H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
66-Mobile Communication Modem Management Configuration Examples
H3C Routers
Copyright © 2024 New H3C Technologies Co., Ltd. All rights reserved
Example: Configuring 5G modem dialup for network access
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
As shown in Figure 1, Router A has a 5G modem module. The user accesses the 5G network through auto-dial DDR and a permanent online connection is established. Configure Router A to meet the following requirements:
·     Channelize Cellular 1/0 into Eth-channel interface Eth-channel 1/0:0. Use Eth-channel 1/0:0 as a DDR dialer interface and enable it to obtain an IP address by using the modem-manufacturer's proprietary protocol.
·     Enable traditional DDR on Eth-channel 1/0:0 and set the dial string for placing calls based on the service provider. Typically, set the dial string for placing calls to *99# for China Mobile or China Unicom and #777 for China Telecom in China mainland.
·     Configure an APN profile, and use an APN automatically assigned by the service provider.
·     Configure DDR to place calls for only IPv4 packets.
Figure 1 Network diagram
When a common 5G SIM card is used for network access, the router can access the 5G network after you use an APN automatically assigned by the service provider in the 5G modem profile. When a 5G IoT or VPDN SIM card is used, you must use the APN provided by the service provider in the 5G modem profile. You must also configure the authentication method for 5G network access based on the username and password provided by the service provider.
Procedures
1.     Assign an IP address to the interface. (Details not shown.)
2.     Configure 5G modem dialup:
# Configure a dialup rule for dialer group 1.
[RouterA] dialer-group 1 rule ip permit
# Configure an APN profile named dynamic1, and use an APN automatically assigned by the service provider.
[RouterA] apn-profile dynamic1
[RouterA-apn-profile-dynamic] apn dynamic
[RouterA-apn-profile-dynamic] quit
# Channelize Cellular 1/0 into an Eth-channel interface.
[RouterA] controller cellular 1/0
[RouterA-Cellular1/0] eth-channel 0
[RouterA-Cellular1/0] quit
# Enable Eth-channel1/0:0 to obtain an IP address automatically through the modem manufacturer's proprietary protocol.
[RouterA] interface eth-channel 1/0:0
[RouterA-Eth-channel1/0:0] ip address cellular-alloc
# Apply APN profile dynamic1 to Eth-channel 1/0:0.
[RouterA-Eth-channel1/0:0] apn-profile apply dynamic1
# Enable traditional DDR on Eth-channel 1/0:0 and associate Eth-channel 1/0:0 with dialer group 1.
[RouterA-Eth-channel1/0:0] dialer circular enable
[RouterA-Eth-channel1/0:0] dialer-group 1
# Set the link idle-timeout timer to 0 seconds, wait-carrier timer to 30 seconds, and auto-dial timer to 5 seconds.
[RouterA-Eth-channel1/0:0] dialer timer idle 0
[RouterA-Eth-channel1/0:0] dialer timer wait-carrier 30
[RouterA-Eth-channel1/0:0] dialer timer autodial 5
# Set the dial string for placing calls. Typically, set the dial string for placing calls to *99# for China Mobile or China Unicom and #777 for China Telecom in China mainland.
[RouterA-Eth-channel1/0:0] dialer number *99# autodial
# Configure an outbound dynamic NAT rule for Eth-channel 1/0:0.
[RouterA-Eth-channel1/0:0] nat outbound
[RouterA-Eth-channel1/0:0] quit
# Configure the default route.
[RouterA] ip route-static 0.0.0.0 0 eth-channel 1/0:0
# Verify that the configured default route takes effect and the user can access the network through the device.
Destination/Mask     Proto   Pre Cost        NextHop         Interface
0.0.0.0/0            Static  60  0          0.0.0.0          E-Ch1/0:0
0.0.0.0/32           Direct  0   0          127.0.0.1        InLoop0
1.0.0.2/32           Direct  0   0          127.0.0.1        InLoop0
127.0.0.0/8          Direct  0   0          127.0.0.1        InLoop0
127.0.0.1/32         Direct  0   0          127.0.0.1        InLoop0
127.255.255.255/32   Direct  0   0          127.0.0.1        InLoop0
Configuration files
 interface gigabitethernet 0/0/1
 apn dynamic
 eth-channel 0
 dialer-group 1
 dialer timer idle 0
 nat outbound
 ip route-static 0.0.0.0 0.0.0.0 eth-channel 1/0:0
Example: Configuring 5G modem dialup link backup
As shown in Figure 2, Router A can access the Internet via the wired link from Router A to Router B. Router A can also access the 5G network through DDR dial-up because it has a 5G modem module. Configure Router A to meet the following requirements:
·     Configure traditional auto-dial DDR and establish a permanent 5G online connection.
·     Configure two routes to the Internet. The wired link forwards data as the primary link, and the 5G link backs up data as the secondary link.
·     Monitor the wired link state so that a link switchover can be performed immediately when the wired link state changes.
Figure 2 Network diagram
Analysis
To have the wired link serve as the primary link to forward data, configure a higher preference for the route over the wired link.
To monitor the wired link state in real time, configure NQA on Router A.
To perform a link switchover immediately upon a link state change, configure track entry association with static routes. When NQA detects a wired link failure, it automatically sets the wired link interface route to inactive. The static route of the 5G link takes effect and forwards data over the 5G network. When NQA detects that the wired link becomes normal, it automatically activates the wired link interface route. The static route of the wired link takes effect and data is forwarded through wired connection.
Procedures
Configuring Router A
1.     Assign IP addresses to interfaces. (Details not shown.)
# Configure the default route for the wired link with preference 50, and associate the route with a track entry. Configure the default route for the 5G link with preference 60.
[RouterA] ip route-static 0.0.0.0 0 gigabitethernet 0/0/2 192.168.2.2 track 1 preference 50
[RouterA] ip route-static 0.0.0.0 0 eth-channel 1/0:0 preference 60
3.     Configure an NQA operation:
# Create an ICMP echo operation with administrator name admin and operation tag test. Specify the destination IP address as 1.1.1.1. (Specify a destination IP as required. This example uses the IP address of GigabitEthernet 0/0/2 as an example.)
