H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
01-Login Configuration Guide
Configuring Telnet Login Using Console Port
It is the most common way to log in to a switch through its console port, and also the basis to configure other login methods.
Network Diagram
Figure 1-1 Network diagram for configuring Telnet login using console port
Networking and Configuration Requirements
As shown in Figure 1-1, the serial port of a PC/terminal is connected to the console port of the switch using a console cable. The current user logs into the switch from the AUX user interface on the console port to configure Telnet login. The current user level is 3, that is, the manage level.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301, Release 5303
All versions
S5510 Series Ethernet Switches
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100, Release 6300
All versions
Configuration Procedure
l          Common configuration for Telnet login
# Enter system view, and enable Telnet service.
# Set the level of commands accessible to the virtual type terminal (VTY) 0 user to 2.
[Sysname] user-interface vty 0
[Sysname-ui-vty0] user privilege level 2
# Enable the Telnet service on VTY 0.
[Sysname-ui-vty0] protocol inbound telnet
# Set the number of lines that can be viewed on the screen of the VTY 0 user to 30.
[Sysname-ui-vty0] screen-length 30
# Set the history command buffer size to 20 for VTY 0.
[Sysname-ui-vty0] history-command max-size 20
# Set the idle-timeout time of VTY 0 to 6 minutes.
[Sysname-ui-vty0] idle-timeout 6
l          Configure the authentication mode for Telnet login
The following three authentication modes are available for Telnet login: none, password, and scheme.
The configuration procedures for the three authentication modes are described below:
1)        Configure not to authenticate Telnet users on VTY 0.
[Sysname-ui-vty0] authentication-mode none
2)        Configure password authentication for Telnet login on VTY 0, and set the password to 123456 in plain text.
[Sysname-ui-vty0] authentication-mode password
[Sysname-ui-vty0] set authentication password simple 123456
3)        Configure local authentication in scheme mode for login users.
# Create a local user named guest and enter local user view.
[Sysname] local-user guest
# Set the authentication password to 123456 in plain text.
[Sysname-luser-guest] password simple 123456
# Set the service type to Telnet and the user level to 2 for the user guest.
[Sysname-luser-guest] service-type telnet level 2
[Sysname-luser-guest] quit
# Enter VTY 0 user interface view.
# Set the authentication mode to scheme for Telnet login on VTY 0.
[Sysname-ui-vty0] authentication-mode scheme
[Sysname-ui-vty0] quit
# Specify the domain system as the default domain, and configure the domain to adopt local authentication in scheme mode.
[Sysname] domain default enable system
[Sysname] domain system
[Sysname-isp-system] scheme local
Complete Configuration
l          Telnet login configuration with the authentication mode being none
 idle-timeout 6 0
 screen-length 30
l          Telnet login configuration with the authentication mode being password
 idle-timeout 6 0
 screen-length 30
l          Telnet login configuration with the authentication mode being scheme
domain system
 authentication default local
local-user guest
 service-type telnet
 level 2
 idle-timeout 6 0
 screen-length 30
Configuration Guidelines
N/A
Configuring Console Port Login Using Telnet
An Ethernet switch supports Telnet, so you can manage and maintain the switch remotely by Telnetting to it.
Network Diagram
Figure 1-2 Network diagram for configuring console port login using Telnet
As shown in Figure 1-2, telnet to the switch to configure console login. The current user level is 3, that is, the manage level.
Product series
Software version
Hardware version
All versions
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
All versions
l          Common configuration for console login
# Specify the level of commands accessible to the AUX 0 user interface to 2.
[Sysname] user-interface aux 0
[Sysname-ui-aux0] user privilege level 2
# Set the baud rate of the console port to 19200 bps.
[Sysname-ui-aux0] speed 19200
# Set the number of lines that can be viewed on the screen of the AUX 0 user to 30.
[Sysname-ui-aux0] screen-length 30
# Set the history command buffer size to 20 for AUX 0.
[Sysname-ui-aux0] history-command max-size 20
# Set the idle-timeout time of AUX 0 to 6 minutes.
[Sysname-ui-aux0] idle-timeout 6
l          Configure the authentication mode for console login
The following three authentication modes are available for console login: none, password, and scheme.
