H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
67-Port Isolation Configuration Examples
67-Port Isolation Configuration Examples 137.71 KB
H3C Routers
Introduction
The following information provides examples for port isolation.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of port isolation.
Example: Configuring port isolation
As shown in Figure 1:
·     LAN users Host A and Host B are connected to GigabitEthernet 0/0/1 and GigabitEthernet 0/0/2 on the device, respectively.
·     The device connects to the Internet through GigabitEthernet 0/0/3.
Configure the device to provide Internet access for Host A and Host B, and isolate them from each other.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
The device supports only one isolation group, which is automatically created by the system as isolation group 1. Users cannot delete this isolation group or create other isolation groups. The number of ports that can be added to the isolation group is not limited.
Procedures
# Assign GigabitEthernet 0/0/1 and GigabitEthernet 0/0/2 to the isolation group.
[Device] interface gigabitethernet 0/0/1
[Device-GigabitEthernet0/0/1] port-isolate enable
[Device-GigabitEthernet0/0/1] quit
[Device-GigabitEthernet0/0/2] port-isolate enable
[Device-GigabitEthernet0/0/2] quit
# Display information about the isolation group.
[Device] display port-isolate group
Port isolation group information:
Group ID: 1
Group members:
GigabitEthernet0/0/1   GigabitEthernet0/0/2
The output shows that GigabitEthernet 0/0/1 and GigabitEthernet 0/0/2 are assigned to the isolation group. As shown in Figure 2, Host A and Host B are isolated from each other at Layer 2.
Figure 2 Host A ping Host B
Configuration files
interface GigabitEthernet0/0/1
 port link-mode bridge
port-isolate enable
interface GigabitEthernet0/0/2
port-isolate enable
Related documentation
·     H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     H3C MSR1000[2600][3600] Routers Command References(V9)
