H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
09-MAC Address Table Management Configuration Guide
Configuring MAC Address Table Management
Network Diagram
Figure 1-1 Network diagram for MAC address table management
Networking and Configuration Requirements
Server is connected to Switch through port GigabitEthernet 1/0/2. Configure a static MAC address entry of Server on Switch, so that Switch always unicasts rather than broadcasts packets destined for Server through GigabitEthernet 1/0/2. Port GigabitEthernet 1/0/10 is connected with a network management server (NMS). For network management security, configure GigabitEthernet 1/0/10 to permit the access of this NMS only.
l          The MAC address of Server is 000f-e20f-dc71
l          Port GigabitEthernet 1/0/2, GigabitEthernet 1/0/5, and GigabitEthernet 1/0/10 belong to VLAN 10
l          The MAC address of NMS is 0014-222c-aa69
l          Set the aging time of MAC address entries on Switch to 500 seconds
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301, Release 5303
All versions
S5510 Series Ethernet Switches
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100, Release 6300
All versions
Configuration Procedure
# Create VLAN 10, and add ports GigabitEthernet 1/0/2, GigabitEthernet 1/0/5, and GigabitEthernet 1/0/10 to VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] port GigabitEthernet1/0/2 GigabitEthernet1/0/5 GigabitEthernet1/0/10
# Add a static MAC address entry.
[Sysname] mac-address static 000f-e20f-dc71 interface GigabitEthernet 1/0/2 vlan 10
# Set the aging time of dynamic MAC address entries on Switch to 500 seconds.
# Display the configuration of MAC address table in system view.
[Sysname] display mac-address interface GigabitEthernet 1/0/2
MAC ADDR          VLAN ID   STATE            PORT INDEX              AGING TIME(s)
000f-e20f-dc71  1          Config static  GigabitEthernet1/0/2  NOAGED
00e0-fc17-a7d6  1          Learned         GigabitEthernet1/0/2  AGING
00e0-fc5e-b1fb  1          Learned         GigabitEthernet1/0/2  AGING
00e0-fc55-f116  1          Learned         GigabitEthernet1/0/2  AGING
---  4 mac address(es) found on port GigabitEthernet1/0/2 ---
# Set the MAC learning limit to 0 on GigabitEthernet 1/0/10, and add a static MAC address entry for the port, so that port GigabitEthernet 1/0/10 can forward only the packets sent by NMS, and other hosts cannot communicate through this port.
[Sysname] interface GigabitEthernet 1/0/10
[Sysname-GigabitEthernet1/0/10] port access vlan 10
[Sysname-GigabitEthernet1/0/10] mac-address max-mac-count 0
[Sysname-GigabitEthernet1/0/10] mac-address static 0014-222c-aa69 vlan 10
# Disable GigabitEthernet 1/0/10 from forward frames whose source MAC addresses are not in the MAC address table when the MAC learning limit is reached. Ethernet switches of the S3610, S5510, and S3500-EA series support this operation.
[Sysname-GigabitEthernet1/0/10] mac-address max-mac-count disable-forwarding
Complete Configuration
vlan 10
 port access vlan 10
 mac-address static 000f-e20f-dc71 vlan 10
interface GigabitEthernet1/0/5
 port access vlan 10
interface GigabitEthernet1/0/10
 port access vlan 10
Configuration Guidelines
l          You cannot configure a static or dynamic MAC address entry on an aggregate port of any device of any version, except for Release 6300 of the S7500 series Ethernet switches.
l          The MAC address aging timer setting takes effect on all ports. It affects only dynamic MAC address entries including those learned by the device and manually configured as dynamic entries.
l          Ethernet switches of the S5500-SI, S5500-EI, and S7500E series do not support the disable-forwarding keyword in the mac-address max-mac-count command. When the MAC learning limit is reached, the port does not forward frames whose source MAC addresses are not in the MAC address table.
