H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
13-IGMP Snooping Configuration Examples
13-IGMP Snooping Configuration Examples 146.52 KB
H3C Routers
Introduction
The following information provides IGMP snooping group policy and static port configuration examples.
IGMP snooping runs on a Layer 2 device as a multicast constraining mechanism to improve multicast forwarding efficiency. It creates Layer 2 multicast forwarding entries from IGMP messages that are exchanged between the hosts and the Layer 3 device.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IGMP snooping.
Example: Configuring multicast group policies
As shown in Figure 1, VLAN 100 is connected to the PIM-DM domain through Device A. Router A runs IGMP and acts as the IGMP querier. Device A runs IGMP snooping. Configure IGMP snooping and a multicast group policy to meet the following requirements:
·     Host A receives only the multicast data addressed to multicast group 224.1.1.1. All other hosts (for example, Host B and Host C) receive only the multicast data addressed to multicast group 225.1.1.1.
·     Device A drops unknown multicast data instead of broadcasting it in VLAN 100.
Figure 1 Network diagram
Analysis
·     By default, IGMP snooping version 2 can process IGMPv1 and IGMPv2 messages, but not IGMPv3 messages, which will be flooded in the VLAN. To avoid this situation, configure IGMP snooping version 3 in VLAN 100.
·     By default, all multicast data not permitted by a multicast group policy is broadcast in VLAN 100, and receivers in VLAN 100 can receive that multicast data. To avoid this situation, enable dropping unknown multicast data packets.
·     To control the multicast groups that hosts can join, create a basic ACL and configure a rule to specify a multicast group range.
Software versions used
This configuration example was created and verified on Release 9141P16 of the MSR2630E-X1 router.
·     To enable IGMP snooping in a VLAN, first enable IGMP snooping globally.
·     You can configure a multicast group policy for a port in interface view or globally for all ports in IGMP snooping view. For a port, the port-specific configuration takes priority over the global configuration.
Procedures
1.     Prerequisites:
# Assign an IP address and subnet mask to each interface. (Details not shown.)
# Configure static routing or dynamic routing for interconnection between the routers in the PIM-DM domain. (Details not shown.)
# Enable PIM-DM on each router. PIM-DM enables the router to establish multicast forwarding entries, which can be used to forward multicast data from the multicast source to multicast receivers.
2.     Configure Router A:
# Enable IP multicast routing.
[RouterA] multicast routing
[RouterA-mrib] quit
# Enable IGMP and specify IGMP version 3 on GigabitEthernet 0/0/1.
[RouterA] interface gigabitethernet 0/0/1
[RouterA-GigabitEthernet0/0/1] igmp enable
[RouterA-GigabitEthernet0/0/1] igmp version 3
[RouterA-GigabitEthernet0/0/1] quit
3.     Configure Device A:
# Enable IGMP snooping globally.
[DeviceA] igmp-snooping
[DeviceA-igmp-snooping] quit
# Create VLAN 100, assign GigabitEthernet 0/0/1 through GigabitEthernet 0/0/4 to the VLAN, enable IGMP snooping and specify IGMP snooping version 3 in the VLAN, and enable dropping unknown multicast data packets.
[DeviceA] vlan 100
[DeviceA-vlan100] port gigabitethernet 0/0/1 to gigabitethernet 0/0/4
[DeviceA-vlan100] igmp-snooping enable
[DeviceA-vlan100] igmp-snooping version 3
[DeviceA-vlan100] igmp-snooping drop-unknown
[DeviceA-vlan100] quit
# Configure a multicast group policy on GigabitEthernet 0/0/2 to specify that Host A in VLAN 100 can join only multicast group 224.1.1.1.
[DeviceA] acl number 2000
[DeviceA-acl-basic-2000] rule permit source 224.1.1.1 0
[DeviceA-acl-basic-2000] quit
[DeviceA] interface gigabitethernet 0/0/2
[DeviceA-GigabitEthernet0/0/2] igmp-snooping group-policy 2000 vlan 100
[DeviceA-GigabitEthernet0/0/2] quit
# Configure a multicast group policy to specify that all other hosts in VLAN 100 can join only multicast group 225.1.1.1.
