H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
02-RADIUS-Based 802.1X Authentication Configuration Examples
H3C Routers
Introduction
The following information provides an example for configuring RADIUS-based 802.1X authentication.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of AAA and 802.1X.
Example: Configuring RADIUS-based 802.1X authentication
As shown in Figure 1, the router works together with the RADIUS server to perform 802.1X authentication for users connected to GigabitEthernet 0/0/1. Configure the network to meet the following requirements:
·     Configure the router to exclude the domain names from the usernames sent to the RADIUS server.
·     Set the username to localuser.
·     Use the IMC server as the RADIUS server to perform authentication and accounting for users, and configure local authentication as the secondary authentication method when RADIUS authentication fails.
·     Implement port-based access and specify mandatory 802.1X authentication domain bbb on the port.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
When you configure RADIUS-based 802.1X authentication, follow these restrictions and guidelines:
·     This example can be implemented on only devices installed with Layer 2 switching cards and having fixed Layer 2 interfaces.
·     Make sure the parameters (such as shared keys, authentication ports, and accounting ports) configured on the router and the RADIUS server are the same.
Procedures
Configuring the RADIUS server
Add an access device
1.     Log in to IMC and click the User tab.
2.     From the navigation pane, select User Access Policy > Access Device Management > Access Device.
3.     Click Add.
4.     On the page that opens, configure the following parameters:
¡     Set the authentication port and accounting port to 1812 and 1813, respectively.
¡     Select H3C (General) from the Access Device Type list.
¡     Set the shared key to name for secure communication with the device and confirm the shared key.
¡     Select an access device from the device list or manually add an access device. In this example, the device IP address is 192.168.100.2.
¡     Use the default settings for other parameters, and then click OK.
Figure 2 Adding an access device
Adding an access service
1.     Click the User tab.
2.     From the navigation pane, select User Access Policy > Access Service.
3.     Click Add.
¡     Enter access service name dot1x auth.
Figure 3 Adding an access service
Adding an access user
2.     From the navigation pane, select Access User > All Access Users.
3.     Click Add.
The Add Access User page opens.
4.     In the Access Information area, click the Add User button for the User Name field.
5.     On the page that opens, configure the following parameters:
¡     Enter test in the User Name field.
¡     Enter account name localuser and set the password to localpass.
¡     Select dot1x auth in the Access Service area.
¡     Click OK.
Figure 4 Adding an access user
# Create VLAN-interface 1, and assign an IP address to it.
[Router] interface vlan-interface 1
[Router-Vlan-interface1] ip address 192.168.200.1 255.255.255.0
[Router-Vlan-interface1] quit
# Configure an IP address for GigabitEthernet 0/0/2.
[Router] interface gigabitethernet 0/0/2
[Router-GigabitEthernet0/0/2] ip address 192.168.100.2 255.255.255.0
[Router-GigabitEthernet0/0/2] quit
# Create a network access user named localuser and set the password to localpass in plaintext form.
[Router] local-user localuser class network
[Router-luser-network-localuser] password simple localpass
# Set the service type to lan-access.
[Router-luser-network-localuser] service-type lan-access
[Router-luser-network-localuser] quit
# Create a RADIUS scheme named radius1 and enter its view.
[Router] radius scheme radius1
# Configure the primary authentication server. Set its IP address to 192.168.100.250, port number to 1812, and shared key to name.
[Router-radius-radius1] primary authentication 192.168.100.250 1812 key simple name
# Configure the primary accounting server. Set its IP address to 192.168.100.250, port number to 1813, and shared key to name.
[Router-radius-radius1] primary accounting 192.168.100.250 1813 key simple name
# Exclude the domain names from the usernames sent to the RADIUS server.
[Router-radius-radius1] user-name-format without-domain
[Router-radius-radius1] quit
# Create an ISP domain named bbb and configure the authentication, authorization, and accounting methods for login users.
[Router] domain bbb
[Router-isp-bbb] authentication lan-access radius-scheme radius1 local
[Router-isp-bbb] authorization lan-access radius-scheme radius1 local
[Router-isp-bbb] accounting lan-access radius-scheme radius1 local
[Router-isp-bbb] quit
# Enable 802.1X on GigabitEthernet 0/0/1.
[Router] interface gigabitethernet 0/0/1
[Router-GigabitEthernet0/0/1] dot1x
# Enable port-based access control and specify mandatory 802.1X authentication domain bbb on the port. By default, the port uses MAC-based access control.
[Router-GigabitEthernet0/0/1] dot1x port-method portbased
[Router-GigabitEthernet0/0/1] dot1x mandatory-domain bbb
[Router-GigabitEthernet0/0/1] quit
# Enable 802.1X globally.
<Router> system-view
[Router] dot1x
# Use the display dot1x interface command to view 802.1X information on GigabitEthernet 0/0/1.
[Router] display dot1x interface gigabitethernet 0/0/1
Global 802.1X parameters:
   802.1X authentication      : Enabled
   CHAP authentication        : Enabled
   Max-tx period              : 30 s
   Handshake period           : 15 s
   Quiet timer                : Disabled
       Quiet period           : 60 s
   Supp timeout               : 30 s
   Server timeout             : 100 s
   Reauth period              : 3600 s
   Max auth requests          : 2
   SmartOn supp timeout       : 30 s
   SmartOn retry counts       : 3
   EAD assistant function     : Disabled
       EAD timeout            : 30 min
   Domain delimiter           : @
 Online 802.1X wired users    : 0
 Online 802.1X wireless users : 0
 GigabitEthernet0/0/1  is link-up
   Handshake                  : Enabled
   Handshake reply            : Disabled
   Handshake security         : Disabled
   Unicast trigger            : Disabled
   Periodic reauth            : Disabled
   Port role                  : Authenticator
   Authorization mode         : Auto
   Port access control        : Port-based
   Multicast trigger          : Enabled
   Mandatory auth domain      : bbb
   Guest VLAN                 : Not configured
   Auth-Fail VLAN             : Not configured
   Critical VLAN              : Not configured
   Critical voice VLAN        : Disabled
   Max online users           : 4294967295
   SmartOn                    : Disabled
   EAPOL packets: Tx 39, Rx 2
   Sent EAP Request/Identity packets : 39
        EAP Request/Challenge packets: 0
        EAP Success packets: 0
        EAP Failure packets: 0
        EAP Notification packets: 0
   Received EAPOL Start packets : 1
            EAPOL LogOff packets: 1
            EAP Response/Identity packets : 0
            EAP Response/Challenge packets: 0
            Error packets: 0
   Online 802.1X users: 0
# Execute the display dot1x sessions command to verify that you can come online after entering the correct username and password.
# Disconnect the device from the RADIUS server. Verify that you can still come online after entering the username and password.
Configuration files
 dot1x
interface Vlan-interface1
interface GigabitEthernet0/0/1
 port link-mode bridge
dot1x
interface GigabitEthernet0/0/2
 port link-mode route
 primary authentication 192.168.100.250 key cipher $c$3$Ua8m/JVT48sS4hXncslGCkRa
VEbAbk
primary accounting 192.168.100.250 key cipher $c$3$x0HaZfI2XD6iXBE5E/zTEgEopD8C
eyI=
domain bbb
 password cipher $c$3$TFxtbGxKPAxP3LUXfHeUuky7uuaBi9jAmoCnWA==
Related documentation
·     User Access and Authentication Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     User Access and Authentication Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