[RouterA] nqa entry admin test
[RouterA-nqa-admin-test] type icmp-echo
[RouterA-nqa-admin-test-icmp-echo] destination ip 1.1.1.1
# Specify the next hop as 192.168.2.2.
[RouterA-nqa-admin-test-icmp-echo] next-hop ip 192.168.2.2
# Configure the ICMP echo operation to perform 5 probes, set the probe timeout time to 500 milliseconds, and configure the operation to repeat every 5000 milliseconds.
[RouterA-nqa-admin-test-icmp-echo] probe count 5
[RouterA-nqa-admin-test-icmp-echo] probe timeout 500
[RouterA-nqa-admin-test-icmp-echo] frequency 5000
# Create reaction entry 1. If the number of consecutive probe failures reaches 2, collaboration is triggered.
[RouterA-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 2 action-type trigger-only
[RouterA-nqa-admin-test-icmp-echo] quit
# Configure track entry 1, and associate it with reaction entry 1 of the NQA operation with administrator name admin and operation tag test.
[RouterA] track 1 nqa entry admin test reaction 1
[RouterA-track-1] quit
# Start the ICMP echo operation.
[RouterA] nqa schedule admin test start-time now lifetime forever
Configuring Router B
2.     Configure a route:
# Configure an outbound dynamic NAT rule for GigabitEthernet 0/0/2.
<RouterB> system-view
[RouterB] interface gigabitethernet 0/0/2
[RouterB-GigabitEthernet0/0/2] nat outbound
[RouterB-GigabitEthernet0/0/2] quit
# Configure a static route to subnet 192.168.1.0/24.
[RouterB] ip route-static 192.168.1.0 255.255.255.0 gigabitethernet 0/0/1 192.168.2.1
# Display routing table information on Router A and verify that the default route of the wired link takes effect.
Destinations : 20       Routes : 20
0.0.0.0/0            Static  50  0           192.168.2.2     GE0/0/2
# Shut down GigabitEthernet 0/0/2. Display routing table information on Router A again and verify that the default route of the 5G network takes effect.
Configuration files
·     Router A:
 ip address 192.168.2.1 255.255.255.0
 apn dynamic
 eth-channel 0
 dialer-group 1
 dialer timer idle 0
 nat outbound
 type icmp-echo
 probe count 5
 probe timeout 500
 frequency 5000
·     Router B:
 ip address 192.168.2.2 255.255.255.0
 ip address 1.1.1.1 255.255.255.0
 nat outbound
Example: Configuring 5G modem dialup and an IPsec tunnel
As shown in Figure 3, Router A has a 5G modem module. The user accesses the 5G network through auto-dial DDR. Establish an IPsec tunnel between branch gateway Router A and headquarters gateway Router B to protect data flows between branch network 192.168.1.0/24 and headquarters network 192.168.2.0/24. Configure the routers to meet the following requirements:
·     On Router A, configure traditional auto-dial DDR and establish a permanent 5G online connection.
·     Specify the encapsulation mode as the tunnel mode, the security protocol as ESP, the encryption algorithm as DES-CBC, and the authentication algorithm as SHA1. Establish IPsec SAs through IKE negotiations.
Figure 3 Network diagram
Analysis
On Router A, channelize Cellular 1/0 into Eth-channel interface Eth-channel 1/0:0. Enable Eth-channel 1/0:0 to obtain an IP address by using the modem-manufacturer's proprietary protocol. On Eth-channel 1/0:0, configure auto-dial DDR and establish a permanent 5G online connection.
Because the IP address of dialer interface Eth-channel 1/0:0 dynamically changes, you must use an IPsec policy template on Router B when you configure the IPsec tunnel. Specify the peer IP address as 0.0.0.0/0 and configure Router A to initiate the tunnel establishment request.
For Router B to have a private network route to each branch gateway, enable IPsec reverse route inject (RRI) on Router B. Then, Router B automatically creates static routes upon IPsec SA creation.
Procedures
[RouterA-apn-profile-vpdn1] apn dynamic
[RouterA-apn-profile-vpdn1] quit
# Enable Eth-channel 1/0:0 to obtain an IP address by using the modem-manufacturer's proprietary protocol.
3.     Configure the IPsec policy:
# Configure IPv4 advanced ACL 3001 to identify traffic from subnet 192.168.1.0/24 to subnet 192.168.2.0/24.
[RouterA] acl advanced 3001
[RouterA-acl-ipv4-adv-3001] rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
[RouterA-acl-ipv4-adv-3001] quit
# Create an IPsec transform set named tran1, and use tunnel as the packet encapsulation mode, SHA1 as the authentication algorithm, and DES-CBC as the encryption algorithm.
[RouterA] ipsec transform-set tran1
[RouterA-ipsec-transform-set-tran1] encapsulation-mode tunnel
[RouterA-ipsec-transform-set-tran1] protocol esp
[RouterA-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[RouterA-ipsec-transform-set-tran1] esp encryption-algorithm des-cbc
[RouterA-ipsec-transform-set-tran1] quit
# Create an IKE proposal named 1, and use 3DES as the encryption algorithm, HMAC-SHA1 as the authentication algorithm, and pre-share as the authentication method.
[RouterA] ike proposal 1
[RouterA-ike-proposal-1] encryption-algorithm 3des-cbc
[RouterA-ike-proposal-1] authentication-algorithm sha
[RouterA-ike-proposal-1] authentication-method pre-share
[RouterA-ike-proposal-1] quit
# Create an IKE keychain named key1 and use 123456 in plain text as the pre-shared key to be used with the remote peer at 1.1.1.1.
[RouterA] ike keychain key1
[RouterA-ike-keychain-key1] pre-shared-key address 1.1.1.1 255.255.255.0 key simple 123456
[RouterA-ike-keychain-key1] quit
# Create an IKE profile named ike1. Specify IKE keychain key1 for the IKE profile, configure a peer ID with the identity type of IP address and the value of 1.1.1.1, and configure DPD to be triggered every 5 seconds on demand.
[RouterA] ike profile ike1
[RouterA-ike-profile-ike1] keychain key1
[RouterA-ike-profile-ike1] match remote identity address 1.1.1.1 255.255.255.0
[RouterA-ike-profile-ike1] dpd interval 5 on-demand
[RouterA-ike-profile-ike1] quit
# Create an IKE-based IPsec policy named policy1. Specify IPsec transform set tran1, IKE profile ike1, and IPv4 advanced ACL 3001 for the policy, and remote IP address 1.1.1.1 for the IPsec tunnel.
