H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
07-BPDU Tunnel Configuration Guide
07-BPDU Tunnel Configuration Guide 46.62 KB
Configuring BPDU Tunnel
Network diagram
Figure 1-1 Network diagram for BPDU tunnel configuration
Networking and Configuration Requirements
Customer A and Customer B are customer network access devices. Provider A and Provider B are service provider network access devices, which are interconnected through configured trunk ports.
The configuration is required to satisfy the following requirements:
l          Geographically dispersed customer network access devices Customer A and Customer B can implement consistent spanning tree calculation across the service provider network.
l          The destination multicast MAC address configured for BPDU tunnel frames is 0x0100-0CCD-CDD0.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301, Release 5303
All versions
S5510 Series Ethernet Switches
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100, Release 6300
All versions
Configuration Procedure
l          Because BPDU tunneling and NTDP are mutually exclusive, to enable BPDU tunneling on a port, use the undo ntdp enable command to disable NTDP on the port first. For details about NTDP, refer to Cluster Management Configuration in the related product manual.
l          The S7500E series Ethernet switches do not support NTDP. Therefore, to enable BPDU tunneling on the port of an S7500E series Ethernet switch, you need not execute the undo ntdp enable command on the port.
l          The S7500E series Ethernet switches whose software version is Release 6300 do not support the bpdu-tunnel dot1q enable command. Therefore, when configuring such switches, you need not execute the bpdu-tunnel dot1q enable command.
1)        Configuration on Provider A
# Configure the destination multicast MAC address for BPDU tunnel frames as 0x0100-0CCD-CDD0.
<ProviderA> system-view
[ProviderA] bpdu-tunnel tunnel-dmac 0100-0ccd-cdd0
# Configure GigabitEthernet 1/0/1 as an access port and assign it to VLAN 2.
[ProviderA] interface GigabitEthernet 1/0/1
[ProviderA-GigabitEthernet1/0/1] port access vlan 2
# Configure GigabitEthernet 1/0/1 to transmit BPDUs transparently.
[ProviderA-GigabitEthernet1/0/1] stp disable
[ProviderA-GigabitEthernet1/0/1] undo ntdp enable
[ProviderA-GigabitEthernet1/0/1] bpdu-tunnel dot1q enable
[ProviderA-GigabitEthernet1/0/1] bpdu-tunnel dot1q stp
2)        Configuration on Provider B
<ProviderB> system-view
[ProviderB] bpdu-tunnel tunnel-dmac 0100-0ccd-cdd0
# Configure GigabitEthernet 1/0/2 as an access port and assign it to VLAN 2.
[ProviderB] interface GigabitEthernet1/0/2
[ProviderB-GigabitEthernet1/0/2] port access vlan 2
# Configure GigabitEthernet 1/0/2 to transmit BPDUs transparently.
[ProviderB-GigabitEthernet1/0/2] stp disable
[ProviderB-GigabitEthernet1/0/2] undo ntdp enable
[ProviderB-GigabitEthernet1/0/2] bpdu-tunnel dot1q enable
[ProviderB-GigabitEthernet1/0/2] bpdu-tunnel dot1q stp
Complete Configuration
l          Configuration on ProviderA
 port access vlan 2
 stp disable
 undo ntdp enable
l          Configuration on Provider B
 port access vlan 2
 stp disable
 undo ntdp enable
Configuration Guidelines
l          By default, BPDU tunneling is enabeld globally and disabled on ports. To have BPDU tunneling take effect on a port, make sure that BPDU tunneling is enabeld globally. To enable BPDU tunneling globally, use the bpdu-tunnel dot1q enable command.
l          BPDU tunneling is mutually exclusive with GVRP, so these two features cannot be enabled at the same time. For introduction to GVRP, refer to GVRP Configuration Guide.
l          For BPDU tunnel frames to be recognized, the destination multicast MAC addresses configured for BPDU tunneling must be the same on the ingress and egress devices on the service provider network.
