H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
20-IS-IS Configuration Examples
20-IS-IS Configuration Examples 182.46 KB
H3C Routers
Introduction
This document provides IS-IS configuration examples.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IS-IS.
Example: Configuring IS-IS
As shown in Figure 1, the company's headquarters and the branch run IS-IS. The partner runs OSPF.
Configure the routers to meet the following requirements:
·     The Marketing department can reach the F&A department, the branch, and the partner.
·     The F&A department and the branch cannot reach each other, and the branch does not have a route to the F&A department.
·     When the IS-IS process on Router C restarts, the communication is not interrupted.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To reduce traffic for Router A and Router B, configure them as Level-1 routers to allow communication only between the Marketing department and the F&A department.
·     Configure Router C to use a prefix list to advertise only network 10.100.1.0/24 to Level-2 to ensure that the branch does not have a route to the F&A department.
·     Configure route redistribution between IS-IS and OSPF on Router D to allow communication between the Marketing department and the partner.
·     Enable IS-IS Graceful Restart (GR) on Router C to ensure that the communication is not interrupted when the IS-IS process on Router C restarts.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
To avoid blackhole routes, do not change the network topology during the IS-IS GR process.
Procedures
Configuring Router A
# Configure an IP address for GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] ip address 192.168.1.1 24
# Configure IP addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Configure IS-IS.
[RouterA] isis 1
[RouterA-isis-1] is-level level-1
[RouterA-isis-1] network-entity 10.1921.6800.1001.00
[RouterA-isis-1] quit
[RouterA–GigabitEthernet1/0/1] isis enable 1
[RouterA–GigabitEthernet1/0/1] quit
[RouterA–GigabitEthernet1/0/2] isis enable 1
[RouterA–GigabitEthernet1/0/2] quit
Configuring Router B
<RouterB> system-view
[RouterB-GigabitEthernet1/0/1] ip address 192.168.2.1 24
# Configure IS-IS.
[RouterB] isis 1
[RouterB-isis-1] is-level level-1
[RouterB-isis-1] network-entity 10.1921.6800.2001.00
[RouterB-isis-1] quit
[RouterB–GigabitEthernet1/0/1] isis enable 1
[RouterB–GigabitEthernet1/0/1] quit
[RouterB–GigabitEthernet1/0/2] isis enable 1
[RouterB–GigabitEthernet1/0/2] quit
Configuring Router C
<RouterC> system-view
[RouterC-GigabitEthernet1/0/1] ip address 192.168.1.2 24
# Configure IS-IS.
[RouterC] isis 1
[RouterC-isis-1] network-entity 10.1921.6801.0001.00
[RouterC-isis-1] quit
[RouterC–GigabitEthernet1/0/1] isis enable 1
[RouterC–GigabitEthernet1/0/1] quit
[RouterC–GigabitEthernet1/0/2] isis enable 1
[RouterC–GigabitEthernet1/0/2] quit
[RouterC] interface gigabitethernet 1/0/3
[RouterC–GigabitEthernet1/0/3] isis enable 1
[RouterC–GigabitEthernet1/0/3] quit
# Configure route leaking from Level-1 to Level-2, and use prefix list 1 to advertise only network 10.100.1.0/24 to Level-2.
[RouterC] ip prefix-list 1 permit 10.100.1.0 24
[RouterC] isis 1
[RouterC-isis-1] address-family ipv4
[RouterC-isis-1-ipv4] import-route isis level-1 into level-2 filter-policy prefix-list 1
[RouterC-isis-1-ipv4] quit
# Enable IS-IS GR.
[RouterC -isis-1] graceful-restart
[RouterC -isis-1] quit
Configuring Router D
<RouterD> system-view
[RouterD-GigabitEthernet1/0/1] ip address 192.168.10.2 24
[RouterD-GigabitEthernet1/0/1] quit
# Configure IS-IS.
[RouterD] isis 1
[RouterD-isis-1] is-level level-2
[RouterD-isis-1] network-entity 20.1921.6802.0001.00
[RouterD-isis-1] quit
[RouterD–GigabitEthernet1/0/1] isis enable 1
[RouterD–GigabitEthernet1/0/1] quit
[RouterD] interface gigabitethernet 1/0/2
[RouterD–GigabitEthernet1/0/2] isis enable 1
[RouterD–GigabitEthernet1/0/2] quit
# Configure OSPF.
[RouterD] ospf
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
# Redistribute OSPF and direct routes into IS-IS.
[RouterD] isis 1
[RouterD-isis-1] address-family ipv4
[RouterD-isis-1-ipv4] import-route ospf
[RouterD-isis-1-ipv4] import-route direct
[RouterD-isis-1-ipv4] quit
# Redistribute IS-IS and direct routes into OSPF.
[RouterD] ospf 1
[RouterD-ospf-1] import-route isis 1
[RouterD-ospf-1] import-route direct
Configuring Router E
<RouterE> system-view
[RouterE] interface gigabitethernet 1/0/1
[RouterE-GigabitEthernet1/0/1] ip address 192.168.20.2 24
[RouterE-GigabitEthernet1/0/1] quit
# Configure OSPF.
[RouterE] ospf
[RouterE-ospf-1] area 0
[RouterE-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] network 10.200.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] quit
[RouterE-ospf-1] quit
# View the IS-IS routing table on Router D and verify that the branch can reach the Marketing department, but cannot reach the F&A department.
