H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
27-MPLS TE Configuration Examples
27-MPLS TE Configuration Examples 321.04 KB
H3C Routers
Introduction
MPLS Traffic Engineering (TE) combines the MPLS technology and traffic engineering. It reserves resources by establishing LSP tunnels along the specified paths, allowing traffic to bypass congested nodes to achieve appropriate load distribution.
Setting up a CRLSP through RSVP-TE
MPLS TE supports static and dynamic CRLSP establishment.
·     A static CRLSP is established by manually specifying the incoming label, outgoing label, and other constraints such as bandwidth on each hop (ingress, transit, and egress) along the path that the traffic travels. Static CRLSPs feature simple configuration, but they cannot automatically adapt to network changes.
·     Dynamic CRLSPs are dynamically established as follows:
¡     MPLS TE calculates the shortest path to the LSP destination according to link state information, uses a label distribution protocol (such as RSVP-TE) to advertise labels, and reserves bandwidth resources on each hop along the path, so as to establish CRLSPs that meet the constraints.
¡     Dynamic CRLSPs adapt to network changes and support CRLSP backup and fast reroute, but they require complicated configurations.
This configuration example describes how to establish CRLSPs dynamically with RSVP-TE.
MPLS TE FRR
MPLS TE supports two network protection technologies, FRR and CRLSP backup.
·     Fast reroute (FRR) is a technology in MPLS TE that implements local network protection. After FRR is enabled for an MPLS TE tunnel, once a link or node fails on the primary CRLSP, FRR reroutes the traffic to a bypass tunnel. The ingress node attempts to set up a new CRLSP. After the new CRLSP is set up, traffic is forwarded on the new CRLSP. FRR can implement 50-millisecond CRLSP failover, which can minimize data loss during network failure to the greatest extent.
·     CRLSP backup uses a CRLSP to back up a primary CRLSP. When the ingress detects that the primary CRLSP fails, it switches traffic to the backup CRLSP. When the primary CRLSP recovers, the ingress switches traffic back.
CRLSP backup provides end-to-end path protection for a CRLSP without time limitation. FRR provides quick but temporary protection for a link or node on a CRLSP. Choose FRR or CRLSP backup according to the practical requirements and the characteristics of these two technologies. This configuration example describes the typical application of FRR.
FRR provides the following protection modes:
·     Link protection—This mode is also called next-hop (NHOP) protection. The Point of Local Repair (PLR) and the Merge Point (MP) are connected through a direct link and the primary CRLSP traverses this link. When the link fails, traffic is switched to the bypass tunnel. As shown in Figure 1, the primary CRLSP is Device A—Device B—Device C—Device D, and the bypass tunnel is Device B—Device E—Device C.
Figure 1 FRR link protection
·     Node protection—This mode is also called next-next-hop (NNHOP) protection. The PLR and the MP are connected through a device and the primary CRLSP traverses this device. When the device fails, traffic is switched to the bypass tunnel. As shown in Figure 2, the primary CRLSP is Device A—Device B—Device C—Device D—Device E, and the bypass tunnel is Device B—Device F—Device D. Device C is the protected device.
Figure 2 FRR node protection
This configuration example describes how to configure MPLS TE FRR that provides link protection.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of MPLS TE.
Example: Establishing an MPLS TE tunnel with RSVP-TE
As shown in Figure 3, Enterprise A and Enterprise B each have a headquarters and a branch, which are interconnected through the carrier's MPLS network. The branches have important data to back up to the servers of their respective headquarters. The maximum bandwidth for the data traffic of Enterprise A is 20000 kbps, while the maximum bandwidth for the data traffic of Enterprise B is 30000 kbps.
On the MPLS network, the maximum bandwidth and maximum reservable bandwidth of each link is 50000 kbps and 40000 kbps. Deploy RSVP-TE on the MPLS network to automatically establish MPLS TE tunnels that meet the bandwidth requirements of the enterprises.
Figure 3 Network diagram
Analysis
·     To use RSVP-TE to configure MPLS TE tunnels, configure MPLS, MPLS TE, and RSVP-TE on the backbone network.
·     To allow the two enterprise users to simultaneously transmit data over the MPLS network of the carrier with guaranteed tunnel bandwidth, configure a tunnel interface and specify the tunnel bandwidth for each user on the ingress node.
·     To ensure the that each link has enough bandwidth, configure MPLS TE attributes for links on each interface that the MPLS TE tunnels traverse to specify the link maximum bandwidth and maximum reservable bandwidth.
·     To generate TE database (TEDB) on each node to calculate the constraints-compliant shortest paths to specific nodes, configure OSPF to support MPLS TE on the backbone so that network nodes can advertise MPLS TE attributes of links through OSPF routes.
·     To use RSVP-TE to allocate MPLS TE labels to establish CRLSPs, configure the MPLS TE tunnel ingress nodes to automatically establish CRLSPs through RSVP-TE.
·     To forward traffic along MPLS TE tunnels, configure static routes on the tunnel ingress nodes to direct traffic to the MPLS TE tunnels.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
To use RSVP-TE for dynamic CRLSP establishment, you must configure the TE extension for the IGP to generate TEDB.
The device supports OSPF TE and IS-IS TE. Without TE extension support, paths are calculated based on IGP routes rather than by the Constraint-based Shortest Path First (CSPF) algorithm.
