H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
10-EAA Monitor Policy Configuration Examples
10-EAA Monitor Policy Configuration Examples 329.26 KB
H3C Routers
Introduction· 1
Prerequisites· 1
Example: Configuring an EAA monitor policy to suppress route flapping· 1
Network configuration· 1
Analysis· 1
Software version used· 1
Restrictions and guidelines· 2
Procedure· 2
Configure Router A· 2
Configure Router B· 2
Verifying the configuration· 4
Configuration files· 5
Example: Configuring an EAA monitor policy for automatic configuration rollback  1
Analysis· 1
Restrictions and guidelines· 1
Procedure· 2
Verifying the configuration· 3
Configuration files· 4
Example: Configuring an EAA monitor policy to monitor and maintain the device running status automatically· 1
Procedure· 1
Verifying the configuration· 2
Example: Configuring an EAA monitor policy for automatic bandwidth assurance for video conferencing· 1
Procedure· 2
Configuration files· 3
Example: Configuring an EAA monitor policy to enable primary/backup link switchover based on the link quality· 1
Analysis· 1
Procedure· 2
Configure Router B· 5
Configure Router C· 6
Verifying the configuration· 6
Configuration files· 9
Example: Configuring a TCL monitoring policy· 1
Software versions used· 1
Procedure· 1
Editing the TCL script 1
Configuring the device· 1
Exmaple: Configuring a CLI-defined monitor policy· 1
Procedure· 1
Related documentation· 1
Introduction
The following information provides examples for configuring EAA monitor policies for network monitoring.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
The following information is provided based on the assumption that you have basic knowledge of EAA monitor policies.
As shown in Figure 1, Router A and Router B run BGP. To prevent network route flapping when BGP peers comes up and goes down repeatedly, configure an EAA monitor policy on Router B to meet the following requirements:
·     Disable the BGP peer relationship automatically when the BGP peer comes up and goes down three times in 10 minutes.
·     Enable BGP peer relationship every 60 minutes.
Figure 1 Network diagram
Analysis
·     For Router A and Router B to automatically disable the BGP peer relations when the BGP peer comes up and goes down consecutively, configure an EAA monitoring policy for them.
·     To enable BGP peer relations between Router A and Router B every 60 minutes, configure a schedule task for them.
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 router.
·     You can configure only one event and runtime for an EAA monitor policy.  If you execute the event or running-time command multiple times, the most recent configuration that has been committed takes effect.
·     If two actions have the same ID, the most recent configured action that has been committed takes effect.
·     After configuring an event, action, user role, and runtime for a CLI-defined monitor policy, you must execute the commit command to commit configuration for the configuration to take effect.
Configure Router A
1.     Assign IP addresses to interfaces.
# Assign an IP address to GigabitEthernet 0/0/1.
[RouterA] interface gigabitethernet 0/0/1
[RouterA-GigabitEthernet0/0/1] ip address 2.1.1.1 255.255.255.0
[RouterA-GigabitEthernet0/0/1] quit
2.     Configure BGP routing.
# Create BGP instance 1 and enter its view. Set the Router ID for BGP to 2.1.1.1. Create BGP peer 2.1.1.2 and set its AS number to 1.
[RouterA] bgp 1
[RouterA-bgp] router-id 2.1.1.1
[RouterA-bgp] peer 2.1.1.2 as-number 1
# Create the BGP IPv4 unicast address family and enter its view. Enable BGP to redistribute direct routes.
[RouterA-bgp] address-family ipv4 unicast
[RouterA-bgp-ipv4] import-route direct
# Enable BGP to exchange IPv4 unicast routing information with peer 2.1.1.2.
[RouterA-bgp-ipv4] peer 2.1.1.2 enable
[RouterA-bgp-ipv4] quit
Configure Router B
<RouterB> system-view
[RouterB] interface gigabitethernet 0/0/1
[RouterB-GigabitEthernet0/0/1] ip address 2.1.1.2 255.255.255.0
[RouterB-GigabitEthernet0/0/1] quit
# Create BGP instance 1 and enter its view. Set the Router ID for BGP to 2.1.1.1. Create BGP peer 2.1.1.1 and set its AS number to 1.
[RouterB] bgp 1
[RouterB-bgp] router-id 2.1.1.2
[RouterB-bgp] peer 2.1.1.1 as-number 1
[RouterB-bgp] address-family ipv4 unicast
[RouterB-bgp-ipv4] import-route direct
# Enable BGP to exchange IPv4 unicast routing information with peer 2.1.1.1.
[RouterB-bgp-ipv4] peer 2.1.1.1 enable
[RouterB-bgp-ipv4] quit
3.     Configure a CLI monitor policy.
# Create CLI monitor policy 1.
[RouterB] rtm cli-policy 1
# Add a CLI event that occurs when a log message that contains "2.1.1.1 state has changed from ESTABLISHED to IDLE" is displayed 3 times within 10 minutes (600 seconds) and the log priority is higher or equal to 5.
[RouterB-rtm-1] event syslog priority 5 msg "2.1.1.1 state has changed from ESTABLISHED to IDLE" occurs 3 period 600
# Add an action that enters system view when the event occurs.
[RouterB-rtm-1] action 0 cli system-view
# Add an action that enters BGP view when the event occurs.
[RouterB-rtm-1] action 1 cli bgp 1
# Add an action that enters BGP IPv4 unicast address family view when the event occurs.
[RouterB-rtm-1] action 2 cli address-family ipv4 unicast
# Add an action that disables BGP from exchanging IPv4 unicast routing information with peer 2.1.1.1 in the IPv4 unicast address family view when the event occurs.
