H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
40-RMON Configuration Examples
40-RMON Configuration Examples 130.52 KB
H3C Routers
Introduction
This document provides an example for configuring RMON.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the MSR routers.
This document assumes that you have basic knowledge of RMON.
Example: Configuring the Ethernet statistics function
As shown in Figure 1, create an RMON Ethernet statistics entry on the device to gather cumulative traffic statistics for GigabitEthernet 0/0/1.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
# Configure the IP addresses of the router interfaces.
<Router> system-view
[Router] interface gigabitethernet 0/0/1
[Router-GigabitEthernet0/0/1] ip address 10.0.0.1 24
[Router-GigabitEthernet0/0/1] quit
[Router] interface gigabitethernet 0/0/2
[Router-GigabitEthernet0/0/2] ip address 192.168.0.1 24
# Create an RMON statistics entry for GigabitEthernet0/0/2. The index is 10 and the owner is user1.
[Router-GigabitEthernet0/0/2] rmon statistics 10 owner user1
[Router-GigabitEthernet0/0/2] quit
# Display statistics collected for GigabitEthernet0/0/2.
[Router] display rmon statistics gigabitethernet 0/0/2
EtherStatsEntry 10 owned by user1 is VALID.
  Interface : GigabitEthernet0/0/2<ifIndex.3>
  etherStatsOctets         : 21657     , etherStatsPkts          : 307
  etherStatsBroadcastPkts  : 56        , etherStatsMulticastPkts : 34
  etherStatsUndersizePkts  : 0         , etherStatsOversizePkts  : 0
  etherStatsFragments      : 0         , etherStatsJabbers       : 0
  etherStatsCRCAlignErrors : 0         , etherStatsCollisions    : 0
  etherStatsDropEvents (insufficient resources): 0
  Incoming packets by size:
  64     : 235       ,  65-127  : 67        ,  128-255  : 4
  256-511: 1         ,  512-1023: 0         ,  1024-1518: 0
Configuration files
interface GigabitEthernet0/0/1
 port link-mode route
 ip address 10.0.0.1 255.255.255.0
interface GigabitEthernet0/0/2
 ip address 192.168.0.1 255.255.255.0
Example: Configuring the history statistics function
As shown in Figure 2, create an RMON history control entry on the device to sample traffic statistics for GigabitEthernet0/0/2 every minute.
Figure 2 Network diagram
# Create an RMON history control entry to sample traffic statistics every minute for GigabitEthernet0/0/2. Retain a maximum of eight samples for the interface in the history statistics table.
[Router-GigabitEthernet0/0/2] rmon history 1 buckets 8 interval 60 owner user1
# Display the history statistics collected for GigabitEthernet0/0/2.
[Router] display rmon history
HistoryControlEntry 1 owned by user1 is VALID
  Sampled interface     : GigabitEthernet0/0/2<ifIndex.3>
  Sampling interval     : 60(sec) with 8 buckets max
  Sampling record 1 :
    dropevents        : 0         , octets               : 834
    packets           : 8         , broadcast packets    : 1
    multicast packets : 6         , CRC alignment errors : 0
    undersize packets : 0         , oversize packets     : 0
    fragments         : 0         , jabbers              : 0
    collisions        : 0         , utilization          : 0
  Sampling record 2 :
    dropevents        : 0         , octets               : 962
    packets           : 10        , broadcast packets    : 3
  Sampling record 3 :
    dropevents        : 0         , octets               : 830
    packets           : 8         , broadcast packets    : 0
  Sampling record 4 :
    dropevents        : 0         , octets               : 933
    multicast packets : 7         , CRC alignment errors : 0
  Sampling record 5 :
    dropevents        : 0         , octets               : 898
    packets           : 9         , broadcast packets    : 2
  Sampling record 6 :
  Sampling record 7 :
    dropevents        : 0         , octets               : 766
    packets           : 7         , broadcast packets    : 0
  Sampling record 8 :
    dropevents        : 0         , octets               : 1154
    packets           : 13        , broadcast packets    : 1
Configuration files
Example: Configuring the alarm function
As shown in Figure 3, configure the device to monitor the incoming traffic statistic on GigabitEthernet0/0/2, and send RMON alarms when either of the following conditions is met:
·     The 5-second delta sample for the traffic statistic crosses the rising threshold (10000).