1)        Configure not to authenticate console login users.
[Sysname-ui-aux0] authentication-mode none
2)        Configure password authentication for console login, and set the password to 123456 in plain text.
[Sysname-ui-aux0] authentication-mode password
[Sysname-ui-aux0] set authentication password simple 123456
3)        Configure local authentication in scheme mode for console login.
# Set the service type to Terminal and the user level to 2 for the user guest.
[Sysname-luser-guest] service-type terminal level 2
# Enter AUX 0 user interface view.
# Set the authentication mode to scheme for console login.
[Sysname-ui-aux0] authentication-mode scheme
l          Console login configuration with the authentication mode being none
 idle-timeout 6 0
 speed 19200
 screen-length 30
l          Console login configuration with the authentication mode being password
 idle-timeout 6 0
 speed 19200
 screen-length 30
l          Console login configuration with the authentication mode being scheme
domain system
local-user guest
 level 2
 idle-timeout 6 0
 speed 19200
 screen-length 30
N/A
Configuring to Log In to a Switch Through the Web-Based NMS
Network Diagram
Figure 1-3 Network diagram for logging in through the web-based network management system
As shown in Figure 1-3, a PC logs into a switch through web-based network management system and manages the switch remotely.
Product series
Software version
Hardware version
All versions
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
# Configure the IP address of VLAN 1 (default VLAN of the switch) interface as 10.153.17.82 with the mask 255.255.255.0.
[Sysname-VLAN-interface1] ip address 10.153.17.82 255.255.255.0
[Sysname-VLAN-interface1] quit
# Configure the Web-based network management system user name as admin, and password as admin, and set the user level to 3.
[Sysname] local-user admin
[Sysname-luser-admin] service-type telnet level 3
[Sysname-luser-admin] password simple admin
[Sysname-luser-admin] quit
# Enable the Web server on the switch.
[Sysname] ip http enable
Log in to the switch through IE: Launch IE on the Web-based network management terminal (your PC) and enter http://10.153.17.82 in the address bar (make sure the route between the Web-based network management terminal and the switch is available), and the login authentication page appears, as shown in Figure 1-4.
Figure 1-4 The login page of the Web-based network management system
# Enter the user name and the password configured on the switch and click Login to display the initial page of the Web-based network management system.
local-user admin
 service-type telnet
 level 3
interface Vlan-interface1
By default, web-based network management system is enabled.
Configuring to Control the Login Users
Network Diagram
Figure 1-5 Network diagram for controlling the login users
As shown in Figure 1-5, only Telnet/SNMP/Web users sourced from the IP addresses of 10.110.100.52 and 10.110.100.46 are permitted to log in to the switch.
Product series
Software version
Hardware version
All versions
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
All versions
# Create basic ACL 2000 and enter basic ACL view.
[Sysname] acl number 2000 match-order config
[Sysname-acl-basic-2000]
# Define ACL rules to allow only Telnet/SNMP/Web users sourced from the IP addresses of 10.110.100.52 and 10.110.100.46 to log in to the switch.
[Sysname-acl-basic-2000] rule 1 permit source 10.110.100.52 0
[Sysname-acl-basic-2000] rule 2 permit source 10.110.100.46 0
[Sysname-acl-basic-2000] rule 3 deny source any
[Sysname-acl-basic-2000] quit
# Apply ACL 2000 to control Telnet users by source IP address.
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] acl 2000 inbound
# Apply ACL 2000 to control SNMP users by source IP address.
[Sysname] snmp-agent community read aaa acl 2000
[Sysname] snmp-agent group v2c groupa acl 2000
[Sysname] snmp-agent usm-user v2c usera groupa acl 2000
# Apply ACL 2000 to control Web users by source IP address.
[Sysname] ip http acl 2000
l          Configuration for controlling Telnet users by source IP address
acl number 2000
 rule 3 deny
 acl 2000 inbound
l          Configuration for controlling SNMP users by source IP address
acl number 2000
 rule 3 deny
l          Configuration for controlling Web users by source IP address
 ip http acl 2000
acl number 2000
 rule 3 deny
The S7500E series Ethernet switches with software version do not support Web login. Therefore, Web user control is not applicable to an S7500E series with software version.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
