H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
43-MCE Configuration Guide
43-MCE Configuration Guide 248.2 KB
Configuring MCE (Redistributing VPN Routes by OSPF/RIP/IS-IS)
Network Diagram
Figure 1-1 Network diagram for MCE configuration (redistributing VPN routes by OSPF/RIP/IS-IS)
Networking and Configuration Requirements
l          An MCE device connects to VPN 1 through VLAN-interface 10, connects to VPN 2 through VLAN-interface 20, and connects to VPN 3 through VLAN-interface 30.
l          Site 1 runs no routing protocol; Site 2 runs RIP; Site 3 runs OSPF.
l          It is required that the MCE device isolate routes between VPNs and advertise all the VPN routes to the PE device using OSPF.
l          The procedure of configuring the advertising of VPN routes to the PE device using RIP or IS-IS are different from that of configuring the advertising of VPN routes to the PE device using OSPF in only the configurations described in Perform routing configuration between MCE and PE 1.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301, Release 5303
All versions
S5510 Series Ethernet Switches
All versions
S7500E Series Ethernet Switches
Release 6100
LSQ1SRP1CB SRPU(s), or exclusively EA series LPUs
Release 6300
All versions
Configuration Procedure
l          To distinguish devices, assume that the system name of the MCE device is MCE, the name of the egress router of VPN 1, VPN 2 and VPN 3 is VR1, VR2, and VR3 respectively, and the system name of the PE 1 is PE1.
l          This example assumes that VR 1, VR 2, VR 3, and PE 1 are all H3C devices. For configuration commands on devices of other vendors, refer to the relevant user manuals.
1)        Configure VPN instances on MCE, and associate the VPN instances with interfaces.
# Configure the MCE device to work in MCE mode and reboot the device.
<MCE> system-view
[MCE] switch-mode mce
[MCE] quit
<MCE> reboot
When configuring MCE for an S7500E series switch, you do not need to configure the switch-mode mce command and reboot the device.
# Configure VPN instances VPN 1, VPN 2 and VPN 3 on the MCE device, setting the RD values to 10:1, 20:1 and 30:1, respectively.
<MCE> system-view
[MCE] ip vpn-instance vpn1
[MCE-vpn-instance-vpn1] route-distinguisher 10:1
[MCE-vpn-instance-vpn1] quit
[MCE] ip vpn-instance vpn2
[MCE-vpn-instance-vpn2] route-distinguisher 20:1
[MCE-vpn-instance-vpn2] quit
[MCE] ip vpn-instance vpn3
[MCE-vpn-instance-vpn3] route-distinguisher 30:1
# Create VLAN 10, add port Ethernet 1/0/10 to VLAN 10, and create VLAN-interface 10.
[MCE-vpn-instance-vpn3] quit
[MCE] vlan 10
[MCE-vlan10] port Ethernet 1/0/10
[MCE-vlan10] quit
[MCE] interface Vlan-interface 10
# Bind VLAN-interface 10 to instance VPN 1, and assign IP address 10.214.10.3/24 to VLAN-interface 10.
[MCE-Vlan-interface10] ip binding vpn-instance vpn1
[MCE-Vlan-interface10] ip address 10.214.10.3 24
[MCE-Vlan-interface10] quit
# Create VLAN 20, add port Ethernet 1/0/20 to VLAN 20, and then create VLAN-interface 20, bind VLAN-interface 20 to instance VPN 2, and assign IP address 10.214.20.3/24 to VLAN-interface 20.
[MCE] vlan 20
[MCE-vlan20] port Ethernet 1/0/20
[MCE-vlan20] quit
[MCE] interface Vlan-interface 20
[MCE-Vlan-interface20] ip binding vpn-instance vpn2
[MCE-Vlan-interface20] ip address 10.214.20.3 24
[MCE-Vlan-interface20] quit
# Create VLAN 30, add port Ethernet 1/0/15 to VLAN 30, and then create VLAN-interface 30, bind VLAN-interface 30 to instance VPN 3, and assign IP address 10.214.30.3/24 to VLAN-interface 30.
