H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
33-Information Center Configuration Guide
33-Information Center Configuration Guide 72.33 KB
Information Center Overview
Acting as the system information hub, information center classifies and manages system information. Used with debug commands, it provides powerful support for network administrators and developers in monitoring network performance and diagnosing network problems.
Configuring to Output Log Information to a Unix Log Host
Network Diagram
Figure 1-1 Network diagram for outputting log information to a Unix log host
Networking and Configuration Requirements
l          Send log information of the switch to the Unix log host with an IP address of 202.38.1.10;
l          Log information with severity higher than informational will be output to the log host;
l          The source modules are ARP and IP.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5510 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100
Release 6300
All versions
S3500-EA Series Ethernet Switches
Release 5303
All versions
Configuration Procedure
l          Configure the switch
# Enable information center.
[Sysname] info-center enable
# By default, the system outputs system information of all modules to channel loghost. To acquire the system information from ARP and IP modules only, you need to disable the information output of all modules to channel loghost first.
[Sysname] undo info-center source default channel loghost
# Specify the host with IP address 202.38.1.10 as the log host. Log information with severity equal or higher than informational will be output to the log host. The source modules are ARP and IP.
[Sysname] info-center loghost 202.38.1.10 facility local4
[Sysname] info-center source arp channel loghost log level informational debug state off trap state off
[Sysname] info-center source ip channel loghost log level informational debug state off trap state off
l          Configure the log host
The following configurations were performed on SunOS 4.0, which has similar configurations to the Unix operating systems implemented by other vendors.
# Execute the following commands as a root user.
# mkdir /var/log/Sysname
# touch /var/log/Sysname/information
# Edit file /etc/syslog.conf and add the following selector/action pairs.
# Sysname configuration messages
local4.info    /var/log/Sysname/information
# After log file information is created and file /etc/syslog.conf is modified, you need to issue the following commands, and then by receiving a HUP signal, the daemon syslogd will read its configuration file /etc/syslog.conf again.
# ps -ae | grep syslogd
147
# kill -HUP 147
Complete Configuration
 info-center source ARP channel 2 trap state off
 info-center source IP channel 2 trap state off
 undo info-center source default channel 2
147
# kill -HUP 147
Configuration Guidelines
Follow these guidelines when editing file /etc/syslog.conf:
l          Comments must be on a separate line and begin with the # sign.
l          Separate the selector/action pairs with a tab, instead of a space.
l          No redundant spaces are allowed after the file name.
l          The logging device name and the information level specified in /etc/syslog.conf file must be the same with those configured on the switch using the info-center loghost and info-center source commands; otherwise the log information may not be output properly to the log host.
Configuring to Output Log Information to a Linux Log Host
Network Diagram
Figure 1-2 Network diagram for outputting log information to a Linux log host
l          Send log information of the switch to the Linux log host with an IP address of 202.38.1.10;
l          Log information with severity higher than errors will be output to the log host;
l          All modules can output log information.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
Release 5303
All versions
# Specify the host with IP address 202.38.1.10 as the log host. Log information with severity equal or higher than errors will be output to the log host. All modules can output log information.
[Sysname] info-center loghost 202.38.1.10 facility local7
[Sysname] info-center source default channel loghost log level errors debug state off trap state off
# Edit file /etc/syslog.conf and add selector/action pairs.
local7.info    /var/log/Sysname/information
# After log file information is created and file /etc/syslog.conf is modified, you need to issue the following commands to display the process ID of daemon syslogd, kill the syslogd progress, and then restart syslogd using the –r option.
147
# kill -9 147
# syslogd -r &
 info-center source default channel 2 log level error trap state off
147
# kill -9 147
# syslogd -r &
Ensure that the daemon syslogd is started with the –r option on a Linux log host.
Configuring to Output Log Information to the Console
Network Diagram
Figure 1-3 Network diagram for sending log information to the console
l          Log information with a severity higher than informational will be output to the console;
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
Release 5303
All versions
# By default, the system outputs system information of all modules to channel console. To acquire the information of ARP and IP modules only, you need to disable the information output of all modules to channel console first.
[Sysname] undo info-center source default channel console
# Configure the information output to the console. Log information with severity level equal or higher than informational will be output to the console. The source modules are ARP and IP.
[Sysname] info-center console channel console
[Sysname] info-center source arp channel console log level informational debug state off trap state off
[Sysname] info-center source ip channel console log level informational debug state off trap state off
# Enable the display of log information on a terminal display.
<Sysname> terminal monitor
<Sysname> terminal logging
 info-center source ARP channel 0 trap state off
 info-center source IP channel 0 trap state off
 undo info-center source default channel 0
None
