H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
25-MPLS L3VPN Configuration Examples
25-MPLS L3VPN Configuration Examples 214.85 KB
H3C Routers
Introduction
The following information provides MPLS L3VPN configuration examples.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of MPLS L3VPN.
Example: Configuring MPLS L3VPN
As shown in Figure 1, customer A and customer B each have two dispersed branches. Configure MPLS L3VPN for the customers, so that branches of the same customer can exchange routes and transfer user data with each other while branches of different customers cannot.
Figure 1 Network diagram
Analysis
·     To transfer packets on the MPLS network, configure an IGP routing protocol on the MPLS backbone, and use LDP to distribute public network (outer) labels to VPN packets.
·     To differentiate routes of different customers, create two VPN instances on each PE, one for customer A and the other for customer B. Configure an RD and RTs for each VPN instance and then redistribute the VPN routes into BGP for the corresponding customer.
·     To transport VPN routes and allocate VPN (inner) labels, establish an MP-IBGP peer relationship between the PEs.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
When an interface is bound to a VPN instance, the settings (including IP address) on the interface will be cleared. Therefore, bind an interface to a VPN instance before you configure other settings on the interface.
Procedures
Configuring an IGP protocol (OSPF in this example) on the MPLS backbone to implement IP connectivity between PEs and Ps
Table 1 Configure PE 1:
# Configure IP addresses for the loopback interface and the backbone network interface.
<PE1>system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] interface gigabitethernet 0/0/2
[PE1-GigabitEthernet0/0/2] ip address 10.1.1.1 24
[PE1-GigabitEthernet0/0/2] quit
# Enable OSPF on the interfaces attached to the backbone network.
[PE1]ospf 1
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
Table 2 Configure P:
# Configure IP addresses for the loopback interface and the backbone network interfaces.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface gigabitethernet 0/0/2
[P-GigabitEthernet0/0/2] ip address 10.1.1.2 24
[P-GigabitEthernet0/0/2] quit
[P] interface gigabitethernet 0/0/1
[P-GigabitEthernet0/0/1] ip address 10.1.4.1 24
[P-GigabitEthernet0/0/1] quit
[P] ospf 1
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.4.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
Table 3  Configure PE 2:
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] interface gigabitethernet 0/0/1
[PE2-GigabitEthernet0/0/1] ip address 10.1.4.2 24
[PE2-GigabitEthernet0/0/1] quit
# Enable OSPF on the interfaces attached to the backbone network side.
[PE2] ospf 1
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.4.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
After the configuration is completed, PE1, P, and PE2 can establish OSPF neighbor relationship. Execute the display ospf peer command to verify that the neighbors are in full state. Execute the display ip routing-table command to verify that the PEs have learned the routes to the loopback interfaces of each other.
Use PE1 as an example.
