H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
05-IP Addressing and Performance Configuration Guide
Configuring IP Addressing
Network Diagram
Figure 1-1 Network diagram for IP address configuration
Networking and Configuration Requirements
As shown in the above figure, VLAN-interface 1 on Switch is connected to a LAN in which hosts belong to two subnets: 172.16.1.0/24 and 172.16.2.0/24. It is required to enable the hosts in the LAN to communicate with external networks through Switch, and to enable the hosts in the two network segments to communicate with each other.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5510 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except
S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100
Release 6300
All versions
S3500-EA Series Ethernet Switches
Release 5303
All versions
Configuration Procedure
Assign a primary IP address and a secondary IP address to VLAN-interface 1 of Switch to ensure that all the hosts on the LAN can access external networks through Switch. Set Switch as the gateway on all the hosts of the two subnets to ensure that they can communicate with each other.
# Assign a primary IP address and a secondary IP address to VLAN-interface 1.
<Switch> system-view
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ip address 172.16.1.1 255.255.255.0
[Switch-Vlan-interface1] ip address 172.16.2.1 255.255.255.0 sub
[Switch-Vlan-interface1] return
# Set the gateway address to 172.16.1.1 on the hosts in subnet 172.16.1.0/24, and to 172.16.2.1 on the hosts in subnet 172.16.2.0/24.
# Ping Host B on Switch to verify the connectivity to subnet 172.16.1.0/24.
<Switch> ping 172.16.1.2
  PING 172.16.1.2: 56  data bytes, press CTRL_C to break
    Reply from 172.16.1.2: bytes=56 Sequence=1 ttl=255 time=25 ms
    Reply from 172.16.1.2: bytes=56 Sequence=2 ttl=255 time=27 ms
    Reply from 172.16.1.2: bytes=56 Sequence=3 ttl=255 time=26 ms
    Reply from 172.16.1.2: bytes=56 Sequence=4 ttl=255 time=26 ms
    Reply from 172.16.1.2: bytes=56 Sequence=5 ttl=255 time=26 ms
  --- 172.16.1.2 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
round-trip min/avg/max = 25/26/27 ms
Information shows that Switch and Host B are reachable to each other.
# Ping Host A on Switch to verify the connectivity to subnet 172.16.2.0/24.
<Switch> ping 172.16.2.2
  PING 172.16.2.2: 56  data bytes, press CTRL_C to break
    Reply from 172.16.2.2: bytes=56 Sequence=1 ttl=255 time=25 ms
    Reply from 172.16.2.2: bytes=56 Sequence=2 ttl=255 time=26 ms
    Reply from 172.16.2.2: bytes=56 Sequence=3 ttl=255 time=26 ms
    Reply from 172.16.2.2: bytes=56 Sequence=4 ttl=255 time=26 ms
    Reply from 172.16.2.2: bytes=56 Sequence=5 ttl=255 time=26 ms
  --- 172.16.2.2 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 25/25/26 ms
Information shows that Switch and Host A are reachable to each other.
# Ping Host B on Host A to verify the connectivity between subnet 172.16.1.0/24 and subnet 172.16.1.0/24. Ping Host B on Host A to verify that the ping operation is successful.
Complete Configuration
interface Vlan-interface1
Configuration Guidelines
l          The primary IP address you assigned to the interface can overwrite the old one if there is any.
l          You cannot assign secondary IP addresses to an interface that has BOOTP, or DHCP configured.
l          The primary and secondary IP addresses you assign to the interface can be located on the same network segment. However, this should not violate the rule that different interfaces on the switch must reside on different network segments.
Configuring IP Performance
Network Diagram
Figure 1-2 Network diagram for configuring reception and forwarding of directed broadcasts
As shown in the figure above, the host’s interface and VLAN-interface 3 on Switch A are on the same subnet (1.1.1.0/24). VLAN-interface 2 on Switch A and VLAN-interface 2 on Switch B are on the other subnet (2.2.2.0/24). Set the default gateway on the host to VLAN-interface 3 on Switch A. Configure a static route to the host on Switch B.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
All versions except
S5500-20TP-SI
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
Release 5303
All versions
l          Configure Switch A
# Enable Switch A to receive directed broadcasts.
[SwitchA] ip forward-broadcast
# Create VLAN 2 and VLAN 3.
[SwitchA] Vlan 2
[SwitchA-Vlan2] quit
[SwitchA] Vlan 3
[SwitchA–Vlan3] quit
# Configure IP addresses for VLAN-interface 3 and VLAN-interface 2 respectively.
[SwitchA-Vlan-interface3] ip address 1.1.1.2 24
[SwitchA-Vlan-interface3] quit
[SwitchA-Vlan-interface2] ip address 2.2.2.2 24
# Enable VLAN-interface 2 to forward directed broadcasts.
[SwitchA-Vlan-interface2] ip forward-broadcast
l          Configure Switch B
# Enable Switch B to receive directed broadcasts.
[SwitchB] ip forward-broadcast
# Create VLAN 2.
[SwitchB] Vlan 2
[SwitchB-Vlan2] quit
# Configure a static route to the host.
[SwitchB] ip route-static 1.1.1.1 24 2.2.2.2
# Configure an IP address for VLAN-interface 2.
[SwitchB-Vlan-interface2] ip address 2.2.2.1 24
After the above configuration, if you ping the subnet broadcast address (2.2.2.255) on the host, ping packets can be received by VLAN-interface 2 of Switch B. However, if you undo the ip forward-broadcast command, ping packets cannot be received by VLAN-interface 2 of Switch B.
vlan 2
vlan 3
interface Vlan-interface2
 ip address 2.2.2.2 255.255.255.0
interface Vlan-interface3
 ip address 1.1.1.2 255.255.255.0
vlan 2
 ip address 2.2.2.1 255.255.255.0
 ip route-static 1.1.1.0 255.255.255.0 2.2.2.2
None.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