[MCE] vlan 30
[MCE-vlan30] port Ethernet 1/0/15
[MCE-vlan30] quit
[MCE] interface Vlan-interface 30
[MCE-Vlan-interface30] ip binding vpn-instance vpn3
[MCE-Vlan-interface30] ip address 10.214.30.3 24
[MCE-Vlan-interface30] quit
2)        Perform routing configuration between MCE and Site 1
As Site 1 is directly connected to MCE and runs no routing protocol, you can configure a static route between them.
l          Configuration on VR 1
# Create a VLAN, add the port connecting to MCE to the VLAN, create a VLAN-interface, and then assign IP address 10.214.10.2/24 to the interface. In addition, assign IP address 192.168.0.1/24 to the interface connecting to Site 1. The detailed configuration steps are similar to those for MCE and are therefore omitted.
# Configure a default route, specifying the next hop address as 10.214.10.3.
<VR1> system-view
[VR1] ip route-static 0.0.0.0 0.0.0.0 10.214.10.3
l          Configuration on MCE
# Define a static route to network segment 192.168.0.0, specifying the next hop address as 10.214.10.2 and binding the route to instance VPN 1.
[MCE] ip route-static vpn-instance vpn1 192.168.0.0 16 10.214.10.2
# Display the routing information of instance VPN 1.
[MCE] display ip routing-table vpn-instance vpn1
Routing Tables: vpn1
         Destinations : 5        Routes : 5
127.0.0.0/8         Direct 0     0            127.0.0.1       InLoop0
127.0.0.1/32        Direct 0     0            127.0.0.1       InLoop0
10.214.10.0/24      Direct 0       0            10.214.10.3     Vlan10
10.214.10.3/32      Direct 0       0            127.0.0.1       InLoop0
192.168.0.0/16     Static 60  0            10.214.10.2     Vlan10
As shown in the output information above, a static route has been installed for Site 1.
3)        Perform routing configuration between MCE and Site 2
l          Configuration on VR 2
# Assign IP address 10.214.20.2/24 to the interface connecting to MCE. (Omitted)
# Configure RIP and advertise network segments 192.168.10.0 and 10.214.20.0.
<VR2> system-view
[VR2] rip 20
[VR2-rip-20] network 192.168.10.0
[VR2-rip-20] network 10.0.0.0
As Site 2 runs RIP, you can configure RIP on MCE, so that MCE can update the routing information of the VPN instance for Site 2 automatically.
# Create RIP process 20 and bind it to instance VPN 2.
[MCE] rip 20 vpn-instance vpn2
# Advertise the network segment 10.214.10.0, disable automatic route summarization, and redistribute the routing information of OSPF process 20. Note that, when the routing protocol between the MCE and the PE is RIP or IS-IS, you need to change the ospf keyword in the import-route command to rip or isis.
[MCE-rip-20] network 10.0.0.0
[MCE-rip-20] undo summary
[MCE-rip-20] import-route ospf
# Display the routing information of instance VPN 2.
[MCE-rip-20] display ip routing-table vpn-instance vpn2
Routing Tables: vpn2
10.214.20.0/24      Direct 0    0            10.214.20.3     Vlan20
10.214.20.3/32      Direct 0    0            127.0.0.1       InLoop0
192.168.10.0/24     RIP    100  1            10.214.20.2     Vlan20
As shown in the output information above, MCE has learnt a private route of Site 2 through RIP, which is maintained in a routing table different from that of Site 1. This achieves the isolation of routes of different VPNs.
4)        Perform routing configuration between MCE and Site 3
l          Configuration on VR 3
# Assign IP address 10.214.30.2/24 to the interface connecting to MCE. (Omitted)
# Create OSPF process 30 and advertise network segments 192.168.20.0 and 10.214.30.0.
<VR3> system-view
[VR3] ospf 30
[VR3-ospf-30] area 0
[VR3-ospf-30-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[VR3-ospf-30-area-0.0.0.0] network 10.214.30.0 0.0.0.255
As Site 3 runs OSPF, you can configure OSPF on MCE, so that MCE can update the routing computation of VPN instance for Site 3 automatically.
# Configure interface Loopback 0 on MCE to specify the router ID for MCE. Assign IP address 101.101.10.1 to the interface. (Omitted)
# Create OSPF process 30, binding it to instance VPN 3, configure OSPF multi-instance (not required when only one OSPF process exists on the MCE), and advertise network segment 10.214.30.0. Note that, when RIP or IS-IS is used as the routing protocol between MCE and PE, you need not configure OSPF multi-instance.