[PE1] display ospf peer verbose
          OSPF Process 1 with Router ID 1.1.1.9
                  Neighbors
 Area 0.0.0.0 interface 10.1.1.1(GE0/0/2       )'s neighbors
 Router ID: 2.2.2.9          Address: 10.1.1.2        GR State: Normal
   State: Full  Mode: Nbr is Master  Priority: 1
   DR: 10.1.1.2  BDR: 10.1.1.1  MTU: 0
   Dead timer due in 38  sec
   Neighbor is up for 17:30:25
   BFD status: Disabled
[PE1] display ip routing-table protocol ospf
Summary Count : 4
Summary Count : 2
3.3.3.9/32         O_INTRA 10  2           10.1.1.2        GE0/0/2
10.1.4.0/24        O_INTRA 10  2           10.1.1.2        GE0/0/2
Summary Count : 2
1.1.1.9/32         O_INTRA 10  0           0.0.0.0         Loop0
10.1.1.0/24        O_INTRA 10  1           0.0.0.0         GE0/0/2
Configuring basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs
# Configure the MPLS LSR ID and enable LDP globally.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
# Enable MPLS and IPv4 LDP capabilities on the interface.
[PE1-GigabitEthernet0/0/2] mpls enable
[PE1-GigabitEthernet0/0/2] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-GigabitEthernet0/0/2] mpls enable
[P-GigabitEthernet0/0/2] mpls ldp enable
[P-GigabitEthernet0/0/1] mpls enable
[P-GigabitEthernet0/0/1] mpls ldp enable
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-GigabitEthernet0/0/1] mpls enable
[PE2-GigabitEthernet0/0/1] mpls ldp enable
Execute the display mpls ldp peer command to verify that LDP sessions in Operational state have been established between PE 1, P, and PE 2. Execute the display mpls ldp lsp command to verify that the LSPs have been established by LDP.
[PE1] display mpls ldp peer
Total number of peers: 1
Peer LDP ID             State         Role     GR   MD5  KA Sent/Rcvd
2.2.2.9:0               Operational   Passive  Off  Off  5/5
[PE1] display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup
FECs: 4            Ingress: 1          Transit: 1      Egress: 3
FEC                In/Out Label        Nexthop         OutInterface
1.1.1.9/32         3/-
                   -/1151(L)
2.2.2.9/32         -/3                 10.1.1.2        GE0/0/2
                   1151/3              10.1.1.2        GE0/0/2
3.3.3.9/32         -/1150              10.1.1.2        GE0/0/2
                   1150/1150           10.1.1.2        GE0/0/2
Configuring VPN instances on PEs to allow CE access
# On PE 1, create a VPN instance named customerA.
[PE1] ip vpn-instance customerA
# Configure the RD as 100:1 for the VPN instance. The RD is used for generating VPNv4 routes and distinguishing routes of different users on the same network segment.
[PE1-vpn-instance-customerA] route-distinguisher 100:1
# Configure import target 111:1 and export target 222:1 for the VPN instance.
[PE1-vpn-instance-customerA] vpn-target 111:1 import-extcommunity
[PE1-vpn-instance-customerA] vpn-target 222:1 export-extcommunity
[PE1-vpn-instance-customerA] quit
# Create VPN instance customerB in the same way. Configure RD 200:1, import target 333:1, and export target 444:1 for the VPN instance.
[PE1] ip vpn-instance customerB
[PE1-vpn-instance-customerB] route-distinguisher 200:1
[PE1-vpn-instance-customerB] vpn-target 333:1 import-extcommunity
[PE1-vpn-instance-customerB] vpn-target 444:1 export-extcommunity
[PE1-vpn-instance-customerB] quit
# Bind interface GigabitEthernet 0/0/1 to VPN instance customerA.
[PE1] interface gigabitethernet 0/0/1
[PE1-GigabitEthernet0/0/1] ip binding vpn-instance customerA
[PE1-GigabitEthernet0/0/1] ip address 100.1.1.2 24
[PE1-GigabitEthernet0/0/1] quit
# Bind interface GigabitEthernet 0/0/3 to VPN instance customerB.
[PE1] interface gigabitethernet 0/0/3
[PE1-GigabitEthernet0/0/3] ip binding vpn-instance customerB
[PE1-GigabitEthernet0/0/3] ip address 200.1.1.2 24
[PE1-GigabitEthernet0/0/3] quit
Table 2 Configure PE 2:
# On PE 2, create a VPN instance named customerA.
[PE2] ip vpn-instance customerA
# Configure an RD for the VPN instance. For ease of identification, as a best practice, set the same RD as that on PE 1.
[PE2-vpn-instance-customerA] route-distinguisher 100:1
# Configure the import target and export target for the VPN instance, which must be the same as the export target and import target on PE 1.
[PE2-vpn-instance-customerA] vpn-target 222:1 import-extcommunity
[PE2-vpn-instance-customerA] vpn-target 111:1 export-extcommunity
[PE2-vpn-instance-customerA] quit
# Create VPN instance customerB in the same way. Configure RD 200:1, import target 444:1, and export target 333:1 for the VPN instance.