Procedures
Table 1 Assigning IP addresses to the network interfaces
Configure IP addresses and masks for interfaces as shown in Figure 3. (Details not shown.)
Table 2 Configure OSPF on each router to ensure IP connectivity between them:
# Configure Router A.
<RouterA> System-view
[RouterA] ospf
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[RouterA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[RouterA-ospf-1] quit
# Configure Router B.
<RouterB> System-view
[RouterB] ospf
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
# Configure Router C.
<RouterC> System-view
[RouterC] ospf
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
Configure Router D.
<RouterD> System-view
[RouterD] ospf
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[RouterD-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
# After the configuration is completed, execute the display ip routing-table command on each router to verify that the routers have learned the routes to each other, including the loopback interface routes. Take Router A as an example:
Destinations : 21        Routes : 21
1.1.1.1/32         Direct  0   0           127.0.0.1       InLoop0
2.2.2.2/32         O_INTRA 10  1           10.1.1.2        GE0/0/1
3.3.3.3/32         O_INTRA 10  1           30.1.1.3        GE0/0/2
4.4.4.4/32         O_INTRA 10  2           10.1.1.2        GE0/0/1
10.1.1.0/24        Direct  0   0           10.1.1.1        GE0/0/1
10.1.1.0/32        Direct  0   0           10.1.1.1        GE0/0/1
10.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.255/32      Direct  0   0           10.1.1.1        GE0/0/1
20.1.1.0/24        O_INTRA 10  2           10.1.1.2        GE0/0/1
30.1.1.0/24        Direct  0   0           30.1.1.1        GE0/0/2
30.1.1.0/32        Direct  0   0           30.1.1.1        GE0/0/2
30.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
30.1.1.255/32      Direct  0   0           30.1.1.1        GE0/0/2
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
224.0.0.0/4        Direct  0   0           0.0.0.0         NULL0
224.0.0.0/24       Direct  0   0           0.0.0.0         NULL0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
Table 3 Configure the LSR ID, enable MPLS, MPLS TE, and RSVP-TE on each router:
[RouterA] mpls lsr-id 1.1.1.1
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterA] interface gigabitethernet 0/0/1
[RouterA-GigabitEthernet0/0/1] mpls enable
[RouterA-GigabitEthernet0/0/1] mpls te enable
[RouterA-GigabitEthernet0/0/1] rsvp enable
[RouterA-GigabitEthernet0/0/1] quit
[RouterA] interface gigabitethernet 0/0/2
[RouterA-GigabitEthernet0/0/2] mpls enable
[RouterA-GigabitEthernet0/0/2] mpls te enable
[RouterA-GigabitEthernet0/0/2] rsvp enable
[RouterA-GigabitEthernet0/0/2] quit
[RouterB] mpls lsr-id 2.2.2.2
[RouterB] mpls te
[RouterB-te] quit
[RouterB] rsvp
[RouterB-rsvp] quit
[RouterB] interface gigabitethernet 0/0/1
[RouterB-GigabitEthernet0/0/1] mpls enable
[RouterB-GigabitEthernet0/0/1] mpls te enable
[RouterB-GigabitEthernet0/0/1] rsvp enable
[RouterB-GigabitEthernet0/0/1] quit
[RouterB] interface gigabitethernet 0/0/2
[RouterB-GigabitEthernet0/0/2] mpls enable
[RouterB-GigabitEthernet0/0/2] mpls te enable
[RouterB-GigabitEthernet0/0/2] rsvp enable
[RouterB-GigabitEthernet0/0/2] quit
[RouterC] mpls lsr-id 3.3.3.3
[RouterC] mpls te
[RouterC-te] quit
[RouterC] rsvp
[RouterC-rsvp] quit
[RouterC] interface gigabitethernet 0/0/1
[RouterC-GigabitEthernet0/0/1] mpls enable
[RouterC-GigabitEthernet0/0/1] mpls te enable
[RouterC-GigabitEthernet0/0/1] rsvp enable
[RouterC-GigabitEthernet0/0/1] quit
[RouterC] interface gigabitethernet 0/0/2
[RouterC-GigabitEthernet0/0/2] mpls enable
[RouterC-GigabitEthernet0/0/2] mpls te enable
[RouterC-GigabitEthernet0/0/2] rsvp enable
[RouterC-GigabitEthernet0/0/2] quit
Configure Router D.
[RouterD] mpls lsr-id 4.4.4.4
[RouterD] mpls te
[RouterD-te] quit
[RouterD] rsvp
[RouterD-rsvp] quit
[RouterD] interface gigabitethernet 0/0/1
[RouterD-GigabitEthernet0/0/1] mpls enable
[RouterD-GigabitEthernet0/0/1] mpls te enable
[RouterD-GigabitEthernet0/0/1] rsvp enable
[RouterD-GigabitEthernet0/0/1] quit
[RouterD] interface gigabitethernet 0/0/2
[RouterD-GigabitEthernet0/0/2] mpls enable
[RouterD-GigabitEthernet0/0/2] mpls te enable
[RouterD-GigabitEthernet0/0/2] rsvp enable
[RouterD-GigabitEthernet0/0/2] quit
Table 4 Configure MPLS TE attributes for links:
# Configure the maximum link bandwidth and maximum reservable bandwidth on Router A.
[RouterA-GigabitEthernet0/0/1] mpls te max-link-bandwidth 50000
[RouterA-GigabitEthernet0/0/1] mpls te max-reservable-bandwidth 40000
[RouterA-GigabitEthernet0/0/2] mpls te max-link-bandwidth 50000
[RouterA-GigabitEthernet0/0/2] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth and maximum reservable bandwidth on Router B.
