H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
34-DNS Configuration Guide
34-DNS Configuration Guide 89.49 KB
Configuring Static Domain Name Resolution
The static domain name resolution means setting up mappings between domain names and IP addresses. IP addresses of the corresponding domain names can be found in the static domain resolution table when you use applications such as telnet.
Network diagram
Figure 1-1 Network diagram for static domain name resolution
Networking and Configuration Requirements
Switch uses the static domain name resolution to access Host with IP address 10.1.1.2 through domain name host.com.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5510 Series Ethernet Switches
Release 5301
Release 5303
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except
S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100
Release 6300
All versions
S3500-EA Series Ethernet Switches
Release 5303
All versions
Configuration procedure
# Configure a mapping between host name host.com and IP address 10.1.1.2.
[Sysname] ip host host.com 10.1.1.2
# Execute the ping host.com command to verify that Switch can use the static domain name resolution to get the IP address 10.1.1.2 corresponding to host.com.
 [Sysname] ping host.com
  PING host.com (10.1.1.2):
  56  data bytes, press CTRL_C to break
    Reply from 10.1.1.2: bytes=56 Sequence=1 ttl=128 time=2 ms
    Reply from 10.1.1.2: bytes=56 Sequence=2 ttl=128 time=2 ms
    Reply from 10.1.1.2: bytes=56 Sequence=3 ttl=128 time=2 ms
    Reply from 10.1.1.2: bytes=56 Sequence=4 ttl=128 time=2 ms
    Reply from 10.1.1.2: bytes=56 Sequence=5 ttl=128 time=2 ms
  --- host.com ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 2/2/2 ms
Complete Configuration
Configuration Guidelines
None
Configuring Dynamic Domain Name Resolution
Domain Name System (DNS) is a distributed database used by TCP/IP applications to translate domain names into corresponding IP addresses. With DNS, you can use easy-to-remember domain names in some applications and let the DNS server translate them into correct IP addresses.
Network diagram
Figure 1-2 Network diagram for dynamic domain name resolution
l          The IP address of the DNS server is 2.1.1.2/16 and the name suffix is com.
l          Switch serves as a DNS client, and uses the dynamic domain name resolution and the suffix to access the host with the domain name host.com and the IP address 3.1.1.1/16.
Product series
Software version
Hardware version
Release 5301
Release 5303
All versions
Release 5301
Release 5303
All versions
Release 1207
All versions except
S5500-20TP-SI
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
Release 5303
All versions
# Enable dynamic domain name resolution.
[Sysname] dns resolve
# Specify the DNS server 2.1.1.2.
[Sysname] dns server 2.1.1.2
# Configure com as the name suffix.
[Sysname] dns domain com
# Execute the ping host command on the device to verify that the communication between the device and the host is normal and that the corresponding destination IP address is 3.1.1.1.
[Sysname] ping host
Trying DNS resolve, press CTRL_C to break
 Trying DNS server (2.1.1.2)
  PING host.com (3.1.1.1):
    Reply from 3.1.1.1: bytes=56 Sequence=1 ttl=126 time=3 ms
    Reply from 3.1.1.1: bytes=56 Sequence=2 ttl=126 time=1 ms
    Reply from 3.1.1.1: bytes=56 Sequence=3 ttl=126 time=1 ms
    Reply from 3.1.1.1: bytes=56 Sequence=4 ttl=126 time=1 ms
    Reply from 3.1.1.1: bytes=56 Sequence=5 ttl=126 time=1 ms
    0.00% packet loss
    round-trip min/avg/max = 1/1/3 ms
 dns resolve
 dns server 2.1.1.2
 dns domain com
l          Before performing the above configuration, assume that the switch and the host are reachable to each other and the IP addresses of the interfaces are configured.
l          The DNS client needs to cooperate with the DNS server to obtain a correct IP address through domain name resolution.
Configuring DNS Proxy
A DNS proxy forwards DNS requests and replies between DNS clients and a DNS server.
A DNS client sends a DNS request to the DNS proxy, which forwards the request to the designated DNS server, and conveys the reply from the DNS server to the client.
The DNS proxy simplifies network management. When the DNS server address is changed, you only need to change the configuration on the DNS proxy instead of on each DNS client.
Network diagram
Figure 1-3 Network diagram for DNS proxy
l          Specify Switch A as the DNS server of Switch B (the DNS client).
l          Switch A acts as a DNS proxy. The IP address of the real DNS server is 4.1.1.1.
l          Switch B implements domain name resolution through Switch A.
Product series
Software version
Hardware version
Release 1207
All versions except
S5500-20TP-SI
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6100
Release 6300
All versions
1)        Configure the DNS proxy
# Specify the DNS server 4.1.1.1.
[SwitchA] dns server 4.1.1.1
# Enable DNS proxy.
[SwitchA] dns proxy enable
2)        Configure the DNS client
# Enable the domain name resolution function.
[SwitchB] dns resolve
[SwitchB] dns server 2.1.1.2
3)        Configuration verification
# Execute the ping host.com command on Switch B to verify that the communication between the device and the host is normal and that the corresponding destination IP address is 3.1.1.1.
[SwitchB] ping host.com
    0.00% packet loss
l          Configure Switch A (DNS proxy)
 dns proxy enable
 dns server 4.1.1.1
l          Configure Switch B (DNS client)
 dns resolve
 dns server 2.1.1.2
l          Before performing the above configuration, make sure that the switch and the host are reachable to each other and the IP addresses of the interfaces are configured.
l          The DNS client needs to contact the DNS server to obtain a correct IP address through domain name resolution.