[PE2] ip vpn-instance customerB
[PE2-vpn-instance-customerB] route-distinguisher 200:1
[PE2-vpn-instance-customerB] vpn-target 444:1 import-extcommunity
[PE2-vpn-instance-customerB] vpn-target 333:1 export-extcommunity
[PE2-vpn-instance-customerB] quit
# Bind GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3 to VPN instance customerA and VPN instance customerB, respectively.
[PE2] interface gigabitethernet 0/0/2
[PE2-GigabitEthernet0/0/2] ip binding vpn-instance customerA
[PE2-GigabitEthernet0/0/2] ip address 101.1.1.1 24
[PE2-GigabitEthernet0/0/2] quit
[PE2] interface gigabitethernet 0/0/3
[PE2-GigabitEthernet0/0/3] ip binding vpn-instance customerB
[PE2-GigabitEthernet0/0/3] ip address 202.1.1.2 24
[PE2-GigabitEthernet0/0/3] quit
Table 3 Configure the CE:
# Configure IP addresses for interfaces on the CE as shown in Figure 1. (Details not shown.)
# After the configuration is completed, execute the display ip vpn-instance command on the PEs to view the VPN instance configuration. Each PE can ping its attached CE device.
Use PE 1 and CE 1 as an example.
[PE1] display ip vpn-instance
  Total VPN-Instances configured : 2
  VPN-Instance Name               RD                     Create time
  customerA                       100:1                  2014/03/22 13:20:08
  customerB                       200:1                  2014/03/22 13:20:20
[PE1] ping -vpn-instance customerA 100.1.1.1
Ping 10.1.1.1 (100.1.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 100.1.1.1: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 100.1.1.1: icmp_seq=1 ttl=255 time=2.000 ms
56 bytes from 100.1.1.1: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 100.1.1.1: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 100.1.1.1: icmp_seq=4 ttl=255 time=0.000 ms
--- Ping statistics for 10.1.1.1 ---
round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms
Establishing EBGP peer relationships between PEs and CEs, and redistributing VPN routes into BGP
# Create BGP process 100 on PE 1.
[PE1] bgp 100
# Specify CE 1 as the peer. Redistribute the direct routes in the routing table of PE 1 into the routing table of the BGP-VPN instance.
[PE1-bgp] ip vpn-instance customerA
[PE1-bgp-customerA] peer 100.1.1.1 as-number 65410
[PE1-bgp-customerA] address-family ipv4 unicast
[PE1-bgp-ipv4-customerA] peer 100.1.1.1 enable
[PE1-bgp-ipv4-customerA] import-route direct
[PE1-bgp-ipv4-customerA] quit
[PE1-bgp-customerA] quit
# Specify CE 2 as the peer. Redistribute the direct routes in the routing table of PE 1 into the routing table of the BGP-VPN instance.
[PE1-bgp] ip vpn-instance customerB
[PE1-bgp-customerB] peer 200.1.1.1 as-number 65410
[PE1-bgp-customerB] address-family ipv4 unicast
[PE1-bgp-ipv4-customerB] peer 200.1.1.1 enable
[PE1-bgp-ipv4-customerB] import-route direct
[PE1-bgp-ipv4-customerB] quit
[PE1-bgp-customerB] quit
[PE1-bgp] quit
# Create BGP process 100 on PE 2.
[PE2] bgp 100
# Specify CE 3 as the peer. Redistribute the direct routes in the routing table of PE 2 into the routing table of the BGP-VPN instance.
[PE2-bgp] ip vpn-instance customerA
[PE2-bgp-customerA] peer 101.1.1.2 as-number 65430
[PE2-bgp-customerA] address-family ipv4 unicast
[PE2-bgp-ipv4-customerA] peer 101.1.1.2 enable
[PE2-bgp-ipv4-customerA] import-route direct
[PE2-bgp-ipv4-customerA] quit
[PE2-bgp-customerA] quit
# Specify CE 4 as the peer. Redistribute the direct routes in the routing table of PE 2 into the routing table of the BGP-VPN instance.
