H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
46-VLAN Configuration Examples
46-VLAN Configuration Examples 76.74 KB
H3C Routers
Introduction
The following information provides examples for VLAN.
This document applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of VLAN.
Restrictions and guidelines: VLAN compatibility
This feature is supported only by Layer 2 interfaces.
Example: Configuring port-based VLANs
As shown in Figure 1:
·     Host A and Host C belong to Department A. VLAN 100 is assigned to Department A.
·     Host B and Host D belong to Department B. VLAN 200 is assigned to Department B.
Configure port-based VLANs so that only hosts in the same department can communicate with each other.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
Procedures
1.     Configure Device A
# Batch set the link mode to bridge for GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-if-range] port link-mode bridge
[DeviceA-if-range] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/1 to VLAN 100.
[DeviceA] vlan 100
[DeviceA-vlan100] port gigabitethernet 1/0/1
[DeviceA-vlan100] quit
# Create VLAN 200, and assign GigabitEthernet 1/0/2 to VLAN 200.
[DeviceA] vlan 200
[DeviceA-vlan200] port gigabitethernet 1/0/2
[DeviceA-vlan200] quit
# Configure GigabitEthernet 1/0/3 as a trunk port, and assign the port to VLANs 100 and 200.
[DeviceA-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-GigabitEthernet1/0/3] port trunk permit vlan 100 200
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
3.     Configure hosts:
¡     Configure Host A and Host C to be on the same IP subnet. For example, 192.168.100.0/24.
¡     Configure Host B and Host D to be on the same IP subnet. For example, 192.168.200.0/24.
# Verify that Host A and Host C can ping each other, but they both fail to ping Host B.
# Verify that Host B and Host D can ping each other, but they both fail to ping Host A.
# Verify that VLANs 100 and 200 are correctly configured on Device A.
[DeviceA-GigabitEthernet1/0/3] display vlan 100
 VLAN ID: 100
 VLAN type: Static
 Description: VLAN 0100
 Tagged ports:
 Untagged ports:
    GigabitEthernet1/0/1
[DeviceA-GigabitEthernet1/0/3] display vlan 200
 VLAN ID: 200
 VLAN type: Static
 Description: VLAN 0200
 Tagged ports:
 Untagged ports:
    GigabitEthernet1/0/2
Configuration files
The configuration on Device B is the same as that on Device A. The following is the configuration file for Device A.
vlan 100
vlan 200
 port access vlan 100
 port access vlan 200
 port trunk permit vlan 1 100 200
Related documentation
·     H3C MSR1000[2600][3600] Routers Configuration Guides (V9)
·     H3C MSR1000[2600][3600] Routers Command References (V9)
