H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
14-IGMP Configuration Examples
14-IGMP Configuration Examples 163.04 KB
H3C Routers
Introduction
The following information provides IGMP configuration examples.
Internet Group Management Protocol (IGMP) establishes and maintains the multicast group memberships between a Layer 3 multicast device and the hosts on the directly connected subnet.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IGMP.
Example: Configuring basic IGMP
As shown in Figure 1, OSPF and PIM-DM run on the network. VOD streams are sent to receiver hosts in multicast. Receiver hosts of different organizations form stub networks N1 and N2. Host A and Host C are receiver hosts in N1 and N2, respectively. IGMPv2 runs between Router A and N1, and between the other two routers and N2. Router A acts as the IGMP querier in N1. Router B acts as the IGMP querier in N2 because it has a lower IP address. Configure the routers to meet the following requirements:
·     The hosts in N1 can join any multicast groups.
·     The hosts in N2 can join only multicast group 224.1.1.1.
Figure 1 Network diagram
Analysis
·     Configure the same multicast group policy on all routers in N2.
·     To control the multicast groups that hosts can join, create a basic ACL and configure a rule to specify a multicast group range.
Software versions used
This configuration example was created and verified on Release 9141P16 of the MSR2630E-X1 router.
Because messages vary with different IGMP versions, configure the same IGMP version for all routers on the same subnet for IGMP to work properly.
Procedures
1.     Configure the interface IP addresses, unicast routing protocol, and multicast routing protocol for each router in the PIM-DM domain:
# Assign an IP address and subnet mask to each interface. (Details not shown.)
# Configure OSPF for interconnection between the routers. Enable PIM-DM on each router. PIM-DM enables the router to establish multicast forwarding entries, which can be used to forward multicast data from the source to receivers.
2.     Configure Router A:
# Enable IP multicast routing, enable PIM-DM on GigabitEthernet 0/0/2, and enable IGMP on GigabitEthernet 0/0/1.
[RouterA] multicast routing
[RouterA-mrib] quit
[RouterA] interface gigabitethernet 0/0/1
[RouterA-GigabitEthernet0/0/1] igmp enable
[RouterA-GigabitEthernet0/0/1] quit
[RouterA] interface gigabitethernet 0/0/2
[RouterA-GigabitEthernet0/0/2] pim dm
[RouterA-GigabitEthernet0/0/2] quit
3.     Configure Router B:
# Enable IP multicast routing, enable PIM-DM on GigabitEthernet 0/0/2, and enable IGMP on GigabitEthernet 0/0/1. Configure a multicast group policy so that the hosts in N2 can join only multicast group 224.1.1.1.
<RouterB> system-view
[RouterB] acl number 2001
[RouterB-acl-basic-2001] rule permit source 224.1.1.1 0
[RouterB-acl-basic-2001] quit
[RouterB] multicast routing
[RouterB-mrib] quit
[RouterB] interface gigabitethernet 0/0/1
[RouterB-GigabitEthernet0/0/1] igmp enable
[RouterB-GigabitEthernet0/0/1] igmp group-policy 2001
[RouterB-GigabitEthernet0/0/1] quit
[RouterB] interface gigabitethernet 0/0/2
[RouterB-GigabitEthernet0/0/2] pim dm
[RouterB-GigabitEthernet0/0/2] quit
4.     Configure Router C:
<RouterC> system-view
[RouterC] acl number 2001
[RouterC-acl-basic-2001] rule permit source 224.1.1.1 0
[RouterC-acl-basic-2001] quit
[RouterC] multicast routing
[RouterC-mrib] quit
[RouterC] interface gigabitethernet 0/0/1
[RouterC-GigabitEthernet0/0/1] igmp enable
[RouterC-GigabitEthernet0/0/1] igmp group-policy 2001
[RouterC-GigabitEthernet0/0/1] quit
[RouterC] interface gigabitethernet 0/0/2
[RouterC-GigabitEthernet0/0/2] pim dm
[RouterC-GigabitEthernet0/0/2] quit
After the configuration, send IGMP reports with multicast group address 224.1.1.1 and IGMP reports with multicast group address 224.1.1.2 from Host C (IP address 10.110.2.10) in N2. Use the display igmp group command to display information about IGMP multicast groups on Router B and Router C.
# Display information about IGMP multicast groups on Router B.
[RouterB] display igmp group
IGMP groups in total:  1.
GigabitEthernet0/0/1(10.110.2.1):
  IGMP groups reported in total: 1
  Group address   Last reporter   Uptime      Expires
   224.1.1.1       10.110.2.10     00:02:04    00:01:15
# Display information about IGMP multicast groups on Router C.
[RouterC] display igmp group
IGMP groups in total:  1..