[RouterA] ipsec policy policy1 10 isakmp
[RouterA-ipsec-policy-isakmp-policy1-10] transform-set tran1
[RouterA-ipsec-policy-isakmp-policy1-10] ike-profile ike1
[RouterA-ipsec-policy-isakmp-policy1-10] security acl 3001
[RouterA-ipsec-policy-isakmp-policy1-10] remote-address 1.1.1.1
[RouterA-ipsec-policy-isakmp-policy1-10] quit
# Apply IPsec policy policy1 to Eth-channel 1/0:0.
[RouterA-Eth-channel1/0:0] ipsec apply policy policy1
1.     Assign IP addresses to interfaces. (Details not shown.) By default, Router B has a default route to the next hop belonging to the public network.
2.     Configure the IPsec policy:
# Configure IPv4 advanced ACL 3003 to identify traffic from subnet 192.168.2.0/24 to subnet 192.168.1.0/24.
[RouterB] acl advanced 3003
[RouterB-acl-ipv4-adv-3003] rule 0 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
[RouterB-acl-ipv4-adv-3003] quit
# Create an IPsec transform set named tran1, and use SHA1 as the authentication algorithm, and DES-CBC as the encryption algorithm.
[RouterB] ipsec transform-set tran1
[RouterB-ipsec-transform-set-tran1] encapsulation-mode tunnel
[RouterB-ipsec-transform-set-tran1] protocol esp
[RouterB-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[RouterB-ipsec-transform-set-tran1] esp encryption-algorithm des-cbc
[RouterB-ipsec-transform-set-tran1] quit
[RouterB] ike proposal 1
[RouterB-ike-proposal-1] encryption-algorithm 3des-cbc
[RouterB-ike-proposal-1] authentication-algorithm sha
[RouterB-ike-proposal-1] authentication-method pre-share
[RouterB-ike-proposal-1] quit
# Create an IKE keychain named key1 and use 123456 in plain text as the pre-shared key to be used with the remote peer.
[RouterB] ike keychain key1
[RouterB-ike-keychain-key1] pre-shared-key address 0.0.0.0 0.0.0.0 key simple 123456
[RouterB-ike-keychain-key1] quit
# Create an IKE profile named ike1. Specify IKE keychain key1 for the IKE profile, and configure a peer ID with the identity type of IP address and the value of 0.0.0.0.
[RouterB] ike profile ike1
[RouterB-ike-profile-ike1] keychain key1
[RouterB-ike-profile-ike1] match remote identity address 0.0.0.0 0.0.0.0
[RouterB-ike-profile-ike1] quit
# Create an IPsec policy template named temp1. Specify IPsec transform set tran1, IKE profile ike1, and IPv4 advanced ACL 3003 for the IPsec policy template.
[RouterB] ipsec policy-template temp1 1
[RouterB-ipsec-policy-template-temp1-1] transform-set tran1
[RouterB-ipsec-policy-template-temp1-1] ike-profile ike1
[RouterB-ipsec-policy-template-temp1-1] security acl 3003
# Enable IPsec RRI.
[RouterB-ipsec-policy-template-temp1-1] reverse-route dynamic
[RouterB-ipsec-policy-template-temp1-1] quit
# Create an IKE-based IPsec policy entry by using IPsec policy template temp1. Specify the policy name as policy1 and set the sequence number to 1.
[RouterB] ipsec policy policy1 10 isakmp template temp1
# Apply IPsec policy policy1 to GigabitEthernet 0/0/1.
[RouterB] interface gigabitethernet 0/0/1
[RouterB-GigabitEthernet0/0/1] ipsec apply policy policy1
[RouterB-GigabitEthernet0/0/1] quit
# Initiate a connection from branch subnet 192.168.1.0/24 to headquarters subnet 192.168.2.0/24 to trigger IKE negotiation. After IPsec SAs are successfully negotiated by IKE, traffic between the two subnets is IPsec-protected.
# Verify that Router A and Router B can ping the private networks of each other. This example uses Router A.
<RouterA> ping -a 192.168.1.1 192.168.2.1
Ping 192.168.2.1 (192.168.2.1): 56 data bytes, press CTRL_C to break
56 bytes from 192.168.2.1: icmp_seq=0 ttl=254 time=7.343 ms
56 bytes from 192.168.2.1: icmp_seq=1 ttl=254 time=1.164 ms
56 bytes from 192.168.2.1: icmp_seq=2 ttl=254 time=1.080 ms
56 bytes from 192.168.2.1: icmp_seq=3 ttl=254 time=1.234 ms
56 bytes from 192.168.2.1: icmp_seq=4 ttl=254 time=1.391 ms
--- Ping statistics for 192.168.2.1 ---
round-trip min/avg/max/std-dev = 1.080/2.442/7.343/2.452 ms
# Verify that IPsec SAs are established on Router A.
<RouterA> display ipsec sa
Interface: Eth-channel1/0:0
  IPsec policy: policy
  Sequence number: 10
  Mode: ISAKMP
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Transmitting entity: Initiator
    Path MTU: 1444
    Tunnel:
        local  address/port: 2.2.2.1/500
        remote address/port: 1.1.1.1/500
    Flow:
        sour addr: 192.168.1.0/255.255.255.0  port: 4500  protocol: ip
        dest addr: 192.168.2.0/255.255.255.0  port: 4500  protocol: ip
Configuration files
·     Router A:
 apn dynamic
 eth-channel 0
 dialer-group 1
 dialer timer idle 0
 acl advanced 3001
 protocol esp
 ike proposal 1
 ike keychain key1
 pre-shared-key address 1.1.1.1 255.255.255.0 key cipher $c$3$6xffbOeJQiOn1UzvH2Vdd1H+2PenaF8c3g==
 ike profile ike1
 keychain key1
 transform-set tran1
 ike-profile ike1
 security acl 3001
·     Router B:
 acl advanced 3003
 protocol esp
 ike proposal 1
 ike keychain key1
 pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $c$3$6xffbOeJQiOn1UzvH2Vdd1H+2PenaF8c3g==
 ike profile ike1
 keychain key1
 transform-set tran1
 ike-profile ike1
 security acl 3003
Example: Configuring 5G modem dialup and ADVPN tunnels
As shown in Figure 4, Router A has a 5G modem module. Users access the 5G network through auto-dial DDR. Establish ADVPN tunnels between branch gateways Router A and Router B and headquarters gateway Router C to realize full-mesh ADVPN between branch networks and between branch and headquarters networks. Configure the routers to meet the following requirements:
·     On Router A, configure traditional auto-dial DDR and establish a permanent online connection.