<MCE> system-view
[MCE] ospf 30 router id 101.101.10.1 vpn-instance vpn3
[MCE-ospf-30] vpn-instance-capability simple
[MCE-ospf-30] area 0
[MCE-ospf-30-area-0.0.0.0] network 10.214.30.0 0.0.0.255
# Display the routing information of instance VPN 3.
[MCE-ospf-30-area-0.0.0.0] display ip routing-table vpn-instance vpn3
Routing Tables: vpn3
10.214.30.0/24      Direct 0    0            10.214.30.3     Vlan30
10.214.30.3/32      Direct 0    0            127.0.0.1       InLoop0
192.168.20.0/24      OSPF   10   2            10.214.30.2     Vlan30
As shown in the above output, MCE has learnt a private route of Site 3 through OSPF.
5)        Perform routing configuration between MCE and PE 1
# Configure port GigabitEthernet 1/1/1 of MCE as a trunk port and specify it to permit tagged packets of VLAN 10, VLAN 20, and VLAN 30.
[MCE] interface GigabitEthernet 1/1/1
[MCE-GigabitEthernet1/1/1] port link-type trunk
[MCE-GigabitEthernet1/1/1] port trunk permit vlan 10 20 30
# Create OSPF process 10, binding the process to instance VPN 1, and set the OSPF domain ID to 10. Advertise the network segment 10.214.10.0 within Area 0, and redistribute static routes of VPN 1.
[MCE-GigabitEthernet1/1/1] quit
[MCE] ospf 10 router-id 101.101.10.1 vpn-instance vpn1
[MCE-ospf-10] domain-id 10
[MCE-ospf-10] area 0
[MCE-ospf-10-area-0.0.0.0] network 10.214.10.0 0.0.0.255
[MCE-ospf-10-area-0.0.0.0] quit
[MCE-ospf-10] import-route static
[MCE-ospf-10] quit
# Create OSPF process 20, binding the process to instance VPN 2, and set the OSPF domain ID to 20. Advertise the network segment 10.214.20.0 within Area 0, and redistribute static routes of VPN 2.
[MCE] ospf 20 router-id 101.101.10.1 vpn-instance vpn2
[MCE-ospf-20] domain-id 20
[MCE-ospf-20] area 0
[MCE-ospf-20-area-0.0.0.0] network 10.214.20.0 0.0.0.255
[MCE-ospf-20-area-0.0.0.0] quit
[MCE-ospf-20] import-route rip
# Create OSPF process 30, binding the process to instance VPN 3, and set the OSPF domain ID to 30. Advertise the network segment 10.214.30.0 within Area 0
[MCE] ospf 30 router-id 101.101.10.1 vpn-instance vpn3
[MCE-ospf-30] domain-id 30
[MCE-ospf-30-area-0.0.0.0] quit
l          Configuration on PE 1
# Configure GigabitEthernet 1/0/18 of PE 1 as a trunk port and configure it to allow tagged packets of VLAN 10, VLAN 20 and VLAN 30.
<PE> system-view
[PE] interface GigabitEthernet 1/0/18
[PE-GigabitEthernet1/0/18] port link-type trunk
[PE-GigabitEthernet1/0/18] port trunk permit vlan 10 20 30
# Configure interface VLAN-interface 10, VLAN-interface 20 and VLAN-interface 30, assign IP addresses 10.214.10.4, 10.214.20.4 and 10.214.30.4 to them respectively, and bind them to instances VPN 1, VPN 2, and VPN 3 respectively. (Omitted)
# Configure Loopback 0 on PE 1 to specify the router ID for PE 1. The IP address for Loopback 0 of PE 1 is 100.100.10.1. (Omitted)
# Create OSPF process 10, binding the process to instance VPN 1, set the OSPF domain ID to 10, and advertise the network segment 10.214.10.0 within Area 0.
[PE-Ethernet1/0/18] quit
[PE] ospf 10 router-id 100.100.10.1 vpn-instance vpn1
[PE-ospf-10] domain-id 10
[PE-ospf-10] area 0
[PE-ospf-10-area-0.0.0.0] network 10.214.10.0 0.0.0.255
# Create OSPF process 20 and 30, binding them to instance VPN 2 and VPN 3 respectively, set the OSPF domain ID to 20 and 30, and advertise the network segment 10.214.20.0 and 10.214.30.0 within Area 0 respectively. (Omitted)
# Display the routing information of VPN 1.
[PE-ospf-10-area-0.0.0.0] display ip routing-table vpn-instance vpn1
         Destinations : 6        Routes : 6
10.214.10.0/24      Direct 0    0            10.214.10.4     Vlan10
10.214.10.4/32      Direct 0    0            127.0.0.1       InLoop0
100.100.10.1/32     Direct 0    0            127.0.0.1       InLoop0
192.168.0.0/16      O_ASE  150  1            10.214.10.2     Vlan10
As shown in the output information above, the static route of Site 1 has been redistributed to the routing table of OSPF process 10 on PE 1.