GigabitEthernet0/0/1(10.110.2.2):
Host C sent IGMP reports with multicast group address 224.1.1.1 and IGMP reports with multicast group address 224.1.1.2. However, only information about multicast group 224.1.1.1 exists on Router B and Router C. This indicates that the multicast group policy has taken effect on Router B and Router C. Multicast receivers in N2 can join only multicast group 224.1.1.1.
Configuration files
·     Router A:
interface GigabitEthernet0/0/1
 port link-mode route
 igmp enable
interface GigabitEthernet0/0/2
 pim dm
multicast routing
·     Router B:
 igmp enable
 pim dm
multicast routing
acl number 2001
 rule 0 permit source 224.1.1.1 0
·     Router C:
 pim dm
 igmp enable
multicast routing
acl number 2001
Example: Configuring IGMP SSM mapping
As shown in Figure 2, the PIM-SSM network provides service for SSM group range 232.1.1.0/24. Router A and Router B run IGMPv3. Host A in N1 and Host C in N2 run IGMPv1 or IGMPv2 and do not support IGMPv3. Other hosts run IGMPv3.
Configure the IGMP SSM mapping feature on the routers to meet the following requirements:
·     The hosts in N1 can receive multicast packets from only Source 1.
·     The hosts in N2 can receive multicast packets from only Source 2.
Figure 2 Network diagram
Procedures
1.     Configure IP addresses and unicast routing protocols:
# Configure IP addresses and subnet masks for interfaces as shown in Figure 2. (Details not shown.)
# Configure OSPF for interconnection between the routers. (Details not shown.)
2.     Enable IP multicast routing, and enable PIM-SM on interfaces:
# Enable IP multicast routing on Router A, and enable PIM-SM on GigabitEthernet 0/0/1.
[RouterA-mrib] quit
[RouterA-GigabitEthernet0/0/1] pim sm
# Configure Router B in the same way Router A is configured. (Details not shown.)
# Enable IP multicast routing on Router C, and enable PIM-SM on each interface.
[RouterC-mrib] quit
[RouterC-GigabitEthernet0/0/1] pim sm
[RouterC-GigabitEthernet0/0/2] pim sm
[RouterC] interface gigabitethernet 0/0/3
[RouterC-GigabitEthernet0/0/3] pim sm
[RouterC-GigabitEthernet0/0/3] quit
3.     Configure a C-BSR and a C-RP on Router C.
[RouterC] pim
[RouterC-pim] c-bsr 192.168.1.1
[RouterC-pim] c-rp 192.168.1.1
[RouterC-pim] quit
4.     Enable IGMPv3 on the interfaces connecting to N1 and N2:
# Enable IGMPv3 on GigabitEthernet 0/0/2 of Router A.
[RouterA-GigabitEthernet0/0/2] igmp enable
[RouterA-GigabitEthernet0/0/2] igmp version 3
5.     Configure SSM multicast group ranges:
# Configure the SSM group range as 232.1.1.0/24 on Router A.
[RouterA] acl number 2000
[RouterA-acl-basic-2000] rule permit source 232.1.1.0 0.0.0.255
[RouterA-acl-basic-2000] quit
[RouterA] pim
[RouterA-pim] ssm-policy 2000
[RouterA-pim] quit
# Configure Router B and Router C in the same way Router A is configured. (Details not shown.)
6.     Configure IGMP SSM mappings:
# Configure an IGMP SSM mapping on Router A so that multicast receivers in N1 can receive multicast packets from only Source 1.
[RouterA] igmp
[RouterA-igmp] ssm-mapping 10.110.5.100 2000
[RouterA-igmp] quit
# Configure an IGMP SSM mapping on Router B so that multicast receivers in N2 can receive multicast packets from only Source 2.
[RouterB] igmp
[RouterB-igmp] ssm-mapping 10.110.5.101 2000
[RouterB-igmp] quit
After the configuration, send IGMPv2 reports with multicast group address 232.1.1.1 from Host A and Host C. Verify the configuration on Router A and Router B.
1.     Verify the configuration on Router A:
# View the IGMP SSM mapping for multicast group 232.1.1.1.
[RouterA] display igmp ssm-mapping 232.1.1.1
 Group: 232.1.1.1
 Source list:
        10.110.5.100
# View the PIM routing table information on Router A.
[RouterA] display pim routing-table
(10.110.5.100, 232.1.1.1)
     Protocol: pim-ssm, Flag:
     UpTime: 00:00:47
     Upstream interface: GigabitEthernet0/0/1
         Upstream neighbor: 192.168.1.1
         RPF prime neighbor: 192.168.1.1
         1: GigabitEthernet0/0/2
             Protocol: igmp, UpTime: 00:00:47, Expires: -
2.     Verify the configuration on Router B:
[RouterB] display igmp ssm-mapping 232.1.1.1
 Group: 232.1.1.1
 Source list:
        10.110.5.101
# View the PIM routing table information on Router B.
[RouterB] display pim routing-table
(10.110.5.101, 232.1.1.1)
     UpTime: 00:00:47
         Upstream neighbor: 192.168.2.1
         RPF prime neighbor: 192.168.2.1
The output shows that Router A has translated (0.0.0.0, 232.1.1.1) in IGMPv2 reports into  (10.110.5.100, 232.1.1.1) and that Router B has translated (0.0.0.0, 232.1.1.1) in IGMPv2 reports into  (10.110.5.101, 232.1.1.1). After the translation, Host A can receive multicast packets from only Source 1. Host C can receive multicast packets from only Source 2.
