H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
50-Small and Medium-Sized Store Configuration Examples
H3C Routers
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Introduction
The following information provides an example for using a router in small- to medium-sized store networking.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
The following information is provided based on the assumption that you have basic knowledge of DHCP, WLAN, PPPoE, and NAT.
Example: Configuring router settings for small and medium-sized store networking
As shown in Figure 1, the networking requirements for a small to medium-sized store are as follows:
·     The router acts as a DHCP server, allocating IP addresses to APs, wireless clients, and wired hosts.
·     Users in the administration zone can access the Internet through wired and wireless connections. Wireless users in the zone access the WLAN using the PSK authentication and key management mode.
·     The router acts as both the portal authentication server and portal Web server. It offers wireless users in the access zone a direct method for portal authentication to access the Internet.
·     The router acts as the exit gateway for Internet access through PPPoE dial-up. It must support NAT for private network address translation.
Figure 1 Network diagram
Access zoneAdministration zoneAccess zoneAdministration zone
1.     Terminal VLAN and address pool resource planning
Device
Corresponding VLAN
DHCP address pool and network segment
AP
100
1: 192.168.100.0/24
Wireless clients in the administration zone
200
2: 192.168.200.0/24
Wired terminals in the administration zone
101
3: 192.168.101.0/24
Wireless clients in the access zone
201
4: 192.168.201.0/24
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 router.
Analysis
·     On the router, configure the AP to obtain the IP address of the AC through Option 43 carried in the DHCP response to complete Layer 3 registration.
·     Configure the wireless AC server on the router to ensure that wireless clients can access the network through the configured wireless service.
·     Configure direct portal authentication service on the router for users to enter a username and password to complete portal authentication before accessing the network.
·     Configure route settings between routers, switches, and APs to enable network interoperability.
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the router
Configuring the DHCP server
# Enable the DHCP service.
<Router> system-view
[Router] dhcp enable
# Create VLAN 102 and VLAN-interface 102, and configure an IP address for the interface. The AP will obtain the IP address to establish a CAPWAP tunnel with the AC.
[Router] vlan 102
[Router-vlan102] quit
[Router] interface Vlan-interface 102
[Router-Vlan-interface102] ip address 10.1.1.1 24
# Configure VLAN-interface 102 to operate in DHCP server mode.
[Router-Vlan-interface102] dhcp select server
[Router-Vlan-interface102] quit
# Configure GigabitEthernet 0/0/1 as a trunk port, and configure the interface to allow VLAN 102 to pass.
[Router] interface gigabitethernet 0/0/1
[Router-GigabitEthernet0/0/1] port link-mode bridge
[Router-GigabitEthernet0/0/1] port link-type trunk
[Router-GigabitEthernet0/0/1] port trunk permit vlan 102
[Router-GigabitEthernet0/0/1] quit
# Create VLANs 200 and 201 for wireless clients to access the wireless network. Configure the IP addresses for VLAN-interface 200 and VLAN-interface 201.
[Router] vlan 200
[Router-vlan200] quit
[Router] interface vlan-interface 200
[Router-Vlan-interface101] ip address 192.168.200.1 24
[Router-Vlan-interface101] quit
[Router] vlan 201
[Router-vlan201] quit
[Router] interface vlan-interface 201
[Router-Vlan-interface201] ip address 192.168.201.1 24
[Router-Vlan-interface201] quit
# Configure DHCP address pool 1 to allocate addresses in subnet 192.168.100.0/24 for APs, with the gateway address set to 192.168.100.1.
[Router] dhcp server ip-pool 1
[Router-dhcp-pool-1] network 192.168.100.0 mask 255.255.255.0
[Router-dhcp-pool-1] gateway-list 192.168.100.1
# Specify the hexadecimal IP address of the router as the content of DHCP Option 43.
[Router-dhcp-pool-1] option 43 hex 80070000010a010101
[Router-dhcp-pool-1] quit
# Configure DHCP address pool 2 to allocate addresses in subnet 192.168.200.0/24 for wireless clients in the administration zone, with the gateway address set to 192.168.200.1.