# Display the routing information of VPN 2.
<PE> display ip routing-table vpn-instance vpn2
10.214.20.0/24      Direct 0    0            10.214.20.4     Vlan20
10.214.20.4/32      Direct 0    0            127.0.0.1       InLoop0
200.200.20.1/32     Direct 0    0            127.0.0.1       InLoop0
192.168.10.0/24     O_ASE  150  1            10.214.20.2     Vlan20
# Display the routing information of VPN 3.
<PE> display ip routing-table vpn-instance vpn3
10.214.30.0/24      Direct 0    0            10.214.30.4     Vlan30
10.214.30.4/32      Direct 0    0            127.0.0.1       InLoop0
200.200.30.3/32     Direct 0    0            127.0.0.1       InLoop0
192.168.20.0/24     OSPF    10  1            10.214.30.2     Vlan30
After the above configurations, the routing information of VPN 1, VPN 2 and VPN 3 can be advertised to PE 1 properly.
When RIP is used as the routing protocol between the MCE and PE, the configuration procedure is as follows:
# Connect GigabitEthernet 1/1/1 of MCE to GigabitEthernet 1/0/18 of PE 1, and configure GigabitEthernet 1/1/1 of MCE as a trunk port and specify it to permit tagged packets of VLAN 10, VLAN 20, and VLAN 30.
# Create RIP process 10, binding the process to instance VPN 1, advertise the network segment 10.214.10.0, and redistribute static routes of VPN 1.
[MCE] rip 10 vpn-instance vpn1
[MCE-rip-10] network 10.0.0.0
[MCE-rip-10] import-route static
[MCE-rip-10] quit
# Create RIP process 20, binding the process to instance VPN 2, and advertise the network segment 10.214.20.0.
[MCE-rip-20] quit
# Create RIP process 30, binding the process to instance VPN 3, advertise the network segment 10.214.30.0, and redistribute ospf routes of VPN 2.
[MCE] rip 30 vpn-instance vpn3
[MCE-rip-30] network 10.0.0.0
[MCE-rip-30] import-route ospf
[MCE-rip-30] quit
<PE1> system-view
[PE1] interface GigabitEthernet 1/0/18
[PE1-GigabitEthernet1/0/18] port link-type trunk
[PE1-GigabitEthernet1/0/18] port trunk permit vlan 10 20 30
[PE1-GigabitEthernet1/0/18] quit
# Configure interfaces VLAN-interface 10, VLAN-interface 20 and VLAN-interface 30, assign IP addresses 10.214.10.4, 10.214.20.4 and 10.214.30.4 to them respectively, and bind them to instances VPN 1, VPN 2, and VPN 3 respectively. (Omitted)
# Create RIP process 10, binding the process to instance VPN 1, set the RIP domain ID to 10, and advertise the network segment 10.214.10.0.
[PE1] rip 10 vpn-instance vpn1
[PE1-rip-10] network 10.0.0.0
# Create RIP processes 20 and 30, binding them to instance VPN 2 and VPN 3 respectively, and advertise network segments 10.214.20.0 and 10.214.30.0 respectively. (Omitted)
When IS-IS is used as the routing protocol between the MCE and PE, the configuration procedure is as follows:
# Connect GigabitEthernet 1/1/1 of MCE to GigabitEthernet 1/0/18 of PE 1, configure GigabitEthernet 1/1/1 of MCE as a trunk port, and specify it to permit tagged packets of VLAN 10, VLAN 20, and VLAN 30.
# Create IS-IS process 10, binding the process to instance VPN 1; set the network entity name to 10.0000.0000.0001.00 and the route type to level-1-2; enable IS-IS process 10 on Vlan-interface 10, and redistribute static routes of VPN 1.