·     Router A and Router B act as spokes, and Router C acts as a hub. Establish a permanent ADVPN tunnel between the hub and each spoke.
·     Configure ADVPN tunnels to be dynamically established based on data between spokes Router A and Router B.
Figure 4 Network diagram
Device
IP address
Device
IP address
Router A (Spoke1)
GE0/0/1
192.168.1.1/24
Router C (Hub)
GE0/0/1
192.168.3.1/24
Tunnel1
192.168.0.1/24
GE0/0/2
1.1.1.1/24
Router B (Spoke2)
GE0/0/1
192.168.2.1/24
Tunnel1
192.168.0.3/24
Tunnel1
192.168.0.2/24
Router D (VAM server)
GE0/0/1
1.1.1.2/24
Analysis
To ensure data privacy between branches and branches and headquarters, apply IPsec profiles to ADVPN tunnels for data encryption. Because the IP address of dialer interface Eth-channel 1/0:0 dynamically changes, specify the peer address as 0.0.0.0/0 when you apply IPsec profiles to ADVPN tunnels.
In this example, configure Router D (VAM server) not to authenticate Router A, Router B, and Router C (VAM clients). You can configure the VAM server to authenticate VAM clients as required.
Procedures
3.     Configure the VAM client:
# Create VAM client Spoke1 and specify ADVPN domain abc for the VAM client.
[RouterA] vam client name spoke1
[RouterA-vam-client-Spoke1] advpn-domain abc
# Configure the preshared key of the VAM client as 123456.
[RouterA-vam-client-Spoke1] pre-shared-key simple 123456
# Specify the IP address of the VAM server and enable the VAM client.
[RouterA-vam-client-Spoke1] server primary ip-address 1.1.1.2
[RouterA-vam-client-Spoke1] client enable
[RouterA-vam-client-Spoke1] quit
# Create an IKE keychain named key and use 123456 in plain text as the pre-shared key to be used with the remote peer.
[RouterA-ike-keychain-key] pre-shared-key address 0.0.0.0 0.0.0.0 key simple 123456
[RouterA-ike-keychain-key] quit
# Create an IKE profile named ike and specify IKE keychain key for it.
[RouterA-ike-profile-abc] keychain key
[RouterA-ike-profile-ike] quit
# Create an IPsec transform set named tran, and use transport as the packet encapsulation mode, SHA1 as the authentication algorithm, and DES-CBC as the encryption algorithm.
[RouterA-ipsec-transform-set-tran] encapsulation-mode transport
[RouterA-ipsec-transform-set-tran] esp encryption-algorithm des-cbc
[RouterA-ipsec-transform-set-tran] esp authentication-algorithm sha1
[RouterA-ipsec-transform-set-tran] quit
# Create an IKE-based IPsec profile named profile1. Specify IPsec transform set tran and IKE profile ike for the IPsec profile.
[RouterA] ipsec profile profile1 isakmp
[RouterA-ipsec-profile-isakmp-profile1] transform-set tran
[RouterA-ipsec-profile-isakmp-profile1] ike-profile ike
[RouterA-ipsec-profile-isakmp-profile1] quit
# Configure OSPF to advertise the private networks.
[RouterA] ospf 1
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[RouterA-ospf-1] quit
# Configure a GRE-mode IPv4 ADVPN tunnel interface named Tunnel1. Set its DR priority to 0 to prevent Router A from participating in DR/BDR election.
[RouterA] interface tunnel1 mode advpn gre
[RouterA-Tunnel1] ip address 192.168.0.1 255.255.255.0
[RouterA-Tunnel1] vam client spoke1
[RouterA-Tunnel1] ospf network-type broadcast
[RouterA-Tunnel1] ospf dr-priority 0
[RouterA-Tunnel1] source eth-channel 1/0:0
[RouterA-Tunnel1] tunnel protection ipsec profile ipsec
[RouterA-Tunnel1] quit
2.     Configure 5G modem dialup.
[RouterB] dialer-group 1 rule ip permit
[RouterB] apn-profile dynamic1
[RouterB-apn-profile-vpdn1] apn dynamic
[RouterB-apn-profile-vpdn1] quit
[RouterB] controller cellular 1/0
[RouterB-Cellular1/0] eth-channel 0
[RouterB-Cellular1/0] quit
[RouterB] interface eth-channel 1/0:0
[RouterB-Eth-channel1/0:0] ip address cellular-alloc
[RouterB-Eth-channel1/0:0] apn-profile apply dynamic1
[RouterB-Eth-channel1/0:0] dialer circular enable
[RouterB-Eth-channel1/0:0] dialer-group 1
[RouterB-Eth-channel1/0:0] dialer timer idle 0
[RouterB-Eth-channel1/0:0] dialer timer wait-carrier 30
[RouterB-Eth-channel1/0:0] dialer timer autodial 5
[RouterB-Eth-channel1/0:0] dialer number *99# autodial
[RouterB-Eth-channel1/0:0] nat outbound
[RouterB-Eth-channel1/0:0] quit
[RouterB] ip route-static 0.0.0.0 0 eth-channel 1/0:0
# Create VAM client Spoke2 and specify ADVPN domain abc for the VAM client.
[RouterB] vam client name spoke2
[RouterB-vam-client-Spoke2] advpn-domain abc
[RouterB-vam-client-Spoke2] pre-shared-key simple 123456
[RouterB-vam-client-Spoke2] server primary ip-address 1.1.1.2
[RouterB-vam-client-Spoke2] client enable
[RouterB-vam-client-Spoke2] quit
[RouterB-ike-keychain-key] pre-shared-key address 0.0.0.0 0.0.0.0 key simple 123456
[RouterB-ike-keychain-key] quit
[RouterB-ike-profile-ike] keychain key
[RouterB-ike-profile-ike] quit
[RouterB-ipsec-transform-set-tran] encapsulation-mode transport
[RouterB-ipsec-transform-set-tran] esp encryption-algorithm des-cbc
[RouterB-ipsec-transform-set-tran] esp authentication-algorithm sha1
[RouterB-ipsec-transform-set-tran] quit
[RouterB] ipsec profile profile1 isakmp
[RouterB-ipsec-profile-isakmp-profile1] transform-set tran
[RouterB-ipsec-profile-isakmp-profile1] ike-profile ike
[RouterB-ipsec-profile-isakmp-profile1] quit
[RouterB] ospf 1
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 192.168.2.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[RouterB-ospf-1] quit
# Configure a GRE-mode IPv4 ADVPN tunnel interface named Tunnel1. Set its DR priority to 0 to prevent Router B from participating in DR/BDR election.
