H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
70-FTP Client Software Upgrade Configuration Examples
H3C Routers
Introduction
The following information provides an example for upgrading the software version of a distributed router through FTP.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of FTP.
Example: Using the device as an FTP client to upgrade software
As shown in Figure 1, the host is connected to GigabitEthernet 0/0/1 of the router. The router acts as the FTP client and the host acts as the FTP server. Configure the network to meet the following requirements:
·     Use FTP to download software upgrade file test.ipe from the FTP server to the FTP client to upgrade the router.
·     Use username 123456 and password 123456 to log in to the FTP server.
Figure 1 Network diagram
Analysis
To upgrade both active and standby MPUs of the router, copy the software image file to the root directory on the standby MPU after downloading the file to the active MPU through FTP.
For the router to use the new software version after reboot, specify the software image file to be used at the next boot as the main startup image file.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
When you configure the device as an FTP client to upgrade software, follow these restrictions and guidelines:
·     If storage space on the device is not enough for the upgrade, use the delete /unreserved file-url command to delete unnecessary files before performing software upgrade.
·     Make sure the username, password, and file name settings for FTP transfer on the host and the router are the same.
Procedures
Configuring the host
# Assign IP address 192.168.100.14/24 to the host. Make sure the host and the router can reach each other. (Details not shown.)
# Start the FTP server on the host. This example uses the 3CDaemon FTP server.
Figure 2 Configuring the FTP server
# Perform the following operations to configure the FTP server parameters:
1.     Click .
2.     Set the username in the Profile filed. This example uses 123456.
3.     Click Set/Change user's password to set the password. This example uses 123456.
4.     Click  to specify the download path for the FTP server.
5.     Click OK.
Figure 3 Configuring the FTP server
Configuring the router
# Assign an IP address to GigabitEthernet 0/0/1 on the router.
<Router> system-view
[Router] interface gigabitethernet 0/0/1
[Router-GigabitEthernet0/0/1] ip address 192.168.100.66 255.255.255.0
[Router-GigabitEthernet0/0/1] quit
[Router] quit
# Verify that the router can ping the FTP server.
<Router> ping 192.168.100.14
  PING 192.168.100.14: 56  data bytes, press CTRL_C to break
    Reply from 192.168.100.14: bytes=56 Sequence=0 ttl=128 time=2 ms
    Reply from 192.168.100.14: bytes=56 Sequence=1 ttl=128 time=1 ms
    Reply from 192.168.100.14: bytes=56 Sequence=2 ttl=128 time=1 ms
    Reply from 192.168.100.14: bytes=56 Sequence=3 ttl=128 time=1 ms
    Reply from 192.168.100.14: bytes=56 Sequence=4 ttl=128 time=1 ms
  --- 192.168.100.14 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 1/1/2 ms
# Use username 123456 and password 123456 to log in to the FTP server.
<Router> ftp 192.168.100.14
Connected to 192.168.100.14 (192.168.100.14).
220 3Com 3CDaemon FTP Server Version 2.0
User (192.168.100.14:(none)): 123456
331 User name ok, need password
Password:
230 User logged in
Remote system type is UNIX.
Using binary mode to transfer files.
# Download upgrade file test.ipe from the FTP server to the active MPU of the router.
ftp> get test.ipe
227 Entering passive mode (192,168,100,14,8,86)
125 Using existing data connection
226 Closing data connection; File transfer successful.
70445056 bytes received in 53.6 seconds (1.25 Mbyte/s)
ftp> quit
# Copy the upgrade file on the active MPU to the root directory of the standby MPU.
<Router> copy flash:/test.ipe slot1#flash:/test.ipe
Copy flash:/test.ipe to slot1#flash:/test.ipe[Y/N]:y
Copying file flash:/test.ipe to slot1#flash:/test.ipe.
........................................................................ Done.
# Specify upgrade file test.ipe as the main startup image file for the active MPU of the router.
<Router> boot-loader file flash:/test.ipe slot 0 main
Verifying the IPE file and the images......Done.
H3C xxx images in IPE:
  test-cmw910-boot-r9141p16.bin
  test-cmw910-system-r9141p16.bin
This command will set the main startup software images. Continue? [Y/N]:Y
Add images to slot 0.
Decompressing file test-cmw910-boot-r9141p16.bin to flash:/test-cmw910-boot-r9141p16.bin...............Done.
Decompressing file test-cmw910-system-r9141p16.bin to flash:/test-cmw910-system-r9141p16.bin..............................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 0.
# Specify upgrade file test-old.ipe as the backup startup image file for the active MPU of the router.
<Router> boot-loader file slot1#flash:/test-old.ipe slot 0 backup
This command will set the backup startup software images. Continue? [Y/N]:y
The images that have passed all examinations will be used as the backup startup
# Specify upgrade file test.ipe as the main startup image file for the standby MPU of the router.
<Router> boot-loader file slot1#flash:/test.ipe slot 1 main
Verifying the IPE file and the images........Done.
This command will set the main startup software images. Continue? [Y/N]:y
Add images to slot 1.
Decompressing file test-cmw910-boot-r9141p16.bin to slot1#flash:/test-cmw910-boot-r9141p16.bin................Done.
Decompressing file test-cmw910-system-r9141p16.bin to slot1#flash:/test-cmw910-system-r9141p16.bin.................................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
# Specify upgrade file test-old.ipe as the backup startup image file for the standby MPU of the router.
<Router> boot-loader file slot1#flash:/test-old.ipe slot 1 backup
# Reboot the device.
<Router> reboot
# Use the display version command to display system version information.
<Router> display version
H3C Comware Software, Version 9.1.063, Release 9141P16
Copyright (c) 2004-2023 New H3C Technologies Co., Ltd. All rights reserved.
H3C xxx uptime is 0 weeks, 0 days, 6 hours, 54 minutes
Last reboot reason : Power on
Boot image: flash:/test-cmw910-boot-r9141p16.bin
Boot image version: 9.1.063, Release 9141P16
Compiled Mar 10 2023 15:00:00
System image: flash:/test-cmw910-system-r9141p16.bin
System image version: 9.1.063, Release 9141P16
# Display the current software images and startup software images on the active MPU of the router.
<Router> display boot-loader slot 0
Software images on slot 0:
Current software images:
Main startup software images:
Backup startup software images:
  flash:/test-cmw910-boot-r9141p14.bin
  flash:/test-cmw910-system-r9141p14.bin
# Display the current software images and startup software images on the standby MPU of the router.
<Router> display boot-loader slot 1
Software images on slot 1:
Configuration files
interface GigabitEthernet0/0/1
 port link-mode route
Related documentation
·     Fundamentals Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Fundamentals Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
