H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
12-HoVPN Configuration Examples
12-HoVPN Configuration Examples 175.75 KB
H3C Routers
Introduction
The following information provides MPLS HoVPN configuration examples.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of HoVPN.
Example: Configure MPLS HoVPN
As shown in Figure 1, the SPE devices are ISP backbone devices in AS 100. The UPE devices are user-facing devices in AS 200. UPE 1 and UPE 2 are connected to CE 1 and CE 2 of VPN1, respectively. CE 1 is connected to two subnets 172.16.1.0/24 and 172.16.2.0/24. CE 2 is connected to subnet 172.16.3.0/24.
Configure HoVPN for the user networks, and configure routing policies to control user access as follows: allow access between CE 1’s 172.16.1.0/24 and CE 2’s 172.16.3.0/24 and deny access between CE 1’s 172.16.2.0/24 and CE 2's 172.16.3.0/24.
Figure 1 Network diagram
Analysis
The configuration mainly includes two parts:
·     Configure the HoVPN service on the network.
·     Configure routing policies on SPE devices and configure SPE 2 to advertise only the 172.16.1.0/24 network of CE 1 to UPE 2.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
·     In an HoVPN network, the routing policy configuration is required. For an SPE to advertise routes to a UPE, you must configure a routing policy on the SPE and enable the SPE to advertise routes to the UPE.
·     When you configure an EBGP peer relationship between an SPE and a UPE to advertise labeled routes, you must enable the label exchange capability between the peers and then configure a routing policy to label the routes advertised to the peer. If you only enable the label exchange capability, routes cannot be advertised to the peer with labels.
·     When an interface is bound to a VPN instance, the settings (including IP address) on the interface will be cleared. Therefore, bind an interface to a VPN instance before you configure other settings on the interface.
Procedures
Configuring MPLS, MPLS LDP, and OSPF on SPEs
1.     Configure SPE 1:
# Configure the Loopback interface address.
<SPE1>system-view
[SPE1] interface loopback 0
[SPE1-LoopBack0] ip address 2.2.2.9 32
[SPE1-LoopBack0] quit
# Configure the MPLS LSR ID and enable LDP globally.
[SPE1] mpls lsr-id 2.2.2.9
[SPE1] mpls ldp
[SPE1-ldp] quit
# Configure an IP address and enable MPLS on interface GigabitEthernet 0/0/1.
[SPE1] interface gigabitethernet 0/0/1
[SPE1-GigabitEthernet0/0/1] ip address 172.1.1.2 24
[SPE1-GigabitEthernet0/0/1] mpls enable
[SPE1-GigabitEthernet0/0/1] quit
# Configure an IP address, and enable MPLS and IPv4 LDP capabilities on interface GigabitEthernet 0/0/2.
[SPE1] interface gigabitethernet 0/0/2
[SPE1-GigabitEthernet0/0/2] ip address 180.1.1.1 24
[SPE1-GigabitEthernet0/0/2] mpls enable
[SPE1-GigabitEthernet0/0/2] mpls ldp enable
[SPE1-GigabitEthernet0/0/2] quit
# Configure OSPF as the IGP to ensure IP connectivity on the backbone network.
[SPE1]ospf 1
[SPE1-ospf-1] area 0
[SPE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[SPE1-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] quit
[SPE1-ospf-1] quit
2.     Configure SPE 2:
<SPE2>system-view
[SPE2] interface loopback 0
[SPE2-LoopBack0] ip address 3.3.3.9 32
[SPE2-LoopBack0] quit
[SPE2] mpls lsr-id 3.3.3.9
[SPE2] mpls ldp
[SPE2-ldp] quit
# Configure an IP address, and enable MPLS and IPv4 LDP capabilities on interface GigabitEthernet 1/0/2.
[SPE2] interface gigabitethernet 0/0/2
[SPE2-GigabitEthernet0/0/2] ip address 180.1.1.2 24
[SPE2-GigabitEthernet0/0/2] mpls enable
[SPE2-GigabitEthernet0/0/2] mpls ldp enable
[SPE2-GigabitEthernet0/0/2] quit
[SPE2] interface gigabitethernet 0/0/1
[SPE2-GigabitEthernet0/0/1] ip address 172.2.1.2 24
[SPE2-GigabitEthernet0/0/1] mpls enable
[SPE2-GigabitEthernet0/0/1] quit
[SPE2]ospf 1
[SPE2-ospf-1] area 0
[SPE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[SPE2-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] quit
[SPE2-ospf-1] quit
After the configuration is completed, execute the display mpls ldp peer command on SPE 1 to verify that an LDP session has been established in Operational state. Execute the display ospf peer command on SPE 1 to verify that an OSPF neighbor relationship has been established in Full state.
Configuring MP-IBGP peering between SPEs to exchange VPNv4 routes
# Configure SPE 1 to establish MP-IBGP peering with SPE 2 to exchange VPNv4 routes.
[SPE1] bgp 100
[SPE1-bgp] peer 3.3.3.9 as-number 100
[SPE1-bgp] peer 3.3.3.9 connect-interface loopback 0
[SPE1-bgp] address-family vpnv4
[SPE1-bgp-vpnv4] peer 3.3.3.9 enable
[SPE1-bgp-vpnv4] quit
[SPE1-bgp] quit
# Configure SPE 2 to establish MP-IBGP peering with SPE 1 to exchange VPNv4 routes.
[SPE2] bgp 100
[SPE2-bgp] peer 2.2.2.9 as-number 100
[SPE2-bgp] peer 2.2.2.9 connect-interface loopback 0
[SPE2-bgp] address-family vpnv4
[SPE2-bgp-vpnv4] peer 2.2.2.9 enable
[SPE2-bgp-vpnv4] quit
[SPE2-bgp] quit
After the configuration is completed, execute the display bgp peer vpnv4 command on SPE 1 and SPE 2 to verify that a BGP peer relationship has been established between the SPEs and is in Established state.