[RouterB-GigabitEthernet0/0/1] mpls te max-link-bandwidth 50000
[RouterB-GigabitEthernet0/0/1] mpls te max-reservable-bandwidth 40000
[RouterB-GigabitEthernet0/0/2] mpls te max-link-bandwidth 50000
[RouterB-GigabitEthernet0/0/2] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth and maximum reservable bandwidth on Router C.
[RouterC-GigabitEthernet0/0/1] mpls te max-link-bandwidth 50000
[RouterC-GigabitEthernet0/0/1] mpls te max-reservable-bandwidth 40000
[RouterC-GigabitEthernet0/0/2] mpls te max-link-bandwidth 50000
[RouterC-GigabitEthernet0/0/2] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth and maximum reservable bandwidth on Router D.
[RouterD-GigabitEthernet0/0/1] mpls te max-link-bandwidth 50000
[RouterD-GigabitEthernet0/0/1] mpls te max-reservable-bandwidth 40000
[RouterD-GigabitEthernet0/0/2] mpls te max-link-bandwidth 50000
[RouterD-GigabitEthernet0/0/2] mpls te max-reservable-bandwidth 40000
Table 5 Configure OSPF TE to advertise the MPLS TE attributes of links:
# On Router A, enable opaque LSA advertisement and reception (enabled by default), and enable MPLS TE in OSPF area 0.
[RouterA] ospf
[RouterA-ospf-1] opaque-capability enable
[RouterA-ospf-1-area-0.0.0.0] mpls te enable
# On Router B, enable opaque LSA advertisement and reception (enabled by default), and enable MPLS TE in OSPF area 0.
[RouterB] ospf
[RouterB-ospf-1] opaque-capability enable
[RouterB-ospf-1-area-0.0.0.0] mpls te enable
# On Router C, enable opaque LSA advertisement and reception (enabled by default), and enable MPLS TE in OSPF area 0.
[RouterC] ospf
[RouterC-ospf-1] opaque-capability enable
[RouterC-ospf-1-area-0.0.0.0] mpls te enable
# On Router D, enable opaque LSA advertisement and reception (enabled by default), and enable MPLS TE in OSPF area 0.
[RouterD] ospf
[RouterD-ospf-1] opaque-capability enable
[RouterD-ospf-1-area-0.0.0.0] mpls te enable
Table 6 Configure MPLS tunnels:
# On Router A, configure MPLS TE tunnel interface Tunnel 1 to transfer data for enterprise A. Specify the tunnel destination address as the LSR ID of Router D (4.4.4.4), use RSVP-TE as the MPLS TE tunnel signaling protocol, assign 20000 kbps bandwidth to the tunnel, and enable route recording.
[RouterA] interface tunnel 1 mode mpls-te
[RouterA-Tunnel1] ip address 7.1.1.1 255.255.255.0
[RouterA-Tunnel1] destination 4.4.4.4
[RouterA-Tunnel1] mpls te signaling rsvp-te
[RouterA-Tunnel1] mpls te bandwidth 20000
[RouterA-Tunnel1] mpls te record-route
[RouterA-Tunnel1] quit
# On Router A, configure MPLS TE tunnel interface Tunnel 2 to transfer data for enterprise A. Specify the tunnel destination address as the LSR ID of Router D (4.4.4.4), use RSVP-TE as the MPLS TE tunnel signaling protocol, assign 30000 kbps bandwidth to the tunnel, and enable route recording.
[RouterA] interface tunnel 2 mode mpls-te
[RouterA-Tunnel2] ip address 8.1.1.1 255.255.255.0
[RouterA-Tunnel2] destination 4.4.4.4
[RouterA-Tunnel2] mpls te signaling rsvp-te
[RouterA-Tunnel2] mpls te bandwidth 30000
[RouterA-Tunnel2] mpls te record-route
[RouterA-Tunnel2] quit
Table 7 Configure static routes on Router A to direct traffic to MPLS TE tunnels.
# Configure a static route to direct the traffic destined for subnet 20.1.1.0/24 to MPLS TE tunnel 1.
[RouterA] ip route-static 20.1.1.0 24 tunnel 1 preference 1
# Configure a static route to direct the traffic destined for subnet 40.1.1.0/24 to MPLS TE tunnel 2.
[RouterA] ip route-static 40.1.1.0 24 tunnel 2 preference 1
# After the configuration is completed, execute the display interface tunnel command on Router A to verify that the two tunnel interfaces are up.