[RouterB] interface tunnel1 mode advpn gre
[RouterB-Tunnel1] ip address 192.168.0.2 255.255.255.0
[RouterB-Tunnel1] vam client spoke2
[RouterB-Tunnel1] ospf network-type broadcast
[RouterB-Tunnel1] ospf dr-priority 0
[RouterB-Tunnel1] source eth-channel 1/0:0
[RouterB-Tunnel1] tunnel protection ipsec profile ipsec
[RouterB-Tunnel1] quit
Configuring Router C
1.     Assign IP addresses to interfaces. (Details not shown.) By default, Router C has a default route to the next hop belonging to the public network.
2.     Configure the VAM client:
<RouterC> system-view
[RouterC] interface gigabitethernet 0/0/2
[RouterC-GigabitEthernet0/0/2] nat outbound
[RouterC-GigabitEthernet0/0/2] quit
# Create VAM client Hub and specify ADVPN domain abc for the VAM client.
[RouterC] vam client name Hub
[RouterC-vam-client-Hub] advpn-domain abc
[RouterC-vam-client-Hub] pre-shared-key simple 123456
[RouterC-vam-client-Hub] server primary ip-address 1.1.1.2
[RouterC-vam-client-Hub] client enable
[RouterC-vam-client-Hub] quit
[RouterC] ike keychain key
[RouterC-ike-keychain-key] pre-shared-key address 0.0.0.0 0.0.0.0 key simple 123456
[RouterC-ike-keychain-key] quit
[RouterC] ike profile ike
[RouterC-ike-profile-ike] keychain key
[RouterC-ike-profile-ike] quit
[RouterC] ipsec transform-set tran
[RouterC-ipsec-transform-set-tran] encapsulation-mode transport
[RouterC-ipsec-transform-set-tran] esp encryption-algorithm des-cbc
[RouterC-ipsec-transform-set-tran] esp authentication-algorithm sha1
[RouterC-ipsec-transform-set-tran] quit
[RouterC] ipsec profile profile1 isakmp
[RouterC-ipsec-profile-isakmp-profile1] transform-set tran
[RouterC-ipsec-profile-isakmp-profile1] ike-profile ike
[RouterC-ipsec-profile-isakmp-profile1] quit
[RouterC] ospf 1
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 192.168.3.0 0.0.0.255
[RouterC-ospf-1] quit
[RouterC] interface tunnel1 mode advpn gre
[RouterC-Tunnel1] ip address 192.168.0.3 255.255.255.0
[RouterC-Tunnel1] vam client Hub
[RouterC-Tunnel1] ospf network-type broadcast
[RouterC-Tunnel1] source gigabitethernet 0/0/2
[RouterC-Tunnel1] tunnel protection ipsec profile ipsec
[RouterC-Tunnel1] quit
Configuring Router D
1.     Assign an IP address to the interface. (Details not shown.) By default, Router D has a default route to the next hop belonging to the public network.
2.     Configure the VAM server:
# Create ADVPN domain abc.
<RouterD> system-view
[RouterD] vam server advpn-domain abc id 1
# Create hub group 0.
[RouterD-vam-server-domain-abc] hub-group 0
# Specify the private IPv4 address as 192.168.0.3 and the public address as 1.1.1.1 (after NAT).
[RouterD-vam-server-domain-abc-hub-group-0] hub private-address 192.168.0.3 public-address 1.1.1.1
# Specify the IPv4 private network address range for spokes in the hub group.
[RouterD-vam-server-domain-abc-hub-group-0] spoke private-address network 192.168.0.0 255.255.255.0
[RouterD-vam-server-domain-abc-hub-group-0] quit
# Configure the preshared key of the VAM server as 123456 and configure the VAM server not to authenticate the VAM clients.
[RouterD-vam-server-domain-abc] pre-shared-key simple 123456
[RouterD-vam-server-domain-abc] authentication-method none
# Enable the VAM server for the ADVPN domain.
[RouterD-vam-server-domain-abc] server enable
[RouterD-vam-server-domain-abc] quit
# Verify that ADVPN tunnels are established between Router A, Router B, and Router C, and their private networks can communicate with each other.
# Display IPv4 address mapping information for all VAM clients registered with the VAM server.
[RouterD] display vam server address-map
Total private address mappings: 3
Group      Private address  Public address              Type   NAT  Holding time
0          192.168.0.1      1.1.1.2                     Spoke  Yes  0H 4M 35S
0          192.168.0.2      1.1.1.3                     Spoke  Yes  0H 4M 17S
0          192.168.0.3      1.1.1.1                     Hub    No   0H 2M 42S
The output shows that the hub, Spoke1, and Spoke2 have all registered their address mapping information with the VAM server.
