H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
20-AAA Configuration Guide
20-AAA Configuration Guide 122.07 KB
AAA Overview
Authentication, Authorization, and Accounting (AAA) provides a uniform framework for configuring these three security functions to implement network security management.
AAA usually uses a client/server model, where the client runs on the network access server (NAS) and the server maintains user information centrally. In an AAA network, a NAS is a server for users but a client for the AAA servers, as shown in Figure 1-1.
Figure 1-1 AAA networking diagram
When a user tries to establish a connection with the NAS and to obtain the rights to access other networks or some network resources, the NAS authenticates the user or the corresponding connection. The NAS can transparently pass the user’s AAA information to the server (RADIUS server or HWTACACS server). The RADIUS/HWTACACS protocol defines how to exchange user information between a NAS and a server.
Configuring AAA by HWTACACS Server for Telnet Users
Network Diagram
Figure 1-2 Configure AAA by an HWTACACS server for Telnet users
Networking and Configuration Requirements
As shown in Figure 1-2, configure the switch to use the HWTACACS server to provide authentication, authorization, and accounting services for login users and use local authentication instead when the HWTACACS server is not available.
l          The HWTACACS server is used for authentication, authentication, and accounting. Its IP address is 10.1.1.1.
l          On the switch, set the shared keys for authentication, authorization, and accounting packets to expert, and specify that the switch send usernames without domain names to the HWTACACS server.
l          On the HWTACACS server, set the shared keys for packet exchange with the switch to expert.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301, Release 5303
All versions
S5510 Series Ethernet Switches
All versions
S5500-SI Series Ethernet Switches
Release 1207
All versions except S5500-20TP-SI
Release 1301
S5500-20TP-SI
S5500-EI Series Ethernet Switches
Release 2102
All versions
S7500E Series Ethernet Switches
Release 6100, Release 6300
All versions
Configuration Procedure
# Enable the Telnet server on the switch.
<Switch> system-view
[Switch] telnet server enable
# Configure the switch to use AAA for Telnet users.
[Switch] user-interface vty 0 4
[Switch-ui-vty0-4] authentication-mode scheme
[Switch-ui-vty0-4] quit
# Configure the HWTACACS scheme.
[Switch] hwtacacs scheme hwtac
[Switch-hwtacacs-hwtac] primary authentication 10.1.1.1 49
[Switch-hwtacacs-hwtac] primary authorization 10.1.1.1 49
[Switch-hwtacacs-hwtac] primary accounting 10.1.1.1 49
[Switch-hwtacacs-hwtac] key authentication expert
[Switch-hwtacacs-hwtac] key authorization expert
[Switch-hwtacacs-hwtac] key accounting expert
[Switch-hwtacacs-hwtac] user-name-format without-domain
[Switch-hwtacacs-hwtac] quit
# Apply the AAA scheme to the domain.
[Switch] domain 1
[Switch-isp-1] authentication login hwtacacs-scheme hwtac local
[Switch-isp-1] authorization login hwtacacs-scheme hwtac local
[Switch-isp-1] accounting login hwtacacs-scheme hwtac local
[Switch-isp-1] quit
# Create a local user named telnet.
[Switch] local-user telnet
[Switch-luser-telnet] service-type telnet
[Switch-luser-telnet] password simple telnet
Complete Configuration
domain 1
user-interface aux 0
local-user telnet
 service-type telnet
Configuration Guidelines
When telneting into the switch, a user enters username userid@1 for authentication using domain 1.
Configuring AAA by Separate Servers for Telnet Users
Network Diagram
Figure 1-3 Configure AAA by separate servers for Telnet users
As shown in Figure 1-3, configure the switch to provide local authentication, HWTACACS authorization, and RADIUS accounting services for the Telnet user. The username and the password for the Telnet user are both telnet.
l          The HWTACACS server is used for authorization. Its IP address is 10.1.1.2. On the switch, set the shared key for packet exchange with the HWTACACS server to expert, and specify that the switch send usernames without domain names to the HWTACACS server.
l          The RADIUS server is used for accounting. Its IP address is 10.1.1.1. On the switch, set the shared key for packet exchange with the RADIUS server to expert.
Configuration of separate AAA for other types of users is similar to that given in this example. The only difference lies in the access type.
Product series
Software version
Hardware version
All versions
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
All versions
# Assign IP addresses to the interfaces (omitted).
[Switch-hwtacacs-hwtac] primary authorization 10.1.1.2 49
# Configure the RADIUS scheme.
[Switch] radius scheme rd
[Switch-radius-rd] primary accounting 10.1.1.1 1813
[Switch-radius-rd] key accounting expert
[Switch-radius-rd] server-type extended
[Switch-radius-rd] user-name-format without-domain
[Switch-radius-rd] quit
# Configure the AAA schemes of the ISP domain.
[Switch] domain 1
[Switch-isp-1] authentication login local
[Switch-isp-1] accounting login radius-scheme rd
[Switch-isp-1] quit
radius scheme rd
domain 1
local-user telnet
 service-type telnet
When telneting into the switch, a user enters username telnet@1 for authentication using domain 1.
Configuring AAA by RADIUS Server for SSH Users
Network Diagram
Figure 1-4 Configure AAA by a RADIUS server for SSH users
As shown in Figure 1-4, configure the switch to use the RADIUS server to provide authentication, authorization, and accounting services for SSH users.
l          The RADIUS server is responsible for both authentication and accounting. Its IP address is 10.1.1.1.
l          On the switch, set both the shared keys for authentication and accounting exchange with the RADIUS server to expert, and specify that the switch send usernames with domain names to the RADIUS server.
l          The RADIUS server runs the CAMS server.