[RouterA] display interface tunnel
Tunnel1
Current state: Up
Line protocol state: Up
Bandwidth: 64kbps
Maximum Transmit Unit: 64000
Internet Address is 7.1.1.1/24 Primary
Tunnel source unknown, destination 4.4.4.4
Tunnel TTL 255
Tunnel2
Current state: Up
Description: Tunnel2 Interface
Bandwidth: 64kbps
Internet Address is 8.1.1.1/24 Primary
Tunnel TTL 255
# Execute the display mpls te tunnel-interface command on Router A to view details of the two tunnels.
[RouterA] display mpls te tunnel-interface
Tunnel Name            : Tunnel 1
Tunnel State           : Up (Main CRLSP up, Shared-resource CRLSP down)
Tunnel Attributes      :
  LSP ID               : 46362           Tunnel ID            : 1
  Admin State          : Normal
  Ingress LSR ID       : 1.1.1.1         Egress LSR ID        : 4.4.4.4
  Signaling            : RSVP-TE         Static CRLSP Name    : -
  Resv Style           : SE
  Tunnel mode          : -
  Reverse-LSP name     : -
  Reverse-LSP LSR ID   : -               Reverse-LSP Tunnel ID: -
  Class Type           : CT0             Tunnel Bandwidth     : 20000 kbps
  Reserved Bandwidth   : 20000 kbps
  Setup Priority       : 7               Holding Priority     : 7
  Affinity Attr/Mask   : 0/0
  Explicit Path        : -
  Backup Explicit Path : -
  Metric Type          : TE
  Record Route         : Enabled         Record Label         : Disabled
  FRR Flag             : Disabled        Bandwidth Protection : Disabled
  Backup Bandwidth Flag: Disabled        Backup Bandwidth Type: -
  Backup Bandwidth     : -
  Bypass Tunnel        : No              Auto Created         : No
  Route Pinning        : Disabled
  Retry Limit          : 3               Retry Interval       : 2 sec
  Reoptimization       : Disabled        Reoptimization Freq  : -
  Backup Type          : None            Backup LSP ID        : -
  Auto Bandwidth       : Disabled        Auto Bandwidth Freq  : -
  Min Bandwidth        : -               Max Bandwidth        : -
  Collected Bandwidth  : -
Tunnel Name            : Tunnel 2
Tunnel Attributes      :
  LSP ID               : 46362           Tunnel ID            : 2
  Resv Style           : SE
  Tunnel mode          : -
  Class Type           : CT0             Tunnel Bandwidth     : 30000 kbps
  Reserved Bandwidth   : 30000 kbps
  Explicit Path        : -
  Metric Type          : TE
# Execute the display ip routing-table command on Router A. The output shows that the routing table contains static routes that uses Tunnel1 and Tunnel2 as the outgoing interfaces.
Destinations : 30        Routes : 30
7.1.1.0/24         Direct  0   0           7.1.1.1         Tun1
7.1.1.0/32         Direct  0   0           7.1.1.1         Tun1
7.1.1.1/32         Direct  0   0           127.0.0.1       InLoop0
7.1.1.255/32       Direct  0   0           7.1.1.1         Tun1
8.1.1.0/24         Direct  0   0           8.1.1.1         Tun2
8.1.1.0/32         Direct  0   0           8.1.1.1         Tun2
8.1.1.1/32         Direct  0   0           127.0.0.1       InLoop0
8.1.1.255/32       Direct  0   0           8.1.1.1         Tun2
20.1.1.0/24        Static  1   0           0.0.0.0         Tun1
40.1.1.0/24        Static  1   0           0.0.0.0         Tun2
# Execute the display rsvp lsp verbose command on Router A. The output shows that the CRLSP of Tunnel 1 uses path Router A—Router B—Router D and that of Tunnel 2 uses path Router A—Router C—Router D.
[RouterA] display rsvp lsp verbose
Tunnel name: RouterA_t1
Destination: 4.4.4.4                      Source: 1.1.1.1
Tunnel ID: 1                              LSP ID: 46362
LSR type: Ingress                         Direction: Unidirectional
Setup priority: 7                         Holding priority: 7
In-Label: -                               Out-Label: 1150
In-Interface: -                           Out-Interface: GE0/0/1
Nexthop:  10.1.1.2                         Exclude-any: 0
Include-Any: 0                            Include-all: 0
Mean rate (CIR): 20000 kbps               Mean burst size (CBS): 1000.00 bytes
Path MTU: 1500                            Class type: CT0
RRO number: 6
  10.1.1.1/32        Flag: 0x00 (No FRR)
  10.1.1.2/32        Flag: 0x40 (No FRR/In-Int)
  2.2.2.2/32         Flag: 0x20 (No FRR/Node-ID)
  20.1.1.2/32        Flag: 0x00 (No FRR)
  20.1.1.4/32        Flag: 0x40 (No FRR/In-Int)
  4.4.4.4/32         Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: None
Tunnel name: RouterA_t2
Tunnel ID: 2                              LSP ID: 46362
In-Interface: -                           Out-Interface: GE0/0/2
Nexthop:  30.1.1.3                         Exclude-any: 0
Mean rate (CIR): 30000 kbps               Mean burst size (CBS): 1000.00 bytes
RRO number: 6
  30.1.1.1/32        Flag: 0x00 (No FRR)
  30.1.1.3/32        Flag: 0x40 (No FRR/In-Int)
  3.3.3.3/32         Flag: 0x20 (No FRR/Node-ID)
  40.1.1.3/32        Flag: 0x00 (No FRR)
  40.1.1.4/32        Flag: 0x40 (No FRR/In-Int)
The previous verification shows that RSVP-TE has automatically established two CRLSPs for the two enterprise users. One CRLSP passes Router A—Router B—Router D and has 20000 kbps bandwidth. The other CRLSP passes Router A—Router C—Router D and has 30000 kbps bandwidth.