[Router] dhcp server ip-pool 2
[Router-dhcp-pool-2] network 192.168.200.0 mask 255.255.255.0
[Router-dhcp-pool-2] gateway-list 192.168.200.1
[Router-dhcp-pool-2] quit
# Configure DHCP address pool 3 to allocate addresses in subnet 192.168.101.0/24 for wired terminals in the administration zone, with the gateway address set to 192.168.101.1.
[Router] dhcp server ip-pool 3
[Router-dhcp-pool-3] network 192.168.101.0 mask 255.255.255.0
[Router-dhcp-pool-3] gateway-list 192.168.101.1
[Router-dhcp-pool-3] quit
# Configure DHCP address pool 4 to allocate addresses in subnet 192.168.201.0/24 for wireless clients in the access zone, with the gateway address set to 192.168.201.1.
[Router] dhcp server ip-pool 4
[Router-dhcp-pool-4] network 192.168.201.0 mask 255.255.255.0
[Router-dhcp-pool-4] gateway-list 192.168.201.1
[Router-dhcp-pool-4] quit
# Configure static routes to each client network segment.
[Router] ip route-static 192.168.100.0 24 10.1.1.2
[Router] ip route-static 192.168.101.0 24 10.1.1.2
Configuring the AC
Table 1 Configure wireless service 1 for the administration zone
# Create wireless service template 1 and enter its view.
[Router] wlan service-template 1
# Set the SSID to employee.
[Router-wlan-st-1] ssid employee
# Specify the authentication and key management mode as PSK and set the PSK key to plaintext string 12345678.
[Router-wlan-st-1] akm mode psk
[Router-wlan-st-1] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[Router-wlan-st-1] cipher-suite ccmp
[Router-wlan-st-1] security-ie rsn
# Specify the AC as the client data forwarder. You can skip this step if the AC is the default client data forwarder.
[Router-wlan-st-1] client forwarding-location ac
# Enable wireless service template 1.
[Router–wlan-st-1] service-template enable
[Router-wlan-st-1] quit
Table 2 Configure service template 2 for the access zone
# Create wireless service template 2 and enter its view.
[Router] wlan service-template 2
# Set the SSID to guest.
[Router-wlan-st-2] ssid guest
# Enable wireless service template 2.
[Router–wlan-st-2] service-template enable
[Router-wlan-st-2] quit
Table 3 Configure the AP in the administrator zone
# Create an AP named ap1 and specify the AP model.
[Router] wlan ap ap1 model WA4320H
# Set the AP serial number to 219801A0YG819BE005JC.
[Router-wlan-ap-ap1] serial-id 219801A0YG819BE005JC
# Enter radio view of radio 1 on AP ap1, bind wireless service template 1 to radio 1, and configure clients coming online from the radio to join VLAN 200.
[Router-wlan-ap-ap1] radio 1
[Router-wlan-ap-ap1-radio-1] service-template 1 vlan 200
# Enable radio 1.
[Router-wlan-ap-ap1-radio-1] radio enable
[Router-wlan-ap-ap1-radio-1] return
Table 4 Configure the AP group for the access zone
# Create AP ap2 and AP ap3, and specify the AP models and serial numbers.
[Router] wlan ap ap2 model WA4320H
[Router-wlan-ap-ap2] serial-id 219801A0YG8198E0064J
[Router-wlan-ap-ap2] quit
[Router] wlan ap ap3 model WA4320H
[Router-wlan-ap-ap3] serial-id 219801A0YG8198E0078C
[Router-wlan-ap-ap3] quit
# Create AP group group1 and add APs ap2 and ap3 to the group.
[Router] wlan ap-group group1
[Router-wlan-ap-group-group1] ap ap2 ap3
# Bind wireless service template 2 to radio 2 on APs in AP group group1, and configure clients coming online from the radio to join VLAN 201.
