Title | Size | Downloads |
H3C LSPM2GP2P Interface Card User Manual-V1.02-book.pdf | 151.8 KB |
- H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
- H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
- H3C S5500-SI Series Ethernet Switches Operation Manual(V1.01)
- H3C S5500-EI Series Ethernet Switches Compliance and Safety Manual-6W101
- H3C S5500-SI Complete Compliance and Safety Manual-6W100
- H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
Installing and removing an interface card
Installing the LSPM2GP2P interface card
Installing an SFP transceiver module
Introduction to LSPM2GP2P
Overview
The LSPM2GP2P interface card provides two 1-Gbps SFP fiber ports.
Figure 1 Front panel of the LSPM2GP2P interface card
NOTE: The LSPM2GP2P interface card is applicable to multiple models of H3C switches, and the switch models that it applies to may update with time. For the latest information, contact H3C technical support or marketing staff. |
Description of SFP ports
The LSPM2GP2P interface card provides two 1-Gbps SFP ports. You can insert an SFP transceiver module into the port to connect it to another SFP port through an optical fiber. For more information about the supported SFP transceiver modules, see Table 1.
Table 1 SFP transceiver modules supported by LSPM2GP2P
Transceiver |
Central wavelength |
Connector |
Interface cable |
Max transmission distance |
SFP-GE-SX-MM850-A |
850 nm |
LC |
50/125 μm multimode optical fiber |
550 m (1804.5 ft) |
62.5/125 μm multimode optical fiber |
275 m (902.2 ft) |
SFP-GE-LX-SM1310-A |
1310 nm |
LC |
9/125 μm single mode optical fiber |
10 km (6.2 mi) |
SFP-GE-LH40-SM1310 |
40 km (24.9 mi) |
SFP-GE-LH40-SM1550 |
1550 nm |
LC |
40 km (24.9 mi) |
SFP-GE-LH70-SM1550 |
70 km (43.5 mi) |
SFP-GE-LH100-SM1550 |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
TX: 1310 nm RX: 1490 nm |
LC |
10 km (6.2 mi) |
SFP-GE-LX-SM1490-BIDI |
TX: 1490 nm RX: 1310 nm |
NOTE: · H3C recommends that you use SFP transceiver modules of H3C on the LSPM2GP2P. · BIDI modules must be used in pair. For example, if an SFP-GE-LX-SM1310-BIDI is used at one end, another SFP-GE-LX-SM1490-BIDI must also be used at the other end. · The types of SFP transceiver modules may update with time. For information about them, contact H3C technical support or marketing staff. · For the models and specifications of each kind of SFP transceiver modules, see the H3C Low End Series Ethernet Switches Pluggable Modules Manual on the H3C website. |
Description of LEDs
There is an LED for each port on the panel of the LSPM2GP2P interface card.
Table 2 Description of LEDs on the LSPM2GP2P
LED |
Status |
Port LED of the LSPM2GP2P interface card |
On |
The port is normally connected. The LED blinks quickly when the port is sending or receiving data. |
Off |
The port is not up. |
NOTE: Port LED of the LSPM2GP2P interface card is not affected by the port mode switching button on your switch. For more information about the port mode switching button, see the installation guide of the switch. |
The following tools are needed for the installation and removal of an interface card:
· Phillips screwdriver
· ESD-preventive wrist strap
NOTE: The installation tools are not shipped together with H3C’s devices. Prepare them yourself. |
Installing
the interface card to the switch
NOTE: The procedure of installing the LSPM2GP2P interface card to different models of H3C switches is similar. This manual takes the S5500-28C-EI switch as an example. |
Follow these steps to install the interface card to the switch:
1. Wear an ESD-preventive wrist strap, and make sure that the ESD-preventive wrist strap makes good skin contact and is properly grounded.
2. Loosen the mounting screws of the filler panel on the interface card slot of the switch with a Phillips screwdriver and remove the filler panel, as shown in Figure 2.
Figure 2 Install an interface card (I)
3. Holding the fastening screws on the front panel of the SFP interface card, gently push the interface card in along the slot guide rail until the interface card is in close contact with the switch, as shown in Figure 3.
4. Tighten the captive screws with a Phillips screwdriver to fix the interface card.
Figure 3 Install an interface card (II)
CAUTION: · Keep the removed filler panel properly for future use. · When tightening the fastening screws at both sides of the interface card with a screwdriver or an electric screwdriver, make sure that the torque is not bigger than 0.4 N-m. |
Removing
the interface card
Follow these steps to remove the interface card:
1. Wear an ESD-preventive wrist strap, and make sure that the ESD-preventive wrist strap makes good skin contact is properly grounded.
2. Use a Phillips screwdriver to loosen the captive screws at both sides of the interface card until all spring pressure is released.
3. Pull the interface card towards you along the guide rails, until it completely comes out of the switch chassis.
CAUTION: When installing or removing an interface card, note the following guidelines: · Do not touch the surface-mounted components directly with your hands. · Do not use too much force in the operation. · After removing an interface card, if no new interface card is to be installed, install the filler panel as soon as possible to prevent dust and ensure the normal ventilation in the switch. |
To avoid component damage caused by improper installation, carefully read the H3C Pluggable SFP/SFP+/XFP Transceiver Modules Installation Guide from the H3C's website before installing the SFP transceiver modules.
Verifying the installation
When the switch runs properly, check whether the interface card is operating properly according to the status of the Port LED on the LSPM2GP2P interface card.
Technical support
Hangzhou H3C Technologies Co., Ltd. provides customers with comprehensive technical support and service. If you purchase the products from the sales agent of Hangzhou H3C Technologies Co., Ltd., please contact our sales agent or technical personnel.
Address: 310 Liuhe Road, Zhijiang Science Park,
Hangzhou, Zhejiang Province, P. R. China
Postal Code: 310053
Website: http://www.h3c.com
E-mail: service@h3c.com
BOM: 3104A06R