Configuration files
·     Router A:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 1.1.1.1
mpls te
rsvp
interface LoopBack0
 ip address 1.1.1.1 255,255,255,255
interface GigabitEthernet0/0/1
 port link-mode route
 mpls enable
 mpls te enable
 rsvp enable
interface GigabitEthernet0/0/2
 ip address 30.1.1.1 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
interface Tunnel1 mode mpls-te
 mpls te bandwidth ct0 20000
 destination 4.4.4.4
interface Tunnel2 mode mpls-te
 mpls te bandwidth ct0 30000
 destination 4.4.4.4
 ip route-static 20.1.1.0 24 Tunnel1 preference 1
 ip route-static 40.1.1.0 24 Tunnel2 preference 1
·     Router B:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 2.2.2.2
mpls te
rsvp
interface LoopBack0
 ip address 2.2.2.2 255,255,255,255
 mpls enable
 mpls te enable
 rsvp enable
 ip address 20.1.1.2 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
·     Router C:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 3.3.3.3
mpls te
rsvp
interface LoopBack0
 ip address 3.3.3.3 255.255.255.0
 ip address 40.1.1.3 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
 ip address 30.1.1.3 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
·     Router D:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 4.4.4.4
mpls te
rsvp
interface LoopBack0
 ip address 4.4.4.4 255,255,255,255
 ip address 40.1.1.4 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
 ip address 20.1.1.4 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
Example: Configuring MPLS TE FRR
As shown in Figure 4, establish a CRLSP over Router A->Router B->Router C->Router D to carry the voice service of an enterprise. Router B and Router C are located far apart, with multiple Layer 2 switches and an unstable link in between. Link failure will probably occur. Therefore, use MPLS TE FRR to protect the link between Router B and Router C. In case of a link failure, it should be able to quickly switch traffic to the bypass CRLSP (Router A -> Router B -> Router E -> Router C -> Router D). (Assume the required bandwidth for both the primary and bypass tunnels is 30000 kbps, with a maximum bandwidth of 50000 kbps for each link and maximum available reserved bandwidth of 40000 kbps.)
Figure 4 Network diagram
Analysis
·     To establish primary and bypass CRLSPs, enable MPLS, MPLS TE, and RSVP-TE on each router.
·     As the paths for the primary CRLSP and bypass CRLSP have been explicitly specified in the networking requirements, you must configure the MPLS TE tunnel to use the explicit paths of the primary CRLSP and bypass CRLSP.
·     To enable the PLR to quickly detect the failure of the protected primary CRLSP link, configure BFD for RSVP-TE on the two ends of the protected link (Router B and Router C), so that BFD can quickly detect link failure and notify RSVP-TE to switch traffic to the bypass tunnel.
·     To ensure quick traffic switchover to the bypass CRLSP in case of a link failure detected by BFD, configure MPLS TE FRR on the ingress node of the primary CRLSP.
·     To ensure that MPLS TE can select the optimal bypass tunnel for link failure when multiple bypass tunnels are available, set the optimal bypass tunnel selection interval to 5 seconds (300 seconds by default) on the PLR node of FRR.
·     Only MPLS TE tunnels established through RSVP-TE support FRR.
·     Do not configure both FRR and RSVP authentication on the same interface.
·     Bypass tunnels are pre-established and require extra bandwidth. Use bypass tunnels to protect only critical interfaces or links when bandwidth is insufficient.
·     Make sure the bandwidth assigned to the bypass tunnel is no less than the total bandwidth needed by all primary CRLSPs to be protected by the bypass tunnel. Otherwise, some primary CRLSPs might not be protected by the bypass tunnel.
·     A bypass tunnel typically does not forward data when the primary CRLSP operates correctly. For a bypass tunnel to also forward data during tunnel protection, you must assign adequate bandwidth to the bypass tunnel.
·     A bypass tunnel cannot be used for services such as VPN.
·     FRR cannot be configured for a bypass tunnel. A bypass tunnel cannot act as a primary CRLSP.
·     A bypass tunnel must not traverse the protected node or interface.
·     When a primary CRLSP that requires no bandwidth protection is associated with a bypass tunnel that provides bandwidth protection, the primary CRLSP can occupy the bandwidth of the bypass tunnel. If the bypass tunnel also protects other primary CRLSPs, the primary CRLSP that comes up first occupies the bandwidth of the bypass tunnel. A primary CRLSP that needs bandwidth protection cannot preempt the one that does not need bandwidth protection.
·     After an FRR, the primary CRLSP will be down if you modify the bandwidth that the bypass tunnel can protect and your modification results in one of the following:
¡     The CT type changes.
¡     The bypass tunnel cannot protect adequate bandwidth as configured.
¡     FRR protection type changes (whether or not to provide bandwidth protection for the primary CRLSP).
Procedures
Table 1 Assign IP addresses to the network interfaces
Configure IP addresses and masks for interfaces as shown in Figure 4. (Details not shown.)
