H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
06-ARP Attack Protection Configuration Examples
06-ARP Attack Protection Configuration Examples 144.71 KB
H3C Routers
Introduction
The following information provides examples for configuring ARP attack protection on routers.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of ARP attack protection.
Example: Configuring ARP scanning and fixed ARP
As shown in Figure 1, Host A connects to the external network through a gateway (Router). Configure ARP scanning and fixed ARP to meet the following requirements:
·     Disable the router from learning dynamic ARP entries.
·     Host B cannot access the router.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
Procedures
# Specify an IP address for GigabitEthernet 0/0/1.
<Router> system-view
[Router] interface gigabitethernet 0/0/1
[Router-GigabitEthernet0/0/1] ip address 10.1.1.1 24
# Enable ARP scanning on GigabitEthernet 0/0/1. (The command is not displayed in the configuration file.)
[Router-GigabitEthernet0/0/1] arp scan
This operation may take a long time to collect these ARP entries, and you can press CTRL_C to break. Please specify a right range. Continue?  [Y/N]: y
Scanning ARP. Please wait...
Scanning is complete.
[Router-GigabitEthernet0/0/1]quit
# Display ARP entry information on the router when the network has only one host.
[Router] display arp
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   I-Invalid
IP address      MAC address    VLAN/VSI name Interface                Aging Type
10.1.1.2        0015-e943-7e6a --            --                       --    D
# Convert the existing dynamic ARP entry to a static ARP entry. (The command is not displayed in the configuration file.)
[Router] arp fixup
This command will convert existing dynamic ARP entries to static ARP entries. Continue? [Y/N]:y
Fixup ARP. Please wait...
Fixup is complete.
# Display the converted ARP entry.
10.1.1.2        0015-e943-7e6a --            --                      --    S
# Disable GigabitEthernet 0/0/1 from learning dynamic ARP entries.
[Router-GigabitEthernet0/0/1] arp max-learning-num 0
[Router-GigabitEthernet0/0/1] quit
# Add Host B to the LAN and display ARP entry information on the router.
The output shows that the router does not have any ARP entry for Host B.
# Verify that Host B cannot ping the router.
C:\> ping 10.1.1.1
Pinging 10.1.1.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.1.1.1:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Configuration files
interface GigabitEthernet0/0/1
 port link-mode route
Example: Configuring ARP active acknowledgement
As shown in Figure 2, Host A connects to the external network through a gateway (Router). Configure ARP active acknowledgement to prevent user spoofing.
Figure 2 Network diagram
Procedures
# Enable ARP active acknowledgement.
[Router] arp active-ack enable
# Display authorized ARP entry information on the router.
10.1.1.2        000f-e123-4568 --            GE0/0/1                  20    D
The output shows that the router has an ARP entry for Host A.
# Enable debugging for ARP packets.
<Router> terminal debugging
The current terminal is enabled to display debugging logs.
<Router> debugging arp packet
# Use Host B to send a forged ARP request in which the sender MAC address is 0086-0005-0004 to the gateway. Upon receiving the ARP request, the router finds that the update interval for the corresponding ARP entry is more than 1 minute. Enabled with ARP active acknowledgement, the gateway sends a unicast ARP request in which the target IP and MAC addresses are the IP and MAC addresses in the ARP entry. If the gateway receives an ARP reply within 5 seconds, it compares the sender IP and MAC addresses in the ARP reply with those in the received ARP request.
*Jul  3 18:07:38:660 2013 Router ARP/7/ARP_RCV:  Received an ARP message, operation: 1, sender MAC: 0086-0005-0004, sender IP: 10.1.1.2, target MAC: 0cda-41c7-057f, target IP: 10.1.1.1
*Jul  3 18:07:38:660 2013 Router ARP/7/ARP_SEND:  Sent an ARP message, operation: 1, sender
MAC: 0cda-41c7-057f, sender IP: 10.1.1.1, target MAC: 000f-e123-4568, target IP: 10.1.1.2
*Jul  3 18:07:38:660 2013 Router ARP/7/ARP_SEND:  Sent an ARP message, operation: 2, sender
MAC:0cda-41c7-057f, sender IP: 10.1.1.1, target MAC: 0086-0005-0004, target IP: 10.1.1.2
*Jul  3 18:07:38:660 2013 Router ARP/7/ARP_RCV:  Received an ARP message, operation: 2, sender MAC: 000f-e123-4568, sender IP: 10.1.1.2, target MAC: 0cda-41c7-057f, target IP: 10.1.1.1
The output shows that the received ARP reply is sent from Host A. The sender IP and MAC addresses in the ARP reply matches the ARP entry. Then, the gateway regards the received ARP request as an attack packet.
# Display ARP entry information on the router.
<Router> display arp
The output shows that the ARP entry is not updated.
Configuration files
Example: Configuring source MAC-based ARP attack detection
As shown in Figure 3, the server and PC access the Internet through a gateway (Router).