[PE2-bgp] ip vpn-instance customerB
[PE2-bgp-customerB] peer 202.1.1.1 as-number 65430
[PE2-bgp-customerB] address-family ipv4 unicast
[PE2-bgp-ipv4-customerB] peer 202.1.1.1 enable
[PE2-bgp-ipv4-customerB] import-route direct
[PE2-bgp-ipv4-customerB] quit
[PE2-bgp-customerB] quit
[PE2-bgp] quit
Table 3 Configure CE 1:
# Create BGP process 65410 on CE 1. Specify PE 1 as the peer with AS number 100.
<CE1>system-view
[CE1] bgp 65410
[CE1-bgp] peer 100.1.1.2 as-number 100
#  Enable CE 1 to exchange IPv4 unicast routing information with peer 100.1.1.2.
[CE1-bgp] address-family ipv4 unicast
[CE1-bgp-ipv4] peer 100.1.1.2 enable
# Redistribute the direct route connected to the host on CE 1 into EBGP.
[CE1-bgp-ipv4] import-route direct
[CE1-bgp-ipv4] quit
[CE1-bgp] quit
Table 4 Configure CE 2:
# Create BGP process 65410 on CE 2. Specify PE 1 as the peer with AS number 100.
<CE2> system-view
[CE2] bgp 65410
[CE2-bgp] peer 200.1.1.2 as-number 100
#  Enable CE 2 to exchange IPv4 unicast routing information with peer 200.1.1.2.
[CE2-bgp] address-family ipv4 unicast
[CE2-bgp-ipv4] peer 200.1.1.2 enable
# Redistribute the direct route connected to the host on CE 2 into EBGP.
[CE2-bgp-ipv4] import-route direct
[CE2-bgp-ipv4] quit
[CE2-bgp] quit
Table 5 Configure CE 3:
# Create BGP process 65430 on CE 3. Specify PE 2 as the peer with AS number 100.
<CE3>system-view
[CE3] bgp 65430
[CE3-bgp] peer 101.1.1.1 as-number 100
#  Enable CE 3 to exchange IPv4 unicast routing information with peer 101.1.1.1.
[CE3-bgp] address-family ipv4 unicast
[CE3-bgp-ipv4] peer 101.1.1.1 enable
# Redistribute the direct route connected to the host on CE 3 into EBGP.
[CE3-bgp-ipv4] import-route direct
[CE3-bgp-ipv4] quit
[CE3-bgp] quit
Table 6 Configure CE 4:
# Create BGP process 65430 on CE 4. Specify PE 2 as the peer with AS number 100.
<CE4>system-view
[CE4] bgp 65430
[CE4-bgp] peer 202.1.1.2 as-number 100
# Enable CE 4 to exchange IPv4 unicast routing information with peer 202.1.1.2.
[CE4-bgp] address-family ipv4 unicast
[CE4-bgp-ipv4] peer 202.1.1.2 enable
# Redistribute the direct route connected to the host on CE 4 into EBGP.
[CE4-bgp-ipv4] import-route direct
[CE4-bgp-ipv4] quit
[CE4-bgp] quit
After the configuration is completed, execute the display bgp peer ipv4 vpn-instance command to verify that the BGP peer relationships have been established between PEs and CEs and are in Established state.