[Router-wlan-ap-group-group1] ap-model WA4320H
[Router-wlan-ap-group-group1-ap-model-WA4320H] radio 2
[Router-wlan-ap-group-group1-ap-model-WA4320H-radio-2] service-template 2 vlan 201
# Enable radio 1.
[Router-wlan-ap-group-group1-ap-model-WA4320H-radio-2] radio enable
[Router-wlan-ap-group-group1-ap-model-WA4320H-radio-2] return
Configuring the portal authentication server and portal Web server
Table 1 Configuring AAA
# Create an ISP domain named dm1 and enter its view.
[Router] domain dm1
# Set the AAA authentication method to local for portal users.
[Router-isp-dm1] authentication portal local
# Set the AAA authorization method for portal users to none.
[Router-isp-dm1] authorization portal none
# Set the AAA accounting method for portal users to none.
[Router-isp-dm1] accounting portal none
Set the idle timeout for users in the ISP domain dm1 to 15 minutes and the minimum traffic to 1024 bytes.
[Router-isp-dm1] authorization-attribute idle-cut 15 1024
[Router-isp-dm1] quit
Table 2 Configure portal authentication
# Specify the URL of the portal Web server as http://192.168.201.1/portal.
[Router] portal web-server newpt
[Router-portal-websvr-newpt] url http://192.168.201.1/portal
[Router-portal-websvr-newpt] quit
# Configure two destination-based portal authentication-free rules to allow traffic to the DNS server.
[Router] portal free-rule 1 destination ip any udp 53
[Router] portal free-rule 2 destination ip any tcp 53
# Enable direct portal authentication on wireless service template 2.
[Router–wlan-st-2] portal enable method direct
# Apply portal Web server newpt to wireless service template 2.
[Router–wlan-st-2] portal apply web-server newpt
[Router–wlan-st-2] quit
# Create an HTTP-based local portal Web service and enter its view.
[Router] portal local-web-server http
# Configure the local portal Web server to use the default authentication paging file bendi.zip. Make sure the file already exist in the root directory of the device storage media.
[Router–portal-local-websvr-http] default-logon-page bendi.zip
[Router–portal-local-websvr-http] quit
# Configure the username and password for local portal authentication.
[Router] local-user guest class network
[Router-luser-network-guest] password simple abc123
[Router-luser-network-guest] service-type portal
[Router-luser-network-guest] quit
# Enable intra-VLAN roaming for portal users.
[Router] portal roaming enable
# Disable the Rule ARP entry feature for portal clients.
[Router] undo portal refresh arp enable
# Enable validity check on wireless portal clients.
[Router] portal host-check enable
Configuring PPPoE dial-up for Internet access
# Create dialer group 1.
[Router] dialer-group 1 rule ip permit
# Create a dialer interface, and configure dialer parameters, IP address negotiation, and PAP authentication.
[Router] interface dialer 0
[Router-Dialer0] dialer bundle enable
[Router-Dialer0] dialer-group 1
[Router-Dialer0] ip address ppp-negotiate
[Router-Dialer0] ppp pap local-user aaa password simple abc123
[Router-Dialer0] quit
# Configure a PPPoE session corresponding to Dialer bundle 1 on GigabitEthernet 0/0/2.
[Router] interface gigabitethernet 0/0/2
[Router-GigabitEthernet0/0/2] pppoe-client dial-bundle-number 1
[Router-GigabitEthernet0/0/2] quit
Configuring NAT
# Configure NAT.
[Router-Dialer0] nat outbound
# Configure a default static route with egress interface Dialer0.
[Router] ip route-static 0.0.0.0 0 Dialer0
[Router] quit
Configuring the switch
Table 3 Configure VLANs and VLAN interfaces.
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.168.100.1 24
[Switch] vlan 101
[Switch] interface vlan-interface 101
[Switch-Vlan-interface101] ip address 192.168.101.1 24
[Switch-Vlan-interface101] quit
[Switch] vlan 102
[Switch-vlan102] quit
[Switch] interface vlan-interface 102
[Switch-Vlan-interface102] ip address 10.1.1.2 24
[Switch-Vlan-interface102] quit
Table 4 Configure GigabitEthernet 0/0/1 connecting the switch to the router as a trunk port and allow VLAN 102 to pass.