[RouterB-rtm-1] action 3 cli undo peer 2.1.1.1 enable
# Specify the network-admin user role for executing the policy.
[RouterB-rtm-1] user-role network-admin
# Enable CLI monitor policy 1.
[RouterB-rtm-1] commit
[RouterB-rtm-1] quit
4.     Configure a scheduled task.
# Create a job named 1 and enter its view.
[RouterB] scheduler job 1
# Assign a command to the job to enter system view.
[RouterB-job-1] command 0 system-view
# Assign a command to the job to enter BGP view.
[RouterB-job-1] command 1 bgp 1
# Assign a command to the job to enter BGP IPv4 unicast address family view.
[RouterB-job-1] command 2 address-family ipv4 unicast
# Assign a command to the job to enable BGP to exchange IPv4 unicast routing information with peer 2.1.1.1 in the IPv4 unicast address family view.
[RouterB-job-1] command 3 peer 2.1.1.1 enable
[RouterB-job-1] quit
5.     Configure a schedule.
# Create a schedule named 1 and enter its view.
[RouterB] scheduler schedule 1
# Allocate the job named 1 to the schedule.
[RouterB-schedule-1] job 1
# Configure the device to execute the schedule every 60 minutes.
[RouterB-schedule-1] time repeating interval 60
[RouterB-schedule-1] quit
# Execute the display rtm policy registered command to verify that a CLI-defined monitor policy named 1 has been created.
<RouterB> display rtm policy registered
Total number: 1
Type  Event      TimeRegistered       PolicyName
CLI   SYSLOG     Jun 18 09:41:06 2014 1
# If the following log is generated on Router B when the BGP peer of Router A and Router B comes up and goes down three times within 10 minutes, the policy is running successfully.
%Jun 18 14:19:26:246 2014 Router RTM/6/RTM_POLICY: CLI policy 1 is running successfully.
# Enter BGP view on Router B and verify that BGP is disabled from exchanging IPv4 unicast routing information with peer 2.1.1.1 in the BGP IPv4 unicast address family view.
[RouterB-bgp] display this
bgp 1
 router-id 2.1.1.2
  import-route direct
Return
# Enter BGP view on Router B 60 minutes later. Verify that BGP is enabled to exchange IPv4 unicast routing information with peer 2.1.1.1 in the BGP IPv4 unicast address family view.
bgp 1
 router-id 2.1.1.2
  import-route direct
  peer 2.1.1.1 enable
Return
[RouterB-bgp] quit
# Execute the display bgp peer ipv4 command to verify that Router A and Router B  has established a BGP peer relationship.
[RouterB] display bgp peer ipv4
 BGP local router ID: 2.1.1.2
 Local AS number: 1
 Total number of peers: 1                  Peers in established state: 1
  2.1.1.1                  1       23       23    0       1 00:16:04 Established
Configuration files
·     Router A:
interface GigabitEthernet0/0/1
bgp 1
 router-id 2.1.1.1
  import-route direct
  peer 2.1.1.2 enable
·     Router B:
bgp 1
 router-id 2.1.1.2
  import-route direct
  peer 2.1.1.1 enable
rtm cli-policy 1
 action 1 cli bgp 1
scheduler job 1
 command 1 bgp 1
 job 1
As shown in Figure 2, the administrator remotely configures the router. To avoid network disconnectivity caused by certain configurations, back up the configuration file in advance. Use NQA to monitor network connectivity. Configure EAA monitor policy to automatically restore the available backup configuration and restart the device when the network is disconnected.
Figure 2 Network diagram
Analysis
Use an EAA monitor policy to monitor the state of the NQA reaction entry. When the monitored object exceeds the threshold of the specified type, the EAA monitor policy is automatically triggered. The NQA reaction entry state (MIB value) is as follows:
·     When the state is invalid (MIB value is 1), the NQA operation is not started.
·     When the state is overThreshold (MIB value is 2), the monitored object exceeds the threshold of the specified type.
·     When the state is belowThreshold (MIB value is 3), the monitored object does not exceed the threshold of the specified type.
1.     Configure interface addresses and save the configuration file.
<Router> system-view
[Router] interface gigabitethernet 0/0/1
[Router-GigabitEthernet0/0/1] port link-mode route
[Router-GigabitEthernet0/0/1] ip address 192.168.1.2 255.255.255.0
[Router-GigabitEthernet0/0/1] quit
# Configure a static route to the host.
[Router] ip route 192.168.100.0 255.255.255.0 192.168.1.1
# Save the running configuration to a configuration file named eaa_test_backup.cfg.
[Router] save eaa_test_backup.cfg
The current configuration will be saved to cfa0:/eaa_test_backup.cfg. Continue? [Y/N] :y
Now saving current configuration to the device.
Saving configuration cfa0:/eaa_test_backup.cfg.Please wait...
Configuration is saved to device successfully.
2.     Configure an NQA operation.
# Create an ICMP echo-type NQA operation with administrator name admin and operation tag test. Specify 192.168.100.1 as the destination IP address.
[Router] nqa entry admin test
[Router-nqa-admin-test] type icmp-echo
[Router-nqa-admin-test-icmp-echo] data-size 20
[Router-nqa-admin-test-icmp-echo] destination ip 192.168.100.1
# Configure the operation to repeat every 1000 milliseconds and set the probe timeout time to 500 milliseconds.
[Router-nqa-admin-test-icmp-echo] frequency 1000
[Router-nqa-admin-test-icmp-echo] probe timeout 500
# Set the maximum number of history records that can be saved to 10.
[Router-nqa-admin-test-icmp-echo] history-record enable
[Router-nqa-admin-test-icmp-echo] history-record number 10
# Create reaction entry 1 for monitoring the probe failures in ICMP echo operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the total number of probe failures reaches or exceeds 5, the state of the entry is set to over-threshold. If it is below the threshold, the state of the entry is set to below-threshold.