[RouterA] ospf
[RouterA-ospf-1-area-0.0.0.0] network 2.1.1.0 0.0.0.255
[RouterB] ospf
[RouterB-ospf-1-area-0.0.0.0] network 2.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 3.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 3.2.1.0 0.0.0.255
[RouterC] ospf
[RouterC-ospf-1-area-0.0.0.0] network 3.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 3.3.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 4.1.1.0 0.0.0.255
Configure Router D.
[RouterD] ospf
[RouterD-ospf-1-area-0.0.0.0] network 4.1.1.0 0.0.0.255
Configure Router E.
<RouterE> System-view
[RouterE] ospf
[RouterE-ospf-1] area 0
[RouterE-ospf-1-area-0.0.0.0] network 5.5.5.5 0.0.0.0
[RouterE-ospf-1-area-0.0.0.0] network 3.2.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] network 3.3.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] quit
[RouterE-ospf-1] quit
Destinations : 19        Routes : 19
2.1.1.0/24         Direct  0   0           2.1.1.1         GE0/0/1
2.1.1.0/32         Direct  0   0           2.1.1.1         GE0/0/1
2.1.1.1/32         Direct  0   0           127.0.0.1       InLoop0
2.1.1.255/32       Direct  0   0           2.1.1.1         GE0/0/1
2.2.2.2/32         O_INTRA 10  1           2.1.1.2         GE0/0/1
3.1.1.0/24         O_INTRA 10  2           2.1.1.2         GE0/0/1
3.2.1.0/24         O_INTRA 10  2           2.1.1.2         GE0/0/1
3.3.1.0/24         O_INTRA 10  3           2.1.1.2         GE0/0/1
3.3.3.3/32         O_INTRA 10  2           2.1.1.2         GE0/0/1
5.5.5.5/32         O_INTRA 10  2           2.1.1.2         GE0/0/1
Table 3 Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE on each router. Enable BFD for RSVP-TE on Router B and Router C:
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterB] mpls te
[RouterB-te] quit
[RouterB] rsvp
[RouterB-rsvp] quit
[RouterB-GigabitEthernet0/0/2] rsvp bfd enable
[RouterB] interface gigabitethernet 0/0/3
[RouterB-GigabitEthernet0/0/3] mpls enable
[RouterB-GigabitEthernet0/0/3] mpls te enable
[RouterB-GigabitEthernet0/0/3] rsvp enable
[RouterB-GigabitEthernet0/0/3] quit
[RouterC] mpls te
[RouterC-te] quit
[RouterC] rsvp
[RouterC-rsvp] quit
[RouterC-GigabitEthernet0/0/2] rsvp bfd enable
[RouterC] interface gigabitethernet 0/0/3
[RouterC-GigabitEthernet0/0/3] mpls enable
[RouterC-GigabitEthernet0/0/3] mpls te enable
[RouterC-GigabitEthernet0/0/3] rsvp enable
[RouterC-GigabitEthernet0/0/3] quit
Configure Router D.
[RouterD] mpls te
[RouterD-te] quit
[RouterD] rsvp
[RouterD-rsvp] quit
Configure Router E.
[RouterE] mpls lsr-id 5.5.5.5
[RouterE] mpls te
[RouterE-te] quit
[RouterE] rsvp
[RouterE-rsvp] quit
[RouterE] interface gigabitethernet 0/0/1
[RouterE-GigabitEthernet0/0/1] mpls enable
[RouterE-GigabitEthernet0/0/1] mpls te enable
[RouterE-GigabitEthernet0/0/1] rsvp enable
[RouterE-GigabitEthernet0/0/1] quit
[RouterE] interface gigabitethernet 0/0/2
[RouterE-GigabitEthernet0/0/2] mpls enable
[RouterE-GigabitEthernet0/0/2] mpls te enable
[RouterE-GigabitEthernet0/0/2] rsvp enable
[RouterE-GigabitEthernet0/0/2] quit
[RouterB-GigabitEthernet0/0/3] mpls te max-link-bandwidth 50000
[RouterB-GigabitEthernet0/0/3] mpls te max-reservable-bandwidth 40000
[RouterC-GigabitEthernet0/0/3] mpls te max-link-bandwidth 50000
[RouterC-GigabitEthernet0/0/3] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth and maximum reservable bandwidth on Router E.
[RouterE-GigabitEthernet0/0/1] mpls te max-link-bandwidth 50000
[RouterE-GigabitEthernet0/0/1] mpls te max-reservable-bandwidth 40000
[RouterE-GigabitEthernet0/0/2] mpls te max-link-bandwidth 50000
[RouterE-GigabitEthernet0/0/2] mpls te max-reservable-bandwidth 40000
# On Router A, enable OSPF opaque LSA advertisement and reception (enabled by default), and enable MPLS TE in OSPF area 0.
[RouterA] ospf
# On Router B, enable OSPF opaque LSA advertisement and reception (enabled by default), and enable MPLS TE in OSPF area 0.
[RouterB] ospf
# On Router C, enable OSPF opaque LSA advertisement and reception (enabled by default), and enable MPLS TE in OSPF area 0.
[RouterC] ospf
# On Router D, enable OSPF opaque LSA advertisement and reception (enabled by default), and enable MPLS TE in OSPF area 0.
[RouterD] ospf
# On Router E, enable OSPF opaque LSA advertisement and reception (enabled by default), and enable MPLS TE in OSPF area 0.
