin Status    : UP                   State           : Backup
 Config Pri      : 100                  Run Pri         : 100
The above output information indicates that in VRRP group 1, Switch A is the master and Switch B is a backup. Packets from Host A to Host B are forwarded through Switch A.
When there is a fault on the link between Switch A and Switch C, you can still successfully ping Host B on Host A. Use the display vrrp command to view information about VRRP group 1.
# Display detailed information about VRRP group 1 on Switch A when there is a fault on the link between Switch A and Switch C.
 Config Pri      : 110                  Run Pri         : 80
 Track Object    : 1                    Pri Reduced     : 30
 Master IP       : 10.1.1.2
# Display detailed information about VRRP group 1 on Switch B when there is a fault on the link between Switch A and Switch C.
The above output information indicates that when there is a fault on the link between Switch A and Switch C, the priority of Switch A decreases to 80. Switch A becomes the backup, and Switch B becomes the master. Packets from Host A to Host B are forwarded through Switch B.
Complete Configuration
l          Configuration on Switch A.
vlan 2 to 3
interface Vlan-interface2
interface Vlan-interface3
 ip address 10.1.2.1 255.255.255.0
 type icmp-echo
  frequency 100
l          Configuration on Switch B.
vlan 2
Configuration Guidelines
l          Do not perform Track object monitoring on the IP address owner.
l          When the status of the monitored Track object turns from Negative to Positive, the corresponding switch restores its priority automatically.
l          The monitored Track object can be nonexistent, so that you can first specify the Track object to be monitored using the vrrp vrid track command, and then create the Track object using the track command.
Configuring Static Routing-Track-NQA Collaboration
Network Diagram
Figure 1-2 Network diagram for Static Routing-Track-NQA collaboration configuration
l          The next hop of the static route from Switch A to Switch C is Switch B.
l          Configure Static Routing-Track-NQA collaboration on Switch A to implement real-time monitoring of the validity of the static route to Switch C.
Product series
Software version
Hardware version
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6300
All versions
1)        Configure the IP address of each interface.
2)        Configure a static route on Switch A and associate it with the Track object.
# Configure the address of the next hop of the static route to Switch C as 10.2.1.1, and configure the static route to associate with Track object 1.
[SwitchA] ip route-static 10.1.1.2 24 10.2.1.1 track 1
3)        Configure an NQA test group on Switch A.
# Create an NQA test group with the administrator admin and the operation tag test.
# Configure the test type as ICMP-echo.
# Configure the destination address as 10.2.1.1
[SwitchA-nqa-admin-test-icmp-echo] destination ip 10.2.1.1
# Configure the test frequency as 100 ms.
# Configure Reaction entry 1, specifying that five consecutive probe failures trigger the Static Routing-Track-NQA collaboration.
# Start NQA probes.
4)        Configure a Track object on Switch A.
5)        Verify the configuration
# Display information of the Track object on Switch A.
[SwitchA] display track all
Track ID: 1
  Status: Positive
  Reference object:
    NQA entry: admin test
    Reaction: 1
# Display the routing table of Switch A.
Routing Tables: Public
         Destinations : 5        Routes : 5
10.1.1.0/24         Static 60   0            10.2.1.1        Vlan3
10.2.1.0/24         Direct 0    0            10.2.1.2        Vlan3
10.2.1.2/32         Direct 0    0            127.0.0.1       InLoop0
The output information above indicates the NQA test result, that is, the next hop 10.2.1.1 is reachable (the status of the Track object is Positive), and the configured static route is valid.
# Remove the IP address of interface VLAN-interface 3 on Switch B.
[SwitchB-Vlan-interface3] undo ip address
Track ID: 1
  Status: Negative
  Reference object:
    Reaction: 1
         Destinations : 4        Routes : 4
The output information above indicates the NQA test result, that is, the next hop 10.2.1.1 is unreachable (the status of the Track object is Negative), and the configured static route is invalid.
l          Configure  Switch A.
vlan 3
 ip address 10.2.1.2 255.255.255.0
 type icmp-echo
  frequency 100
 trigger-only
 ip route-static 10.1.1.0 255.255.255.0 10.2.1.1 track 1
None
