H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
00-1Cover
00-1Cover 47.92 KB
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: 20081203-C-1.01
Copyright © 2008, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
Technical Support
[email protected]
http://www.h3c.com
About This Manual
Organization
H3C Low-End and Mid-Range Ethernet Switches Configuration Examples is organized as follows:
Part
01-Login Configuration Guide
l      Configuring Telnet Login Using Console Port
l      Configuring Console Port Login Using Telnet
l      Configuring to Log In to a Switch Through the Web-Based NMS
l      Configuring to Control the Login Users
02-VLAN Configuration Guide
l      Configuring Port-Based VLAN
l      Configuring MAC-Based VLAN
l      Configuring Protocol-Based VLAN
l      Configuring IP Subnet-Based VLAN
l      Configuring Isolate-User-VLAN
l      Configuring a Super VLAN
03-GVRP Configuration Guide
Configuring GVRP
04-Voice VLAN Configuration Guide
Configuring Voice VLAN
05-IP Addressing and Performance Configuration Guide
l      Configuring IP Addressing
l      Configuring IP Performance
06-QinQ Configuration Guide
l      Configuring QinQ
l      Configuring Flow-Based Selective QinQ
l      Configuring One-to-One VLAN Mapping
07-BPDU Tunnel Configuration Guide
Configuring BPDU Tunnel
08-VLAN Mapping Configuration Guide
l      One-to-One/Many-to-One VLAN Mapping Configuration Example
l      One-to-Two/Two-to-Two VLAN Mapping Configuration Example
09-MAC Address Table Management Configuration Guide
Configuring MAC Address Table Management
10-Link Aggregation Configuration Guide
Configuring Link Aggregation
11-IP Source Guard Configuration Guide
l      Configuring Static Binding Entries
l      Configuring Dynamic Binding
12-DLDP Configuration Guide
Configuring DLDP
13-MSTP Configuration Guide
l      Configuring MSTP
l      Configuring RSTP
14-IPv4 Routing Configuration Guide
l      Configuring a Static Route
l      Configuring the RIP Version
l      Configuring RIP Route Redistribution
l      Configuring an Additional Metric for a RIP Interface
l      Configuring RIP to Advertise a Summary Route
l      Configuring OSPF Basic Functions
l      Configuring OSPF
l      Configuring OSPF to Advertise a Summary Route
l      Configuring an OSPF Stub Area
l      Configuring an OSPF NSSA Area
l      Configuring OSPF DR Election
l      Configuring an OSPF Virtual Link
l      Configuring OSPF GR
l      Configuring Route Filtering
l      Configuring IS-IS Basic Functions
l      Configuring IS-IS DIS Election
l      Configuring IS-IS Route Redistribution
l      Configuring IS-IS GR
l      Configuring IS-IS Authentication
l      Configuring BGP Basic Functions
l      Configuring BGP and IGP Route Synchronization
l      Configuring BGP Load Balancing
l      Configuring BGP Community
l      Configuring BGP Route Reflector
l      Configuring BGP Confederation
l      Configuring BGP Path Selection
l      Configuring Route Policy Application in IPv4 Route Redistribution
l      Applying a Route Policy to Filter Received BGP Routes
15-IPv6 Configuration Guide
l      Configuring IPv6 Basics
l      Configuring IPv6 Manual Tunnel
l      Configuring Automatic IPv4-Compatible IPv6 Tunnel
l      Configuring Automatic 6to4 Tunnel
l      Configuring ISATAP Tunnel
16-IPv6 Routing Configuration Guide
l      Configuring an IPv6 Static Route
l      Configuring IPv6 RIPng
l      Configuring RIPng Route Redistribution
l      Configuring IPv6 RIPng over IPv4 Tunnel
l      Configuring an OSPFv3 Area
l      Configuring OSPFv3 Route Redistribution
l      Configure OSPFv3 DR Election
l      Configuring IPv6 IS-IS
l      Configuring IPv6 BGP
l      Configuring IPv6 BGP Route Reflector