[MCE] isis 10 vpn-instance vpn1
[MCE-isis-10] network-entity 10.0000.0000.0001.00
[MCE-isis-10] is-level level-1-2
[MCE-isis-10] import-route static level-1-2
[MCE-isis-10] quit
[MCE-vpn-instance-vpn10] isis enable 10
[MCE-vpn-instance-vpn10] quit
# Create IS-IS process 20, binding the process to instance VPN 2; set the network entity name to 10.0000.0000.0002.00 and the route type to level-1-2; enable IS-IS process 20 on Vlan-interface 20, and redistribute rip routes of VPN 2.
[MCE] isis 20 vpn-instance vpn2
[MCE-isis-20] network-entity 10.0000.0000.0002.00
[MCE-isis-20] is-level level-1-2
[MCE-isis-20] import-route rip level-1-2
[MCE-isis-20] quit
[MCE-vpn-instance-vpn20] isis enable 20
[MCE-vpn-instance-vpn20] quit
# Create IS-IS process 30, binding the process to instance VPN 3; set the network entity name to 10.0000.0000.0003.00 and the route type to level-1-2; enable IS-IS process 30 on Vlan-interface 30, and redistribute ospf routes of VPN 3.
[MCE] isis 30 vpn-instance vpn3
[MCE-isis-30] network-entity 10.0000.0000.0003.00
[MCE-isis-30] is-level level-1-2
[MCE-isis-30] import-route ospf level-1-2
[MCE-isis-30] quit
[MCE-vpn-instance-vpn30] isis enable 30
[MCE-vpn-instance-vpn30] quit
<PE1> system-view
# Create IS-IS process 10, binding the process to instance VPN 1, set the network entity name to 10.0000.0000.0004.00 and the route type to level-1-2; enable IS-IS process 10 on Vlan-interface 10.
[PE1] isis 10 vpn-instance vpn1
[PE1-isis-30] network-entity 10.0000.0000.0004.00
[PE1-isis-30] is-level level-1-2
[PE1-isis-30] quit
[PE1] interface Vlan-interface 10
[PE1-Vlan-interface10] isis enable 10
[PE1-Vlan-interface10] quit
# Create IS-IS processes 20 and 30, binding them to instances VPN 2 and VPN 3 respectively, set the network entity names to 10.0000.0000.0005.00 and 10.0000.0000.0006.00 respectively; enable IS-IS process 20 on Vlan-interface 20 and IS-IS process 30 on Vlan-interface 30 (Omitted)
Complete Configuration
The following lists only the complete configuration of MCE. For configuration of other devices in the network diagram, refer to the device user manual.
If OSPF is the routing protocol between MCE and PE, the complete configuration is as follows:
vlan 1
vlan 10
vlan 20
vlan 30
interface LoopBack0
 ip address 101.101.10.1 255.255.255.255
interface Vlan-interface10
 ip address 10.214.10.3 255.255.255.0
interface Vlan-interface20
 ip address 10.214.20.3 255.255.255.0
interface Vlan-interface30
 ip address 10.214.30.3 255.255.255.0
interface Ethernet1/0/10
 port access vlan 10
interface Ethernet1/0/15
 port access vlan 30
interface Ethernet1/0/20
 port access vlan 20
interface GigabitEthernet1/1/1
 port trunk permit vlan 1 10 20 30
 import-route static
 domain-id 0.0.0.10
 area 0.0.0.0
 import-route rip 20
 domain-id 0.0.0.20
 area 0.0.0.0
 domain-id 0.0.0.30
 area 0.0.0.0
 network 10.0.0.0
 import-route ospf 20
 ip route-static vpn-instance vpn1 192.168.0.0 255.255.0.0 10.214.10.2
If RIP is the routing protocol between MCE and PE, the complete configuration is as follows:
vlan 1
vlan 10
vlan 20
vlan 30
 port access vlan 10
 port access vlan 30
 port access vlan 20
 import-route static
 network 10.0.0.0
 network 10.0.0.0
 import-route ospf 30
 area 0.0.0.0
 import-route rip 30
If IS-IS is the routing protocol between MCE and PE, the complete configuration is as follows:
vlan 1
vlan 10
vlan 20
vlan 30
 isis enable 10
 isis enable 20
 isis enable 30
 port access vlan 10
 port access vlan 30
 port access vlan 20
 is-level level-1-2
 is-level level-1-2
 import-route rip 20 level-1-2
 is-level level-1-2
 import-route ospf 30 level-1-2
 area 0.0.0.0
 import-route isis 30
 network 10.0.0.0
 import-route isis 20
Configuration Guidelines
None
Configuring MCE (Redistributing VPN Routes by BGP)
Network Diagram
Figure 1-2 Network diagram for MCE configuration (redistributing VPN routes by BGP
l          An H3C switch functions as MCE. It is required that VPN routes of site 1 and site 2 be advertised to the PE so that devices in the same VPN can communicate with each other properly across the MPLS backbone network.
l          OSPF runs within both site 1 and site 2, and EBGP runs between MCE and PE.