·     The 5-second delta sample for the traffic statistic drops below the falling threshold (5000).
Figure 3 Network diagram
Analysis
·     For the NMS to manage and monitor the router, configure the SNMP agent on the router.
·     For the router to periodically monitor the traffic on GigabitEthernet0/0/2, first define an RMON statistics entry to collect traffic statistics.
·     For the router to send traps to the NMS when the traffic on GigabitEthernet0/0/2 is abnormal, create an alarm entry on the router, and set the alarm threshold.
This configuration example was created and verified on R9141P16 of the router and iMC PLAT 7.0(E0202) and iMC UAM 7.0(E0202).
For correct communication between the NMS and router, make sure the following parameters are the same on them:
·     SNMP version.
·     Read community name.
·     Read and write community name.
Procedures
Configuring the router
1.     Configure the IP addresses of the router interfaces.
2.     Configure the SNMP agent.
# Configure the SNMP agent (the device) with the same SNMP settings as the NMS at 10.0.0.100. This example uses SNMPv1, read community public, and write community private.
[Router] snmp-agent
[Router] snmp-agent community read public
[Router] snmp-agent community write private
[Router] snmp-agent sys-info version v1
[Router] snmp-agent trap enable
[Router] snmp-agent target-host trap address udp-domain 10.0.0.100 params securityname public
# Create an RMON event entry and an RMON alarm entry to send SNMP notifications when the delta sample for 1.3.6.1.4.1.25506.2.125.1.1.1 exceeds 10000 or drops below 5000.
[Router] rmon event 1 trap public owner user1
[Router] rmon alarm 1 1.3.6.1.4.1.25506.2.125.1.1.1 5 absolute rising-threshold 10000 1 falling-threshold 5000 1 owner user1
Configuring the NMS
# Add a device.
1.     Log in to IMC.
2.     Click the Resources tab.
3.     From the navigation pane, select Resource Management > Add Device.
¡     On the Add Device page, configure the following parameters:
Enter 10.0.0.1 in the Host Name/IP field.
¡     Set the device label to Router.
¡     Select Telnet from the Login Type list.
¡     Use the default values for other parameters.
Figure 4 Adding a device
# Expand the SNMP Settings section. Click Configure.
·     Set the parameter type to SNMPv1.
·     Set the read community to public.
·     Set the write and read community to private.
·     Use the default settings for other parameters, and then click OK.
Figure 5 Configuring SNMP parameters
# Display the RMON alarm entry.
[Router] display rmon alarm 1
AlarmEntry 1 owned by user1 is VALID.
  Sample type          : absolute
  Sampled variable     : 1.3.6.1.4.1.25506.2.125.1.1.1<etherStatsOctets.1>
  Sampling interval (in seconds)    : 5
  Rising threshold      : 10000(associated with event 1)
  Falling threshold     : 5000(associated with event 1)
  Alarm sent upon entry startup  : risingOrFallingAlarm
  Latest value          : 0
# Display statistics for GigabitEthernet0/0/2.
  etherStatsOctets         : 57329     , etherStatsPkts          : 455
  etherStatsBroadcastPkts  : 53        , etherStatsMulticastPkts : 353
  Incoming packets by size :
  64     : 7         ,  65-127  : 413       ,  128-255  : 35
  256-511: 0         ,  512-1023: 0         ,  1024-1518: 0
Configuration files
 snmp-agent
ame public
Related documentation
·     Network Management and Monitor Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides (V9)
·     Network Management and Monitor Command Reference in H3C MSR1000[2600][3600] Routers Command References (V9)