l      Configuring Route Policy Application in IPv6 Route Redistribution
17-IPv4 Multicast Configuration Guide
l      IGMP Configuration Examples
l      IGMP Snooping Configuration Examples
l      Multicast VLAN Configuration Examples
l      PIM Configuration Examples
l      MSDP Configuration Examples
l      Multicast Routing and Forwarding Configuration Example
l      MBGP Configuration Examples
18-IPv6 Multicast Configuration Examples
l      MLD Configuration Examples
l      MLD Snooping Configuration Examples
l      IPv6 Multicast VLAN Configuration Examples
l      IPv6 MBGP Configuration Examples
19-802.1x Configuration Guide
l      Configuring 802.1x
l      Configuring Dynamic VLAN Assignment
l      Configuring ACL Assignment
l      Configuring EAD Fast Deployment
20-AAA Configuration Guide
l      Configuring AAA by HWTACACS Server for Telnet Users
l      Configuring AAA by Separate Servers for Telnet Users
l      Configuring AAA by RADIUS Server for SSH Users
l      Configuring EAD Application
21-MAC Authentication Configuration Guide
l      Configuring Local MAC Authentication
l      Configuring RADIUS Based MAC Authentication
22-Portal Configuration Guide
l      Configuring Direct Portal Authenction
l      Configuring Re-DHCP Portal Authentication
l      Configuring Layer 3 Portal Authentication
l      Configuring Direct Portal Authentication for EAD
23-ARP Configuration Guide
l      Configuring ARP Basics
l      Configuring Proxy ARP
l      Configuring Local Proxy ARP
l      ARP Detection Configuration Example
24-DHCP Configuration Guide
l      Configuring Static IP Address Allocation
l      Configuring Dynamic IP Address Allocation
l      Configuring DHCP Relay Agent
l      Configuring DHCP Snooping
l      Configuring DHCP Snooping Option 82 Support
l      Configuring DHCP Client
l      Configuring Auto-Configuration
l
25-ACL Configuration Guide
l      Configuring a Basic IPv4 ACL
l      Configuring an Advanced IPv4 ACL
l      Configuring an Ethernet Frame Header ACL
l      Configuring a User-Defined ACL and a Flow Template
l      Configuring a Basic IPv6 ACL
l      Configuring an Advanced IPv6 ACL
26-QoS Configuration Guide
l      Configuring Rate Limiting and Traffic Policing
l      Configuring Priority Marking and Queue Scheduling
l      Configuring Priority Mapping and Queue Scheduling
l      Configuring Traffic Mirroring and Redirecting Traffic to a Port
l      Redirecting Traffic to the Next Hop
27-Port Mirroring Configuration Guide
l      Configuring Local Port Mirroring
l      Configuring Remote Port Mirroring (with a Reflector Port)
l      Configuring Remote Port Mirroring (with an Egress Port)
28-Cluster Management Configuration Guide
Configuring Cluster Management
29-SNMP-RMON Configuration Guide
l      Configuring SNMPv2c to Monitor and Manage a Switch
l      Configuring SNMPv3 to Monitor and Manage a Switch
l      Configuring SNMP Logging
l      Configuring RMON
30-NTP Configuration Guide
l      Configuring NTP Client/Server Mode
l      Configuring NTP Symmetric Peers Mode
l      Configuring NTP Broadcast Mode
l      Configuring NTP Multicast Mode
l      Configuring NTP Broadcast Mode with Authentication
31-FTP-TFTP Configuration Guide
l      Configuring FTP Client
l      Configuring FTP Server
l      Configuring TFTP Client
32-UDP Helper Configuration Guide
Configuring UDP Helper
33-Information Center Configuration Guide
l      Configuring to Output Log Information to a Unix Log Host
l      Configuring to Output Log Information to a Linux Log Host
l      Configuring to Output Log Information to the Console
34-DNS Configuration Guide
l      Configuring Static Domain Name Resolution
l      Configuring Dynamic Domain Name Resolution
