H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
37-NQA Configuration Guide
37-NQA Configuration Guide 164.93 KB
NQA Overview
Network Quality Analyzer (NQA) analyzes network performance, services and service quality by sending test packets, and provides you with network performance and service quality parameters such as jitter, TCP connection delay, FTP connection delay and file transfer rate.
With the NQA test results, you can:
1)        Know network performance in time and then take corresponding measures.
2)        Diagnose and locate network faults.
Configuring NQA
ICMP Echo Test Configuration Example
Network diagram
Figure 1-1 ICMP echo test network diagram
Networking and configuration requirements
Use NQA to perform ICMP-echo test to see whether the NQA client (Switch A) can send packets to the specified destination (Switch B) and test the roundtrip time of the packets.
Applicable product matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5510 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100
Release 6300
All versions
Configuration procedure
# Create an ICMP echo test group and configure related test parameters.
[SwitchA] nqa entry admin test
[SwitchA-nqa-admin-test] type icmp-echo
[SwitchA-nqa-admin-test-icmp-echo] destination ip 10.2.2.2
# Configure optional parameters.
[SwitchA-nqa-admin-test-icmp-echo] probe count 10
[SwitchA-nqa-admin-test-icmp-echo] probe timeout 500
[SwitchA-nqa-admin-test-icmp-echo] frequency 5000
[SwitchA-nqa-admin-test-icmp-echo] history-records 10
[SwitchA-nqa-admin-test-icmp-echo] quit
# Start the ICMP echo test operation.
[SwitchA] nqa schedule admin test start-time now lifetime forever
# Stop the ICMP echo test operation after the test begins for a period of time.
[SwitchA] undo nqa schedule admin test
# Display results of the last test in the ICMP echo test.
[SwitchA] display nqa result admin test
  NQA entry(admin admin, tag test) test results:
    Destination IP address: 10.2.2.2
      Send operation times: 10             Receive response times: 10
      Min/Max/Average round trip time: 0/16/1
      Square-Sum of round trip time: 256
      Last succeeded probe time: 2007-08-23 15:00:01.2
    Extend results:
      Packet lost in test: 0%
      Failures due to timeout: 0
      Failures due to disconnect: 0
      Failures due to no connection: 0
      Failures due to sequence error: 0
      Failures due to internal error: 0
      Failures due to other errors: 0
# Display the history of the ICMP echo test.
[SwitchA] display nqa history admin test
  NQA entry(admin admin, tag test) history record(s):
    Index      Response     Status           Time
    370        3            Succeeded        2007-08-23 15:00:01.2
    369        3            Succeeded        2007-08-23 15:00:01.2
    368        3            Succeeded        2007-08-23 15:00:01.2
    367        5            Succeeded        2007-08-23 15:00:01.2
    366        3            Succeeded        2007-08-23 15:00:01.2
    365        3            Succeeded        2007-08-23 15:00:01.2
    364        3            Succeeded        2007-08-23 15:00:01.1
    363        2            Succeeded        2007-08-23 15:00:01.1
    362        3            Succeeded        2007-08-23 15:00:01.1
    361        2            Succeeded        2007-08-23 15:00:01.1
Complete configuration
l          Configuration on Switch A
 type icmp-echo
  probe count 10
  probe timeout 500
  frequency 5000
  history-records 10
Configuration guidelines
Configuration of the end time of an NQA test is not supported on the device, and you need to use the undo nqa schedule command to end an NQA test.
DHCP Test Configuration Example
Network diagram
Figure 1-2 DHCP test network diagram
Use the DHCP function to test the time necessary for Switch A to obtain an IP address from the DHCP server Switch B.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
# Create a DHCP NQA test group and configure related test parameters.
[SwitchA-nqa-admin-test] type dhcp
[SwitchA-nqa-admin-test-dhcp] operation interface vlan-interface 2
[SwitchA-nqa-admin-test-dhcp] quit
# Start the DHCP test operation.
# Stop the DHCP test operation after the test begins for a period of time.
# Display results of the last test in the DHCP test.
      Send operation times: 1              Receive response times: 1
      Min/Max/Average round trip time: 624/624/624
      Square-Sum of round trip time: 389376
      Last succeeded probe time: 2007-11-22 09:56:03.2
    Extend results:
