H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
57-BIDIR-PIM Configuration Examples
57-BIDIR-PIM Configuration Examples 132.06 KB
H3C Routers
Introduction
This document introduces BIDIR-PIM configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of BIDIR-PIM.
Example: Configuring BIDIR-PIM
As shown in Figure 1:
·     Router A, Router B, and Router C run OSPF.
·     Source 1 and Source 2 send multicast data to multicast group 225.1.1.1.
·     Host A and Host B are member hosts of multicast group 225.1.1.1.
Configure BIDIR-PIM on the routers to implement multicast forwarding.
Figure 1 Network diagram
Device
IP address
Device
IP address
Router A
GE0/0/1
10.10.1.1/24
Router C
GE0/0/1
10.13.1.3/24
Router A
GE0/0/2
10.12.1.1/24
Router C
GE0/0/2
10.23.1.3/24
Router A
GE0/0/3
10.13.1.1/24
Router C
GE0/0/3
10.102.1.1/24
Router B
GE0/0/1
10.12.1.2/24
Router C
GE0/0/4
10.33.1.3/24
Router B
GE0/0/2
10.23.1.2/24
Source 1
10.10.1.2/24
Router B
GE0/0/3
10.101.1.1/24
Source 2
10.33.1.4/24
Analysis
To meet the network requirements, perform the following tasks:
·     To establish the bidirectional RPT, configure GigabitEthernet 0/0/2 on Router A as a C-RP.
·     To use the BSR mechanism to dynamically elect the RP, configure GigabitEthernet 0/0/2 on Router A as a C-BSR.
·     To avoid multicast forwarding interruption when the RP fails, specify the unused IP address 10.13.1.4/24 as the static RP. In this way, the link on the subnet 10.13.1.0/24 becomes the RPL. Router A and Router C on the link function as the RPs.
Software versions used
This configuration example was created and verified on Release 9141P16 of the MSR2630E-X1 router.
When you configure BIDIR-PIM, follow these restrictions and guidelines:
·     Enable the same PIM mode on the interfaces that belong to the same VPN instance on each router.
·     Configure the same static RP on all the routers in the BIDIR-PIM domain.
·     Enable PIM-SM for all interfaces on the routers in the BIDIR-PIM domain.
·     Enable IGMP for the interfaces that connect to the stub networks on all the routers in the BIDIR-PIM domain.