l      Configuring DNS Proxy
35-File System Management Configuration Guide
l      Configuring File System Management
l      Configuring Configuration File Management
36-Remote Upgrade Configuration Guide
l      Configuring Remote Upgrade (on a Distributed Switch)
l      Configuring Remote Upgrade (on a Centralized Switch)
37-NQA Configuration Guide
l      ICMP Echo Test Configuration Example
l      DHCP Test Configuration Example
l      FTP Test Configuration Example
l      HTTP Test Configuration Example
l      UDP Jitter Test Configuration Example
l      SNMP Test Configuration Example
l      TCP Test Configuration Example
l      UDP Echo Test Configuration Example
38-VRRP Configuration Guide
l      Configuring Single VRRP Group
l      Configuring VRRP Interface Tracking
l      Configuring Multiple VRRP Groups
39-SSH Configuration Guide
l      SSH Server Configuration (Password Authentication)
l      SSH Server Configuration (Publickey Authentication)
l      SSH Client Configuration (Password Authentication)
l      SSH Client Configuration (Publickey Authentication)
l      SFTP Client Configuration
l      SFTP Server Configuration
40-Port Security Configuration Guide
l      Configuring the Port Security autolearn Mode
l      Configuring the userLoginWithOUI Mode
l      Configuring the macAddressWithRadius Mode
l      Configuring macAddressElseUserLoginSecure Mode
41-Port Isolation Configuration Guide
Configuring Port Isolation
42-LLDP Configuration Guide
l      Configuring LLDP
l      CDP-Compatible LLDP Configuration Example
43-MCE Configuration Guide
l      Configuring MCE (Redistributing VPN Routes by OSPF/RIP/IS-IS)
l      Configuring MCE (Redistributing VPN Routes by BGP)
44-PoE Configuration Guide
l      Configuring PoE for Centralized Devices
l      Configuring PoE for Distributed Devices
45-OAM Configuration Guide
Configuring OAM
46-Connectivity Fault Detection Configuration Guide
Configuring Connectivity Fault Detection
47-RRPP Configuration Guide
l      Configuring a Single-Ring Topology
l      Configuring a Single-Domain Intersecting-Ring Topology
l      Configuring a Multi-Domain Intersecting-Ring Topology
l      Configuring a Intersecting-Ring Topology
l      Configuring Intersecting-Ring Load Balancing
48-sFlow Configuration Guide
Configuring sFlow
49-SSL-HTTPS Configuration Guide
Configuring SSL-HTTPS
50-PKI Configuration Guide
l      Requesting a Certificate from a CA Running RSA Keon
l      Requesting a Certificate from a CA Running Windows 2003 Server
l      Configuring a Certificate Attribute-Based Access Control Policy
51-Track Configuration Guide
l      Configuring VRRP-Track-NQA Collaboration
l      Configuring Static Routing-Track-NQA Collaboration
52-EPON-OLT Configuration Guide
l      OLT Configuration Examples
l      ONU Remote Management Configuration Examples
l      UNI Port Configuration Examples
53-Smart Link Configuration Guide
l      Single Smart Link Group Configuration Example
l      Multiple Smart Link Groups Load Sharing Configuration Example
54-MPLS Configuration Guide
l      MPLS Configuration Guide
l      Guide for Configuring a Remote CCC Connection
l      Configuring SVC MPLS L2VPN
l      Configuring Martini MPLS L2VPN
l      Configuring Kompella MPLS L2VPN
l      Configuring MPLS L3VPNs
l      Configuring Inter-Provider VPN Option A
l      Configuring Inter-Provider VPN Option B
l      Configuring Inter-Provider VPN Option C
l      Configuring Carrier’s Carrier
l      Configuring Nested VPN
l      Configuring OSPF Sham Links
l      Configuring BGP AS Number Substitution
Conventions
The manual uses the following conventions:
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means a complementary description.