Use PE 1 and CE 1 as an example:
[PE1] display bgp peer ipv4 vpn-instance customerA
 BGP local router ID: 1.1.1.9
 Local AS number: 100
 Total number of peers: 1                  Peers in established state: 1
  100.1.1.1             65410        4        4    0       2 13:35:25 Established
Establishing an MP-IBGP peer relationship between PEs
# On PE 1, specify PE 2 as the BGP peer, and specify loopback 0 as the source interface for TCP connections to the peer.
[PE1] bgp 100
[PE1-bgp] peer 3.3.3.9 as-number 100
[PE1-bgp] peer 3.3.3.9 connect-interface loopback 0
# Enter  BGP VPNv4 address family view, and specify PE 2 as the peer.
[PE1-bgp] address-family vpnv4
[PE1-bgp-vpnv4] peer 3.3.3.9 enable
[PE1-bgp-vpnv4] quit
[PE1-bgp] quit
# On PE 2, specify PE 1 as the BGP peer, and specify Loopback 0 as the source interface for TCP connections to the peer.
[PE2] bgp 100
[PE2-bgp] peer 1.1.1.9 as-number 100
[PE2-bgp] peer 1.1.1.9 connect-interface loopback 0
# Enter BGP VPNv4 address family view, and specify PE 1 as the peer.
[PE2-bgp] address-family vpnv4
[PE2-bgp-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-vpnv4] quit
[PE2-bgp] quit
After the configuration is completed, execute the display bgp peer vpnv4 command to verify that the BGP peer relationships have been established between PEs and are in Established state.
[PE1] display bgp peer vpnv4
  3.3.3.9                100        8        8    0       0 00:00:08 Established
# Execute the display ip routing-table vpn-instance command on a PE to view the route destined to the peer CE.
Use VPN instance customerA on PE 1 as an example:
[PE1] display ip routing-table vpn-instance customerA
Destinations : 13        Routes : 13
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
100.1.1.0/24        Direct 0    0            100.1.1.2       GE0/0/1
100.1.1.0/32        Direct 0    0            100.1.1.2       GE0/0/1
100.1.1.2/32        Direct 0    0            127.0.0.1       InLoop0
100.1.1.255/32      Direct 0    0            100.1.1.2       GE0/0/1
101.1.1.0/24        BGP    255  0            3.3.3.9         GE0/0/2
127.0.0.1/32        Direct 0    0            127.0.0.1       InLoop0
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
CEs in the same VPN can ping each other. CEs in different VPNs cannot ping each other.
For example, CE 1 can ping CE 3 (101.1.1.2), but it cannot ping CE 4 (202.1.1.1).
Configuration files
·     PE 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
 ip address 1.1.1.9 255.255.255.255
interface GigabitEthernet0/0/1
 port link-mode route
 ip address 100.1.1.2 255.255.255.0
interface GigabitEthernet0/0/2
 mpls enable
 mpls ldp enable
interface GigabitEthernet0/0/3
 ip address 200.1.1.2 255.255.255.0
bgp 100
 peer 3.3.3.9 connect-interface LoopBack0
  peer 3.3.3.9 enable
   import-route direct
   import-route direct
·     P:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
 ip address 2.2.2.9 255.255.255.255
 ip address 10.1.4.1 255.255.255.0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
·     PE 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
 ip address 3.3.3.9 255.255.255.255
 ip address 10.1.4.2 255.255.255.0
 mpls enable
 mpls ldp enable
 ip address 101.1.1.1 255.255.255.0
 ip address 202.1.1.2 255.255.255.0
bgp 100
 peer 1.1.1.9 connect-interface LoopBack0
  peer 1.1.1.9 enable
   import-route direct
   import-route direct
·     CE 1:
 ip address 100.1.1.1 255.255.255.0
bgp 65410
  import-route direct
·     CE 2:
 ip address 200.1.1.1 255.255.255.0
bgp 65410
  import-route direct
·     CE 3:
 ip address 101.1.1.2 255.255.255.0
bgp 65430
  import-route direct
·     CE 4:
 ip address 202.1.1.1 255.255.255.0
bgp 65430
  import-route direct
Related documentation
·     MPLS Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides (V9)
·     MPLS Command Reference in H3C MSR1000[2600][3600] Routers Command References (V9)
·     Layer 3—IP Routing Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides (V9)
·     Layer 3—IP Routing Command Reference in H3C MSR1000[2600][3600] Routers Command References (V9)