# Verify that Spoke1 can ping private address 192.168.2.1 of Spoke2.
<RouterA> ping 192.168.2.1
56 bytes from 192.168.2.1: icmp_seq=0 ttl=255 time=2.000 ms
56 bytes from 192.168.2.1: icmp_seq=1 ttl=255 time=60.000 ms
56 bytes from 192.168.2.1: icmp_seq=2 ttl=255 time=7.000 ms
56 bytes from 192.168.2.1: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 192.168.2.1: icmp_seq=4 ttl=255 time=1.000 ms
# Display IPv4 ADVPN tunnel information on Spoke1.
[RouterA] display advpn session
Interface         : Tunnel1
Number of sessions: 2
Private address      Public address       Port  Type  State        Holding time
192.168.0.2          1.1.1.3              --    S-S   Establishing 0H 0M 22S
192.168.0.3          1.1.1.1              --    S-H   Success      0H 1M 25S
# Display IPv4 ADVPN tunnel information on the hub.
[RouterC] display advpn session
Interface         : Tunnel1
192.168.0.1          1.1.1.2              --    H-S   Success      0H 2M 40S
192.168.0.2          1.1.1.3              --    H-S   Success      0H 1M 53S
Configuration files
·     Router A:
 apn dynamic
 eth-channel 0
 dialer-group 1
 dialer timer idle 0
 nat outbound
 advpn-domain abc
  pre-shared-key cipher $c$3$k4hxzHYdkYZ8QUIr6+XsNTxsG/lGk6SGeQ==
 client enable
 ike keychain key
 pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $c$3$i/ODxQdpM7b0kmqHCMj+VpV6G+x/IBDycg==
 ike profile ike
 keychain key
 transform-set tran
 ike-profile ike
 ospf 1
 area 0
 vam client spoke1
 ospf dr-priority 0
·     Router B:
 apn dynamic
 eth-channel 0
 dialer-group 1
 dialer timer idle 0
 nat outbound
 advpn-domain abc
 client enable
 ike keychain key
 ike profile ike
 keychain key
 transform-set tran
 ike-profile ike
 ospf 1
 area 0
 vam client spoke2
 ospf dr-priority 0
·     Router C:
 ip address 192.168.3.1 255.255.255.0
 nat outbound
 vam client name Hub
 advpn-domain abc
 client enable
 ike keychain key
 ike profile ike
 keychain key
 transform-set tran
 ike-profile ike
 ospf 1
 area 0
 vam client Hub
·     Router D:
 ip address 1.1.1.2 255.255.255.0
 hub-group 0
 pre-shared-key cipher $c$3$qb30FA4sK0lRsl3UgtHXhVZwwJtz4YdPrg==
 server enable
Example: Configuring 5G modem dialup and a VPDN tunnel
As shown in Figure 5, Router A has a 5G modem module. The user accesses the VPDN network of the service provider through auto-dial DDR. Establish an IPsec tunnel between branch gateway Router A and headquarters gateway Router B, and establish an L2TP tunnel between the service provider device LAC and Router B. Configure the devices to meet the following requirements:
·     Configure traditional DDR on Router A to allow it to access the 5G network through both IPv4 and IPv6 and establish a permanent 5G online connection.
·     Establish a NAS-initiated L2TP tunnel between the LAC and Router B. Traffic between the branch and the headquarters gateways goes through the service provider private line, which is isolated from the public network.
·     Configure an IKE-based IPsec tunnel between Router A and Router B to encrypt traffic between the branch and headquarters gateways.
Figure 5 Network diagram
Analysis
On Router A, channelize Cellular 1/0 into Eth-channel interface Eth-channel 1/0:0. Enable Eth-channel 1/0:0 to obtain an IP address by using the modem-manufacturer's proprietary protocol. On Eth-channel 1/0:0, configure auto-dial DDR to access the service provider VPDN network and configure a permanent online connection.
Establish a NAS-initiated L2TP tunnel between the LAC and Router B. The LAC and Router B, serving as LNS devices, use local authentication.
For the branch gateway to dial to the service provider VPDN network, use a VPDN SIM card for DDR dialup. When you configure DDR dialup, configure the 5G modem profile and dialup authentication based on the APN, authentication mode, username, and password of the service provider VPDN.
Procedures
[RouterA] dialer-group 1 rule ipv6 permit
# Configure an APN profile named vpdn1. Specify the IPv4 and IPv6 PDP data carrying protocols, APN vdpn, the CHAP or PAP authentication mode, username user1, and password password1. (Configure the APN, authentication mode, username, and password based on those provided by the service provider.)
[RouterA] apn-profile vpdn1
[RouterA-apn-profile-vpdn1] pdp-type ipv4v6
[RouterA-apn-profile-vpdn1] apn static vpdn
[RouterA-apn-profile-vpdn1] authentication-mode pap-chap user1 password simple password1
# Enable Eth-channel 1/0:0 to obtain an IPv4 address and an IPv6 address by using the modem-manufacturer's proprietary protocol.
[RouterA-Eth-channel1/0:0] ipv6 address cellular-alloc
# Apply APN profile vpdn1 to Eth-channel 1/0:0.
[RouterA-Eth-channel1/0:0] apn-profile apply vpdn1
[RouterA] ipv6 route-static 0::0 0 eth-channel 1/0:0
3.     Configure the IPsec tunnel:
# Configure IPv4 advanced ACL 3000 to identify traffic from subnet 192.168.1.0/24 to subnet 192.168.2.0/24.
[RouterA] acl advanced 3000
[RouterA-acl-ipv4-adv-3000] rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
[RouterA-acl-ipv4-adv-3000] quit
# Configure IPv6 advanced ACL 3500 to identify traffic from subnet 2001::/64 to subnet 2002::/64.
[RouterA] acl ipv6 advanced 3500
[RouterA-acl-ipv6-adv-3500] rule 0 permit ipv6 source 2001::0 64 destination 2002::0 64
[RouterA-acl-ipv6-adv-3500] quit
# Create an IKE keychain named key1 and use 123456 in plain text as the pre-shared key to be used with the remote peer at 192.168.0.1 and 2003::1.
[RouterA-ike-keychain-key1] pre-shared-key address 192.168.0.1 24 key simple 123456
[RouterA-ike-keychain-key1] pre-shared-key address ipv6 2003::1 64 key simple 123456
# Create an IKE profile named ike1 and specify IKE keychain key1 for it. Configure a peer ID with the identity type of IPv4 address and the value of 192.168.0.1. Configure a peer ID with the identity type of IPv6 address and the value as 2003::1.
[RouterA-ike-profile-ike1] match remote identity address 192.168.0.1 24
[RouterA-ike-profile-ike1] match remote identity address ipv6 2003::1 64
# Create an IPv4 IKE-based IPsec policy named policy1. Specify IPsec transform set tran1, IKE profile ike1, and IPv4 advanced ACL 3000 for the policy, and remote IP address 192.168.0.1 for the IPsec tunnel.