Product series
Software version
Hardware version
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
Release 6300
All versions
1)        Configure the RADIUS server.
This example assumes that the RADIUS server runs the CAMS server Version 2.10.
# Add an access device.
Log into the CAMS management platform and select System Management > System Configuration from the navigation tree. In the System Configuration window, click Modify of the Access Device item, and then click Add to enter the Add Access Device window and perform the following configurations:
l          Specify the IP address of the switch as 192.168.1.70
l          Set both the shared keys for authentication and accounting packets to expert
l          Select LAN Access Service as the service type
l          Specify the ports for authentication and accounting as 1812 and 1813 respectively
l          Select Extensible Protocol as the protocol type
l          Select Standard as the RADIUS packet type.
# Add an administrator for device management
From the navigation tree, select User Management > User for Device Management, and then in the right pane, click Add to enter the Add Account window and perform the following configurations:
l          Add a user named hello@bbb, and specify the password
l          Select SSH as the service type
l          Specify the IP address range of the hosts to be managed.
2)        Configure the switch
# Configure the IP address of VLAN-interface 2, through which the SSH user accesses the switch.
[Switch-Vlan-interface2] ip address 192.168.1.70 255.255.255.0
[Switch-Vlan-interface2] quit
# Generate RSA and DSA key pairs and enable the SSH server.
[Switch] public-key local create rsa
[Switch] public-key local create dsa
[Switch] ssh server enable
# Configure the switch to use AAA for SSH users.
# Configure the user interfaces to support SSH.
[Switch-ui-vty0-4] protocol inbound ssh
[Switch] radius scheme rad
[Switch-radius-rad] primary authentication 10.1.1.1 1812
[Switch-radius-rad] primary accounting 10.1.1.1 1813
[Switch-radius-rad] key authentication expert
[Switch-radius-rad] key accounting expert
[Switch-radius-rad] user-name-format with-domain
[Switch-radius-rad] quit
[Switch] domain bbb
[Switch-isp-bbb] authentication login radius-scheme rad
[Switch-isp-bbb] authorization login radius-scheme rad
[Switch-isp-bbb] accounting login radius-scheme rad
[Switch-isp-bbb] quit
When using SSH to log in, a user enters a username in the form userid@bbb for authentication using domain bbb.
3)        Verify the configuration
After the above configuration, the SSH user should be able to use the configured account and to access the user interface of the switch. The commands that the user can access depend on the settings for EXEC users on the CAMS server.
radius scheme rad
domain bbb
ssh server enable
Configuring EAD Application
Network Diagram
Figure 1-5 Configure EAD application
l          Host is connected to interface Ethernet 2/0/1 on the switch.
l          Configure the switch to redirect the user to the update server to download the 802.1x client when the user accesses the Internet through IE before passing authentication.
l          Configure the switch, RADIUS server, and security policy server, so that the RADIUS server performs remote authentication of users and the security policy server controls EAD operations of users.
This configuration example gives only the configurations on the switch. For configurations on the RADIUS server and security policy server, refer to the relevant descriptions.
Product series
Software version
Hardware version
All versions
All versions
Release 1207
Release 1301
S5500-20TP-SI
Release 2102
All versions
All versions
1)        Configure the Web server
Before using the EAD fast deployment feature, configure the update server as the Web server, that is, the server for downloading the 802.1x client.
2)        Configure EAD fast deployment
# Configure a free IP range.
[Switch] dot1x free-ip 10.110.91.0 24
# Configure the URL for HTTP redirection.
[Switch] dot1x url http:// 10.110.91.168
# Enable 802.1x globally.
[Switch] dot1x
# Enable 802.1x for interface Ethernet 2/0/1.
[Switch] interface ethernet 2/0/1
[Switch-Ethernet2/0/1] dot1x
3)        Configure EAD
# Configure a RADIUS scheme.
[Switch] radius scheme cams
[Switch-radius-cams] primary authentication 10.110.91.164 1812
[Switch-radius-cams] primary accounting 10.110.91.164 1813
[Switch-radius-cams] key authentication expert
[Switch-radius-cams] key accounting expert
[Switch-radius-cams] user-name-format with-domain
[Switch-radius-cams] server-type extended
# Configure the IP address of the security policy server.
[Switch-radius-cams] security-policy-server 10.110.91.166
# Configure the default AAA schemes.
[Switch] domain aaa
[Switch-isp-aaa] authentication default radius-scheme cams
[Switch-isp-aaa] authorization default radius-scheme cams
[Switch-isp-aaa] accounting default radius-scheme cams
When telneting into the switch, a user enters username userid@aaa for authentication using domain aaa.
4)        User login
When a user tries to access the Internet before passing 802.1x authentication, the switch will redirect the user to the update server page, where the user can download the 802.1x client.
After the user downloads and launches the 802.1x client, enters the correct username and password, and passes 802.1x authentication, the security client (software installed on the host) interacts with the security policy server to check the security status of the client. If the client does not satisfy the security requirements, the security policy server issues an ACL to the switch, which then restricts the client to the update server.
After the client installs the required patches and satisfies the security requirements, the security policy server reissues an ACL to the switch, which then allows the client to access more network resources.
radius scheme cams
domain aaa
dot1x
dot1x