Product series
Software version
Hardware version
All versions
All versions
Release 6100
Release 6300
All versions
# Configure the MCE device to work in the MCE mode and reboot the device.
<MCE> system-view
[MCE] quit
<MCE> reboot
# Configure VPN instances VPN 1 and VPN 2 on MCE; set the route distinguishers (RDs) to 10:1 and 20:1 respectively; set the same values for the VPN (both export and import) target attributes.
<MCE> system-view
[MCE-vpn-instance-vpn1] vpn-target 10:1 both
[MCE-vpn-instance-vpn2] vpn-target 20:1 both
# Create VLAN 2, assign port Ethernet 1/0/10 to VLAN 2, and create VLAN-interface 2.
[MCE] vlan 2
[MCE-vlan2] port Ethernet 1/0/10
[MCE-vlan2] quit
# Bind VLAN-interface 2 to instance VPN 1; configure the IP address of the VLAN interface as 10.100.10.1 and the mask as 24 bits.
[MCE-Vlan-interface2] ip binding vpn-instance vpn1
[MCE-Vlan-interface2] ip address 10.100.10.1 24
[MCE-Vlan-interface2] quit
# Take similar steps to configure VLAN 3; assign Ethernet 1/0/20 to VLAN 3; bind the VLAN interface to instance VPN 2, and assign an IP address to the VLAN interface.
[MCE] vlan 3
[MCE-vlan3] port Ethernet 1/0/20
[MCE-vlan3] quit
[MCE-Vlan-interface3] ip binding vpn-instance vpn2
[MCE-Vlan-interface3] ip address 10.100.20.1 24
[MCE-Vlan-interface3] quit
# Create OSPF process 10 on VR 1 and advertise network segments 172.16.10.0 and 10.100.10.0 within area 0.
<VR1> system-view
[VR1] ospf 10
[VR1-ospf-10] area 0
[VR1-ospf-10-area-0.0.0.0] network 10.100.10.0 0.0.0.255
[VR1-ospf-10-area-0.0.0.0] network 172.16.10.0 0.0.0.255
# Create OSPF process 10 for MCE and bind OSPF process 10 to VPN 1; set the router ID to 10.10.10.1; redistribute the BGP routing information of VPN 1, configure OSPF multi-instance, and advertise network segment 10.100.10.0.
<MCE> system-view
[MCE] ospf 10 router-id 10.10.10.1 vpn-instance vpn1
[MCE-ospf-10] vpn-instance capability simple
[MCE-ospf-10] import-route bgp
[MCE-ospf-10-area-0.0.0.0] network 10.100.10.0 0.0.0.255
[MCE-ospf-10-area-0.0.0.0] display ip routing-table vpn-instance vpn1
10.100.10.0/24      Direct 0    0            10.100.10.1     Vlan2
10.100.10.1/32      Direct 0    0            127.0.0.1       InLoop0
172.16.10.0/24      OSPF   10   1            10.100.10.2     Vlan2
As shown in the output information above, MCE has learnt the routing information of Site 1 through OSPF process 10.
# Create OSPF process 20 and advertise network segments 172.16.20.0 and 10.100.20.0 within area 0.
<VR2> system-view
[VR2] ospf 20
[VR2-ospf-20] area 0
[VR2-ospf-20-area-0.0.0.0] network 10.100.20.0 0.0.0.255
[VR2-ospf-20-area-0.0.0.0] network 172.16.20.0 0.0.0.255
# Create OSPF process 20 for MCE and bind OSPF process 20 to instance VPN 2; set the router ID to 10.10.10.1; redistribute the BGP routing information of VPN 2, configure OSPF multi-instance, and advertise network segment 10.100.20.0.