[DeviceA] acl number 2001
[DeviceA-acl-basic-2001] rule permit source 225.1.1.1 0
[DeviceA-acl-basic-2001] quit
[DeviceA-igmp-snooping] group-policy 2001 vlan 100
Send multicast data from the multicast source to multicast groups 224.1.1.1, 224.2.2.2, and 225.1.1.1.
# Display information about dynamic IGMP snooping group entries in VLAN 100 on Device A.
[DeviceA] display igmp-snooping group vlan 100
Total 2 entries.
VLAN 100: Total 2 entries.
  (0.0.0.0, 224.1.1.1)
    Host slots (1 in total):
      3
    Host ports (1 in total):
      GE0/0/2
  (0.0.0.0, 225.1.1.1)
      3
    Host ports (2 in total):
      GE0/0/3
      GE0/0/4
The output shows that GigabitEthernet 0/0/2 to which Host A attached joined multicast group 224.1.1.1 but did not join multicast group 224.2.2.2 or 225.1.1.1. GigabitEthernet 0/0/3 and GigabitEthernet 0/0/4 joined multicast group 225.1.1.1 but did not join multicast group 224.1.1.1 or 224.2.2.2.
Configuration files
·     Router A:
interface GigabitEthernet0/0/1
 port link-mode route
 igmp enable
 igmp version 3
multicast routing
·     Device A:
igmp-snooping
vlan 100
 port link-mode bridge
 port access vlan 100
interface GigabitEthernet0/0/2
interface GigabitEthernet0/0/3
interface GigabitEthernet0/0/4
acl number 2000
 rule 0 permit source 224.1.1.1 0
acl number 2001
 rule 0 permit source 225.1.1.1 0
Example: Configuring static ports
As shown in Figure 2, VLAN 100 is connected to the PIM-DM domain through Device A. Each device in VLAN 100 runs IGMP snooping. Router A runs IGMPv2 and acts as the IGMP querier.
A ring topology is used for enhancing the reliability of multicast traffic transmission. STP is used for avoiding loops. One of the links between Device A and Device B (Device A—Device B or Device A—Device C—Device B) will be blocked.
Configure static ports to meet the following requirements:
·     After one link between Device A and Device B switch to the other link and the STP state of the new link becomes stable, multicast data can be immediately sent to receivers over the new link.
·     Host A, Host B, and Host C can always receive the multicast data addressed to multicast group 224.1.1.1.
Figure 2 Network diagram
Analysis
·     After a link switchover is completed, a minimum of one IGMP query-response cycle must be completed before multicast data flows to the receivers along the new link. In this case, the multicast delivery is interrupted during the process. To avoid this situation, configure GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3 on Device A, GigabitEthernet 0/0/4 on Device B, and GigabitEthernet 0/0/2 on Device C as static router ports. Then, multicast data will be fast directed to static router ports and switched to the new link for transmission.
·     For Host A, Host B, and Host C to always receive the multicast data addressed to multicast group 224.1.1.1, configure GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3 on Device B and GigabitEthernet 0/0/3 on Device C as static member ports.
To successfully enable IGMP snooping in a VLAN, first enable IGMP snooping globally.
Procedures
1.     Prerequisites:
# Configure OSPF for interconnection between the routers in the PIM-DM domain. (Details not shown.)
# Enable PIM-DM on each router. PIM-DM enables the router to establish multicast forwarding entries, which can be used to forward multicast data from the source to receivers.
2.     Configuring Router A:
[RouterA-mrib] quit
# Enable IGMP snooping on GigabitEthernet 0/0/1.
# Create VLAN 100, assign GigabitEthernet 0/0/1 through GigabitEthernet 0/0/4 to the VLAN, and enable IGMP snooping in the VLAN.
[DeviceA] vlan 100
# Configure GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3 as static router ports.
[DeviceA-GigabitEthernet0/0/2] igmp-snooping static-router-port vlan 100
[DeviceA] interface gigabitethernet 0/0/3
[DeviceA-GigabitEthernet0/0/3] igmp-snooping static-router-port vlan 100
[DeviceA-GigabitEthernet0/0/3] quit
4.     Configure Device B:
[DeviceB] igmp-snooping
[DeviceB-igmp-snooping] quit
# Create VLAN 100, assign GigabitEthernet 0/0/1 and GigabitEthernet 0/0/4 to the VLAN, and enable IGMP snooping in the VLAN.
