H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
04-Voice VLAN Configuration Guide
Configuring Voice VLAN
The voice VLAN feature is provided to separate voice traffic from data traffic and assign higher priority to voice traffic, thus decreasing voice transmission delay and jitter.
You can assign or remove a port to or from the voice VLAN manually or have the switch do that dynamically by configuring the automatic voice VLAN assignment mode on the port.
On a port configured with the automatic voice VLAN assignment mode, the switch automatically assigns the port to the voice VLAN when receiving a packet with the source MAC address matching a recognizable voice device vendor OUI. As soon as the port is assigned to the voice VLAN, an aging timer starts. If no recognizable voice traffic has been received before the timer expires, the port is removed from the voice VLAN.
Network Diagram
Figure 1-1 Network diagram for automatic voice VLAN assignment configuration
Networking and Configuration Requirements
As shown in Figure 1-1_Ref166924823, PC is connected to GigabitEthernet 1/0/1 of Switch A through IP phone 1, and IP phone 2 is connected to GigabitEthernet 1/0/2 of Switch A. IP phone 1 sends out voice traffic with the tag of the voice VLAN, while IP phone 2 sends out voice traffic without any VLAN tag.
Configure the voice VLAN feature to satisfy the following requirements:
l          Configure VLAN 2 as the voice VLAN, and set the aging time of the voice VLAN to 100 minutes. Use VLAN 6 to transmit user service data.
l          GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 can recognize voice traffic automatically. Service data from PC and voice traffic are assigned to different VLANs and then transmitted to the server and the voice gateway respectively through Switch B.
l          Because the OUI addresses of IP phone 1 and IP phone 2 are not in the default voice device vendor OUI list of the switch, you are required to add their OUI addresses 000f-e200-0000 and 000f-2200-0000 to the OUI list. In addition, configure their descriptions as IP Phone1 and IP Phone2 respectively.
Applicable Product Matrix
Product Series
Software Version
Hardware Version
S3610 series Ethernet switches
Release 5301, Release 5303
All versions
S5510 series Ethernet switches
All versions
S5510-SI series Ethernet switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5510-EI series Ethernet switches
Release 2102
All versions
S7500E series Ethernet switches
Release 6100, Release 6300
All versions
Configuration Procedure
# Create VLAN 2 and VLAN 6.
[SwitchA] vlan 2
[SwitchA-vlan2] quit
[SwitchA] vlan 6
[SwitchA-vlan6] quit
# Set the aging time for the voice VLAN.
[SwitchA] voice vlan aging 100
# Add 000f-e200-0000 to the OUI address list and configure its description as IP Phone1.
[SwitchA] voice vlan mac-address 000f-e200-0000 mask ffff-ff00-0000 description IP Phone1
# Add 000f-2200-0000 to the OUI address list and configure its description as IP Phone2.
[SwitchA] voice vlan mac-address 000f-2200-0000 mask ffff-ff00-0000 description IP Phone2
# Configure VLAN 2 as the voice VLAN.
[SwitchA] voice vlan 2 enable
# Configure the automatic voice VLAN assignment mode on Ethernet 1/0/1. This step is optional, because the mode is enabled by default.
[SwitchA] interface GigabitEthernet 1/0/1
[SwitchA-GigabitEthernet1/0/1] voice vlan mode auto
# Configure Ethernet 1/0/1 as a trunk port.
[SwitchA-GigabitEthernet1/0/1] port link-type trunk
# Configure VLAN 6 as the default VLAN of Ethernet 1/0/1 and configure Ethernet 1/0/1 to permit the packets of VLAN 6 to pass through. (PC data will be transmitted in the VLAN.)
[SwitchA-GigabitEthernet1/0/1] port trunk pvid vlan 6
[SwitchA-GigabitEthernet1/0/1] port trunk permit vlan 6
# Enable voice VLAN on GigabitEthernet 1/0/1.
[SwitchA-GigabitEthernet1/0/1] voice vlan enable
l          After the configuration is completed, PC data will be assigned to VLAN 6 (the data VLAN) on GigabitEthernet 1/0/1 for transmission. When IP phone traffic arrives at GigabitEthernet 1/0/1, the port automatically joins the voice VLAN and transmits the voice traffic with the voice VLAN tag, so that IP phone 1 can receive packets normally.
l          GigabitEthernet 1/0/1 can be a hybrid port. In this case, you can follow the same configuration procedure except that you should set the data VLAN as the default VLAN. When IP phone traffic arrives at the port, the port automatically permits the voice VLAN and transmits the traffic with the voice VLAN tag.
# Set the voice VLAN assignment mode of GigabitEthernet 1/0/2 to manual. The manual mode must be adopted because the voice traffic from IP phone 2 is untagged.
[SwitchA-GigabitEthernet1/0/1] quit
[SwitchA] interface GigabitEthernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] undo voice vlan mode auto
# Configure GigabitEthernet 1/0/2 to be an access port and assign it to the voice VLAN.
[SwitchA-GigabitEthernet1/0/2] port access vlan 2
# Enable voice VLAN on GigabitEthernet 1/0/2.
[SwitchA-GigabitEthernet1/0/2] voice vlan enable
l          You can set GigabitEthernet 1/0/2 as a trunk or hybrid port. In either case, configure the voice VLAN as the default VLAN and configure the port to remove the VLAN tag when forwarding traffic with the voice VLAN tag.
l          If traffic from IP phone 2 is tagged, configure GigabitEthernet 1/0/2 as a trunk or hybrid port and send the packets of VLAN 2 with the VLAN tag.
Complete Configuration
vlan 1 to 2
vlan 6
 port trunk permit vlan 1 6
 voice vlan enable
 port access vlan 2
 voice vlan enable
 voice vlan 2 enable
Configuration Guidelines
By default, the system maintains the OUI list shown in Table 1-1. You can remove or modify these pre-defined OUI addresses as needed.
Table 1-1 Default OUI addresses preconfigured on the switch
No.
OUI Address
Vendor
1
0001-e300-0000
Siemens phones
2
0003-6b00-0000
Cisco phones
3
0004-0d00-0000
Avaya phones
4
00d0-1e00-0000
Pingtel phones
5
0060-b900-0000
Philips/NEC phones
6
00e0-7500-0000
Polycom phones
7
00e0-bb00-0000
3com phones
l          To use a VLAN as a protocol VLAN and the voice VLAN at the same time, ensure that the voice VLAN assignment mode on the port to be associated with the protocol VLAN is not automatic mode. In automatic mode, the port cannot be assigned to the voice VLAN manually and thus can cause your attempt to associate the protocol VLAN with the port to fail.
l          You cannot set the voice VLAN as the default VLAN on a port in automatic voice VLAN assignment mode.
l          The switch supports only one voice VLAN.
l          Only a static VLAN can be configured as the voice VLAN.
l          In the voice VLAN operating in security mode, the device allows only the packets whose source address matches a recognizable voice device vendor OUI to pass through. All other packets, including authentication packets such as 802.1x authentication packets, will be dropped. Therefore, you are discouraged to transmit both voice and data in the voice VLAN at the same time. If that is needed, disable the security mode of the voice VLAN first.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