[RouterA-ipsec-policy-isakmp-policy1-10] security acl 3000
[RouterA-ipsec-policy-isakmp-policy1-10] remote-address 192.168.0.1
# Create an IPv6 IKE-based IPsec policy named policy2. Specify IPsec transform set tran1, IKE profile ike1, and IPv6 advanced ACL 3500 for the policy, and remote IP address 2003::1 for the IPsec tunnel.
[RouterA] ipsec ipv6-policy policy2 20 isakmp
[RouterA-ipsec-policy-isakmp-policy2-20] transform-set tran1
[RouterA-ipsec-policy-isakmp-policy2-20] ike-profile ike1
[RouterA-ipsec-policy-isakmp-policy2-20] security acl ipv6 3500
[RouterA-ipsec-policy-isakmp-policy2-20] remote-address ipv6 2003::1
[RouterA-ipsec-policy-isakmp-policy2-20] quit
# Apply IPv4 IPsec policy policy1 and IPv6 IPsec policy policy2 to Eth-channel 1/0:0.
[RouterA-Eth-channel1/0:0] ipsec apply ipv6-policy policy2
Configuring the LAC
1.     Assign an IP address to the interface. (Details not shown.) The following configuration for the LAC is for your reference only. You do not need to configure the LAC during actual configuration.
2.     Configure the LAC end on the L2TP tunnel:
# Create a local VPDN user with username user1 and password password1, and enable the PPP service.
<LAC> system-view
[LAC] local-user user1 class network
[LAC-luser-network-user1] password simple password1
[LAC-luser-network-user1] service-type ppp
[LAC-luser-network-user1] quit
# Configure ISP domain system to perform local AAA for VPDN users.
[LAC] domain system
[LAC-isp-system] authentication ppp local
[LAC-isp-system] quit
# Enable L2TP.
[LAC] l2tp enable
# Create L2TP group 1 in LAC mode. Specify the local tunnel name as LAC, the condition for the LAC to initiate tunneling requests as user1, and LNS IP address as 10.1.2.2.
[LAC] l2tp-group 1 mode lac
[LAC-l2tp1] tunnel name LAC
[LAC-l2tp1] user fullusername user1
[LAC-l2tp1] lns-ip 10.1.1.2
# Enable tunnel authentication, and set the tunnel authentication key to aabbcc.
[LAC-l2tp1] tunnel authentication
[LAC-l2tp1] tunnel password simple aabbcc
[LAC-l2tp1] quit
1.     Assign an IP address to the interface. (Details not shown.) By default, Router B has a default route to the next hop belonging to the public network.
2.     Configure the LNS end on the L2TP tunnel:
[RouterB] local-user user1 class network
[RouterB-luser-network-user1] password simple password1
[RouterB-luser-network-user1] service-type ppp
[RouterB-luser-network-user1] quit
[RouterB] domain system
[RouterB-isp-system] authentication ppp local
# Specify the authorized IPv6 prefix 2013::/64.
[RouterB-isp-system] authorization-attribute ipv6-prefix 2003:: 64
[RouterB-isp-system] quit
# Enable L2TP, and create L2TP group 1 in LNS mode.
[RouterB] l2tp enable
[RouterB] l2tp-group 1 mode lns
# Configure the local tunnel name as LNS, and specify VT interface 1 for receiving calls from the peer (LAC) named LAC.
[RouterB-l2tp1] tunnel name LNS
[RouterB-l2tp1] allow l2tp virtual-template 1 remote LAC
[RouterB-l2tp1] tunnel authentication
[RouterB-l2tp1] tunnel password simple aabbcc
[RouterB-l2tp1] quit
# Configure the PPP address pool.
[RouterB] ip pool aaa 192.168.0.10 192.168.0.20
[RouterB] ip pool aaa gateway 192.168.0.1
# Create Virtual-Template1 and specify IPv4 address 192.168.0.1/24 and IPv6 address 2003::1/64 for it. Enable the interface to advertise RA messages. Configure the interface to use CHAP and PAP for authenticating the peer and assign an IPv4 address from address pool aaa to Router A.
[RouterB] interface virtual-template 1
[RouterB-virtual-template1] ip address 192.168.0.1 255.255.255.0
[RouterB-virtual-template1] ipv6 address 2003::1 64
[RouterB-virtual-template1] undo ipv6 nd ra halt
[RouterB-virtual-template1] ppp authentication-mode chap pap domain system
[RouterB-virtual-template1] remote address pool aaa
[RouterB-virtual-template1] quit
# Create an IPsec transform set named tran1, and use ESP as the protocol, SHA1 as the authentication algorithm, and DES-CBC as the encryption algorithm.
[RouterB-ike-keychain-key1] pre-shared-key address ipv6 0::0 0 key simple 123456
# Create an IKE profile named ike1 and specify IKE keychain key1 for it. Configure a peer ID with the identity type of IPv4 address and the value of 0.0.0.0. Configure a peer ID with the identity type of IPv6 address and the value of 0::0.
[RouterB-ike-profile-ike1] match remote identity address ipv6 0::0 0
# Create an IPv4 IPsec policy template named temp1. Specify IPsec transform set tran1 and IKE profile ike1 for the IPsec policy template and enable IPsec RRI.
# Create an IPv6 IPsec policy template named temp2. Specify IPsec transform set tran1 and IKE profile ike1 for the IPsec policy template and enable IPsec RRI.
[RouterB] ipsec ipv6-policy-template temp2 2
[RouterB-ipsec-ipv6-policy-template-temp2-2] transform-set tran1
[RouterB-ipsec-ipv6-policy-template-temp2-2] ike-profile ike1
[RouterB-ipsec-ipv6-policy-template-temp2-2] reverse-route dynamic
[RouterB-ipsec-ipv6-policy-template-temp2-2] quit
# Create an IPv4 IKE-based IPsec policy entry by using IPsec policy template temp1. Specify the policy name as policy1 and set the sequence number to 10.
# Create an IPv6 IKE-based IPsec policy entry by using IPsec policy template temp2. Specify the policy name as policy2 and set the sequence number to 20.
