H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
44-PoE Configuration Guide
44-PoE Configuration Guide 80.28 KB
PoE Overview
Power over Ethernet (PoE) means that power sourcing equipment (PSE) supplies power to powered devices (PD) such as IP telephone, wireless LAN access point, and web camera from Ethernet interfaces through twisted pair cables.
Configuring PoE for Centralized Devices
Network Diagram
Figure 1-1 Network diagram for PoE
Networking and Configuration Requirements
The switch supplies power to a PD through a PoE interface.
l          GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 are connected to IP telephones.
l          GigabitEthernet 1/0/11 and GigabitEthernet 1/0/12 are connected to access point (AP) devices.
l          The power priority of GigabitEthernet 1/0/2 is critical. No power will be supplied to a new PD if the PSE power is overloaded, that is, the default policy of PD power management is adopted.
l          The power of the AP device connected to GigabitEthernet 1/0/11 does not exceed 9,000 milliwatts.
Applicable Product Matrix
Product series
Software version
Hardware version
S5500-SI Series Ethernet Switches
Release 1207
PoE model of the S5500-SI series
S5500-EI Series Ethernet Switches
Release 2102
PoE model of the S5500-EI series
Configuration Procedure
# Enable PoE on GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, GigabitEthernet 1/0/11 and GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/1] poe enable
[Sysname] interface GigabitEthernet 1/0/2
[Sysname-GigabitEthernet1/0/2] poe enable
[Sysname-GigabitEthernet1/0/2] quit
[Sysname] interface GigabitEthernet 1/0/11
[Sysname-GigabitEthernet1/0/11] poe enable
[Sysname-GigabitEthernet1/0/11] quit
[Sysname] interface GigabitEthernet 1/0/12
[Sysname-GigabitEthernet1/0/12] poe enable
[Sysname-GigabitEthernet1/0/12] return
# Set the power priority level of GigabitEthernet 1/0/2 to critical.
[Sysname-GigabitEthernet1/0/2] poe priority critical
# Set the maximum power of GigabitEthernet 1/0/11 to 9,000 milliwatts.
[Sysname-GigabitEthernet1/0/11] poe max-power 9000
After the above takes effect, the IP telephones and AP devices are powered and can work normally.
Complete Configuration
 poe enable
 poe enable
interface GigabitEthernet1/0/11
 poe enable
 poe max-power 9000
interface GigabitEthernet1/0/12
 poe enable
Configuration Guidelines
None
Configuring PoE for Distributed Devices
Network Diagram
Figure 1-2 Network diagram for PoE
l          The device is equipped with two PoE-supporting cards, which are inserted in Slot 3 and Slot 5 respectively. The PSE IDs are 10 and 16.
l          Allocate 400 watts to PSE 10, provided the default maximum power to PSE 16 can meet the requirements.
l          GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2 are connected to IP telephones.
l          GigabitEthernet 5/0/1 and GigabitEthernet 5/0/2 are connected to access point (AP) devices.
l          The power priority of GigabitEthernet 3/0/2 is critical. No power will be supplied to the new PD if the PSE power is overloaded, that is, the default policy of PD power management is adopted.
l          The power of the AP device connected to GigabitEthernet 5/0/1 does not exceed 9,000 milliwatts.
Product series
Software version
Hardware version
S7500E Series Ethernet Switches
Release 6100, Release 6300
The S7500E series(equipped with PoE-capable card)
# Enable PoE for the PSE.
[Sysname] poe enable pse 10
[Sysname] poe enable pse 16
# Set the maximum power of PSE to 400 watts.
[Sysname] poe max-power 400 pse 10
# Enable PoE on GigabitEthernet 3/0/1, GigabitEthernet 3/0/2, GigabitEthernet 5/0/1 and GigabitEthernet 5/0/2.
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] poe enable
[Sysname-GigabitEthernet3/0/1] quit
[Sysname] interface gigabitethernet 3/0/2
[Sysname-GigabitEthernet3/0/2] poe enable
[Sysname-GigabitEthernet3/0/2] quit
[Sysname] interface gigabitethernet 5/0/1
[Sysname-GigabitEthernet5/0/1] poe enable
[Sysname-GigabitEthernet5/0/1] quit
[Sysname] interface gigabitethernet 5/0/2
[Sysname-GigabitEthernet5/0/2] poe enable
[Sysname-GigabitEthernet5/0/2] quit
# Set the power priority level of GigabitEthernet 3/0/2 to critical.
[Sysname-GigabitEthernet3/0/2] poe priority critical
# Set the maximum power of GigabitEthernet 5/0/1 to 9,000 milliwatts.
[Sysname-GigabitEthernet5/0/1] poe max-power 9000
 poe enable pse 10
 poe enable pse 16
interface GigabitEthernet3/0/1
 poe enable
interface GigabitEthernet3/0/2
 poe enable
interface GigabitEthernet5/0/1
 poe enable
 poe max-power 9000
interface GigabitEthernet5/0/2
 poe enable
To provide PoE supply to attached devices, the S7500E series require appropriate PoE power modules. PoE power modules fall into external and internal types.
1)        The S7502E requires both internal power modules for its own power feed and an appropriate external PoE power module, PSE2500-A3 for example, to provide PoE supply.
2)        The S7503E, S7506E, S7506E-V, and S7510E require only internal PoE power modules, PSR1400-D for example, for both their own power feed and PoE supply to attached devices.
For the details, refer to H3C S7500E Series Ethernet Switches  Installation Manual.
