H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
30-NTP Configuration Guide
30-NTP Configuration Guide 137.88 KB
NTP Overview
Defined in RFC 1305, the Network Time Protocol (NTP) synchronizes timekeeping among distributed time servers and clients. NTP runs over the User Datagram Protocol (UDP), using UDP port 123.
The purpose of using NTP is to keep consistent timekeeping among all clock-dependent devices within the network, so that the devices can provide diverse applications based on the consistent time.
For a local system running NTP, its time can be synchronized by other reference sources and can be used as a reference source to synchronize other clocks.
Configuring NTP Client/Server Mode
Network Diagram
Figure 1-1 Network diagram for NTP client/server mode configuration
Networking and Configuration Requirements
l          The local clock of Device A is to be used as a reference source, with the stratum level of 2.
l          Device B works in the client/server mode and Device A is to be used as the NTP server of Device B.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5510 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100
Release 6300
All versions
S3500-EA Series Ethernet Switches
Release 5303
All versions
Configuration Procedure
l          Configure Device A
# Specify the local clock as the reference source, with the stratum level of 2.
[DeviceA] ntp-service refclock-master 2
l          Configure Device B
# Specify Device A as the NTP server of Device B.
[DeviceB] ntp-service unicast-server 1.0.1.11
Complete Configuration
l          Configuration on Device A
l          Configuration on Device B
Configuration Guidelines
1)        The local clock of an S7500E series Ethernet switch can be configured as a reference source.
2)        The local clock of an S3610/S5510/S5500-SI/S5500-EI switch cannot be configured as a reference source, unless it is synchronized by other clocks first.
Configuring NTP Symmetric Peers Mode
Network Diagram
Figure 1-2 Network diagram for NTP symmetric peers mode configuration
l          Device B works in the client mode and Device A is to be used as the NTP server of Device B.
l          Device C works in the symmetric peers mode and Device B will act as the peer of Device C. Device C is the symmetric-active peer while Device B is the symmetric-passive peer.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
Release 5303
All versions
1)        Configure Device A
2)        Configure Device B
[DeviceB] ntp-service unicast-server 3.0.1.31
3)        Configure Device C (after Device B is synchronized to Device A)
# Configure Device B as a symmetric peer.
<DeviceC> system-view
[DeviceC] ntp-service unicast-peer 3.0.1.32
l          Configuration on Device C
Configuring NTP Broadcast Mode
Network Diagram
Figure 1-3 Network diagram for NTP broadcast mode configuration
l          Device C is a switch that supports to use its local clock as a reference source (for example, an S7500E switch). Its local clock is to be used as a reference source, with the stratum level of 2.
l          Device A and Device D are Ethernet switches of any model listed in Applicable Product Matrix. Set Switch A and Switch D to work in the broadcast client mode and receive broadcast messages through their respective VLAN-interface 2.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
Release 5303
All versions
1)        Configure Device C
# Configure Device C to work in the broadcast server mode and send out broadcast messages through VLAN-interface 2.
[DeviceC] interface Vlan-interface 2
[DeviceC-Vlan-interface2] ntp-service broadcast-server
2)        Configure Device A (perform the same configuration on Device D)
# Configure Device A to work in the broadcast client mode and receive broadcast messages through VLAN-interface 2.
[DeviceA] interface Vlan-interface 2
[DeviceA-Vlan-interface2] ntp-service broadcast-client
3)        Configure Device D
# Configure Device D to work in the broadcast client mode and receive broadcast messages through VLAN-interface 2.
<DeviceD> system-view
[DeviceD] interface Vlan-interface 2
[DeviceD-Vlan-interface2] ntp-service broadcast-client
interface Vlan-interface2
 ip address 3.0.1.13 255.255.255.0
 ip address 3.0.1.11 255.255.255.0
l          Configuration on Device D
 ip address 3.0.1.14 255.255.255.0
Configuring NTP Multicast Mode
Network Diagram
Figure 1-4 Network diagram for NTP multicast mode configuration
l          The local clock of Switch C is to be used as a reference source, with the stratum level of 2.
l          Switch C works in the multicast server mode, and sends out multicast messages from VLAN-interface 2.
l          Switch A and Switch D work in the multicast client mode and receive multicast messages through VLAN-interface 3 and VLAN-interface 2 respectively.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
Release 5303
All versions
1)        Configure Switch C.
[SwitchC] ntp-service refclock-master 2
# Configure Switch C to work in the multicast server mode and send out multicast messages through VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service multicast-server
2)        Configure Switch D.
# Configure Switch D to work in the multicast client mode and receive multicast messages through VLAN-interface 2.
<SwitchD> system-view
[SwitchD] interface vlan-interface 2
[SwitchD-Vlan-interface2] ntp-service multicast-client
3)        Configure Switch B.
Because Switch A and Switch C are not on the same subnet, the multicast function needs to be configured on Switch B; otherwise, Switch A cannot receive the multicast messages from Switch C.
# Configure the multicast function.
[SwitchB] multicast routing-enable
[SwitchB-Vlan-interface2] pim dm
[SwitchB] vlan 3
[SwitchB-vlan3] port GigabitEthernet 1/0/1
[SwitchB-vlan3] quit
[SwitchB-Vlan-interface3] igmp enable
[SwitchB] interface GigabitEthernet 1/0/1
[SwitchB-GigabitEthernet1/0/1] igmp-snooping static-group 224.0.1.1 vlan 3
4)        Configure Switch A.
# Configure Switch A to work in the multicast client mode and receive multicast messages through VLAN-interface 3.
[SwitchA-Vlan-interface3] ntp-service multicast-client
l          Configuration on Switch A
interface Vlan-interface3
l          Configuration on Switch B
 pim dm
 igmp enable
 port access vlan 3
l          Configuration on Switch C
l          Configuration on Switch D
3)        Switch B in this configuration example cannot be an S5500-SI series Ethernet switch, for the switch does not support the Layer 3 multicast function.
Configuring NTP Broadcast Mode with Authentication
Network Diagram
Figure 1-5 Network diagram for configuration of NTP broadcast mode with authentication
l          The local clock of Switch C is to be used as a reference source, with the stratum level of 3.
l          Switch C works in the broadcast server mode, and sends out broadcast messages from VLAN-interface 2.
l          Switch D works in the broadcast client mode and receives broadcast messages through VLAN-interface 2.
l          NTP authentication is enabled on both Switch C and Switch D.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
Release 5303
All versions
# Specify the local clock as the reference source, with the stratum level of 3.
[SwitchC] ntp-service refclock-master 3
# Configure NTP authentication.
[SwitchC] ntp-service authentication enable
[SwitchC] ntp-service authentication-keyid 88 authentication-mode md5 123456
[SwitchC] ntp-service reliable authentication-keyid 88
# Specify Switch C as an NTP broadcast server, and specify an authentication key.
[SwitchC-Vlan-interface2] ntp-service broadcast-server authentication-keyid 88
[SwitchD] ntp-service authentication enable
[SwitchD] ntp-service authentication-keyid 88 authentication-mode md5 123456
[SwitchD] ntp-service reliable authentication-keyid 88
# Configure Switch D to work in the NTP broadcast client mode.
[SwitchD-Vlan-interface2] ntp-service broadcast-client
 ntp-service authentication-keyid 88 authentication-mode md5 OUM!K%F<+$[Q=^Q`MAF4<1!!