[Switch] interface gigabitethernet 0/0/1
[Switch-GigabitEthernet0/0/1] port link-type trunk
[Switch-GigabitEthernet0/0/1] port trunk permit vlan 102
[Switch-GigabitEthernet0/0/1] quit
Table 5 Configure GigabitEthernet 0/0/2 connecting the switch to wired terminals in the administration zone as an access port and add the port to VLAN 101.
[Switch] interface gigabitethernet 0/0/2
[Switch-GigabitEthernet0/0/2] port link-type access
[Switch-GigabitEthernet0/0/2] port access vlan 101
[Switch-GigabitEthernet0/0/2] quit
Table 6 # Configure GigabitEthernet 0/0/3 connecting the switch to APs in the administration zone as a trunk port, block VLAN 1, and allow VLAN 100 to pass.
[Switch] interface gigabitethernet 0/0/3
[Switch-GigabitEthernet0/0/3] port link-type trunk
[Switch-GigabitEthernet0/0/3] undo port trunk permit vlan 1
[Switch-GigabitEthernet0/0/3] port trunk permit vlan 100
[Switch-GigabitEthernet0/0/3] port trunk pvid vlan 100
[Switch-GigabitEthernet0/0/3] quit
Table 7 Configure GigabitEthernet 0/0/4 and GigabitEthernet 0/0/5 as trunk ports, block VLAN 1, and allow VLAN 100 to pass.
[Switch] interface gigabitethernet 0/0/4
[Switch-GigabitEthernet0/0/4] port link-type trunk
[Switch-GigabitEthernet0/0/4] undo port trunk permit vlan 1
[Switch-GigabitEthernet0/0/4] port trunk permit vlan 100
[Switch-GigabitEthernet0/0/4] port trunk pvid vlan 100
[Switch-GigabitEthernet0/0/4] quit
[Switch] interface gigabitethernet 0/0/5
[Switch-GigabitEthernet0/0/5] port link-type trunk
[Switch-GigabitEthernet0/0/5] undo port trunk permit vlan 1
[Switch-GigabitEthernet0/0/5] port trunk permit vlan 100
[Switch-GigabitEthernet0/0/5] port trunk pvid vlan 100
[Switch-GigabitEthernet0/0/5] quit
Table 8 Configure the switch to act as a DHCP relay and specify IP address 10.1.1.1 of the router as the DHCP server address.
[Switch] dhcp enable
[Switch-Vlan-interface100] dhcp select relay
[Switch-Vlan-interface100] dhcp relay server-address 10.1.1.1
[Switch-Vlan-interface101] dhcp select relay
[Switch-Vlan-interface101] dhcp relay server-address 10.1.1.1
Table 9 Configure a default route.
[Switch] ip route-static 0.0.0.0 0 10.1.1.1
Table 1 View the IP address allocation information for the address pool on the router.
<Router> display dhcp server ip-in-use
IP address       Client identifier/    Lease expiration      Type
                 Hardware address
192.168.100.2    0194-292f-9314-c0     Sep  2 15:32:28 2022  Auto(C)
192.168.100.3    0154-2bde-fd4b-a0     Sep  2 15:32:30 2022  Auto(C)
192.168.100.4    0102-6121-250c-0e     Sep  2 15:32:30 2022  Auto(C)
192.168.101.2    0035-6361-352e-6339-  Sep  2 15:58:42 2022  Auto(C)
                 6330-2e30-3330-362d-
                 4745-302f-302f-31
192.168.200.2    018e-7170-24dd-21     Sep  2 15:45:13 2022  Auto(C)
192.168.201.2    011a-95ad-b5a7-08     Sep  2 15:44:57 2022  Auto(C)
192.168.201.3    0112-2016-7f1b-01     Sep  2 15:44:16 2022  Auto(C)
Table 2 View the AP registration information on the AC.