Procedures
Configure Router A
1.     Enable IP multicast routing.
[RouterA] multicast routing
[RouterA-mrib] quit
2.     Configure each interface and enable PIM-SM.
# Assign an IP address to GigabitEthernet 0/0/1, and enable PIM-SM on the interface.
[RouterA] interface gigabitethernet 0/0/1
[RouterA-GigabitEthernet0/0/1] ip address 10.10.1.1 24
[RouterA-GigabitEthernet0/0/1] pim sm
[RouterA-GigabitEthernet0/0/1] quit
# Assign an IP address to GigabitEthernet 0/0/2, enable PIM-SM on the interface.
[RouterA-vlan12] interface gigabitethernet 0/0/2
[RouterA-GigabitEthernet0/0/2] ip address 10.12.1.1 24
[RouterA-GigabitEthernet0/0/2] pim sm
[RouterA-GigabitEthernet0/0/2] quit
# Assign an IP address to GigabitEthernet 0/0/3, enable PIM-SM on the interface.
[RouterA] interface gigabitethernet 0/0/3
[RouterA-GigabitEthernet0/0/3] ip address 10.13.1.1 24
[RouterA-GigabitEthernet0/0/3] pim sm
[RouterA-GigabitEthernet0/0/3] quit
3.     Configure a C-RP, a C-BSR, and the static RP.
# Configure GigabitEthernet 0/0/2 as a C-BSR and a C-RP.
[RouterA] pim
[RouterA-pim] c-bsr 10.12.1.1
[RouterA-pim] c-rp 10.12.1.1 bidir
# Specify the unused IP address 10.13.1.4 as a static RP.
[RouterA-pim] static-rp 10.13.1.4 bidir
4.     Enable BIDIR-PIM.
[RouterA-pim] bidir-pim enable
[RouterA-pim] quit
5.     Configure OSPF.
[RouterA] ospf 1
[RouterA-ospf-1] import-route direct
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[RouterA-ospf-1] quit
Configure Router B
<RouterB> system-view
[RouterB] multicast routing
[RouterB-mrib] quit
# Assign an IP address to GigabitEthernet 0/0/1, enable PIM-SM on the interface.
[RouterB] interface gigabitethernet 0/0/1
[RouterB-GigabitEthernet0/0/1] ip address 10.12.1.2 24
[RouterB-GigabitEthernet0/0/1] pim sm
[RouterB-GigabitEthernet0/0/1] quit
[RouterB] interface gigabitethernet 0/0/2
[RouterB-GigabitEthernet0/0/2] ip address 10.23.1.2 24
[RouterB-GigabitEthernet0/0/2] pim sm
[RouterB-GigabitEthernet0/0/2] quit
# Assign an IP address to GigabitEthernet 0/0/3, enable PIM-SM and IGMP on the interface.
[RouterB] interface gigabitethernet 0/0/3
[RouterB-GigabitEthernet0/0/3] ip address 10.101.1.1 24
[RouterB-GigabitEthernet0/0/3] pim sm
[RouterB-GigabitEthernet0/0/3] igmp enable
[RouterB-GigabitEthernet0/0/3] quit
3.     Specify the unused IP address 10.13.1.4 as a static RP.
[RouterB] pim
[RouterB-pim] static-rp 10.13.1.4 bidir
[RouterB-pim] bidir-pim enable
[RouterB-pim] quit
5.     Configure OSPF.
[RouterB] ospf 1
[RouterB-ospf-1] import-route direct
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[RouterB-ospf-1] quit
Configure Router C
<RouterC> system-view
[RouterC] multicast routing
[RouterC-mrib] quit
# Assign an IP address to GigabitEthernet 0/0/4, enable PIM-SM on the interface.
[RouterC] interface gigabitethernet 0/0/4
[RouterC-GigabitEthernet0/0/4] ip address 10.33.1.3 24
[RouterC-GigabitEthernet0/0/4] pim sm
[RouterC-GigabitEthernet0/0/4] quit
[RouterC] interface gigabitethernet 0/0/1
[RouterC-GigabitEthernet0/0/1] ip address 10.13.1.3 24
[RouterC-GigabitEthernet0/0/1] pim sm
[RouterC-GigabitEthernet0/0/1] quit
[RouterC] interface gigabitethernet 0/0/2
[RouterC-GigabitEthernet0/0/2] ip address 10.23.1.3 24
[RouterC-GigabitEthernet0/0/2] pim sm
[RouterC-GigabitEthernet0/0/2] quit
[RouterC] interface gigabitethernet 0/0/3
[RouterC-GigabitEthernet0/0/3] ip address 10.102.1.1 24
[RouterC-GigabitEthernet0/0/3] pim sm
[RouterC-GigabitEthernet0/0/3] igmp enable
[RouterC-GigabitEthernet0/0/3] quit
[RouterC] pim
[RouterC-pim] static-rp 10.13.1.4 bidir
4.     Enable BIDIR-PIM
[RouterC-pim] bidir-pim enable
[RouterC-pim] quit
5.     Configure OSPF.
[RouterC] ospf 1
[RouterC-ospf-1] import-route direct
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[RouterC-ospf-1] quit
1.     Verify that Router A, Router B, and Router C have established PIM neighbor relationships.
# Display PIM neighbor information on Router A.
[RouterA] display pim neighbor
 Total Number of Neighbors = 2
 Neighbor        Interface           Uptime   Expires  DR-Priority Mode
 10.12.1.2       GE0/0/2                    00:02:27 00:01:45 1           B