[RouterD] display isis route
                         Level-2 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 192.168.10.0/24      10         NULL    GE1/0/1         Direct          D/L/-
 192.168.1.0/24       20         NULL    GE1/0/1         192.168.10.1    R/-/-
 10.100.1.0/24        30         NULL    GE1/0/1         192.168.10.1    R/-/-
 192.168.2.0/24       20         NULL    GE1/0/1         192.168.10.1    R/-/-
 192.168.20.0/24      10         NULL    GE1/0/2         Direct          D/L/-
# Verify that the company can communicate with the partner.
·     Display the IS-IS routing table on Router C.
[RouterC] display isis route
                         Level-1 IPv4 Forwarding Table
 192.168.10.0/24      10         NULL    GE1/0/3         Direct          D/L/-
 192.168.1.0/24       10         NULL    GE1/0/1         Direct          D/L/-
 10.100.1.0/24        20         NULL    GE1/0/1         192.168.1.1     R/L/-
 10.100.2.0/24        20         NULL    GE1/0/2         192.168.2.1     R/-/-
 192.168.2.0/24       10         NULL    GE1/0/2         Direct          D/L/-
 10.200.1.0/24        10         0       GE1/0/3         192.168.10.2    R/-/-
 192.168.20.0/24      10         0       GE1/0/3         192.168.10.2    R/-/-
·     Ping 10.200.1.1 from Router C.
[RouterC] ping 10.200.1.1
Ping 10.200.1.1 (10.200.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.200.1.1: icmp_seq=0 ttl=254 time=1.862 ms
56 bytes from 10.200.1.1: icmp_seq=1 ttl=254 time=2.969 ms
56 bytes from 10.200.1.1: icmp_seq=2 ttl=254 time=1.402 ms
56 bytes from 10.200.1.1: icmp_seq=3 ttl=254 time=1.324 ms
56 bytes from 10.200.1.1: icmp_seq=4 ttl=254 time=1.510 ms
--- Ping statistics for 10.200.1.1 ---
round-trip min/avg/max/std-dev = 1.324/1.813/2.969/0.606 ms
# Verify that the communication is not interrupted when the IS-IS process restarts.
·     Ping Router B from Router A.
[RouterA] ping -c 10000 10.100.2.1
Ping 10.100.2.1 (10.100.2.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.100.2.1: icmp_seq=0 ttl=254 time=1.185 ms
56 bytes from 10.100.2.1: icmp_seq=1 ttl=254 time=1.087 ms
·     Restart the IS-IS process on Router C.
[RouterC] quit
<RouterC> reset isis all graceful-restart
Reset IS-IS process? [Y/N] :y
# Ping Router B from Router A and verify that the communication is not interrupted when the IS-IS process restarts.
56 bytes from 13.13.13.3: icmp_seq=2 ttl=254 time=1.672 ms
56 bytes from 13.13.13.3: icmp_seq=3 ttl=254 time=1.751 ms
56 bytes from 13.13.13.3: icmp_seq=4 ttl=254 time=1.816 ms
56 bytes from 13.13.13.3: icmp_seq=5 ttl=254 time=1.814 ms
# Check the IS-IS GR state on Router C.
<RouterC> display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
                          Level-1 restart information
Total number of interfaces: 3
Number of waiting LSPs: 0
                          Level-2 restart information
Configuration files
Router A
isis 1
 is-level level-1
 isis enable 1
 ip address 10.100.1.1 255.255.255.0
 isis enable 1
Router B
isis 1
 is-level level-1
 ip address 192.168.2.1 255.255.255.0
 isis enable 1
 ip address 10.100.2.1 255.255.255.0
 isis enable 1
Router C
isis 1
 graceful-restart
 address-family ipv4 unicast
 ip address 192.168.1.2 255.255.255.0
 isis enable 1
 ip address 192.168.2.2 255.255.255.0
 isis enable 1
 ip address 192.168.10.1 255.255.255.0
 isis enable 1
 ip prefix-list 1 index 10 permit 10.100.1.0 24
Router D
isis 1
 is-level level-2
  import-route direct
  import-route ospf 1
ospf 1
 import-route direct
 import-route isis 1
 area 0.0.0.0
 ip address 192.168.10.2 255.255.255.0
 isis enable 1
 ip address 192.168.20.1 255.255.255.0
Router E
ospf 1
 area 0.0.0.0
 ip address 192.168.20.2 255.255.255.0
 ip address 10.200.1.1 255.255.255.0
Example: Configuring IS-IS route summarization
As shown in Figure 2, the five departments of a company use IS-IS to connect to the backbone network. The five departments are assigned the networks 192.168.1.0/24, 192.168.2.0/24, 192.168.3.0/24, 192.168.4.0/24, and 192.168.5.0/24, respectively. Configure IS-IS route summarization to reduce routing entries and save system resources for Device B.