[RouterE] ospf
[RouterE-ospf-1] opaque-capability enable
[RouterE-ospf-1-area-0.0.0.0] mpls te enable
Table 6 Configure an MPLS TE tunnel on Router A, the ingress node of the primary CRLSP:
# Configure an explicit path named pri-path for the primary CRLSP. Use the default strict explicit path mode.
[RouterA] explicit-path pri-path
[RouterA-explicit-path-pri-path] nexthop 2.1.1.2
[RouterA-explicit-path-pri-path] nexthop 3.1.1.3
[RouterA-explicit-path-pri-path] nexthop 4.1.1.4
[RouterA-explicit-path-pri-path] nexthop 4.4.4.4
[RouterA-explicit-path-pri-path] quit
# Configure MPLS TE tunnel interface Tunnel 4 for the primary CRLSP: Specify the tunnel destination address as the LSR ID of Router D (4.4.4.4); use RSVP-TE as the MPLS TE tunnel signaling protocol; assign 30000 kbps bandwidth to the tunnel; and specify the explicit path of tunnel as pri-path.
[RouterA] interface tunnel4 mode mpls-te
[RouterA-Tunnel4] ip address 10.1.1.1 255.255.255.0
[RouterA-Tunnel4] destination 4.4.4.4
[RouterA-Tunnel4] mpls te signaling rsvp-te
[RouterA-Tunnel4] mpls te bandwidth 30000
[RouterA-Tunnel4] mpls te path preference 1 explicit-path pri-path
# Enable FRR for the MPLS TE tunnel.
[RouterA-Tunnel4] mpls te fast-reroute
[RouterA-Tunnel4] quit
# After the configuration is completed, execute the display interface tunnel command on Router A to verify that interface Tunnel4 is up.
Tunnel4
Current state: Up
Description: Tunnel4 Interface
Bandwidth: 64kbps
Internet Address is 10.1.1.1/24 Primary
Tunnel TTL 255
# Execute the display mpls te tunnel-interface command on Router A to view details of the tunnel Interface.
Tunnel Name            : Tunnel 4
Tunnel Attributes      :
  LSP ID               : 37325           Tunnel ID            : 4
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : pri-path
  Metric Type          : TE
  Record Route         : Enabled         Record Label         : Enabled
  FRR Flag             : Enabled         Bandwidth Protection : Disabled
Table 7 Configure auto FRR on Router B (the PLR):
# Configure an explicit path named by-path for the bypass  tunnel.
[RouterB] explicit-path by-path
[RouterB-explicit-path-by-path] nexthop 3.2.1.5
[RouterB-explicit-path-by-path] nexthop 3.3.1.3
[RouterB-explicit-path-by-path] nexthop 3.3.3.3
[RouterB-explicit-path-by-path] quit
# Configure MPLS TE tunnel interface Tunnel 5 for the bypass tunnel: Specify the tunnel destination address as the LSR ID of Router C (3.3.3.3); use RSVP-TE as the MPLS TE tunnel signaling protocol; assign 30000 kbps bandwidth to the tunnel; and specify the explicit path of tunnel as by-path.
[RouterB] interface tunnel 5 mode mpls-te
[RouterB-Tunnel5] ip address 11.1.1.1 255.255.255.0
[RouterB-Tunnel5] destination 3.3.3.3
[RouterB-Tunnel5] mpls te signaling rsvp-te
[RouterA-Tunnel5] mpls te bandwidth 30000
[RouterB-Tunnel5] mpls te path preference 1 explicit-path by-path
# Configure the bypass tunnel to provide unlimited bandwidth protection.
[RouterB-Tunnel5] mpls te backup bandwidth un-limited
[RouterB-Tunnel5] quit
# Bind the bypass tunnel to the protected interface.
[RouterB-GigabitEthernet0/0/2] mpls te fast-reroute bypass-tunnel tunnel 5
# After the configuration is completed execute the display interface tunnel command on Router B to verify that interface Tunnel5 is up.
[RouterB] display interface tunnel
Tunnel5
Current state: Up
Line protocol state: Down
Description: Tunnel5 Interface
Bandwidth: 64kbps
Internet Address is 11.1.1.1/24 Primary
Tunnel source unknown, destination 3.3.3.3
Tunnel TTL 255
Table 8  Configure a static route to direct traffic to the MPLS TE tunnel.
# Configure a static route on Router A to direct the traffic destined for 4.1. 1.0/24 to MPLS TE tunnel 4.
[Router A] ip route-static 4.1.1.0 24 tunnel 4 preference 1
# Execute the display mpls lsp command on each router to view LSP information. The output shows that Router B has two LSPs, and the bypass tunnel backs up the primary CRLSP.