[RouterB] ipsec ipv6-policy policy2 20 isakmp template temp2
# Apply IPv4 IPsec policy policy1 and IPv6 IPsec policy policy2 to Virtual-Template 1.
[RouterB-Virtual-Template1] ipsec apply policy policy1
[RouterB-Virtual-Template1] ipsec apply ipv6-policy policy2
[RouterB-Virtual-Template1] quit
# Verify that after Router A successfully accesses the network through DDR dialup, the LAC and Router B establish an L2TP tunnel and an L2TP session. The private networks of Router A and Router B can communicate with each other. Traffic forwarding between Router A and Router B also triggers IPsec tunnel establishment to encrypt the private network traffic between the routers.
# Display information about L2TP tunnels on Router B.
[RouterB] display l2tp tunnel
LocalTID RemoteTID State        Sessions RemoteAddress   RemotePort RemoteName
18986    558       Established  1        10.1.1.1        1701       LAC
[RouterB] display l2tp session
LocalSID    RemoteSID    LocalTID    State
50693       61202        18986       Established
[RouterA] display ipsec sa
  IPsec policy: policy1
  Sequence number: 10
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1444
    Tunnel:
        local  address/port: 192.168.0.10/500
        remote address/port: 192.168.0.1/500
    Flow:
        sour addr: 192.168.1.0/255.255.255.0  port: 0  protocol: ip
        dest addr: 192.168.2.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 367543574 (0x15e84516)
      Connection ID: 4294967296
      Transform set: ESP-ENCRYPT-DES-CBC ESP-AUTH-SHA1
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843199/3533
      Max received sequence-number: 4
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 4212574134 (0xfb16c7b6)
      Connection ID: 4294967297
      Max sent sequence-number: 4
      Status: Active
  IPsec policy: policy2
  Sequence number: 20
  Alias: policy2-20
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1424
    Tunnel:
        local  address/port: 2003::F85B:7EE1:1410:74C9/500
        remote address/port: 2003::1/500
    Flow:
    sour addr: 2001::/64  port: 0  protocol: ipv6
    dest addr: 2002::/64  port: 0  protocol: ipv6
    [Inbound ESP SAs]
      SPI: 3314600301 (0xc590c96d)
      SA remaining duration (kilobytes/sec): 1843196/3462
      Max received sequence-number: 29
      Status: Active
    [Outbound ESP SAs]
      SPI: 3370073640 (0xc8df3e28)
      Max sent sequence-number: 29
      Status: Active
Configuration files
·     Router A:
 ipv6 address 2001::1 64
 apn-profile vpdn1
 pdp-type ipv4v6
 apn static vpdn
 eth-channel 0
 dialer-group 1
 dialer timer idle 0
 ipv6 route-static :: 0 eth-channel 1/0:0
 acl advanced 3000
 rule 0 permit ipv6 source 2001::/64 destination 2002::/64
 protocol esp
 ike keychain key1
 pre-shared-key address 192.168.0.1 255.255.255.0 key cipher $c$3$0kzuqazKcTGikVRekZ1E8R7jTOC2ZrJR2A==
 pre-shared-key address ipv6 2003::1 64 key cipher $c$3$+93VGZhgfe4yG5D0d9VsLxWS6dlGVw2/Fw==
 ike profile ike1
 keychain key1
 match remote identity address 192.168.0.1 255.255.255.0
 transform-set tran1
 ike-profile ike1
 security acl 3000
 transform-set tran1
 ike-profile ike1
·     LAC:
 service-type ppp
 domain system
 l2tp enable
 tunnel name LAC
 lns-ip 10.1.1.2
·     Router B:
 ip address 192.168.1.2 255.255.255.0
 ipv6 address 2002::1 64
 service-type ppp
 domain system
 l2tp enable
 tunnel name LNS
 acl advanced 3000
 rule 0 permit ipv6 source 2002::/64 destination 2001::/64
 protocol esp
 ike keychain key1
 pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $c$3$vZXXcxKbhB/YCMg4oFr5IVJyrxwQTcB4Mg==
 pre-shared-key address ipv6 0::0 0 key cipher $c$3$ua9potCkbZArSufmcQhY+LgLA+38vxmiXw==
 ike profile ike1
 keychain key1
 match remote identity address ipv6 :: 0
 transform-set tran1
 ike-profile ike1
 security acl 3000
 transform-set tran1
 ike-profile ike1
Example: Configuring 5G modem IPv6 dialup
As shown in Figure 6, Router A has a 5G modem module. The user accesses the IPv6 5G network through auto-dial DDR and a permanent online connection is established. Configure Router A to meet the following requirements:
·     Enable traditional DDR on Eth-channel 1/0:0. Set the dial string for placing calls based on the service provider. Typically, set the dial string for placing calls to *99# for China Mobile or China Unicom and #777 for China Telecom in China mainland.
·     Configure DDR to place calls for only IPv6 packets.
Figure 6 Network diagram
Analysis
Procedures
# On Eth-channel 1/0:0, configure an IPv6 source prefix mapping from 2001::/64 to 2002:0DF8:0001::/48.
[RouterA-Eth-channel1/0:0] nat66 prefix source 2001:: 64 2002:0df8:0001:: 48
[RouterA] ipv6 route-static :: 0 eth-channel 1/0:0
[RouterA] display ipv6 routing-table
Destinations : 6        Routes : 6
Destination: ::/0                                        Protocol  : Static
NextHop    : ::1                                         Preference: 60
Interface  : E-CH1/0:0                                   Cost      : 0
Destination: 100::/128                                   Protocol  : Direct
NextHop    : ::1                                         Preference: 4
Interface  : InLoop0                                     Cost      : 0
Destination: 100::1/128                                  Protocol  : Direct
Destination: 100::7B/128                                 Protocol  : Direct
# Verify that the host can ping the external network, such as Baidu.
C:\Users\host1>ping www.baidu.com
Pinging www.baidu.com [112.80.248.76] with 32 bytes of data:
Reply from 112.80.248.76: Bytes=32 time=91ms TTL=122
Reply from 112.80.248.76: Bytes=32 time=92ms TTL=122
Reply from 112.80.248.76: Bytes=32 time=81ms TTL=122
Reply from 112.80.248.76: Bytes=32 time=88ms TTL=122
Ping statistics for 112.80.248.76:
Approximate round trip time in milli-seconds:
    Minimum = 81ms, Maximum = 92ms, Average = 88ms
Configuration files
 apn dynamic
 eth-channel 0
 eth-channel 0
 dialer-group 1
 dialer timer idle 0
