H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
49-WLAN AC Configuration Examples
49-WLAN AC Configuration Examples 94.71 KB
H3C Routers
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Introduction
This document provides an example for configuring a router that acts as a WLAN AC.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
The following information is provided based on the assumption that you have basic knowledge of WLAN AC.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 router.
Example: Configuring WLAN AC functions
As shown in Figure 1, the AP connects to the router that acts as the AC through a Layer 2 switch. Configure the router to meet the following requirements:
·     The client can access the router through the 2.4G and 5G wireless networks provided by the AP and automatically obtain an IP address in the VLAN 20 network segment.
·     The AP can automatically obtain the IP address in the VLAN 10 network segment.
·     The AP obtains power from the Layer 2 switch through PoE.
Figure 1 Network diagram
Analysis
·     Configure 2.4G and 5G wireless service templates on the router. In this case, to provide clients with a better wireless experience, configure the parameters as follows, considering the environment around the AP:
Wireless service template
SSID
Work mode
Working channel
Maximum transmission rate
2.4G
service1
802.11g
6
19dm
5G
service2
802.11ac
157
19dm
·     Create VLAN 10 and VLAN 20 on the router. Use VLAN 10 to exchange packets between the router and the AP, and bind VLAN 20 to the 2.4G and 5G wireless service templates.
·     Enable the DHCP server function on the router for both the AP and the client to automatically obtain IP addresses.
·     You can adjust the work mode, channel, and maximum transmission rate based on the actual usage of the wireless network.
·     Configure the interface between the router and the switch, along with the port on the switch connecting to the AP, as trunk ports to allow both the AP management VLAN and service VLAN to pass through. Specify the AP management VLAN as the default VLAN.
·     Create a manual AP or enable auto AP to bring the AP online. In this example, a manual AP is created. You can find the AP's serial number on the label at the back of the AP device.
Procedures
Configuring the router
# Configure VLANs and the interface IP addresses.
<Router> system-view
[Router] vlan 10
[Router-vlan10] quit
[Router] vlan 20
[Router-vlan20] quit
[Router] interface GigabitEthernet 0/0/1
[Router-GigabitEthernet0/0/1] port link-mode bridge
[Router-GigabitEthernet0/0/1] port link-type trunk
[Router-GigabitEthernet0/0/1] port trunk pvid vlan 10
[Router-GigabitEthernet0/0/1] port trunk permit vlan 10 20
[Router-GigabitEthernet0/0/1] quit
[Router] interface Vlan-interface 10
[Router-Vlan-interface10] ip address 192.168.10.1 255.255.255.0
[Router-Vlan-interface10] quit
[Router] interface Vlan-interface 20
[Router-Vlan-interface20] ip address 192.168.20.1 255.255.255.0
[Router-Vlan-interface20] quit
# Enable the DHCP Server feature.
[Router] dhcp enable
# Configure DHCP address pool 1 to allocate addresses in subnet 192.168.10.0/24 for APs, and specify the gateway address as 192.168.10.1.
[Router] dhcp server ip-pool 1
[Router-dhcp-pool-1] network 192.168.10.0 mask 255.255.255.0
[Router-dhcp-pool-1] gateway-list 192.168.10.1
[Router-dhcp-pool-1] quit
# Configure DHCP address pool 2  to allocate addresses in subnet 192.168.20.0/24 for clients. Specify the address of the DNS server as the gateway address. In this example, the gateway address is 192.168.20.1.
[Router] dhcp server ip-pool 2
[Router-dhcp-pool-2] network 192.168.20.0 mask 255.255.255.0
[Router-dhcp-pool-2] gateway-list 192.168.20.1
[Router-dhcp-pool-2] dns-list 192.168.20.1
[Router-dhcp-pool-2] quit
# Create a manual AP for the AP to establish a connection with the AC.
[Router] wlan ap ap1 model WA4320H
[Router-wlan-ap-ap1] serial-id 219801A0YG819BE005JC
[Router-wlan-ap-ap1] quit
# Create 2.4G wireless service template map1, specify the SSID as service1, configure clients coming online through the service template to join VLAN 20, and enable the service template.
[Router] wlan service-template map1
[Router-wlan-st-map1] ssid service1
[Router-wlan-st-map1] vlan 20
[Router-wlan-st-map1] service-template enable
[Router-wlan-st-map1] quit
# Configure 2.4G radios. Specify the radio type as 802.11g, specify the work channel as 6, and set the maximum transmit power to 19 dBm.
[Router-wlan-ap-ap1] radio 2
[Router-wlan-ap-ap1-radio-2] type dot11g
[Router-wlan-ap-ap1-radio-2] channel 6
[Router-wlan-ap-ap1-radio-2] max-power 19
# Bind wireless service template map1 to radio 2.
[Router-wlan-ap-ap1-radio-2] radio enable
[Router-wlan-ap-ap1-radio-2] service-template map1
[Router-wlan-ap-ap1]quit
# Create 5G wireless service template map2, specify the SSID as service2, configure clients coming online through the service template to join VLAN 20, and enable the service template.