[Router-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type none
[Router-nqa-admin-test-icmp-echo] quit
# Schedule the operation with administrator name test and operation tag test to start immediately and last forever.
[Router] nqa schedule admin test start-time now lifetime forever
# Enable SNMP.
[Router] snmp-agent
3.     Configure a CLI-defined EAA monitor policy.
# Create CLI monitoring policy 1.
[Router] rtm cli-policy 1
# Add a CLI event: Configure the system to check the value of MIB object 1.3.6.1.4.1.25506.8.3.1.13.1.11.1.49.1.49.1 every 5 seconds. Trigger and execute the monitor policy and disable monitoring when the value is 2. Restart monitoring when the value is 3.
[Router-rtm-1] event snmp oid 1.3.6.1.4.1.25506.8.3.1.13.1.11.1.49.1.49.1 monitor-obj get start-op eq start-val 2 restart-op eq restart-val 3 interval 5
# Add an action that specifies eaa_test_backup.cfg as the next-startup configuration file when the event occurs.
[Router-rtm-1] action 0 cli startup saved-configuration eaa_test_backup.cfg
# Add an action that reboots the device when the event occurs.
[Router-rtm-1] action 1 reboot
# Enable CLI-defined monitor policy 1.
[Router-rtm-1] commit
[Router-rtm-1] quit
[Router] display rtm policy registered
Total number: 1
CLI   SNMP       Jul 10 15:31:37 2014 1
# Change the IP address of GigabitEthernet 0/0/1 on the router, making the router disconnected from the host.
[Router-GigabitEthernet0/0/1] ip address 10.1.1.1 24
# Verify that the device reboots.
%Jul 10 15:33:40:112 2024 Router DEV/5/SYSTEM_REBOOT: System is rebooting now.
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing....Done.
*                  BootWare, Version 9.1.063                               *
Copyright (c) 2004-2024 New H3C Technologies Co., Ltd.
Compiled Date       : Apr  1 2024
CPU ID              : 0x3
Memory Type         : DDR3 SDRAM
Memory Size         : 2048MB
BootWare Size       : 1024KB
Flash Size          : 8MB
cfa0 Size           : 497MB
CPLD Version        : 2.0
PCB Version         : 2.0
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Loading the main image files...
System image is starting...
Line con1 is available.
Press ENTER to get started.
<Router>%Jul 10 16:15:08:059 2024 Router SHELL/5/SHELL_LOGIN: Console logged in from con1.
<Router>
Configuration files
 type icmp-echo
  data-size 20
  frequency 1000
  probe timeout 500
 snmp-agent
 snmp-agent local-engineid 800063A280000605B36B9E00000001
 snmp-agent sys-info version v3
rtm cli-policy 1
 action 1 reboot
As shown in Figure 3, the router has network connectivity to the TFTP server. To prevent high CPU usage on the router, configure an EAA monitor policy to monitor the CPU usage of the router automatically and perform the following actions when the CPU usage exceeds 80%:
·     Display the memory information, interface statistics, and routing table information at the time when the CPU usage exceeds 80%, and save them to a specified file.
·     Upload the file to the TFTP server.
·     After uploading the file to the TFTP server, delete the local file.
Figure 3 Network diagram
[Router-GigabitEthernet0/0/1] ip address 192.168.1.1 255.255.255.0
# Enable SNMP.
[Router] snmp-agent
# Add a CLI event: Configure the system to check the CPU usage (MIB object 1.3.6.1.4.1.25506.2.6.1.1.1.1.6.16) every 5 seconds. Trigger and execute the monitor policy and disable monitoring when the CPU usage exceeds 80% and restart monitoring when the CPU usage falls below 40%.
[Router-rtm-1] event snmp oid 1.3.6.1.4.1.25506.2.6.1.1.1.1.6.16 monitor-obj get start-op gt start-val 80 restart-op lt restart-val 40 interval 5
# Add an action that displays the device's current date and time and saves the displayed information to the file named test1.txt when the event occurs.
[Router-rtm-1] action 0 cli display clock >> test1.txt
# Add an action that displays memory usage and appends the displayed information to the file named test1.txt when the event occurs.
[Router-rtm-1] action 1 cli display memory >> test1.txt
# Add an action that displays running status of interfaces and appends the displayed information to the file named test1.txt when the event occurs.
[Router-rtm-1] action 2 cli display interface >> test1.txt
# Add an action that displays routing table information and appends the displayed information to the file named test1.txt when the event occurs.
[Router-rtm-1] action 3 cli display ip routing-table >> test1.txt
# Add an action that uploads file test1.txt to TFTP server 192.168.100.14 when the event occurs.
[Router-rtm-1] action 4 cli tftp 192.168.100.14 put test1.txt
# Add an action that deletes file test1.txt when the event occurs
[Router-rtm-1] action 5 cli delete /unreserved test1.txt
[Router-rtm-1] action 6 cli y
[Router-rtm-1] user-role network-admin
[Router-rtm-1] quit
Total number: 1
# Verify that the CLI-defined monitor policy is running successfully when the CPU usage exceeds 80%.
%Jul 14 10:57:22:127 2014 Router RTM/6/RTM_POLICY: CLI policy 1 is running successfully.
# Verity that a file named test1.txt has been generated on the log server. Open the file and verify that  the file contains the current time, date, local time zone configuration, memory usage, memory running status, interface running status, and routing table information.
