H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
23-ARP Configuration Guide
23-ARP Configuration Guide 88.76 KB
Configuring ARP Basics
Network Diagram
None
Networking and Configuration Requirements
l          Set the aging time for dynamic ARP entries to 10 minutes.
l          Set the maximum number of dynamic ARP entries that VLAN-interface 10 can learn to 1000.
l          Add a permanent static ARP entry, with the IP address being 192.168.1.1/24, the MAC address being 000f-e201-0000, and the outbound port being GigabitEthernet 1/0/10 of VLAN 10.
l          Add a non-permanent static ARP entry, with the IP address being 192.168.1.2/24, the MAC address being 000f-e201-0001.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5510 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except
S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100
Release 6300
All versions
S3500-EA Series Ethernet Switches
Release 5303
All versions
Configuration Procedure
# Set the aging time for dynamic ARP entries to 10 minutes.
[Switch] arp timer aging 10
# Set the maximum number of dynamic ARP entries that VLAN-interface 10 can learn to 1000.
[Switch] vlan 10
[Switch-vlan10] quit
[Switch-GigabitEthernet1/0/10] port access vlan 10
[Switch-GigabitEthernet1/0/10] quit
[Switch] interface vlan-interface 10
[Switch-vlan-interface10] arp max-learning-num 1000
[Switch-vlan-interface10] quit
# Add a permanent static ARP entry.
[Switch] arp static 192.168.1.1 000f-e201-0000 10 gigabitethernet1/0/10
# Add a non-permanent static ARP entry.
[Switch] arp static 192.168.1.2 000f-e201-0001
Complete Configuration
vlan 10
interface Vlan-interface10
interface GigabitEthernet1/0/10
 port access vlan 10
 arp timer aging 10
 arp static 192.168.1.1 000f-e201-0000 10 GigabitEthernet1/0/10
Configuration Guidelines
None
Configuring Proxy ARP
Network Diagram
Figure 1-1 Network diagram for proxy ARP
l          Host A that belongs to VLAN 1 has an IP address of 192.168.10.100/16; Host D that belongs to VLAN 2 has an IP address of 192.168.20.200/16.
l          Configure proxy ARP on the switch to enable communication between Host A and Host D.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
All versions except
S5500-20TP-SI
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
Release 5303
All versions
# Configure the IP address of VLAN-interface 1 and then enable proxy ARP on the interface.
<Switch> system-view
[Switch-Vlan-interface1] ip address 192.168.10.99 255.255.255.0
[Switch-Vlan-interface1] proxy-arp enable
[Switch-Vlan-interface1] quit
# Configure the IP address of VLAN-interface 2 and then enable proxy ARP on the interface.
[Switch-Vlan-interface2] ip address 192.168.20.99 255.255.255.0
[Switch-Vlan-interface2] proxy-arp enable
[Switch-Vlan-interface2] quit
 proxy-arp enable
interface Vlan-interface2
 proxy-arp enable
None
Configuring Local Proxy ARP
Network Diagram
Figure 1-2 Network diagram for local proxy ARP between isolated ports
l          Host A and Host B belong to the same VLAN, and are connected to GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 of Switch B respectively.
l          Switch B is connected to Switch A via GigabitEthernet 1/0/1.
l          On Switch B, Layer 2 and Layer 3 port isolation are configured on GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3. Enable proxy ARP on Switch A to allow communication between Host A and Host B.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
All versions except
S5500-20TP-SI
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
Release 5303
All versions
# Add GigabitEthernet 1/0/1, GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 to VLAN 2.
[SwitchB] vlan 2
[SwitchB-vlan2] port gigabitethernet 1/0/1
[SwitchB-vlan2] port gigabitethernet 1/0/2
[SwitchB-vlan2] port gigabitethernet 1/0/3
[SwitchB-vlan2] quit
# Isolate GigabitEthernet 1/0/2 from GigabitEthernet 1/0/3 at Layer 2.
[SwitchB] interface gigabitethernet 1/0/2
[SwitchB-GigabitEthernet1/0/2] port-isolate enable
[SwitchB] interface gigabitethernet 1/0/3
[SwitchB-GigabitEthernet1/0/3] port-isolate enable
[SwitchB-GigabitEthernet1/0/3] quit
# Configure an IP address for VLAN-interface 2 on Switch A.
[SwitchA] vlan 2
[SwitchA-vlan2] port gigabitethernet 1/0/2
[SwitchA-vlan2] quit
[SwitchA-Vlan-interface2] ip address 192.168.10.100 255.255.0.0
# Enable local proxy ARP to let Host A and Host B communicate at Layer 3.
[SwitchA-Vlan-interface2] local-proxy-arp enable
l          Configure Switch B
vlan 2
 port access vlan 2
 port access vlan 2
 port-isolate enable
 port access vlan 2
 port-isolate enable
l          Configure Switch A
vlan 2
 port access vlan 2
l          For details about port isolation, refer to Port Isolation Configuration Guide.
l          If Switch B has Layer 2 and Layer 3 port isolation configured, you need to configure local proxy ARP on the VLAN-interface 2 of Switch A to enable communication between Host A and Host B, as shown in Figure 1-2.
l          If Switch B (S3610&S5510 series Ethernet switches, for example) has only Layer 2 port isolation configured, you can enable communication between the two hosts by configuring local proxy ARP directly on VLAN-interface 2 of Switch B.
ARP Detection Configuration Example
Network diagram
Figure 1-3 Network diagram for ARP detection configuration
Network requirements
l          Enable DHCP snooping on Switch. Enable ARP detection for VLAN 10 to allow only packets from valid clients to pass.
l          Configure Host A and Host B as DHCP clients.
Product series
Software version
Hardware version
Release 6100
Release 6300
All versions
1)        Configure a DHCP server (the configuration procedure is omitted).
2)        Configure Host A and Host B as DHCP clients (the configuration procedure is omitted).
3)        Configure Switch
# Add all the ports on the Switch into VLAN 10 (the configuration procedure is omitted).
# Enable DHCP snooping.
[Switch] dhcp-snooping
[Switch] interface gigabitethernet 2/0/1
[Switch-GigabitEthernet2/0/1] dhcp-snooping trust
[Switch-GigabitEthernet2/0/1] quit
# Enable ARP detection for VLAN 10. Configure the upstream port as a trusted port and the downstream ports as untrusted ports (a port is an untrusted port by default).
[Switch] vlan 10
[Switch-vlan10] arp detection enable
[Switch-vlan10] interface gigabitethernet 2/0/1
[Switch-GigabitEthernet2/0/1] arp detection trust
# Enable the checking of the MAC addresses and IP addresses of ARP packets.
[Switch] arp detection validate dst-mac ip src-mac
# Specify the ARP packet rate on GigabitEthernet2/0/2 and GigabitEthernet2/0/3 as 150 pps.
[Switch] interface GigabitEthernet2/0/2
[Switch-GigabitEthernet2/0/2] arp rate-limit rate 150 drop
[Switch-GigabitEthernet2/0/2] quit
[Switch] interface gigabitethernet 2/0/3
[Switch-GigabitEthernet2/0/3] arp rate-limit rate 150 drop
[Switch-GigabitEthernet2/0/3] quit
 dhcp-snooping
interface GigabitEthernet2/0/1
 dhcp-snooping trust
 arp detection trust
vlan 10
interface GigabitEthernet2/0/3
None.