[Router] wlan service-template map2
[Router-wlan-st-map1] ssid service2
# Configure 5G radios. Specify the radio type as 802.11ac, specify the work channel as 157, and set the maximum transmit power to 19 dBm.
[Router-wlan-ap-ap1] radio 1
[Router-wlan-ap-ap1-radio-1] type dot11ac
[Router-wlan-ap-ap1-radio-1] channel 157
[Router-wlan-ap-ap1-radio-1] max-power 19
# Bind wireless service template map2 to radio 1.
[Router-wlan-ap-ap1-radio-1] radio enable
[Router-wlan-ap-ap1-radio-1] service-template map2
[Router-wlan-ap-ap1-radio-1] quit
[Router]
Configuring the Layer 2 switch
# Configure VLANs and interfaces.
<L2 switch> system-view
[L2 switch] vlan 10
[L2 switch-vlan10] quit
[L2 switch] vlan 20
[L2 switch-vlan20] quit
[L2 switch] interface gigabitethernet 0/0/1
[L2 switch-GigabitEthernet0/0/1] port link-type trunk
[L2 switch-GigabitEthernet0/0/1] port trunk pvid vlan 10
[L2 switch-GigabitEthernet0/0/1] port trunk permit vlan 10 20
[L2 switch-GigabitEthernet0/0/1] quit
[L2 switch] interface gigabitethernet 0/0/2
[L2 switch-GigabitEthernet0/0/2] port link-type trunk
[L2 switch-GigabitEthernet0/0/2] port trunk pvid vlan 10
[L2 switch-GigabitEthernet0/0/2] port trunk permit vlan 10 20
[L2 switch-GigabitEthernet0/0/2] quit
[L2 switch]
# Enable PoE on GigabitEthernet 0/0/2.
[L2 switch-GigabitEthernet0/0/2] poe enable
# View the detailed AP information and verify that the AP has established a connection to the AC and is in Run state.
[Router]display wlan ap name ap1 verbose
AP name                       : ap1
AP ID                         : 1
AP group name                 : default-group
State                         : Run
Backup type                   : Master
Online time                   : 0 days 4 hours 7 minutes 27 seconds
System uptime                 : 0 days 4 hours 17 minutes 4 seconds
Model                         : WA4320H
Region code                   : CN
Region code lock              : Disabled
Serial ID                     : 219801A0YG819BE005JC
MAC address                   : 9429-2f93-14c0
IP address                    : 192.168.0.4
UDP control port number       : 25930
UDP data port number          : 25930
H/W version                   : Ver.B
S/W version                   : R2439P01
Boot version                  : 7.21
USB state                     : Disabled
Power level                   : N/A
Power info                    : N/A
Description                   : Not configured
Priority                      : 4
Echo interval                 : 10 seconds
Echo count                    : 3 counts
# Verify that the client can access the 2.4G and 5G networks through SSIDs service1 and service2, respectively. To view client connections, use the display wlan client verbose command.
[Router]display wlan client verbose
Total number of clients: 2
 MAC address                       : 424a-b9db-91bf
 IPv4 address                      : 192.168.20.3
 IPv6 address                      : N/A
 Username                          : N/A
 AID                               : 2
 AP ID                             : 1
 AP name                           : ap1
 Radio ID                          : 2
 SSID                              : service1
 BSSID                             : 9429-2f93-14d0
 VLAN ID                           : 20
 Sleep count                       : 22
 Wireless mode                     : 802.11g
 Supported rates                   : 1, 2, 5.5, 6, 9, 11,
                                     12, 18, 24, 36, 48, 54 Mbps
 QoS mode                          : WMM
 Listen interval                   : 20
 RSSI                              : 54
 Rx/Tx rate                        : 0/0 Mbps
 Speed                             : N/A
 Authentication method             : Open system
 Security mode                     : PRE-RSNA
 AKM mode                          : Not configured
 Cipher suite                      : N/A
 User authentication mode          : Bypass
 WPA3 status                       : N/A
 Authorization CAR                 : N/A
 Authorization ACL ID              : N/A
 Authorization user profile        : N/A
 Roam status                       : N/A
 Key derivation                    : N/A
 PMF status                        : N/A
 Forwarding policy name            : Not configured
 Online time                       : 0days 0hours 0minutes 6seconds
 FT status                         : Inactive
Configuration files
The router configuration is as follows:
Vlan 10
Vlan 20
interface Vlan-interface10
interface Vlan-interface20
interface GigabitEthernet0/0/1
 port trunk permit vlan 1 10 20
ssid service1
vlan 20
ssid service2
vlan 20
 radio 1
  type dot11ac
  channel 157
  max-power 19
  radio enable
 radio 2
  type dot11g
  channel 6
  max-power 19
  radio enable
Related documentation
·     WLAN Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     WLAN Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
·     WLAN Configuration Guide in H3C MSR Router Series Comware 7 Configuration Guides
·     WLAN Command Reference in H3C MSR Router Series Comware 7 Command References