[RouterA] display mpls lsp
FEC                         Proto    In/Out Label    Interface/Out NHLFE
1.1.1.1/4/37325             RSVP     -/1150          GE0/0/1
2.1.1.2                     Local    -/-             GE0/0/1
Tunnel4                     Local    -/-             NHLFE1026
[RouterB] display mpls lsp
1.1.1.1/4/37325             RSVP     1150/1147       GE0/0/2
Backup                               1150/1147       Tun5
2.2.2.2/5/18928             RSVP     -/1149          GE0/0/3
3.1.1.3                     Local    -/-             GE0/0/2
3.2.1.5                     Local    -/-             GE0/0/3
Tunnel5                     Local    -/-             NHLFE1027
[RouterC] display mpls lsp
1.1.1.1/4/37325             RSVP     1147/3          GE0/0/1
2.2.2.2/5/18928             RSVP     3/-             -
4.1.1.4                     Local    -/-             GE0/0/1
# Shut down the protected interface GigabitEthernet0/0/2 on the PLR (Router B).
[RouterB-GigabitEthernet0/0/2] shutdown
# Execute display interface tunnel 4 command on Router A to verify that interface Tunnel4 is up.
[RouterA] display interface tunnel 4
Tunnel4
Current state: Up
Bandwidth: 64kbps
Tunnel TTL 255
Tunnel State           : Up (Main CRLSP up, Shared-resource CRLSP being set up)
Tunnel Attributes      :
  Resv Style           : SE
  Tunnel mode          : -
  Metric Type          : TE
# Execute the display mpls lsp command on Router B. The output shows that the bypass tunnel is used.
1.1.1.1/4/37325             RSVP     1150/1147       Tun5
# On the PLR, set the optimal bypass tunnel selection interface to 5 seconds.
[RouterB] mpls te
[RouterB-te] fast-reroute timer 5
[RouterB-te] quit
# Bring up the protected interface GigabitEthernet0/0/2 on the PLR.
[RouterB-GigabitEthernet0/0/2] undo shutdown
Tunnel4
Current state: Up
Bandwidth: 64kbps
Tunnel TTL 255
# Wait for about five seconds. Execute the display mpls lsp verbose command on Router B. The output shows that Tunnel 5 is still bound to interface GigabitEthernet 0/0/2 but not in use.
[RouterB] display mpls lsp verbose
Destination  : 4.4.4.4
FEC          : 1.1.1.1/4/53319
Protocol     : RSVP
LSR Type     : Transit
Service      : -
In-Label     : 1150
Path ID      : 0x540000003.1
State        : Active
Out-Label    : 1150
Nexthop      : 3.1.1.3
BkLabel      : 1150
BkInterface  : Tun5
Destination  : 3.3.3.3
FEC          : 2.2.2.2/5/16429
Protocol     : RSVP
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1025
State        : Active
Out-Label    : 1151
Nexthop      : 3.2.1.5
Out-Interface: GE0/0/3
Destination  : 3.1.1.3
FEC          : 3.1.1.3
Protocol     : Local
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1027
State        : Active
Nexthop      : 3.1.1.3
Destination  : 3.2.1.5
FEC          : 3.2.1.5
Protocol     : Local
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1024
State        : Active
Nexthop      : 3.2.1.5
FEC          : Tunnel5
Protocol     : Local
LSR Type     : Ingress
Service      : -
NHLFE ID     : 268435461
State        : Active
Out-Interface: NHLFE1025
# Execute the display ip routing-table command on Router A. The output shows that the routing table contains a static route that uses Tunnel 4 as the outgoing interface.
Destinations : 25        Routes : 25
4.1.1.0/24         Static  1   0           0.0.0.0         Tun4
4.4.4.4/32         O_INTRA 10  3           2.1.1.2         GE0/0/1
10.1.1.0/24        Direct  0   0           10.1.1.1        Tun4
10.1.1.0/32        Direct  0   0           10.1.1.1        Tun4
10.1.1.255/32      Direct  0   0           10.1.1.1        Tun4
Configuration files
·     Router A:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 1.1.1.1
mpls te
 nexthop index 1 2.1.1.2 include strict
 nexthop index 101 3.1.1.3 include strict
 nexthop index 201 4.1.1.4 include strict
 nexthop index 301 4.4.4.4 include strict
rsvp
interface LoopBack0
 ip address 2.1.1.1 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
interface Tunnel4 mode mpls-te
 destination 4.4.4.4
ip route-static 4.1.1.0 24 Tunnel4 preference 1
·     Router B:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 2.2.2.2
mpls te
 nexthop index 1 3.2.1.5 include strict
 nexthop index 101 3.3.1.3 include strict
 nexthop index 201 3.3.3.3 include strict
rsvp
interface LoopBack0
 ip address 2.1.1.2 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
 ip address 3.1.1.2 255.255.255.0
 mpls enable
 mpls te enable
 mpls te fast-reroute bypass-tunnel Tunnel5
 rsvp enable
 rsvp bfd enable
interface GigabitEthernet0/0/3
 ip address 3.2.1.2 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
interface Tunnel5 mode mpls-te
 destination 3.3.3.3
·     Router C:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 3.3.3.3
mpls te
rsvp
interface LoopBack0
 ip address 3.3.3.3 255,255,255,255
 ip address 4.1.1.3 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
 ip address 3.1.1.3 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
 rsvp bfd enable
 ip address 3.3.1.3 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
·     Router D:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 4.4.4.4
mpls te
rsvp
interface LoopBack0
 ip address 4.1.1.4 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
·     Router E:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 5.5.5.5
mpls te
rsvp
interface LoopBack0
 ip address 5.5.5.5 255,255,255,255
 ip address 3.2.1.5 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
 ip address 3.3.1.5 255.255.255.0
 mpls enable
 mpls te enable
 rsvp enable
Related documentation
·     MPLS Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides (V9)
·     MPLS Command Reference in H3C MSR1000[2600][3600] Routers Command References (V9)