11:14:55 UTC Mon 07/14/2014
The statistics about memory is measured in KB:
Slot 0:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       2028984    540492   1488492         0       564    156532       73.4%
-/+ Buffers/Cache:    383396   1645588
Swap:           0         0         0
Slot 1:
Mem:       2028984    468996   1559988         0       312    126668       76.9%
-/+ Buffers/Cache:    342016   1686968
Swap:           0         0         0
Slot 2:
Mem:       4081140   1162996   2918144         0         0     42416       71.5%
-/+ Buffers/Cache:   1120580   2960560
Swap:           0         0         0
Aux0/0/1
Description: Aux0/0/1 Interface
Bandwidth: 9kbps
Internet protocol processing: disabled
Physical layer: asynchronous, Baudrate: 9600 bps
Phy-mru: 1700
Destinations : 16   Routes : 16
10.1.1.0/24        Direct  0   0           10.1.1.1        GE0/0/2
10.1.1.0/32        Direct  0   0           10.1.1.1        GE0/0/2
10.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.255/32      Direct  0   0           10.1.1.1        GE0/0/2
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
127.0.0.1/32       Direct  0   0           127.0.0.1       InLoop0
192.168.100.0/24   Direct  0   0           192.168.100.68  GE0/0/1
192.168.100.0/32   Direct  0   0           192.168.100.68  GE0/0/1
192.168.100.68/32  Direct  0   0           127.0.0.1       InLoop0
192.168.100.255/32 Direct  0   0           192.168.100.68  GE0/0/1
224.0.0.0/4        Direct  0   0           0.0.0.0         NULL0
224.0.0.0/24       Direct  0   0           0.0.0.0         NULL0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
Configuration files
 snmp-agent
rtm cli-policy 1
 action 6 cli y
As shown in Figure 4, a host and a VoIP video system access the Internet through the router. When a video conference is held, it requires a significant amount of bandwidth, and it is necessary to limit the Internet traffic of the host. Configure an EAA monitor policy on the router to meet the following requirements:
·     When the video traffic is greater than or equal to 100000 packets per second, disallow host packets to pass and allow only video package to pass.
·     When the video traffic is less than 100000 packets per second, allow both video and host packets to pass.
Figure 4 Network diagram
# Assign an IP address to GigabitEthernet 0/0/2.
[Router] interface gigabitethernet 0/0/2
[Router-GigabitEthernet0/0/2] ip address 10.1.1.1 255.255.255.0
[Router-GigabitEthernet0/0/2] quit
2.     Configuring an ACL policy
# Configure ACL 3001 to permit packets only from source address 10.1.1.2.
[Router] acl number 3001
[Router-acl-adv-3001] rule 0 permit ip source 10.1.1.2 0
[Router-acl-adv-3001] quit
# Create ACL 3002 to deny packets from source address 10.1.1.2 and permit other packets.
[Router] acl number 3002
[Router-acl-adv-3002] rule 0 deny ip source 10.1.1.2 0
[Router-acl-adv-3002] rule 5 permit ip
[Router-acl-adv-3002] quit
# Apply ACL 3001 on the inbound traffic direction on GigabitEthernet 0/0/2 to filter packets.
[Router-GigabitEthernet0/0/2] qos car inbound acl 3001 cir 1000
3.     Enable SNMP and configure an environment variable.
# Enable SNMP agent.
[Router] snmp-agent
# Create an environment variable video and set its value to 0.
[Router] rtm environment video 0
4.     Configure CLI monitor policy 1
# Add a CLI event: Configure the system to check the number of packets (MIB object 1.3.6.1.4.1.25506.2.8.2.2.3.1.31.1.3001.0) every 10 seconds. Trigger and execute the policy when the value is greater than or equal to 0.
[Router-rtm-1] event snmp oid 1.3.6.1.4.1.25506.2.8.2.2.3.1.31.1.3001.0 monitor-obj get start-op ge start-val 0 restart-op ge restart-val 0 interval 10
# Add an action that clears ACL 3001 statistics when the event occurs.
[Router-rtm-1] action 0 cli reset acl counter 3001
# Add an action that enters Tcl configuration view from user view when the event occurs.
[Router-rtm-1] action 1 cli tclsh
# Add an action that enters system view from user view when the event occurs.
[Router-rtm-1] action 2 cli system-view
# Add an action that checks the number of received messages from the video device when the event occurs. If the number reaches 100000, permit only video traffic from 10.1.1.2 on GigabitEthernet 0/0/2 and limit the committed information rate of other traffic to 1024 kbps.
[Router-rtm-1] action 3 cli if { $_oid_value >= 100000 && $video == 0 } { rtm environment video 1; interface gigabitethernet 0/0/2; qos car inbound acl 3002 cir 1024}
# Add an action that checks the number of received messages from the video device when the event occurs. If the number is less than 100000, permit not only video traffic but also other traffic on GigabitEthernet 0/0/2.
[Router-rtm-1] action 4 cli if { $_oid_value < 100000 && $video == 1 } { rtm environment video 0; interface gigabitethernet 0/0/2; undo qos car inbound acl 3002}
[Router-rtm-1] quit
Total number: 1
CLI   SNMP       Jul 11 16:07:51 2014 1
# When the video traffic on GigabitEthernet 0/0/2 reaches or exceeds 100000 packets per second, a log is displayed that EAA monitor policy 1 has been executed successfully.
%Jul 11 16:13:46:552 2014 Router RTM/6/RTM_POLICY: CLI policy 1 is running successfully.
Configuration files
acl number 3001
acl number 3002
 rule 5 permit ip
interface GigabitEthernet0/0/2
snmp-agent
rtm cli-policy 1
 action 1 cli tclsh
 action 3 cli if { $_oid_value >= 100000 && $video == 0 } { rtm environment video 1; interface GigabitEthernet0/0/2; qos car inbound acl 3002 cir 1024}
 action 4 cli if { $_oid_value < 100000 && $video == 1 } { rtm environment video 0; interface GigabitEthernet0/0/2; undo qos car inbound acl 3002}
 commit
As shown in Figure 5, Router A and Router B are reachable to each other. Typically, the direct link between Router A and Router B acts as the primary link, and the link through Router C acts as the backup link. Configure an EAA monitor policy on Router A to meet the following requirements:
·     When the primary link has a packet loss rate exceeding 20% or a delay greater than 200 ms, switch over the traffic to the backup link.
·     When the primary link does not have packet loss and has a latency less than 100 ms, switch back the traffic to the primary link.