# Verify that the AP state is R/M, which indicates that the AP has been successfully registered with the AC.
<Router> display wlan ap all
Total number of APs: 3
Total number of connected APs: 3
Total number of connected manual APs: 3
Total number of connected auto APs: 0
Total number of connected common APs: 3
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 16
Remaining APs: 13
Total AP licenses: 128
Local AP licenses: 128
Server AP licenses: 0
Remaining Local AP licenses: 125
Sync AP licenses: 0
                                 AP information
 State : I = Idle,      J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,    DC = DataCheck,  R  = Run,   M = Master,  B = Backup
AP name                        APID  State Model           Serial ID
ap1                            1     R/M   WA4320H         219801A0YG819BE005JC
ap2                            2     R/M   WA4320H         219801A0YG8198E0064J
ap3                            3     R/M   WA4320H         219801A0YG8198E0078C
Table 3 View client information on the AC.
# Verify that the client has come online from radio 1.
<Router> display wlan client
Total number of clients: 3
MAC address    User name            AP name               R IP address      VLAN
8e71-7024-dd21 N/A                  ap1                   1 192.168.200.2   200
1a95-adb5-a708 N/A                  ap2                   2 192.168.201.2   201
1220-167f-1b01 N/A                  ap2                   2 192.168.201.3   201
Table 4 Verify that the wireless client has obtained an IP address and come online.
Use a wireless client in the administration zone as an example:
Table 5 Verify that users in the access zone can perform portal authentication through a Web page. Before authentication, all web access initiated by a user is redirected to the portal authentication page (http://192.168.201.1/portal), as shown in the figure below:
A user must enter the username and password manually at the first-time portal authentication. For subsequent network access, the user can directly access Internet resources without noticing the portal authentication process.
View the information about online portal users generated on the router.
<Router> display portal user all
Total portal users: 2
Username: guest
  AP name: ap2
  Radio ID: 2
  SSID: guest
  Portal server: N/A
  State: Online
  VPN instance: N/A
  MAC             IP                    VLAN    Interface
  1a95-adb5-a708  192.168.201.2         201     WLAN-BSS0/4
  Authorization information:
    DHCP IP pool: N/A
    User profile: N/A
    Session group profile: N/A
    ACL number/name: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Username: guest
  AP name: ap2
  Radio ID: 2
  SSID: guest
  Portal server: N/A
  State: Online
  VPN instance: N/A
  1220-167f-1b01  192.168.201.3         201     WLAN-BSS0/4
    DHCP IP pool: N/A
    User profile: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Configuration files
·     Router
 dhcp enable
vlan 102
vlan 200 to 201
 ssid employee
 akm mode psk
 preshared-key pass-phrase cipher $c$3$mczcUlpjginwHwJ3vABq97tR3kLdRI823mKv
 cipher-suite ccmp
 security-ie rsn
 ssid guest
interface Dialer0
 ppp pap local-user h3c password cipher $c$3$Z3pvO6H0my2Z6Yq5QfmoMO5SrTDn7A==
 dialer-group 1
 nat outbound
interface Vlan-interface102
interface Vlan-interface200
 ip address 192.168.200.1 255.255.255.0
interface Vlan-interface201
 ip address 192.168.201.1 255.255.255.0
interface GigabitEthernet0/0/2
 port link-mode route
interface GigabitEthernet0/0/1
domain dm1
 password cipher $c$3$N+s6HOuF0o1QxOe48Ly+kHVQrT21UBXNgA==
 service-type portal
 url http://192.168.201.1:8080/portal
 vlan 1
 ap ap2
 ap ap3
 ap-model WA4320H
  radio 1
  radio 2
   radio enable
 vlan 1
 radio 1
  radio enable
 radio 2
 serial-id 219801A0YG819BE0064J
 vlan 1
 radio 1
 radio 2
 serial-id 219801A0YG819BE0078C
 vlan 1
 radio 1
 radio 2
·     Switch
dhcp enable
vlan 100 to 102
interface Vlan-interface100
 ip address 192.168.100.1 255.255.255.0
 dhcp select relay
interface Vlan-interface101
 ip address 192.168.101.1 255.255.255.0
 dhcp select relay
interface GigabitEthernet0/0/3
interface GigabitEthernet0/0/4
interface GigabitEthernet0/3