# Display the history of the DHCP test.
    1          624          Succeeded        2007-11-22 09:56:03.2
 type dhcp
  operation interface Vlan-interface2
FTP Test Configuration Example
Network diagram
Figure 1-3 FTP test network diagram
Use the FTP function on Switch A to test the connection with a specified FTP server and the time necessary for Switch A to upload a file to the FTP server. The login username is admin, the login password is systemtest, and the file to be transferred to the FTP server is config.txt.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
# Create an FTP NQA test group and configure related test parameters.
[SwitchA-nqa-admin-test] type ftp
[SwitchA-nqa-admin-test-ftp] destination ip 10.2.2.2
[SwitchA-nqa-admin-test-ftp] source ip 10.1.1.1
[SwitchA-nqa-admin-test-ftp] operation put
[SwitchA-nqa-admin-test-ftp] username admin
[SwitchA-nqa-admin-test-ftp] password systemtest
[SwitchA-nqa-admin-test-ftp] filename config.txt
[SwitchA-nqa-admin-test-ftp] quit
# Start the FTP test operation.
# Stop the FTP test operation after the test begins for a period of time.
# Display results of the last test in the FTP test.
      Min/Max/Average round trip time: 173/173/173
      Square-Sum of round trip time: 29929
      Last succeeded probe time: 2007-11-22 10:07:28.6
    Extend results:
# Display the history of the FTP test.
    1           173          Succeeded        2007-11-22 10:07:28.6
 type ftp
  filename config.txt
  operation put
  password systemtest
  source ip 10.1.1.1
  username admin
HTTP Test Configuration Example
Network diagram
Figure 1-4 HTTP test network diagram
Use the HTTP function on Switch A to test the connection with a specified HTTP server and the time required to obtain data from the HTTP server.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
# Create an HTTP NQA test group and configure related test parameters.
[SwitchA-nqa-admin-test] type http
[SwitchA-nqa-admin-test-http] destination ip 10.2.2.2
[SwitchA-nqa-admin-test-http] operation get
[SwitchA-nqa-admin-test-http] url /index.htm
[SwitchA-nqa-admin-test-http] http-version v1.0
[SwitchA-nqa- admin-test-http] quit
# Start the HTTP test operation.
# Stop the HTTP test operation after the test begins for a period of time.
# Display results of the last test in the HTTP test.
      Min/Max/Average round trip time: 64/64/64
      Square-Sum of round trip time: 4096
      Last succeeded probe time: 2007-11-22 10:12:47.9
    Extend results:
# Display the history of the HTTP test.
    1          64           Succeeded        2007-11-22 10:12:47.9
 type http
  url /index.htm
UDP Jitter Test Configuration Example
Network diagram
Figure 1-5 UDP jitter test network diagram
Use the UDP jitter function to test the delay jitter of packet transmission between Switch A and Switch B.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
1)        Configure Switch B.
# Enable the NQA server and configure the listening IP address as 10.2.2.2 and port number as 9000.
[SwitchB] nqa server enable
[SwitchB] nqa server udp-echo 10.2.2.2 9000
2)        Configure Switch A.