Figure 5 Network diagram
Analysis
Configure Router A
[RouterA-GigabitEthernet0/0/1] port link-mode route
[RouterA-GigabitEthernet0/0/1] ip address 12.1.1.1 255.255.255.0
[RouterA] interface gigabitethernet 0/0/2
[RouterA-GigabitEthernet0/0/2] port link-mode route
[RouterA-GigabitEthernet0/0/2] ip address 11.1.1.2 255.255.255.0
[RouterA-GigabitEthernet0/0/2] quit
# Create an ICMP echo-type NQA operation with administrator name 1 and operation tag 1. Specify 12.1.1.2 as the destination IP address.
[RouterA] nqa entry 1 1
[RouterA-nqa-1-1] type icmp-echo
[RouterA-nqa-1-1-icmp-echo] destination ip 12.1.1.2
# Configure the operation to repeat every 15000 milliseconds and set the probe timeout time to 800 milliseconds. Configure the ICMP echo operation to perform 15 probes.
[RouterA-nqa-1-1-icmp-echo] frequency 15000
[RouterA-nqa-1-1-icmp-echo] probe timeout 800
[RouterA-nqa-1-1-icmp-echo] probe count 15
# Create reaction entry 1 for monitoring the ICMP-echo probe duration, and set the upper limit to 200 milliseconds and lower limit to 0 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average probe duration is checked. If it exceeds the upper limit, the state is set to over-threshold. If it is below the lower limit, the state of the reaction entry is set to below-threshold.
[RouterA-nqa-1-1-icmp-echo] reaction 1 checked-element probe-duration threshold-type average threshold-value 200 0 action-type none
# Create reaction entry 2 for monitoring the number of ICMP-echo probe failures. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the total number of probe failures reaches or exceeds 3, the state of the entry is set to over-threshold. If it is below the threshold, the state of the entry is set to below-threshold.
[RouterA-nqa-1-1-icmp-echo] reaction 2 checked-element probe-fail threshold-type accumulate 3 action-type none
# Create reaction entry 3 for monitoring the ICMP-echo probe duration, and set the upper limit to 100 milliseconds and lower limit to 0 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average probe duration is checked. If it reaches the upper limit, the state is set to over-threshold. If it is below the lower limit, the state of the reaction entry is set to below-threshold.
[RouterA-nqa-1-1-icmp-echo] reaction 3 checked-element probe-duration threshold-type average threshold-value 100 0 action-type none
# # Create reaction entry 4 for monitoring the probe failures in ICMP echo operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the total number of probe failures reaches or exceeds 1, the state of the entry is set to over-threshold. If it is below the threshold, the state of the entry is set to below-threshold.
[RouterA-nqa-1-1-icmp-echo] reaction 4 checked-element probe-fail threshold-type accumulate 1 action-type none
[RouterA-nqa-1-1-icmp-echo] quit
# Enable the NQA client.
[RouterA] nqa agent enable
# Schedule the operation with administrator name 1 and operation tag 1 to start immediately and last forever.
[RouterA] nqa schedule 1 1 start-time now lifetime forever
[RouterA] snmp-agent
3.     Configure environment variables for the monitor policy.
# Create environment variable delay for the monitor policy and set its value to 0.
[RouterA] rtm environment delay 0
# Create environment variable loss for the monitor policy and set its value to 0.
[RouterA] rtm environment loss 0
# Create environment variable backup for the monitor policy and set its value to 0.
[RouterA] rtm environment backup 0
4.     Configure CLI-defined monitor policy 1.
# Create CLI-defined monitor policy 1.
[RouterA] rtm cli-policy 1
# Configure the system to check the value of MIB object 1.3.6.1.4.1.25506.8.3.1.13.1.11.1.49.1.49.1 every 10 seconds. Trigger and execute the monitor policy and disable monitoring when the value of the MIB object is 2 and restart monitoring is when the value is 3.
[RouterA-rtm-1] event snmp oid 1.3.6.1.4.1.25506.8.3.1.13.1.11.1.49.1.49.1 monitor-obj get start-op eq start-val 2 restart-op eq restart-val 3 interval 10
[RouterA-rtm-1] action 0 cli tclsh
[RouterA-rtm-1] action 1 cli system-view
# Add an action that changes the value of environment variable delay from 0 to 1.
[RouterA-rtm-1] action 2 cli if { $delay==0 } { rtm environment delay 1 }
# Add an action that changes the value of environment variable backup from 0 to 1, and configures a static route destined to 100.1.1.0/24 with next hop 11.1.1.1 and priority 10.
[RouterA-rtm-1] action 3 cli if { $backup==0 } { rtm environment backup 1; ip route-static 100.1.1.0 24 11.1.1.1 preference 10 }
[RouterA-rtm-1] commit
[RouterA-rtm-1] quit
5.     Configure CLI monitor policy 2.
# Create CLI monitor policy 2
[RouterA] rtm cli-policy 2
# Add a CLI event: Configure the system to check the value of MIB object 1.3.6.1.4.1.25506.8.3.1.13.1.11.1.49.1.49.2 every 10 seconds. Trigger and execute the monitor policy and disable monitoring when the value of the MIB object is 2 and restart monitoring is when the value is 3.
[RouterA-rtm-2] event snmp oid 1.3.6.1.4.1.25506.8.3.1.13.1.11.1.49.1.49.2 monitor-obj get start-op eq start-val 2 restart-op eq restart-val 3 interval 10
[RouterA-rtm-2] action 0 cli tclsh
[RouterA-rtm-2] action 1 cli system-view
# Add an action that changes the value of environment variable loss from 0 to 1 when the event occurs.
[RouterA-rtm-2] action 2 cli if { $loss==0 } { rtm environment loss 1 }
# Add an action that changes the value of environment variable backup from 0 to 1, and configures a static route destined to 100.1.1.0/24 with next hop 11.1.1.1 and priority 10 when the event occurs.
