H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
29-NAT DNS Mapping Configuration Examples
29-NAT DNS Mapping Configuration Examples 69.74 KB
H3C Routers
NAT DNS Mapping
Introduction
The following information provides examples for configuring NAT DNS mapping on routers.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of NAT.
Example: Configuring NAT DNS mapping
As shown in Figure 1, the internal Web server at 10.0.0.2/24 provides Web services for external users. The private network has three public addresses 172.31.123.201 to 172.31.123.203. The DNS server at 172.31.123.181 is on the public network.
Configure NAT so that both internal and external hosts can access the internal server by using their domain names.
Figure 1 Network diagram
Analysis
·     Configure a NAT server mapping to map the private IP address and port of the internal server to a public address and port so that external users can access the internal server.
·     Configure NAT DNS mapping and ALG so that the public IP address of the internal server in the payload of the DNS response packet can be translated to the private IP address.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
Procedures
# Specify IP addresses for GigabitEthernet 0/0/1 and GigabitEthernet 0/0/2.
<Router> system-view
[Router] interface gigabitethernet 0/0/2
[Router-GigabitEthernet0/0/2] ip address 172.31.123.201 24
[Router-GigabitEthernet0/0/2] quit
[Router] interface gigabitethernet 0/0/1
[Router-GigabitEthernet0/0/1] ip address 10.0.0.1 24
[Router-GigabitEthernet0/0/1] quit
# Enable NAT ALG for DNS.
[Router] nat alg dns
# Configure NAT Server to allow external hosts to access the internal Web server by using address 172.31.123.202.
[Router-GigabitEthernet0/0/2] nat server protocol tcp global 172.31.123.202 inside 10.0.0.2 http
[Router-GigabitEthernet0/0/2] nat outbound
# Configure a NAT DNS mapping entry by mapping domain name www.server.com of the Web server to 172.31.123.202.
[Router] nat dns-map domain www.server.com protocol tcp ip 172.31.123.202 port http
[Router] quit
# Verify that both internal and external hosts can access the internal server by using domain names. (Details not shown.)
# Display all NAT configuration and statistics.
<Router> display nat all
NAT internal server information:
  Totally 1 internal servers.
  Interface: GigabitEthernet0/0/2
    Protocol: 6(TCP)
    Global IP/port: 172.31.123.202/80
    Local  IP/port: 10.0.0.2/80
    NAT counting  : 0
    Config status : Active
NAT DNS mapping information:
  Totally 1 NAT DNS mappings.
  Domain name: www.server.com
  Global IP  : 172.31.123.202
  Global port: 80
  Protocol   : TCP(6)
  Config status: Active
NAT logging:
  Log enable          : Disabled
  Flow-begin          : Disabled
  Flow-end            : Disabled
  Flow-active         : Disabled
  Port-block-assign   : Disabled
  Port-block-withdraw : Disabled
  Alarm               : Disabled
  NO-PAT IP usage     : Disabled
NAT mapping behavior:
  Mapping mode: Address and Port-Dependent
  ACL         : ---
NAT ALG:
  DNS        : Enabled
  FTP        : Enabled
  H323       : Enabled
  ICMP-ERROR : Enabled
  ILS        : Enabled
  MGCP       : Enabled
  NBT        : Enabled
  PPTP       : Enabled
  RTSP       : Enabled
  RSH        : Enabled
  SCCP       : Enabled
  SCTP       : Enabled
  SIP        : Enabled
  SQLNET     : Enabled
  TFTP       : Enabled
  XDMCP      : Enabled
Static NAT load balancing:     Disabled
NAT link-switch recreate-session: Disabled
NAT configuration-for-new-connection: Disabled
NAT global-policy compatible-previous-version rule-type ipv4-snat-and-dnat trans
late-before-secp : Disabled
Configuration files
interface GigabitEthernet0/0/1
 port link-mode route
 ip address 10.0.0.1 255.255.255.0
interface GigabitEthernet0/0/2
 ip address 172.31.123.201 255.255.255.0
 nat outbound
 nat server protocol tcp global 172.31.123.202 80 inside 10.0.0.2 80
nat alg dns
nat dns-map domain www.server.com protocol tcp ip 172.31.123.202 port 80
Related documentation
·     NAT and IPv6 Transition Technologies Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     NAT and IPv6 Transition Technologies Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
