H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
41-IPv4 NetStream Sampling Configuration Examples
H3C Routers
Introduction
The following information provides examples for configuring IPv4 NetStream sampling on routers.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of samplers and IPv4 NetStream.
Example: Configuring IPv4 NetStream sampling
As shown in Figure 1, the router acts as the gateway to provide external network access. Configure the following settings to collect traffic statistics in the outbound direction on GigabitEthernet 0/0/2 and in the inbound direction on GigabitEthernet 0/0/3 on the router and export the collected data to the NetStream server:
·     Configure random sampling in the outbound direction to select one packet randomly from 200 packets on GigabitEthernet 0/0/2.
·     Configure fixed sampling in the inbound direction to select the first packet from 100 packets on GigabitEthernet 0/0/3.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
Procedures
# Create sampler samplerin in fixed mode and set the rate to 100. The first packet of 100 packets is selected.
[Device] sampler samplerin mode fixed packet-interval 100
# Create sampler samplerout in random mode and set the rate to 200. One packet from 200 packets is selected.
[Device] sampler samplerout mode random packet-interval 200
# Enable IPv4 NetStream to use sampler samplerin to collect statistics for the inbound traffic on GigabitEthernet 0/0/3.
[Device] interface gigabitethernet 0/0/3
[Device-GigabitEthernet0/0/3] ip address 10.0.0.1 24
[Device-GigabitEthernet0/0/3] ip netstream inbound
[Device-GigabitEthernet0/0/3] ip netstream sampler samplerin inbound
[Device-GigabitEthernet0/0/3] quit
#Enable IPv4 NetStream to use sampler samplerout to collect statistics for the outbound traffic on GigabitEthernet 0/0/2.
[Device] interface gigabitethernet 0/0/2
[Device-GigabitEthernet0/0/2] ip address 192.168.0.1 24
[Device-GigabitEthernet0/0/2] ip netstream outbound
[Device-GigabitEthernet0/0/2] ip netstream sampler samplerout outbound
[Device-GigabitEthernet0/0/2] quit
# Specify an IP address for GigabitEthernet 0/0/1.
[Device] interface gigabitethernet 0/0/1
[Device-GigabitEthernet0/0/1] ip address 192.168.1.1 24
[Device-GigabitEthernet0/0/1] quit
# Specify destination address 192.168.1.2 and UDP port 5000 for NetStream data export.
[Device] ip netstream export host 192.168.1.2 5000
# Execute the display sampler command to display configuration information for sampler samplerin and sampler samplerout.
[Device] display sampler
 Sampler name: samplerout
  Mode: random;  Packet-interval: 200
 Sampler name: samplerin
  Mode: fixed;  Packet-interval: 100
# After the router operates for a period of time, use the display ip netstream cache command to view NetStream flow cache configuration and status.
[Device] display ip netstream cache
IP NetStream cache information:
  Active flow timeout               : 30 min
  Inactive flow timeout             : 30 sec
  Max number of entries             : 10000
  IP active flow entries            : 1
  MPLS active flow entries          : 0
  L2 active flow entries            : 0
  IPL2 active flow entries          : 0
  IP flow entries counted           : 7
  MPLS flow entries counted         : 0
  L2 flow entries counted           : 0
  IPL2 flow entries counted         : 0
  Last statistics resetting time    : Never
IP packet size distribution (157 packets in total):
 1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
 .000 .929 .031 .006 .000 .006 .000 .000 .000 .000 .025 .000 .000 .000 .000
  512  544  576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
 Protocol          Total  Packets    Flows  Packets Active(sec) Idle(sec)
                   Flows  /sec       /sec   /flow   /flow       /flow
 TCP-other             3        0        0       26           7        30
 ICMP                  1        0        0        1           0        30
 UDP-BOOTP             1        0        0        4          15        30
 TCP-Telnet            2        0        0       35          24        30
Type DstIP(Port)            SrcIP(Port)            Pro ToS If(Direct)  Pkts
     DstMAC(VLAN)           SrcMAC(VLAN)
     TopLblType(IP/MASK)    Lbl-Exp-S-List
IP   192.168.0.1(23)       192.168.0.2(56839)      6   0   GE0/0/2(I)    1
# Execute the display ip netstream export command to view information about the NetStream data export.
[Device] display ip netstream export
IP export information:
  Flow source interface                           : Not specified
  Flow destination VPN instance                   : Not specified
  Flow destination IP address (UDP)               : 192.168.1.2 (5000)
  Version 5 exported flows number                 : 0
  Version 5 exported UDP datagrams number (failed): 0 (0)
  Version 9 exported flows number                 : 8
  Version 9 exported UDP datagrams number (failed): 6 (6)
Configuration files
interface GigabitEthernet0/0/1
 port link-mode route
interface GigabitEthernet0/0/2
 ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/0/3
 ip address 10.0.0.1 255.255.255.0
Related documentation
·     Network Management and Monitoring Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Network Management and Monitoring Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