# Create a UDP jitter NQA test group and configure related test parameters.
[SwitchA-nqa-admin-test] type udp-jitter
[SwitchA-nqa-admin-test-udp-jitter] destination ip 10.2.2.2
[SwitchA-nqa-admin-test-udp-jitter] destination port 9000
[SwitchA-nqa-admin-test-udp-jitter] quit
# Start the UDP jitter test operation.
# Stop the UDP jitter test operation after the test begins for a period of time.
# Display results of the last test in the UDP jitter test.
      Min/Max/Average round trip time: 7/10/8
      Square-Sum of round trip time: 646
      Last succeeded probe time: 2007-11-22 10:16:49.0
    Extend results:
    UDP-jitter results:
     RTT number: 10
      SD max delay: 5                        DS max delay: 5
      Min positive SD: 1                     Min positive DS: 0
      Max positive SD: 1                     Max positive DS: 0
      Positive SD number: 2                  Positive DS number: 0
      Positive SD sum: 2                     Positive DS sum: 0
      Positive SD average: 1                 Positive DS average: 0
      Positive SD square sum: 2              Positive DS square sum: 0
      Min negative SD: 1                     Min negative DS: 0
      Max negative SD: 2                     Max negative DS: 0
      Negative SD number: 3                  Negative DS number: 0
      Negative SD sum: 4                     Negative DS sum: 0
      Negative SD average: 1                 Negative DS average: 0
      Negative SD square sum: 6              Negative DS square sum: 0
      SD lost packet(s): 0                   DS lost packet(s): 0
      Lost packet(s) for unknown reason: 0
In a UDP jitter test, a group of probe packets are sent in a probe, and this group of packets corresponds to one history record. Therefore, to know the results of a UDP jitter test, you are recommended to use the display nqa result command to view the probe results, rather than the display nqa history command to view the history record.
l          Configuration on Switch B
 nqa server enable
 type udp-jitter
SNMP Test Configuration Example
Network diagram
Figure 1-6 SNMP test network diagram
Use the SNMP query function to test the time it takes for Switch A to send an SNMP query packet to the SNMP agent (Switch B) and receive a response packet.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
1)        Configurations on SNMP Agent.
# Enable the SNMP agent service and set the SNMP version to all, the read community to public, and the write community to private.
[SwitchB] snmp-agent sys-info version all
[SwitchB] snmp-agent community read public
[SwitchB] snmp-agent community write private
2)        Configurations on Switch A.
# Create an SNMP query test group and configure related test parameters.
[SwitchA-nqa-admin-test] type snmp
[SwitchA-nqa-admin-test-snmp] destination ip 10.2.2.2
[SwitchA-nqa-admin-test-snmp] quit
# Start the SNMP test operation.
# Stop the SNMP test operation after the test begins for a period of time.
# Display results of the last test in the SNMP test.
      Min/Max/Average round trip time: 50/50/50
      Square-Sum of round trip time: 2500
      Last succeeded probe time: 2007-11-22 10:24:41.1
    Extend results:
# Display the history of the SNMP test.
    1          50           Timeout          2007-11-22 10:24:41.1
 type snmp
 snmp-agent
 snmp-agent local-engineid 800063A20300E0FC123456
TCP Test Configuration Example
Network diagram
Figure 1-7 TCP test network diagram
Use the TCP function to test the time for establishing a TCP connection between Switch A and Switch B. The port number used is 9000.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
[SwitchB] nqa server tcp-connect 10.2.2.2 9000
# Create a TCP NQA test group and configure related test parameters.
[SwitchA-nqa-admin-test] type tcp
[SwitchA-nqa-admin-test-tcp] destination ip 10.2.2.2
[SwitchA-nqa-admin-test-tcp] destination port 9000
[SwitchA-nqa-admin-test-tcp] quit
# Start the TCP test operation.
# Stop the TCP test operation after the test begins for a period of time.
# Display results of the last test in the TCP test.
      Min/Max/Average round trip time: 13/13/13
      Square-Sum of round trip time: 169
      Last succeeded probe time: 2007-11-22 10:27:25.1
    Extend results:
# Display the history of the TCP test.
    1          13             Succeeded        2007-11-22 10:27:25.1
 nqa server enable
 type tcp
UDP Echo Test Configuration Example
Network diagram
Figure 1-8 UDP echo test network diagram
Use the UDP echo function to test the round trip time of UDP packets between Switch A and Switch B. The port number is 8000.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
# Enable the NQA server and configure the listening IP address as 10.2.2.2 and port number as 8000.
[SwitchB] nqa server udp-echo 10.2.2.2 8000
# Create a UDP echo test group and configure related test parameters.
[SwitchA-nqa-admin-test] type udp-echo
[SwitchA-nqa-admin-test-udp-echo] destination ip 10.2.2.2
[SwitchA-nqa-admin-test-udp-echo] destination port 8000
[SwitchA-nqa-admin-test-udp-echo] quit
# Start the UDP echo test operation.
# Stop the UDP echo test operation after the test begins for a period of time.
# Display results of the last test in the UDP echo test.
      Min/Max/Average round trip time: 25/25/25
      Square-Sum of round trip time: 625
      Last succeeded probe time: 2007-11-22 10:36:17.9
    Extend results:
# Display the history of the UDP echo test.
    1           25            Succeeded        2007-11-22 10:36:17.9
 nqa server enable
 type udp-echo
