H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
40-Port Security Configuration Guide
40-Port Security Configuration Guide 122.75 KB
Configuring the Port Security autolearn Mode
In the port security mode of autolearn, a port can learn a specified number of MAC addresses and save those addresses as secure MAC addresses. When the number of secure MAC addresses reaches the upper limit, the port changes to work in secure mode, and permits only frames whose source MAC addresses are secure MAC addresses or configured static MAC addresses.
Network Diagram
Figure 1-1 Network diagram for configuring the autolearn mode
Networking and Configuration Requirements
Restrict port GigabitEthernet 1/01 of the switch as follows:
l          Allow up to 64 users to access the port without authentication and permit the port to learn and add the MAC addresses of the users as secure MAC addresses.
l          After the number of secure MAC addresses reaches 64, the port stops learning MAC addresses. If any frame with an unknown MAC address arrives, intrusion protection is triggered and the port is disabled for 30 seconds.
Applicable Product Matrix
Product series
Software version
Hardware version
S5500-SI Series Ethernet Switches
Release 1207
All versions except for S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6300
All versions
Configuration Procedure
1)        Configure port security
# Enable port security.
<Switch> system-view
[Switch] port-security enable
# Enable intrusion protection trap.
[Switch] port-security trap intrusion
# Set the maximum number of secure MAC addresses allowed on the port to 64.
[Switch] interface GigabitEthernet 1/0/1
[Switch-GigabitEthernet1/0/1] port-security max-mac-count 64
# Set the port security mode to autoLearn.
[Switch-GigabitEthernet1/0/1] port-security port-mode autolearn
# Configure the port to be disabled for 30 seconds after the intrusion protection feature is triggered.
[Switch-GigabitEthernet1/0/1] port-security intrusion-mode disableport-temporarily
[Switch] port-security timer disableport 30
2)        Verify the configuration
After completing the above configurations, you can use the following command to view the port security configuration information:
<Switch> display port-security interface gigabitethernet 1/0/1
 Equipment port-security is enabled
 Intrusion trap is enabled
 Disableport Timeout: 30s
 OUI value:
GigabitEthernet1/0/1 is link-up
   Port mode is autoLearn
   NeedToKnow mode is disabled
   Intrusion Protection mode is DisablePortTemporarily
   Max MAC address number is 64
   Stored MAC address number is 0
   Authorization is permitted
As shown in the output, the maximum number of secure MAC addresses allowed on the port is 64, the port security mode is autoLearn, the intrusion protection trap is enabled, and the intrusion protection action is to disable the port for 30 seconds.
You can also use the above command repeatedly to track the number of MAC addresses learned by the port, or use the display this command in interface view to display the secure MAC addresses learned, as shown below:
[Switch-GigabitEthernet1/0/1] display this
 port-security mac-address security 0002-0000-0015 vlan 1
 port-security mac-address security 0002-0000-0014 vlan 1
 port-security mac-address security 0002-0000-0013 vlan 1
 port-security mac-address security 0002-0000-0012 vlan 1
 port-security mac-address security 0002-0000-0011 vlan 1
Issuing the display port-security interface command after the number of MAC addresses learned by the port reaches 64, you will see that the port security mode has changed to secure. When any frame with a new MAC address arrives, intrusion protection is triggered and you will see trap messages as follows:
#May  2 03:15:55:871 2000 Switch PORTSEC/1/VIOLATION:Traph3cSecureViolation
 A intrusion occurs!
 IfIndex: 9437207
 Port: 9437207
 MAC Addr: 0.2.0.0.0.21
 VLAN ID: 1
 IfAdminStatus: 1
In addition, you will see that the port security feature has disabled the port if you issue the following command:
<Switch-GigabitEthernet1/0/1> display interface gigabitethernet 1/0/1
 GigabitEthernet1/0/1 current state:  Port Security Disabled
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-cb00-5558
 Description: GigabitEthernet1/0/1 Interface
The port should be re-enabled 30 seconds later.
[Switch-GigabitEthernet1/0/1] display interface gigabitethernet 1/0/1
 GigabitEthernet1/0/1 current state: UP
Now, if you manually delete several secure MAC addresses, the port security mode of the port will be restored to autoLearn, and the port will be able to learn MAC addresses again.
