H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
55-NAT Hairpin in C-S Mode Configuration Examples
H3C Routers
NAT Hairpin in C/S Mode
Introduction
The following information provides examples for configuring NAT hairpin in C/S mode on routers.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of NAT.
Example: Configuring NAT hairpin in C/S mode
As shown in Figure 1, Host A and the FTP server reside in the same LAN and the router acts as the gateway in the LAN. Configure NAT hairpin to meet the following requirements:
·     External hosts can access the internal FTP server through the router.
·     Host A accesses the FTP server by using a public address to protect the server from internal network attacks.
Figure 1 Network diagram
Analysis
·     Configure an ACL rule and associate it with NAT configuration. Only packets from subnet 192.168.1.0/24 that match the ACL rule are processed by NAT.
·     To allow external hosts to access the internal FTP server by using a public IP address, configure NAT Server on the interface connected to the external network.
·     To allow Host A to access the internal FTP server by using a public IP address, enable NAT hairpin on the interface connected to the internal network.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
Procedures
# Specify IP addresses for GigabitEthernet 0/0/1 and GigabitEthernet 0/0/2.
<Router> system-view
[Router] interface gigabitethernet 0/0/1
[Router-GigabitEthernet0/0/1] ip address 192.168.1.1 24
[Router-GigabitEthernet0/0/1] quit
[Router] interface gigabitethernet 0/0/2
[Router-GigabitEthernet0/0/2] ip address 10.0.0.1 24
[Router-GigabitEthernet0/0/2] quit
# Configure ACL 2000 to identify packets from subnet 192.168.1.0/24.
[Router] acl number 2000
[Router-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Router-acl-ipv4-basic-2000] quit
# Configure a NAT server mapping on GigabitEthernet 0/0/2 to map the IP address of the FTP server to a public address, allowing external users to access the internal FTP server.
[Router-GigabitEthernet0/0/2] nat server protocol tcp global 10.0.0.1 inside 192.168.1.5 ftp
# Enable outbound NAT with Easy IP on GigabitEthernet 0/0/2 so that NAT translates the source addresses of the packets from Host A into the IP address of GigabitEthernet 0/0/2.
[Router-GigabitEthernet0/0/2] nat outbound 2000
# Enable NAT hairpin on GigabitEthernet 0/0/1.
[Router-GigabitEthernet0/0/1] nat hairpin enable
# Verify that both internal and external hosts can access the internal FTP server through the public address. (Details not shown.)
# Execute the display nat all command to display all NAT configuration and statistics and verify that GigabitEthernet 0/0/1 is enabled with NAT hairpin.
[Router] display nat all
NAT outbound information:
  Totally 1 NAT outbound rules.
  Interface: GigabitEthernet0/0/2
    ACL: 2000
    Address group ID: ---
    Port-preserved: N        NO-PAT: N  Reversible: N
    NAT counting: 0
Config status: Active
NAT internal server information:
  Totally 1 internal servers.
    Protocol: 6(TCP)
    Global IP/port: 10.0.0.1/21
    Local  IP/port: 192.168.1.5/21
    NAT counting  : 0
    Config status : Active
NAT logging:
  Log enable          : Disabled
  Flow-begin          : Disabled
  Flow-end            : Disabled
  Flow-active         : Disabled
  Port-block-assign   : Disabled
  Port-block-withdraw : Disabled
  Alarm               : Disabled
  NO-PAT IP usage     : Disabled
NAT hairpinning:
  Totally 1 interfaces enabled with NAT hairpinning.
  Interface: GigabitEthernet0/0/1
NAT mapping behavior:
  Mapping mode: Address and Port-Dependent
  ACL         : ---
NAT ALG:
  DNS        : Enabled
  FTP        : Enabled
  H323       : Enabled
  ICMP-ERROR : Enabled
  ILS        : Enabled
  MGCP       : Enabled
  NBT        : Enabled
  PPTP       : Enabled
  RTSP       : Enabled
  RSH        : Enabled
  SCCP       : Enabled
  SCTP       : Enabled
  SIP        : Enabled
  SQLNET     : Enabled
  TFTP       : Enabled
  XDMCP      : Enabled
Static NAT load balancing:     Disabled
NAT link-switch recreate-session: Disabled
NAT configuration-for-new-connection: Disabled
NAT global-policy compatible-previous-version rule-type ipv4-snat-and-dnat trans
late-before-secp : Disabled
# Execute the display nat session verbose command to display NAT sessions that are generated when Host A accesses the FTP server.
[Router] display nat session verbose
Slot 1:
Initiator:
  Source      IP/port: 192.168.1.2/1694
  Destination IP/port: 10.0.0.1/21
  DS-Lite tunnel peer: -
  VPN instance/VLAN ID/VLL ID: -/-/-
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet0/0/1
Responder:
  Source      IP/port: 192.168.1.5/21
  Destination IP/port: 10.0.0.1/1025
  Protocol: TCP(6)
State: TCP_ESTABLISHED
Application: HTTP
Rule ID: -/-/-
Rule name:
Start time: 2013-08-15 14:53:29  TTL: 3597s
Initiator->Responder:            7 packets        308 bytes
Responder->Initiator:            5 packets        312 bytes
Total sessions found: 1
Configuration files
interface GigabitEthernet0/0/1
 port link-mode route
 nat hairpin enable
interface GigabitEthernet0/0/2
 ip address 10.0.0.1 255.255.255.0
 nat outbound 2000
 nat server protocol tcp global 10.0.0.1 21 inside 192.168.1.5 21
acl number 2000
 rule 0 permit source 192.168.1.0 0.0.0.255
Related documentation
·     NAT and IPv6 Transition Technologies Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     NAT and IPv6 Transition Technologies Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