Configuration files
·     Router A:
 pim sm
 igmp enable
 igmp version 3
multicast routing
pim
 ssm-policy 2000
igmp
acl number 2000
 rule 0 permit source 232.1.1.0 0.0.0.255
·     Router B:
 pim sm
 igmp enable
 igmp version 3
multicast routing
pim
 ssm-policy 2000
igmp
acl number 2000
·     Router C:
 pim sm
 pim sm
interface GigabitEthernet0/0/3
 pim sm
multicast routing
pim
 c-bsr 192.168.1.1
 c-rp 192.168.1.1
Example: Configuring IGMP proxying
As shown in Figure 3, N1 and N2 are connected to Router B (IGMP querier) in the PIM-DM domain through Router A.
Configure the IGMP proxying feature on Router A so that Router A can forward multicast packets to receivers in N1 and N2 without running PIM-DM.
Figure 3 Network diagram
Analysis
Enable IGMP proxying on the upstream interface of the IGMP proxy, so the IGMP proxy acts as a host for the upstream IGMP querier. Enable IGMP on the downstream interface of the IGMP proxy, so the IGMP proxy acts as an IGMP querier for the downstream receiver hosts.
·     Before you enable IGMP proxying, you must enable IP multicast routing.
·     If you enable both IGMP proxying and IGMP on the same interface, IGMP does not take effect. On an interface enabled with IGMP proxying, only the igmp version command takes effect and other IGMP commands do not take effect.
·     If you enable both IGMP proxying and a multicast routing protocol (such as PIM or MSDP) on the same device, the multicast routing protocol does not take effect.
Procedures
1.     Configure IP addresses:
# Configure IP addresses and subnet masks for interfaces as shown in Figure 3. (Details not shown.)
# Configure OSPF for interconnection between the routers in the PIM-DM domain. (Details not shown.)
# Enable IP multicast routing, and enable IGMP proxying on GigabitEthernet 0/0/1.
[RouterA-mrib] quit
[RouterA-GigabitEthernet0/0/1] igmp proxy enable
# Enable IGMP on receiver-side interfaces GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3.
[RouterA] interface gigabitethernet 0/0/3
[RouterA-GigabitEthernet0/0/3] igmp enable
[RouterA-GigabitEthernet0/0/3] quit
# Enable IP multicast routing, and enable PIM-DM on GigabitEthernet 0/0/2.
[RouterB-mrib]quit
[RouterB-GigabitEthernet0/0/1] pim dm
# Enable IGMP on receiver-side interface GigabitEthernet 0/0/1.
After the configuration, send IGMP reports with multicast group address 224.1.1.1 from Host A in N1. Use the display igmp group command to display information about IGMP multicast groups on Router A and Router B.
# View information about IGMP multicast groups for GigabitEthernet 0/0/2 on Router A.
[RouterA] display igmp group interface GigabitEthernet0/0/2
GigabitEthernet0/0/2(10.110.1.1):
   224.1.1.1       10.110.1.10    00:02:04    00:01:15
# View information about IGMP multicast groups maintained by the IGMP proxy on Router A.
[RouterA] display igmp proxy group
IGMP proxy group records in total: 1
 GigabitEthernet0/0/1(192.168.1.1):
   Group address      Member state      Expires
   224.1.1.1          Delay            00:00:02
The output shows that GigabitEthernet 0/0/2 on Router A establishes and maintains group memberships after receiving IGMP reports from hosts. For the hosts, the downstream interface on Router A acts as an IGMP querier.
# View information about IGMP multicast groups for GigabitEthernet 0/0/1 on Router B.
[RouterB] display igmp group interface GigabitEthernet0/0/1
GigabitEthernet0/0/1(192.168.1.2):
   224.1.1.1       192.168.1.1      00:02:04    00:01:15
The output shows that GigabitEthernet 0/0/1 on Router B establishes and maintains group memberships after receiving IGMP reports from the IGMP proxy. For the upstream  IGMP querier (Router B), the upstream interface on Router A acts as a host.
Configuration files
·     Router A:
 igmp proxy enable
 igmp enable
 igmp enable
multicast routing
·     Router B:
 igmp enable
 pim dm
multicast routing
Related documentation
·     IP Multicast Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     IP Multicast Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