Complete Configuration
Configuration Guidelines
l          Before enabling port security, you need to disable 802.1x and MAC authentication globally.
l          You cannot configure port security on a port configured with aggregation group.
l          The maximum number of users a port supports is the lesser of the maximum number of secure MAC addresses or the maximum number of authenticated users the security mode supports.
l          Port security cannot be disabled if there is any user present on a port.
Configuring the userLoginWithOUI Mode
In userLoginWithOUI mode, a port supports one 802.1x user as well as one user whose source MAC address has an OUI value among the specified ones.
Network Diagram
Figure 1-2 Network diagram for configuring the userLoginWithOUI mode
The user (Host in the figure) is connected to the switch through port GigabitEthernet 1/0/1. The switch authenticates the user by the RADIUS server. If the authentication succeeds, the user is authorized to access the Internet.
Restrict port GigabitEthernet 1/0/1 of the switch as follows:
l          Allow only one 802.1x user to be authenticated.
l          Allow up to 16 OUI values to be configured and allow one additional user whose MAC address has an OUI among the configured ones to access the port.
Product series
Software version
Hardware version
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
S7500ESeries Ethernet Switches
Release 6300
All versions
l          The following configuration steps cover some AAA/RADIUS configuration commands. For details about the commands, refer to AAA RADIUS HWTACACS Configuration.
l          Configurations on the host and RADIUS servers are omitted.
1)        Configure the RADIUS protocol
# Configure a RADIUS scheme named radsun.
[Switch] radius scheme radsun
# Set the IP addresses of the primary authentication and accounting servers to 192.168.1.1 and 192.168.1.2 respectively.
[Switch-radius-radsun] primary authentication 192.168.1.1
[Switch-radius-radsun] primary accounting 192.168.1.2
# Set the IP addresses of the secondary authentication and accounting servers to 192.168.1.2 and 192.168.1.1 respectively.
[Switch-radius-radsun] secondary authentication 192.168.1.2
[Switch-radius-radsun] secondary accounting 192.168.1.1
# Set the encryption key for the switch to use when interacting with the authentication server to name.
[Switch-radius-radsun] key authentication name
# Set the encryption key for the switch to use when interacting with the accounting server to money.
[Switch-radius-radsun] key accounting money
# Set the RADIUS server response timeout time to five seconds and the maximum number of RADIUS packet transmission attempts to 5.
