H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
19-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
H3C Routers
Introduction
The following information provides IPv6 manual tunnel with OSPFv3 configuration examples.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IPv6 over IPv4 manual tunneling and OSPFv3.
Example: Configuring an IPv6 over IPv4 manual tunnel with OSPFv3
As shown in Figure 1, IPv6 is deployed in the headquarters (HQ) and its branches and they are connected through an IPv4 network. Device A, Device B, and Device C are gateways of the HQ, Branch 1, and Branch 2, respectively. Configure an IPv6 over IPv4 manual tunnel between the HQ and each branch B so the IPv6 networks of the HQ and branch can reach each other over the IPv4 network. Configure OSPFv3 so that the gateway devices can have routes to reach the destination IPv6 addresses through the tunnels, and the branches can communicate with each other through the HQ.
Figure 1 Network diagram
Table 1 Interface and address assignment
Device
IP address
Device
IP address
Device A
GE1/0/1
20.1.1.1/24
Device B
GE1/0/1
30.1.1.1/24
GE1/0/2
2001::1/64
GE1/0/2
5001::1/64
Tunnel1
3001::1/64
Tunnel1
3001::2/64
Tunnel2
4001::1/64
Device C
GE1/0/1
40.1.1.1/24
GE1/0/2
6001::1/64
Tunnel2
4001::2/64
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
Procedures
Before you perform the following configuration, make sure the gateway devices have IPv4 connectivity to each other.
Configuring IPv6 over IPv4 manual tunnels
1.     Configure Device A:
# Assign an IP address to interface GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] ip address 20.1.1.1 24
# Assign IP addresses to other interfaces on Device A in the same way. (Details not shown.)
# Create IPv6 over IPv4 manual tunnel interface Tunnel 1.
[DeviceA] interface tunnel 1 mode ipv6-ipv4
# Assign an IPv6 address to interface Tunnel 1.
[DeviceA-Tunnel1] ipv6 address 3001::1/64
# Configure the source interface of Tunnel 1 as GigabitEthernet 1/0/1. (The IP address of the source interface will be used as the source IP address of the IPv4 packets after encapsulation.)
[DeviceA-Tunnel1] source gigabitethernet 1/0/1
# Configure the destination IP address of Tunnel 1. (The specified IP address will be used as the destination IP address of the IPv4 packets after encapsulation.)
[DeviceA-Tunnel1] destination 30.1.1.1
[DeviceA-Tunnel1] quit
# Create IPv6 over IPv4 manual tunnel interface Tunnel 2.
[DeviceA] interface tunnel 2 mode ipv6-ipv4
# Assign an IPv6 address to interface Tunnel 2.
[DeviceA-Tunnel2] ipv6 address 4001::1/64
# Configure the source interface of Tunnel 2 as GigabitEthernet 1/0/1.
[DeviceA-Tunnel2] source gigabitethernet 1/0/1
Configure the destination address of the Tunnel 2.
[DeviceA-Tunnel2] destination 40.1.1.1
[DeviceA-Tunnel2] quit
2.     Configure Device B:
[DeviceB-GigabitEthernet1/0/1] ip address 30.1.1.1 24
# Assign IP addresses to other interfaces on Device B in the same way. (Details not shown.)
[DeviceB] interface tunnel 1 mode ipv6-ipv4
[DeviceB-Tunnel1] ipv6 address 3001::2/64
[DeviceB-Tunnel1] source gigabitethernet 1/0/1
[DeviceB-Tunnel1] destination 20.1.1.1
[DeviceB-Tunnel1] quit
3.     Configure Device C:
<DeviceC> system-view
[DeviceC-GigabitEthernet1/0/1] ip address 40.1.1.1 24
# Assign IP addresses to other interfaces on Device C in the same way. (Details not shown.)
[DeviceC] interface tunnel 2 mode ipv6-ipv4
[DeviceC-Tunnel2] ipv6 address 4001::2/64
# Configure the source interface of Tunnel 2 as GigabitEthernet 1/0/1. (The IP address of the source interface will be used as the source IP address of the IPv4 packets after encapsulation.)
[DeviceC-Tunnel2] source gigabitethernet 1/0/1
# Configure the destination IP address of Tunnel 2. (The specified IP address will be used as the destination IP address of the IPv4 packets after encapsulation.)
[DeviceC-Tunnel2] destination 20.1.1.1
[DeviceC-Tunnel2] quit
Configuring OSPFv3
# Configure the router ID of Device A as 1.1.1.1.
[DeviceA] ospfv3 1
[DeviceA-ospfv3-1] router-id 1.1.1.1
[DeviceA-ospfv3-1] quit
# Enable OSPFv3 on Tunnel 1.
[DeviceA] interface Tunnel 1
[DeviceA-Tunnel1] ospfv3 1 area 0
# Enable OSPFv3 on Tunnel 2.
[DeviceA] interface Tunnel 2
[DeviceA-Tunnel2] ospfv3 1 area 0
# Enable OSPFv3 on GigabitEthernet 1/0/2.
[DeviceA-GigabitEthernet1/0/2] ospfv3 1 area 0
Configure the router ID of Device B as 2.2.2.2.
[DeviceB] ospfv3 1
[DeviceB-ospfv3-1] router-id 2.2.2.2
[DeviceB-ospfv3-1] quit
[DeviceB] interface Tunnel 1
[DeviceB-Tunnel1] ospfv3 1 area 0
[DeviceB-GigabitEthernet1/0/2] ospfv3 1 area 0
Configure the router ID of Device C as 3.3.3.3.
[DeviceC] ospfv3 1
[DeviceC-ospfv3-1] router-id 3.3.3.3
[DeviceC-ospfv3-1] quit
[DeviceC] interface Tunnel 2
[DeviceC-Tunnel2] ospfv3 1 area 0
[DeviceC-GigabitEthernet1/0/2] ospfv3 1 area 0
# Verify that PC 2 can successfully ping PC 1.
D:\>ping6 -s 5001::3 2001::3
Pinging 2001::3
from 5001::3 with 32 bytes of data:
Reply from 2001::3: bytes=32 time=13ms
Reply from 2001::3: bytes=32 time=1ms
Reply from 2001::3: bytes=32 time<1ms
Ping statistics for 2001::3:
Minimum = 0ms, Maximum = 13ms, Average = 3ms
# Verify that PC 2 can successfully ping PC 3.
D:\>ping6 -s 5001::3 6001::3
Pinging 6001::3
from 6001::3 with 32 bytes of data:
Reply from 6001::3: bytes=32 time=13ms
Reply from 6001::3: bytes=32 time=1ms
Reply from 6001::3: bytes=32 time<1ms
Ping statistics for 6001::3:
Configuration files
Device A
ospfv3 1
 router-id 1.1.1.1
 area 0.0.0.0
 ip address 20.1.1.1 255.255.255.0
 ospfv3 1 area 0.0.0.0
 ipv6 address 2001::1/64
interface Tunnel1 mode ipv6-ipv4
 source GigabitEthernet1/0/1
interface Tunnel2 mode ipv6-ipv4
Device B
ospfv3 1
 router-id 2.2.2.2
 area 0.0.0.0
 ip address 30.1.1.1 255.255.255.0
 ipv6 address 5001::1/64
Device C
ospfv3 1
 router-id 3.3.3.3
 area 0.0.0.0
 ip address 40.1.1.1 255.255.255.0
 ipv6 address 6001::1/64
Related documentation
·     Layer 3—IP Routing Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Layer 3—IP Routing Command Reference in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     IP Tunneling and Security VPN Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     IP Tunneling and Security VPN Command Reference in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