<MCE> system-view
[MCE] ospf 20 router-id 10.10.10.1  vpn-instance vpn2
[MCE-ospf-20] vpn-instance capability simple
[MCE-ospf-20] import-route bgp
[MCE-ospf-20-area-0.0.0.0] network 10.100.20.0 0.0.0.255
[MCE] display ip routing-table vpn-instance vpn2
10.100.20.0/24      Direct 0    0            10.100.20.1     Vlan3
10.100.20.1/32      Direct 0    0            127.0.0.1       InLoop0
172.16.20.0/24      OSPF   10   1            10.100.20.2     Vlan3
4)        Perform routing configuration between MCE and PE 1
# Configure port Ethernet 1/0/3 of MCE as a trunk port and specify to permit tagged packets of VLAN 2, and VLAN 3.
[MCE] interface Ethernet 1/0/3
[MCE-Ethernet1/0/3] port link-type trunk
[MCE-Ethernet1/0/3] port trunk permit vlan 2 3
# Create BGP process 100 for MCE.
[MCE] bgp 100
[MCE-bgp]
# Enter the IPv4 address family view of instance VPN 1.
[MCE-bgp] ipv4-family vpn-instance vpn1
[MCE-bgp-vpn1]
# Configure PE 1 as an EBGP peer and inject the routing information of OSPF process 10 (assuming that the address of the interface bound to VPN 1 is 10.100.10.3 and the ID of the BGP process is 200).
[MCE-bgp-vpn1] peer 10.100.10.3 as-number 200
[MCE-bgp-vpn1] import-route ospf 10
[MCE-bgp-vpn1] quit
# Enter the IPv4 address family view of instance VPN 2, specify PE 1 as an EBGP peer and inject the routing information of OSPF process 20 (assuming that the address of the interface bound to VPN 2 is 10.100.20.3 and the ID of the BGP process is 200).
[MCE-bgp] ipv4-family vpn-instance vpn2
[MCE-bgp-vpn2] peer 10.100.20.3 as-number 200
[MCE-bgp-vpn2] import-route ospf 20
# Configure Ethernet 1/0/18 of PE 1 as a trunk port and configure it to allow tagged packets of VLAN 2, and VLAN3 to pass through.
<PE1> system-view
[PE1] interface Ethernet1/0/18
[PE1-Ethernet1/0/18] port link-type trunk
[PE1-Ethernet1/0/18] port trunk permit vlan 2 3
# Configure interface VLAN-interface 2 and VLAN-interface 3, assign IP addresses 10.100.10.3 and 10.100.20.3 to them respectively, and bind them to instance VPN 1 and VPN 2 respectively. (Omitted)
# Create BGP process 200 on PE 1, and configure MCE as an EBGP peer in the IPv4 address family view of the two VPN instances respectively.
[PE1] bgp 200
[PE1-bgp] ipv4-family vpn-instance vpn1
[PE1-bgp-vpn1] peer 10.100.10.1 as-number 100
[PE1-bgp-vpn1] quit
[PE1-bgp] ipv4-family vpn-instance vpn2
[PE1-bgp-vpn2] peer 10.100.20.1 as-number 100
[PE1-bgp-vpn2] return
# Display the routing information of VPN 1 on PE 1.
<PE1> display ip routing-table vpn-instance vpn1
10.100.10.0/24      Direct 0    0            10.100.10.3     Vlan2
10.100.10.3/32      Direct 0    0            127.0.0.1       InLoop0
172.16.10.0/24      BGP    255  2            10.100.10.2     Vlan2
# Display the routing information of VPN 2 on PE 1.
<PE1> display ip routing-table vpn-instance vpn2
10.100.20.0/24      Direct 0    0            10.100.20.3     Vlan3
10.100.20.3/32      Direct 0    0            127.0.0.1       InLoop0
172.16.20.0/24      BGP    255  2            10.100.20.2     Vlan3
After the above configurations, MCE has imported the OSPF routing information of VPN 1 and VPN 2 to the EBGP routing table of PE 1 properly.
 vpn-target 10:1 export-extcommunity
 vpn-target 10:1 import-extcommunity
 vpn-target 20:1 export-extcommunity
 vpn-target 20:1 import-extcommunity
vlan 1
vlan 10
vlan 20
interface LoopBack0
 ip address 101.10.10.1 255.255.255.255
 ip address 10.100.10.1 255.255.255.0
 ip address 10.100.20.1 255.255.255.0
 port access vlan 10
 port access vlan 20
bgp 100
 undo synchronization
 area 0.0.0.0
 import-route bgp
ospf 10 router-id 10.10.20.1 vpn-instance vpn2
 area 0.0.0.0
 import-route bgp
The VPN target values of the VPNs configured on MCE must match those configured on the PE.