Figure 2 Network diagram
Analysis
Configure route summarization on Device A, because route summarization applies only to locally generated LSPs.
To avoid blackhole routes, set the summary route to 192.168.0.0/21.
Procedures
Configuring IP addresses for interfaces
# Configure an IP address for GigabitEthernet 1/0/6 on Device A.
[DeviceA] interface gigabitethernet 1/0/6
[DeviceA-GigabitEthernet1/0/6] ip address 172.16.1.1 24
[DeviceA-GigabitEthernet1/0/6] quit
# Configure IP addresses for other interfaces as shown in Figure 2 in the same way GigabitEthernet 1/0/6 is configured. (Details not shown.)
Configuring basic IS-IS
Configuring Device A
# Enable IS-IS on Device A and configure Device A as a Level-1-2 router.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 10.0000.0000.0001.00
[DeviceA-isis-1] is-level level-1-2
[DeviceA-isis-1] quit
# Enable IS-IS on GigabitEthernet 1/0/1.
[DeviceA–GigabitEthernet1/0/1] isis enable 1
[DeviceA–GigabitEthernet1/0/1] quit
# Configure other interfaces in the same way GigabitEthernet 1/0/1 is configured. (Details not shown.)
Configuring Device B
# Enable IS-IS on Device B and configure Device B as a Level-2 router.
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 10.0000.0000.0002.00
[DeviceB-isis-1] is-level level-2
[DeviceB-isis-1] quit
[DeviceB–GigabitEthernet1/0/1] isis enable 1
[DeviceB–GigabitEthernet1/0/1] quit
Configuring the gateways
# Enable IS-IS on GW 1 and configure GW 1 as a Level-1 router.
[GW1] isis 1
[GW1-isis-1] network-entity 10.0001.0001.0001.00
[GW1-isis-1] is-level level-1
[GW1-isis-1] quit
[GW1] interface gigabitethernet 1/0/1
[GW1–GigabitEthernet1/0/1] isis enable 1
[GW1–GigabitEthernet1/0/1] quit
# Configure other gateways in the same way GW 1 is configured. (Details not shown.)
Displaying IS-IS routing information on Device B
# Display IS-IS routing information on Device B to view the network address of each department.
[DeviceB] display isis route
 192.168.1.0/24       30         NULL    GE1/0/1         172.16.1.1      R/-/-
 10.1.1.0/24          20         NULL    GE1/0/1         172.16.1.1      R/-/-
 192.168.2.0/24       30         NULL    GE1/0/1         172.16.1.1      R/-/-
 10.1.2.0/24          20         NULL    GE1/0/1         172.16.1.1      R/-/-
 192.168.3.0/24       30         NULL    GE1/0/1         172.16.1.1      R/-/-
 10.1.3.0/24          20         NULL    GE1/0/1         172.16.1.1      R/-/-
 192.168.4.0/24       30         NULL    GE1/0/1         172.16.1.1      R/-/-
 10.1.4.0/24          20         NULL    GE1/0/1         172.16.1.1      R/-/-
 192.168.5.0/24       30         NULL    GE1/0/1         172.16.1.1      R/-/-
 10.1.5.0/24          20         NULL    GE1/0/1         172.16.1.1      R/-/-
 172.16.1.0/24        10         NULL    GE1/0/1         Direct          D/L/-
# Configure IS-IS route summarization on Device A.
[DeviceA] isis 1
[DeviceA-isis-1] address-family ipv4
[DeviceA-isis-1-ipv4] summary 192.168.0.0 21
# Display IS-IS routing information on Device B.
 192.168.0.0/21       30         NULL    GE1/0/1         172.16.1.1      R/-/-
The output shows that the networks have been summarized into a single network 192.168.0.0/21.
Configuration files
Device A
isis 1
 address-family ipv4
 summary 192.168.0.0 255.255.248.0
 port link-mode route
 isis enable 1
 ip address 10.1.2.1 255.255.255.0
 isis enable 1
 ip address 10.1.3.1 255.255.255.0
 isis enable 1
interface GigabitEthernet1/0/4
 ip address 10.1.4.1 255.255.255.0
 isis enable 1
interface GigabitEthernet1/0/5
 ip address 10.1.5.1 255.255.255.0
 isis enable 1
interface GigabitEthernet1/0/7
 ip address 172.16.1.1 255.255.255.0
 isis enable 1
Device B
isis 1
 is-level level-2
 ip address 172.16.1.2 255.255.255.0
 isis enable 1
GW 1
isis 1
 is-level level-1
 isis enable 1
 isis enable 1
Other gateways
The configuration files for other gateways are similar to the configuration file for GW 1. (Details not shown.)
Related documentation
·     Layer 3—IP Routing Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Layer 3—IP Routing Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