[Switch-radius-radsun] timer response-timeout 5
[Switch-radius-radsun] retry 5
# Set the interval at which the switch sends real-time accounting packets to the RADIUS server to 15 minutes.
[Switch-radius-radsun] timer realtime-accounting 15
# Specify that the switch sends user names without domain names to the RADIUS server.
[Switch-radius-radsun] user-name-format without-domain
[Switch-radius-radsun] quit
# Create an ISP domain named sun and enter its view.
[Switch] domain sun
# Configure the ISP domain to use RADIUS scheme radsun as its default RADIUS scheme.
[Switch-isp-sun] authentication default radius-scheme radsun
# Allow the ISP domain to accommodate up to 30 users.
[Switch-isp-sun] access-limit enable 30
[Switch-isp-sun] quit
2)        Configure port security
# Add five OUI values.
[Switch] port-security oui 1234-0100-1111 index 1
[Switch] port-security oui 1234-0200-1111 index 2
[Switch] port-security oui 1234-0300-1111 index 3
[Switch] port-security oui 1234-0400-1111 index 4
[Switch] port-security oui 1234-0500-1111 index 5
# Set the port security mode to userLoginWithOUI.
[Switch-GigabitEthernet1/0/1] port-security port-mode userlogin-withoui
3)        Verify the configuration
After completing the above configurations, you can use the following command to view the configuration information of the RADIUS scheme radsun:
<Switch> display radius scheme radsun
SchemeName  = radsun
  Index = 0                           Type = standard
  Primary Auth IP  = 192.168.1.1      Port = 1812   State = active
  Primary Acct IP  = 192.168.1.2      Port = 1813   State = active
  Second  Auth IP  = 192.168.1.2      Port = 1812   State = active
  Second  Acct IP  = 192.168.1.1      Port = 1813   State = active
  Auth Server Encryption Key = name
  Acct Server Encryption Key = money
  Accounting-On packet disable, send times = 5 , interval = 3s
  Interval for timeout(second)                            = 5
  Retransmission times for timeout                        = 5
  Interval for realtime accounting(minute)                = 15
  Retransmission times of realtime-accounting packet      = 5
  Retransmission times of stop-accounting packet          = 500
  Quiet-interval(min)                                     = 5
  Username format                                         = without-domain
  Data flow unit                                          = Byte
  Packet unit                                             = one
Use the following command to view the configuration information of the ISP domain sun:
<Switch> display domain sun
   Domain = sun
   State = Active
   Access-limit = 30
   Accounting method = Required
   Default authentication scheme      : radius=radsun
   Default authorization scheme       : local
   Default accounting scheme          : local
   Domain User Template:
   Idle-cut = Disable
   Self-service = Disable
Use the following command to view the port security configuration information:
 Trap is disabled
 Disableport Timeout: 20s
 OUI value:
   Index is 1,  OUI value is 123401
   Index is 2,  OUI value is 123402
   Index is 3,  OUI value is 123403
   Index is 4,  OUI value is 123404
   Index is 5,  OUI value is 123405
   Port mode is userLoginWithOUI
   Intrusion Protection mode is NoAction
   Max MAC address number is not configured
After an 802.1x user gets online, you can see that the number of secure MAC addresses stored is 1. You can also use the following command to view information about 802.1x users:
<Switch> display dot1x interface gigabitethernet 1/0/1
 Equipment 802.1X protocol is enabled
 CHAP authentication is enabled
Configuration: Transmit Period   30 s,  Handshake Period       15 s
                Quiet Period      60 s,  Quiet Period Timer is disabled
                Supp Timeout      30 s,  Server Timeout        100 s
                The maximal retransmitting times    2
Total maximum 802.1X user resource number is 1024 per slot
 Total current used 802.1X resource number is 1
   Handshake is enabled
   The port is an authenticator
   Authentication Mode is Auto
   Port Control Type is Mac-based
   Guest VLAN: 0
   Max number of on-line users is 256
   EAPOL Packet: Tx 16331, Rx 102
   Sent EAP Request/Identity Packets : 16316
        EAP Request/Challenge Packets: 6
        EAP Success Packets: 4, Fail Packets: 5
   Received EAPOL Start Packets : 6
            EAPOL LogOff Packets: 2
            EAP Response/Identity Packets : 80
            EAP Response/Challenge Packets: 6
            Error Packets: 0
 1. Authenticated user : MAC address: 0002-0000-0011
   Controlled User(s) amount to 1
In addition, the port allows an additional user whose MAC address has an OUI among the specified OUIs to access the port. You can use the following command to view the related information:
<Switch> display mac-address interface gigabitethernet 1/0/1
MAC ADDR        VLAN ID   STATE          PORT INDEX               AGING TIME(s)
1234-0300-0011  1       Learned       GigabitEthernet1/0/1    AGING
  ---  1 mac address(es) found  ---
 port-security oui 1234-0100-0000 index 1
 port-security oui 1234-0200-0000 index 2
 port-security oui 1234-0300-0000 index 3
 port-security oui 1234-0400-0000 index 4
 port-security oui 1234-0500-0000 index 5
 retry 5
domain sun
l          You can configure multiple OUI values.
Configuring the macAddressWithRadius Mode
In macAddressWithRadius mode, a port performs MAC authentication of users.
Network Diagram
Figure 1-3 Network diagram for configuring the macAddressWithRadius mode
The user (Host in the figure) is connected to the switch through GigabitEthernet 1/0/1. The switch authenticates the user by the RADIUS server. If the authentication succeeds, the user is authorized to access the Internet.
l          Perform MAC authentication of users.
l          All users belong to the default domain sun. Use the MAC address of a user as the username and password for MAC authentication of the user.
l          Upon receiving packets from users that do not pass MAC authentication, trigger intrusion protection and drop such packets to ensure port security.