[RouterA-rtm-2] action 3 cli if { $backup==0 } { rtm environment backup 1; ip route-static 100.1.1.0 24 11.1.1.1 preference 10 }
# Enable CLI monitoring policy 2.
[RouterA-rtm-2] user-role network-admin
[RouterA-rtm-2] commit
6.     Configure CLI monitoring policy 3
# Create CLI monitoring policy 3.
[RouterA] rtm cli-policy 3
# Add a CLI event: Configure the system to check the value of MIB object 1.3.6.1.4.1.25506.8.3.1.13.1.11.1.49.1.49.3 every 10 seconds. Trigger and execute the monitor policy and disable monitoring when the value of the MIB object is 2 and restart monitoring is when the value is 3.
[RouterA-rtm-3] event snmp oid 1.3.6.1.4.1.25506.8.3.1.13.1.11.1.49.1.49.3 monitor-obj get start-op eq start-val 3 restart-op eq restart-val 2 interval 10
[RouterA-rtm-3] action 0 cli tclsh
[RouterA-rtm-3] action 1 cli system-view
# Add an action that changes the value of environment variable delay from 0 to 1 when the event occurs.
[RouterA-rtm-3] action 2 cli if { $delay==1 } { rtm environment delay 0 }
# Add an action that waits for 5000 milliseconds after the event occurs.
[RouterA-rtm-3] action 3 cli after 5000
# Add an action that changes the value of environment variables backup and loss to 0, and delete the static route destined to 100.1.1.0/24 with next hop 11.1.1.1 and priority 10.
[RouterA-rtm-3] action 4 cli if { $backup==1 && $loss==0 } { undo ip route-static 100.1.1.0 24 11.1.1.1 preference 10; rtm environment backup 0 }
# Enable CLI monitor policy 3.
[RouterA-rtm-3] user-role network-admin
[RouterA-rtm-3] commit
7.     Configure CLI monitor policy 4.
# Create CLI monitor policy 4.
[RouterA] rtm cli-policy 4
# Add a CLI event: Configure the system to check the value of MIB object 1.3.6.1.4.1.25506.8.3.1.13.1.11.1.49.1.49.4 every 10 seconds. Trigger and execute the monitor policy and disable monitoring when the value of the MIB object is 2 and restart monitoring is when the value is 3.
[RouterA-rtm-4] event snmp oid 1.3.6.1.4.1.25506.8.3.1.13.1.11.1.49.1.49.4 monitor-obj get start-op eq start-val 3 restart-op eq restart-val 2 interval 10
[RouterA-rtm-4] action 0 cli tclsh
[RouterA-rtm-4] action 1 cli system-view
# Add an action that changes the value of environment variable loss from 1 to 0 when the event occurs.
[RouterA-rtm-4] action 2 cli if { $loss==1 } { rtm environment loss 0 }
[RouterA-rtm-4] action 3 cli after 5000
# Add an action that keeps the value of environment variables backup and delay at 0, and configures a static route destined to 100.1.1.0/24 with next hop 11.1.1.1 and priority 10 when the event occurs.
[RouterA-rtm-4] action 4 cli if { $backup==1 && $delay==0 } { undo ip route-static 100.1.1.0 24 11.1.1.1 preference 10;  rtm environment backup 0 }
# Enable CLI monitor policy 4.
[RouterA-rtm-4] user-role network-admin
[RouterA-rtm-4] commit
[RouterA-rtm-4] quit
Configure Router B
1.     Assign IP addresses to interfaces:
[RouterB-GigabitEthernet0/0/1] port link-mode route
[RouterB-GigabitEthernet0/0/1] ip address 12.1.1.2 255.255.255.0
[RouterB] interface gigabitethernet 0/0/2
[RouterB-GigabitEthernet0/0/2] port link-mode route
[RouterB-GigabitEthernet0/0/2] ip address 100.1.1.2 255.255.255.0
[RouterB-GigabitEthernet0/0/2] quit
2.     Configure OSPF routing to enable network connectivity between Router C and Router B.
[RouterB] ospf 1
[RouterB-ospf-1] area 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
Configure Router C
<RouterC> system-view
[RouterC] interface gigabitethernet 0/0/1
[RouterC-GigabitEthernet0/0/1] port link-mode route
[RouterC-GigabitEthernet0/0/1] ip address 11.1.1.1 255.255.255.0
[RouterC-GigabitEthernet0/0/1] quit
[RouterC] interface gigabitethernet 0/0/2
[RouterC-GigabitEthernet0/0/2] port link-mode route
[RouterC-GigabitEthernet0/0/2] ip address 100.1.1.1 255.255.255.0
[RouterC-GigabitEthernet0/0/2] quit
2.     Configure OSPF routing to enable network connectivity between Router B and Router C.
[RouterC] ospf 1
[RouterC-ospf-1] area 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
# Display detailed information about all EAA monitor policies.
<RouterA> display rtm policy registered  verbose
  Total number: 4
   Policy Name: 1
   Policy Type: CLI
    Event Type: SNMP
TimeRegistered: Jul 14 15:04:24 2014
     User-role: network-admin
   Policy Name: 2
   Policy Type: CLI
    Event Type: SNMP
TimeRegistered: Jul 14 15:14:50 2014
   Policy Name: 3
   Policy Type: CLI
    Event Type: SNMP
TimeRegistered: Jul 14 15:17:32 2014
   Policy Name: 4
   Policy Type: CLI
    Event Type: SNMP
TimeRegistered: Jul 14 15:18:33 2014
1.     When the message delay from Router A to Router B is 300 milliseconds, exceeding the threshold of 200 milliseconds, observe the information displayed on Router A.
# The log information shows that EAA policy 1 has been successfully executed.
%Jul 14 14:50:16:677 2014 RouterA RTM/6/RTM_POLICY: CLI policy 1 is running successfully.
# Execute the display rtm environment command to display the user-defined EAA environment variables. Verify that the value of environment variable backup changes to 1, and the value of delay changes to 1.
[RouterA] display rtm environment
 Name                 Value
 backup               1
 delay                1
 loss                 0
# Execute the display this command to display the effective configuration in the current view. Verify that a static route to 100.1.1.0/24 exists and traffic from Router A to Router B have been switched over to the backup link.
