H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
35-OSPF Multi-Process Configuration Examples
35-OSPF Multi-Process Configuration Examples 74.49 KB
H3C Routers
Example: Configuring the OSPF multi-process feature
As shown in Figure 1, Device A and Device B establish a neighbor relationship in OSPF process 100, and Device B and Device C establish a neighbor relationship in OSPF process 200. Device A and Device C cannot learn routes from each other through OSPF.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
Procedures
Configuring Device A
# Specify DeviceA as the device name.
[Sysname] sysname DeviceA
# Enable OSPF process 100 and enable OSPF on interfaces whose primary IP address is on network 172.10.1.0/24.
[DeviceA] ospf 100 router-id 1.1.1.9
[DeviceA-ospf-100] area 0.0.0.0
[DeviceA-ospf-100-area-0.0.0.0] network 172.10.1.0 0.0.0.255
[DeviceA-ospf-100-area-0.0.0.0] quit
[DeviceA-ospf-100] quit
Configuring Device B
# Specify DeviceB as the device name.
[Sysname] sysname DeviceB
[DeviceB] ospf 100 router-id 2.2.2.9
[DeviceB-ospf-100] area 0.0.0.0
[DeviceB-ospf-100-area-0.0.0.0] network 172.10.1.0 0.0.0.255
[DeviceB-ospf-100-area-0.0.0.0] quit
[DeviceB-ospf-100] quit
# Enable OSPF process 200 and enable OSPF on interfaces whose primary IP address is on network 131.108.1.0/24.
[DeviceB] ospf 200 router-id 2.2.2.9
[DeviceB-ospf-200] area 0.0.0.0
[DeviceB-ospf-200-area-0.0.0.0] network 131.108.1.0 0.0.0.255
[DeviceB-ospf-200-area-0.0.0.0] quit
[DeviceB-ospf-200] quit
Configuring Device C
# Specify DeviceC as the device name.
[Sysname] sysname DeviceC
[DeviceC] ospf 200 router-id 3.3.3.9
[DeviceC-ospf-200] area 0.0.0.0
[DeviceC-ospf-200-area-0.0.0.0] network 131.108.1.0 0.0.0.255
[DeviceC-ospf-200-area-0.0.0.0] quit
[DeviceC-ospf-200] quit
# Execute the display ospf peer command on Device B to verify that it has established a neighbor relationship with Device A and Device C separately.
[DeviceB] display ospf peer
         OSPF Process 100 with Router ID 2.2.2.9
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 1.1.1.9         172.10.1.1      1   30         Full/DR           GE1/0/1
         OSPF Process 200 with Router ID 2.2.2.9
 Area: 0.0.0.0
 3.3.3.9         131.108.1.1     1   39         Full/BDR          GE1/0/2
# Execute the display ip routing-table command on Device A to verify that Device A does not have a route to 131.108.1.0/24.
[DeviceA] display ip routing-table
Destinations : 11       Routes : 11
1.1.1.9/32         Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
172.10.1.0/24      Direct  0   0           172.10.1.1      GE1/0/1
172.10.1.0/32      Direct  0   0           172.10.1.1      GE1/0/1
172.10.1.1/32      Direct  0   0           127.0.0.1       InLoop0
172.10.1.255/32    Direct  0   0           172.10.1.1      GE1/0/1
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
# Execute the display ip routing-table command on Device C to verify that Device C does not have a route to 172.10.1.0/24.
# Execute the display ip routing-table command on Device C.
3.3.3.9/32         Direct  0   0           127.0.0.1       InLoop0
131.108.1.0/24     Direct  0   0           131.108.1.1     GE1/0/2
131.108.1.0/32     Direct  0   0           131.108.1.1     GE1/0/2
131.108.1.1/32     Direct  0   0           127.0.0.1       InLoop0
131.108.1.255/32   Direct  0   0           131.108.1.1     GE1/0/2
Configuration files
Device A
 sysname DeviceA
 area 0.0.0.0
 ip address 172.10.1.2 255.255.255.0
Device B
 sysname DeviceB
 area 0.0.0.0
 area 0.0.0.0
 ip address 172.10.1.1 255.255.255.0
 ip address 131.108.1.3 255.255.255.0
Device C
 sysname DeviceC
 area 0.0.0.0
 ip address 131.108.1.1 255.255.255.0
Related documentation
·     Layer 3—IP Routing Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Layer 3—IP Routing Command Reference in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