Product series
Software version
Hardware version
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6300
All versions
[Switch] domain sun
# Configure the ISP domain for MAC authentication.
[Switch] mac-authentication domain sun
# Set the port security mode to macAddressWithRadius.
[Switch-GigabitEthernet1/0/1] port-security port-mode mac-authentication
# Configure the intrusion protection feature as blockmac.
[Switch-GigabitEthernet1/0/1] port-security intrusion-mode blockmac
After the above configurations, you can use the following command to view the port security configuration information:
 Trap is disabled
 OUI value:
   Port mode is macAddressWithRadius
   Intrusion Protection mode is BlockMacAddress
   Stored MAC address number is 1
Use the following command to view the MAC authentication information:
<Switch> display mac-authentication interface gigabitethernet 1/0/1
MAC address authentication is enabled.
 User name format is MAC address, like xxxxxxxxxxxx
 Fixed username:mac
 Fixed password:not configured
          Offline detect period is 300s
          Quiet period is 60s
          Server response timeout value is 100s
          The max allowed user number is 1024 per slot
          Current user number amounts to 1
          Current domain is sun
Silent MAC User info:
          MAC Addr         From Port                    Port Index
  Authenticate success: 1, failed: 0
  Current online user number is 1
          MAC Addr         Authenticate State           Auth Index
          000f-3d80-2b38   MAC_AUTHENTICATOR_SUCCESS     11
In addition, as the blockmac intrusion protection feature is configured, upon receiving packets from users that do not pass MAC authentication, the switch will trigger intrusion protection and drop such packets to ensure port security..
 retry 5
domain sun
return
Configuring macAddressElseUserLoginSecure Mode
The macAddressElseUserLoginSecure mode is the combination of the macAddressWithRadius and userLoginSecure modes, with MAC authentication having a higher priority.
l          Upon receiving a non-802.1x frame, a port in this mode performs only MAC authentication.
l          Upon receiving an 802.1x frame, the port performs MAC authentication and then, if MAC authentication fails, 802.1x authentication.
Network Diagram
Figure 1-4 configure the macAddressElseUserLoginSecure mode
The user (Host in the figure) is connected to the switch through GigabitEthernet 1/0/1. The switch authenticates the user by the RADIUS server. If the authentication succeeds, the client is authorized to access the Internet.
l          Allow more than one MAC authenticated user to log on.
l          For 802.1x users, perform MAC authentication first and then, if MAC authentication fails, 802.1x authentication. Allow only one 802.1x user to log on.
l          Configure the MAC authentication username type as fixed username. Set the total number of MAC authenticated users and 802.1x-authenticated user to 64.
l          Enable NeedToKnow (NTK) to prevent frames from being sent to unknown MAC addresses.
Product series
Software version
Hardware version
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6300
All versions
Create a RADIUS scheme named radsun.
[Switch] domain sun
# Configure MAC authentication to work in fixed username mode, setting the user name and password to aaa and 123456 respectively.
[Switch] mac-authentication user-name-format fixed account aaa password simple 123456
# Set the port security mode to macAddressElseUserLoginSecure.
[Switch-GigabitEthernet1/0/1] port-security port-mode mac-else-userlogin-secure
# Set the NTK mode of the port to ntkonly.
[Switch-GigabitEthernet1/0/1] port-security ntk-mode ntkonly
 Trap is disabled
 OUI value:
   Port mode is macAddressElseUserLoginSecure
   NeedToKnow mode is NeedToKnowOnly
Use the following command to view MAC authentication information:
 User name format is fixed account
 Fixed username:aaa
 Fixed password:123456
          Quiet period is 60s
          Current user number amounts to 0
  Authenticate success: 3, failed: 1
  Current online user number is 3
    1234-0300-0011   MAC_AUTHENTICATOR_SUCCESS     13
    1234-0300-0012   MAC_AUTHENTICATOR_SUCCESS     14
    1234-0300-0013   MAC_AUTHENTICATOR_SUCCESS     15
Use the following command to view 802.1x authentication information:
 EAD quick deploy configuration:
                EAD timeout:   30 m
 The maximum 802.1X user resource number is 1024 per slot
   802.1X Multicast-trigger is enabled
   Guest VLAN: 0
            Error Packets: 0
In addition, as NTK is enabled, frames with unknown destination MAC addresses, multicast addresses, and broadcast addresses should be discarded.
 retry 5
domain sun
l          On a port operating in either macAddressElseUserLoginSecure mode or macAddressElseUserLoginSecureExt mode, intrusion protection is triggered only after both MAC authentication and 802.1x authentication for the same frame fail.