[DeviceB] vlan 100
[DeviceB-vlan100] port gigabitethernet 0/0/1 gigabitethernet 0/0/4
[DeviceB-vlan100] igmp-snooping enable
[DeviceB-vlan100] quit
# Configure GigabitEthernet 0/0/4 as a static router port.
[DeviceB] interface gigabitethernet 0/0/4
[DeviceB-GigabitEthernet0/0/4] igmp-snooping static-router-port vlan 100
[DeviceB-GigabitEthernet0/0/4] quit
# Configure GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3 as static member ports of multicast group 224.1.1.1 in VLAN 100.
[DeviceB] interface gigabitethernet 0/0/2
[DeviceB-GigabitEthernet0/0/2] igmp-snooping static-group 224.1.1.1 vlan 100
[DeviceB-GigabitEthernet0/0/2] quit
[DeviceB] interface gigabitethernet 0/0/3
[DeviceB-GigabitEthernet0/0/3] igmp-snooping static-group 224.1.1.1 vlan 100
[DeviceB-GigabitEthernet0/0/3] quit
5.     Configure Device C:
<DeviceC> system-view
[DeviceC] igmp-snooping
[DeviceC-igmp-snooping] quit
[DeviceC] vlan 100
[DeviceC-vlan100] port gigabitethernet 0/0/1 to gigabitethernet 0/0/4
[DeviceC-vlan100] igmp-snooping enable
[DeviceC-vlan100] quit
# Configure GigabitEthernet 0/0/2 as a static router port.
[DeviceC] interface gigabitethernet 0/0/2
[DeviceC-GigabitEthernet0/0/2] igmp-snooping static-router-port vlan 100
[DeviceC-GigabitEthernet0/0/2] quit
# Configure GigabitEthernet 0/0/3 as a static member port of multicast group 224.1.1.1 in VLAN 100.
[DeviceC] interface gigabitethernet 0/0/3
[DeviceC-GigabitEthernet0/0/3] igmp-snooping static-group 224.1.1.1 vlan 100
[DeviceC-GigabitEthernet0/0/3] quit
# Display static router port information in VLAN 10 on Device A.
[DeviceA] display igmp-snooping static-router-port vlan 100
VLAN 100:
  Router slots (1 in total):
    3
  Router ports (2 in total):
    GE0/0/2
    GE0/0/3
The output shows that GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3 on Device A have become static router ports.
# Display static router port information in VLAN 10 on Device B.
[DeviceB] display igmp-snooping static-router-port vlan 100
VLAN 100:
    3
  Router ports (1 in total):
    GE0/0/4
The output shows that GigabitEthernet 0/0/4 on Device B has become a static router port.
# Display information about static IGMP snooping group entries in VLAN 100 on Device B.
[DeviceB] display igmp-snooping static-group vlan 100
Total 1 entries.
VLAN 100: Total 1 entries.
      3
      GE0/0/2
      GE0/0/3
The output shows that GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3 on Device B have become static member ports of  multicast group 224.1.1.1 in VLAN 100.
# Display static router port information in VLAN 10 on Device C.
[DeviceC] display igmp-snooping static-router-port vlan 100
VLAN 100:
    3
    GE0/0/2
The output shows that GigabitEthernet 0/0/2 on Device C has become a static router port.
# Display information about static IGMP snooping group entries in VLAN 100 on Device C.
[DeviceC] display igmp-snooping static-group vlan 100
Total 1 entries.
      3
      GE0/0/3
The output shows that GigabitEthernet 0/0/3 on Device C has become a static member port of multicast group 224.1.1.1 in VLAN 100.
Configuration files
·     Router A:
 igmp enable
 igmp version 2
multicast routing
·     Device A:
igmp-snooping
vlan 100
·     Device B:
igmp-snooping
vlan 100
·     Device C:
igmp-snooping
vlan 100
Related documentation
·     IP Multicast Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     IP Multicast Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