[RouterA] display this
 sysname RouterA
 snmp-agent
Return
2.     When the packet loss rate from Router A to Router B is 25%, exceeding the threshold, observe the information displayed on Router A.
# The log information shows that EAA policy 2 has been executed successfully.
%Jul 14 15:15:23:802 2014 RouterA RTM/6/RTM_POLICY: CLI policy 2 is running successfully.
# Execute the display rtm environment command to display the user-defined EAA environment variables. Verify that the value of environment variable loss changes to 1.
 Name                 Value
 backup               1
 delay                1
 loss                 1
# Execute the display this command to display the effective configuration in the current view. Verify that the traffic from Router A still reach Router B over the backup link.
 sysname RouterA
 snmp-agent
Return
3.     When the message delay between Router A and Router B falls to the normal range, and the packet loss rate remains at 25%, observe the information displayed on Router A.
# The log information shows that EAA policy 3 has been successfully executed.
%Jul 14 15:19:13:771 2014 RouterA RTM/6/RTM_POLICY: CLI policy 3 is running successfully.
# Execute the display rtm environment command to display the user-defined EAA environment variables. Verify that the value of environment variable delay changes to 0.
 Name                 Value
 backup               1
 delay                0
 loss                 1
# Execute the display this to display the effective configuration in the current view. Verify that the traffic from Router A still reaches Router B via the backup link.
 sysname RouterA
 snmp-agent
Return
4.     When both the message delay and packet loss rate between Router A and Router B fall to the normal range, observe the information displayed on Router A.
# The log information shows that EAA policy 4 has been executed successfully.
%Jul 14 15:19:13:771 2014 RouterA RTM/6/RTM_POLICY: CLI policy 4 is running successfully.
# Execute the display rtm environment command to display the user-defined EAA environment variables. Verify that the values of environment variables backup, delay, and loss change to 0.
 Name                 Value
 backup               0
 delay                0
 loss                 0
 sysname RouterA
 snmp-agent
Return
Configuration files
·     Router A:
nqa entry 1 1
 type icmp-echo
  frequency 15000
  probe count 15
  probe timeout 800
 snmp-agent
rtm cli-policy 1
 action 0 cli tclsh
rtm cli-policy 2
 event snmp oid 1.3.6.1.4.1.25256.8.3.1.13.1.11.1.49.1.49.2 monitor-obj get start-op eq start-val 2 restart-op eq restart-val 3 interval 10
 action 0 cli tclsh
rtm cli-policy 3
 action 0 cli tclsh
rtm cli-policy 4
 action 0 cli tclsh
·     Router B:
ospf 1
 area 0.0.0.0
·     Router C:
ospf 1
 area 0.0.0.0
Configure a TCL monitoring policy for the device to execute the following actions when the incoming traffic on GigabitEthernet 0/0/1 reaches or exceeds 500 Mbps:
·     Generate logs for traffic that exceeds the range.
·     Display the current CPU state and save it to a file.
·     Display the state of GigabitEthernet 0/0/1 and save it to a file.
If the subsequent incoming traffic reaches or exceeds 200Mbps, monitoring will restart. When the incoming traffic on the interface is detected to exceed 500Mbps again, the aforementioned operations are executed again.
# Use Notepad to edit the test.tcl file as follows:
# Define the monitored event. Configure interface GigabitEthernet 0/0/1 to focus on inbound traffic. When the inbound traffic reaches or exceeds 500 Mbps, configure the device to execute the specified action. The condition to re-enable polling is when the interface traffic reaches or exceeds 200 Mbps.
::comware::rtm::event_register interface gigabitethernet 0/0/1 monitor-obj rcv-bps start-op ge start-val 500000000 restart-op ge restart-val 200000000 user-role network-admin
# Configure the action to take when the monitored event occurs: Send log message GE0/0/1 input rate exceeded 500000000bps with priority level 1 and device number local1.
::comware::rtm::action syslog priority 1 facility local1 msg "GE0/0/1 input rate exceeded 500000000bps"
# Configure the device to execute the display cpu-usage command to display CPU usage statistics and save the information in ge0_info.txt when the event occurs.
display cpu-usage >> ge0_info.txt
# Configure the device to execute the display interface gigabitethernet 0/0/1 command to display the current operating state and related information for GigabitEthernet 0/0/1 and save the information in ge0_info.txt when the event occurs.
display interface gigabitethernet 0/0/1 >> ge0_info.txt
[Device] interface gigabitethernet 0/0/1
[Device-GigabitEthernet0/0/1] ip address 192.168.100.66 255.255.255.0
[Device-GigabitEthernet0/0/1] quit
[Device] quit
# Download test.tcl to the device through TFTP.
<Device> tftp 192.168.100.14 get test.tcl
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   189  100   189    0     0   7900      0 --:--:-- --:--:-- --:--:-- 12600
# Create and enable a TCL monitoring policy, and bind the policy to TCL script test.tcl.
[Device] rtm tcl-policy test test.tcl
[Device] quit
# Use the display rtm policy registered command to view the policy named test with type Tcl.
<Device> display rtm policy registered
Total number: 1
TCL   INTERFACE         Oct 22 14:06:20 2017 test
# When the inbound traffic on interface GigabitEthernet 0/0/1 reaches or exceeds 500 Mbps, check all files and folder information in the device for the existence of ge0_info.txt.