 10.13.1.3       GE0/0/3             00:02:27 00:01:19 1           B
# Display PIM neighbor information on Router B.
[RouterB] display pim neighbor
 10.12.1.1       GE0/0/1             00:03:05 00:01:44 1           B
 10.23.1.3       GE0/0/3             00:13:49 00:01:29 1           B
# Display PIM neighbor information on Router C.
[RouterC] display pim neighbor
 10.13.1.1       GE0/0/1             00:03:28 00:01:39 1           B
 10.23.1.2       GE0/0/2                    00:14:05 00:01:36 1           B
2.     Verify that GigabitEthernet 0/0/2 on Router A has been elected as the BSR on each router.
# Display BSR information on Router A.
[RouterA] display pim bsr-info
 Scope: non-scoped
     State: Elected
     Bootstrap timer: 00:01:18
     Elected BSR address: 10.12.1.1
       Priority: 64
       Hash mask length: 30
       Uptime: 00:04:01
     Candidate BSR address: 10.12.1.1
       Priority: 64
# Display BSR information on Router B.
[RouterB] display pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:00:26
       Priority: 64
       Uptime: 00:10:41
# Display BSR information on Router C.
[RouterC] display pim bsr-info
 Scope: non-scoped
     Bootstrap timer: 00:02:08
       Priority: 64
       Uptime: 00:15:41
3.     Verify that GigabitEthernet 0/0/2 on Router A has been elected as the RP, and verify that the IP address of the static RP is 10.13.1.4 on each router.
# Display RP information on Router A.
[RouterA] display pim rp-info
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: 224.0.0.0/4 [B]
       RP address               Priority  HoldTime  Uptime    Expires
       10.12.1.1 (local)        192       150       00:06:01  00:02:58
 Static RP information:
       RP address               ACL   Mode    Preferred
       10.13.1.4                ----  bidir   No
# Display RP information on Router B.
[SwatchB] display pim rp-info
 BSR RP information:
   Scope: non-scoped
       10.12.1.1                192       150       00:06:33  00:02:26
# Display RP information on Router C.
[RouterC] display pim rp-info
 BSR RP information:
   Scope: non-scoped
       10.12.1.1                192       150       00:06:51  00:02:05
4.     Verify that the DFs have been elected for BIDIR-PIM on each router.
# Display information about DFs for BIDIR-PIM on Router A.
[RouterA] display pim df-info
RP address: 10.12.1.1
 Interface           State   DF-Pref    DF-Metric  DF-Uptime DF-Address
 GE0/0/1             Win     0          0          00:01:09  10.10.1.1 (local)
 GE0/0/2                    -       -          -          -         -
 GE0/0/3             Win     0          0          00:01:10  10.13.1.1 (local)
RP address: 10.13.1.4
 GE0/0/1             Win     0          0          00:00:07  10.10.1.1 (local)
 GE0/0/2                    Win     0          0          00:00:07  10.12.1.1 (local)
 GE0/0/3             -       -          -          -         -
# Display information about DFs for BIDIR-PIM on Router B.
[RouterB] display pim df-info
 GE0/0/1             -       -          -          -         -
 GE0/0/2                    Win     0          0          00:01:46  10.23.1.2 (local)
 GE0/0/3             Win     0          0          00:01:45  10.101.1.1 (local)
 GE0/0/1             Lose    0          0          00:00:44  10.12.1.1
 GE0/0/2                    Lose    0          0          00:00:53  10.23.1.3
 GE0/0/3             Win     10         2          00:00:53  10.101.1.1 (local)
# Display information about DFs for BIDIR-PIM on Router C.
[RouterC] display pim df-info
 GE0/0/3             Win     10         2          00:02:07  10.102.1.1 (local)
 GE0/0/4             Win     10         2          00:02:06  10.33.1.3 (local)
 GE0/0/1             Lose    0          0          00:02:07  10.13.1.1
 GE0/0/2                    Lose    0          0          00:02:07  10.23.1.2
 GE0/0/3             Win     0          0          00:01:24  10.102.1.1 (local)
 GE0/0/4             Win     0          0          00:01:23  10.33.1.3 (local)
 GE0/0/1             -       -          -          -         -
 GE0/0/2                    Win     0          0          00:01:24  10.23.1.3 (local)