Configure source MAC-based ARP attack detection on the router to meet the following requirements:
·     If the number of ARP packets received from the PC within 5 seconds exceeds 30, the device generates log messages and filters out subsequent ARP packets from the PC.
·     Exclude the MAC address of the server from source MAC-based ARP attack detection.
Figure 3 Network diagram
Analysis
Enable source MAC-based ARP attack detection on the router and specify the filter handling method.
Procedures
# Enable source MAC-based ARP attack detection and specify the filter handling method.
[Router] arp source-mac filter
# Set the threshold to 30.
[Router] arp source-mac threshold 30
# Set the aging time for ARP attack entries to 60 seconds.
[Router] arp source-mac aging-time 60
# Exclude MAC address 0086-0005-0004 from this detection.
[Router] arp source-mac exclude-mac 0086-0005-0004
# Use the PC to send ARP packets to the router at a rate of 6 pps. Display ARP attack entries detected by source MAC-based ARP attack detection on the router.
<Router> display arp source-mac interface GigabitEthernet0/0/1
Source-MAC          VLAN ID  Interface                Aging-time
The router does not generate any log message or ARP attack entry.
# Use the PC to send ARP packets to the router at a rate of 10 pps. Display ARP attack entries detected by source MAC-based ARP attack detection on the router.
0088-0008-0009      N/A      GE0/0/1                    48
The output shows that the router has generated an ARP attack entry.
# Log messages generated by the router are as follows:
*Jun 20 13:54:42:482 2013 Router ARP/7/ARP_RCV:  Received an ARP message, opera
tion: 1, sender MAC: 0088-0008-0009, sender IP: 10.1.1.20, target MAC: 0cda-41c7
*Jun 20 13:54:42:482 2013 Router ARP/7/ARP_SEND:  Sent an ARP message, operatio
n: 2, sender MAC: 0cda-41c7-057f, sender IP: 10.1.1.1, target MAC: 0088-0008-000
9, target IP: 10.1.1.20
*Jun 20 13:54:42:582 2013 Router ARP/7/ARP_RCV:  Received an ARP message, opera
*Jun 20 13:54:42:582 2013 Router ARP/7/ARP_SEND:  Sent an ARP message, operatio
*Jun 20 13:54:42:682 2013 Router ARP/7/ARP_RCV:  Received an ARP message, opera
*Jun 20 13:54:42:682 2013 Router ARP/7/ARP_SEND:  Sent an ARP message, operatio
# Use the server to send ARP packets to the router at a rate of 10 pps. Display ARP attack entries detected by source MAC-based ARP attack detection on the router.
Configuration files
 shutdown
Example: Configuring ARP source suppression
As shown in Figure 4, the hosts in VLAN 10 and VLAN 20 access the Internet through a gateway (Router).
Configure ARP source suppression on the router to protect the router from processing a large number of unresolvable IP packets from the same IP address.
Figure 4 Network diagram
Procedures
# Specify IP addresses for GigabitEthernet 0/0/1 and GigabitEthernet 0/0/2.
[Router-GigabitEthernet0/0/1] ip address 20.1.1.1 24
[Router] interface gigabitethernet 0/0/2
[Router-GigabitEthernet0/0/2] ip address 10.1.1.1 24
[Router-GigabitEthernet0/0/2] quit
# Enable ARP source suppression.
[Router] arp source-suppression enable
# Configure the router to process a maximum of 2 unresolvable packets per source IP address within 5 seconds.
[Router] arp source-suppression limit 2
# Use Host D to send IP packets with destination address 20.1.1.2 which does not exist in the LAN to the router. Verify how the router processes ARP packets with ARP source suppression enabled.
*Jul 23 17:29:03:061 2014 Router ARP/7/ARP_SEND: Sent an ARP message, operation: 1,
sender MAC: d07e-28e6-6814, sender IP: 20.1.1.1, target MAC: 0000-0000-0000, tar
get IP: 20.1.1.2
*Jul 23 17:29:05:262 2014 Router ARP/7/ARP_SEND: Sent an ARP message, operation: 1,
get IP: 20.1.1.2
*Jul 23 17:29:07:462 2014 Router ARP/7/ARP_SEND: Sent an ARP message, operation: 1,
get IP: 20.1.1.2
*Jul 23 17:29:09:662 2014 Router ARP/7/ARP_SEND: Sent an ARP message, operation: 1,
get IP: 20.1.1.2
*Jul 23 17:29:11:862 2014 Router ARP/7/ARP_SEND: Sent an ARP message, operation: 1,
get IP: 20.1.1.2
*Jul 23 17:29:14:062 2014 Router ARP/7/ARP_SEND: Sent an ARP message, operation: 1,
get IP: 20.1.1.2
The output shows that when the router has processed 2 unresolvable packets from Host D within 5 seconds, it stops processing the packets from Host D until the 5 seconds elapse.
Configuration files
 ip address 20.1.1.1 255.255.255.0
interface GigabitEthernet0/0/2
Related documentation
·     Security Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Security Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