<Device> dir
Directory of cfa0:
   0 -rw-        3227 Nov 19 2017 17:28:36   1.cfg
   1 -rw-        2296 Apr 26 2017 18:55:08   5660_data.ak
   2 -rw-        2304 Apr 26 2017 18:54:56   5660_security.ak
   3 -rw-        2298 Apr 26 2017 18:55:16   5660_voice.ak
   4 -rw-        3227 Nov 19 2017 17:15:19   STARTUP110.CFG
   5 drw-           - Mar 10 2017 04:10:10   diagfile
   6 -rw-         567 Jul 17 2017 14:25:00   dsakey
   7 -rw-         223 Jul 17 2017 14:25:00   ecdsakey
   8 -rw-         278 Jul 17 2017 14:25:00   ge0_info.txt
   9 -rw-         735 Jul 17 2017 14:25:00   hostkey
  10 -rw-         492 Nov 18 2017 16:40:50   ifindex.dat
  11 -rw-         276 Apr 23 2017 19:00:00   lauth.dat
  12 drw-           - Jul 17 2017 11:26:34   license
  13 drw-           - Apr 24 2017 12:39:38   logfile
507492 KB total (298412 KB free)
# Use TFTP to copy file ge0_info.txt to the TFTP server.
<Device> tftp 192.168.100.14 put ge0_info.txt
# View file ge0_info.txt to display the current state of the CPU and interface GigabitEthernet 0/0/1.
Slot 1 CPU 0 CPU usage:
       5% in last 5 seconds
       5% in last 1 minute
       6% in last 5 minutes
Slot 2 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
Current state: UP
Line protocol state: UP
Description: GigabitEthernet0/0/1 Interface
Bandwidth: 1000000kbps
Maximum Transmit Unit: 1500
Internet Address is 192.168.100.66/24 Primary
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 4431-9255-f3fc
IPv6 Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 4431-9255-f3fc
Media type is twisted pair
Port hardware type is 1000_BASE_T
Port priority: 0
1000Mbps-speed mode, full-duplex mode
Flow-control is not enabled
The Maximum Frame Length is 9216
 Peak value of input: 108106680 bytes/sec, at 2017-10-15 14:14:30
 Peak value of output: 20 bytes/sec, at 2017-10-15 13:24:25
 Last 300 seconds input:  1028465 packets/sec 65821768 bytes/sec 69%
 Last 300 seconds output:  0 packets/sec 9 bytes/sec 0%
 Input (total):  9585460958 packets, 759947089836 bytes
          9585460803 unicasts, 3 broadcasts, 9 multicasts, 0 pauses
 Input (normal):  9585460815 packets, - bytes
 Input:  1 input errors, 0 runts, 0 giants, 0 throttles
          1 CRC, 0 frame, - overruns, 0 aborts
          - ignored, - parity errors
 Output (total): 313 packets, 94288 bytes
          0 unicasts, 0 broadcasts, 313 multicasts, 0 pauses
 Output (normal): 313 packets, - bytes
          0 lost carrier, - no carrier
Configuration files
·     Script text for test.tcl:
::comware::rtm::event_register interface gigabitethernet1/0/1 monitor-obj rcv-bps start-op ge start-val 500000000 restart-op ge restart-val 200000000 user-role network-admin
·     Device:
Configure a CLI-defined monitor policy for the device to execute the following actions when the incoming traffic on GigabitEthernet 0/0/1 reaches or exceeds 500 Mbps:
·     For the same policy, you can configure only one trigger event and runtime. If you execute the event or running-time commands multiple times, the most recently configured and committed one takes effect.
·     If the number of a newly configured action is the same as the number of an existing action, the most recently configured one will take effect after you execute the commit command.
·     After configuring events, actions, user roles, and runtime for a CLI-defined monitor policy, you must execute the commit command for the policy and its configurations to be activated.
# Create a CLI-defined monitor policy numbered 1.
[Device] rtm cli-policy 1
# Configure a CLI-defined policy to monitor the receiving rate on GigabitEthernet 0/0/1. Set the start threshold to 500 Mbps and the restart threshold to 200 Mbps. Enable EAA to execute the policy when the rate reaches or exceeds 1000 for the first time. Enable EAA to re-execute the inspection if the rate reaches or exceeds 200 Mbps.
[Device-rtm-1] event interface gigabitethernet 0/0/1 monitor-obj rcv-bps start-op ge start-val 500000000 restart-op ge restart-val 200000000
# Configure an action for the CLI-defined policy to send log message "GE0/0/1 input rate exceeded 500000000bps" with a severity of 1 from the facility device local1.
[Device-rtm-1] action 1 syslog priority 1 facility local1 msg "GE0/0/1 input rate exceeded 500000000bps"
# Configure a CLI action for the CLI-defined policy to display CPU usage statistics and save the statistics in file ge0_info.txt.
[Device-rtm-1] action 2 cli display cpu-usage >> ge0_info.txt
# Configure a CLI action for the CLI-defined policy to display the running status and information about GigabitEthernet 0/0/1 and save the statistics in file ge0_info.txt.
[Device-rtm-1] action 3 cli display interface gigabitethernet 0/0/1 >> ge0_info.txt
# Set the action runtime to 30 seconds for the CLI-defined policy.
[Device-rtm-1] running-time 30
# Assign user role network-admin to the CLI-defined policy.
[Device-rtm-1] user-role network-admin
# Enable the CLI-defined policy.
[Device-rtm-1] commit
[Device-rtm-1] quit
# Verify that CLI-defined policy 1 exists.
Total number: 1
CLI   INTERFACE  May 04 00:12:40 2017  1
# Verify that file ge0_info.txt exists on the device when the inbound traffic on interface GigabitEthernet 0/0/1 reaches or exceeds 500 Mbps.
<Device> dir
Directory of cfa0:
# Verify that file ge0_info.txt contains the CPU usage and status of interface GigabitEthernet 0/0/1.
       5% in last 1 minute
       1% in last 1 minute
Current state: UP
Port priority: 0
Configuration files
rtm cli-policy 1
 event interface GigabitEthernet0/0/1 monitor-obj rcv-bps start-op ge start-val 500000000 restart-op ge restart-val 200000000
 running-time 30
·     Network Management and Monitoring Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Network Management and Monitoring Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
·     Layer 3—IP Routing Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Layer 3—IP Routing Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