5.     Verify that DFs for multicast forwarding are correct on each router.
# Display information about DFs for multicast forwarding on Router A.
[RouterA] display multicast forwarding df-info
Total 2 RPs, 2 matched
00001. RP address: 10.12.1.1
     Flags: 0x0
     Uptime: 00:02:42
     RPF interface: GigabitEthernet0/0/2
     List of 2 DF interfaces:
       1: GigabitEthernet0/0/1
       2: GigabitEthernet0/0/3
00002. RP address: 10.13.1.4
     Flags: 0x0
     Uptime: 00:01:41
     RPF interface: GigabitEthernet0/0/3
       2: GigabitEthernet0/0/2
# Display information about DFs for multicast forwarding on Router B.
[RouterB] display multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:03:18
     RPF interface: GigabitEthernet0/0/1
       1: GigabitEthernet0/0/2
     Flags: 0x0
     Uptime: 00:02:24
     List of 1 DF interfaces:
       1: GigabitEthernet0/0/3
# Display information about DFs for multicast forwarding on Router C.
[RouterC] display multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:03:38
       2: GigabitEthernet0/0/4
     Flags: 0x0
     Uptime: 2d:18h
     List of 3 DF interfaces:
       3: GigabitEthernet0/0/2
6.     Send IGMP reports from Host A and Host B to join multicast group 225.1.1.1, and send multicast data from Source 1 and Source 2 to the group. (Details not shown.)
7.     Verify that PIM forwarding entries have been correctly established on each router.
# Display information about PIM routing entries on Router A.
[RouterA] display pim routing-table
 Total 1 (*, G) entry; 0 (S, G) entry
 (*, 225.1.1.1)
     RP: 10.12.1.1 (local)
     Protocol: pim-bidir, Flag: WC LOC ACT
     UpTime: 00:21:59
     Upstream interface: GigabitEthernet0/0/2
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
             Protocol: pim-bidir, UpTime: 00:21:59, Expires: -
             Protocol: pim-bidir, UpTime: 00:03:26, Expires: -
# Display information about PIM routing entries on Router B.
[RouterB] display pim routing-table
 (*, 225.1.1.1)
     RP: 10.12.1.1
     UpTime: 00:23:47
     Upstream interface: GigabitEthernet0/0/1
     Total number of downstreams: 3
             Protocol: pim-bidir, UpTime: 00:23:47, Expires: -
             Protocol: pim-bidir, UpTime: 00:21:56, Expires: -
         3: GigabitEthernet0/0/3
             Protocol: igmp, UpTime: 00:23:47, Expires: -
# Display information about PIM routing entries on Router C.
[RouterC] display pim routing-table
 (*, 225.1.1.1)
     RP: 10.12.1.1
     Protocol: pim-bidir, Flag: WC ACT
     UpTime: 00:01:45
         Upstream neighbor: 10.23.1.2
         RPF prime neighbor: 10.23.1.2
     Total number of downstreams: 2
             Protocol: igmp, UpTime: 00:01:05, Expires: -
             Protocol: pim-bidir, UpTime: 00:00:53, Expires: -
Configuration files
·     Router A:
ospf 1
 import-route direct
 area 0.0.0.0
interface GigabitEthernet0/0/1
 port link-mode route
 ip address 10.10.1.1 255.255.255.0
 pim sm
interface GigabitEthernet0/0/2
 ip address 10.12.1.1 255.255.255.0
 pim sm
interface GigabitEthernet0/0/3
 ip address 10.13.1.1 255.255.255.0
 pim sm
multicast routing
pim
 c-bsr 10.12.1.1
 bidir-pim enable
·     Router B:
ospf 1
 import-route direct
 area 0.0.0.0
 combo enable copper
 ip address 10.12.1.2 255.255.255.0
 pim sm
 combo enable copper
 ip address 10.23.1.2 255.255.255.0
 pim sm
 combo enable copper
 ip address 10.101.1.1 255.255.255.0
 pim sm
 igmp enable
multicast routing
pim
 bidir-pim enable
·     Router C:
ospf 1
 import-route direct
 area 0.0.0.0
 ip address 10.13.1.3 255.255.255.0
 pim sm
 ip address 10.23.1.3 255.255.255.0
 pim sm
 ip address 10.102.1.1 255.255.255.0
 pim sm
 igmp enable
interface GigabitEthernet0/0/4
 ip address 10.33.1.3 255.255.255.0
 pim sm
multicast routing
pim
 bidir-pim enable
Related documentation
·     IP Multicast Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     IP Multicast Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