Enabling MPLS on UPEs
1.     Configure UPE 1:
<UPE1>system-view
[UPE1] interface loopback 0
[UPE1-LoopBack0] ip address 1.1.1.9 32
[UPE1-LoopBack0] quit
# Configure the MPLS LSR ID for the device.
[UPE1] mpls lsr-id 1.1.1.9
[UPE1] interface gigabitethernet 0/0/1
[UPE1-GigabitEthernet0/0/1] ip address 172.1.1.1 24
[UPE1-GigabitEthernet0/0/1] mpls enable
[UPE1-GigabitEthernet0/0/1] quit
2.     Configure UPE 2:
<UPE2>system-view
[UPE2] interface loopback 0
[UPE2-Loopback0] ip address 4.4.4.9 32
[UPE2-Loopback0] quit
[UPE2] mpls lsr-id 4.4.4.9
[UPE2] interface gigabitethernet 0/0/1
[UPE2-GigabitEthernet0/0/1] ip address 172.2.1.1 24
[UPE2-GigabitEthernet0/0/1] mpls enable
[UPE2-GigabitEthernet0/0/1] quit
Configuring EBGP peering between SPEs and UPEs to exchange labeled routes and establish BGP LSPs
1.     Configure SPE 1:
# Establish EBGP peering with UPE 1.
[SPE1] bgp 100
[SPE1-bgp] peer 172.1.1.1 as-number 200
# In BGP IPv4 unicast address family view, enable the capability of exchanging labeled IPv4 routes with the peer.
[SPE1-bgp] address-family ipv4
[SPE1-bgp-ipv4] peer 172.1.1.1 enable
[SPE1-bgp-ipv4] peer 172.1.1.1 label-route-capability
# Apply routing policy policy1 to the routes to be advertised to the peer.
[SPE1-bgp-ipv4] peer 172.1.1.1 route-policy policy1 export
[SPE1-bgp-ipv4] network 2.2.2.9 255.255.255.255
[SPE1-bgp-ipv4] quit
[SPE1-bgp] quit
# Configure the routing policy to allocate labels to routes.
[SPE1] route-policy policy1 permit node 0
[SPE1-route-policy-policy1-0] apply mpls-label
[SPE1-route-policy-policy1-0] quit
2.     Configure UPE 1:
[UPE1] bgp 200
[UPE1-bgp] peer 172.1.1.2 as-number 100
[UPE1-bgp] address-family ipv4
[UPE1-bgp-ipv4] peer 172.1.1.2 enable
[UPE1-bgp-ipv4] peer 172.1.1.2 label-route-capability
[UPE1-bgp-ipv4] peer 172.1.1.2 route-policy policy1 export
[UPE1-bgp-ipv4] network 1.1.1.9 255.255.255.255
[UPE1-bgp-ipv4] quit
[UPE1-bgp] quit
[UPE1] route-policy policy1 permit node 0
[UPE1-route-policy-policy1-0] apply mpls-label
[UPE1-route-policy-policy1-0] quit
3.     Configure SPE 2:
Establish EBGP peering with UPE 2.
[SPE2] bgp 100
[SPE2-bgp] peer 172.2.1.1 as-number 200
[SPE2-bgp] address-family ipv4
[SPE2-bgp-ipv4] peer 172.2.1.1 enable
[SPE2-bgp-ipv4] peer 172.2.1.1 label-route-capability
[SPE2-bgp-ipv4] peer 172.2.1.1 route-policy policy1 export
[SPE2-bgp-ipv4] network 3.3.3.9 255.255.255.255
[SPE2-bgp-ipv4] quit
[SPE2-bgp] quit
[SPE2] route-policy policy1 permit node 0
[SPE2-route-policy-policy1-0] apply mpls-label
[SPE2-route-policy-policy1-0] quit
4.     Configure UPE 2:
# Establish EBGP peering with UPE 2.
[UPE2] bgp 200
[UPE2-bgp] peer 172.2.1.2 as-number 100
[UPE2-bgp] address-family ipv4
[UPE2-bgp-ipv4] peer 172.2.1.2 enable
[UPE2-bgp-ipv4] peer 172.2.1.2 label-route-capability
[UPE2-bgp-ipv4] peer 172.2.1.2 route-policy policy1 export
[UPE2-bgp-ipv4] network 4.4.4.9 255.255.255.255
[UPE2-bgp-ipv4] quit
[UPE2-bgp] quit
[UPE2] route-policy policy1 permit node 0
[UPE2-route-policy-policy1-0] apply mpls-label
[UPE2-route-policy-policy1-0] quit
After the configuration is completed, execute the display mpls lsp command on each device to verify that BGP LSPs have been established between SPEs and UPEs.
Configuring MP-EBGP peering between SPEs and UPEs and enabling HoVPN
1.     Configure UPE 1:
# Configure MP-EBGP peering with SPE 1.
[UPE1] bgp 200
[UPE1-bgp] peer 2.2.2.9 as-number 100
[UPE1-bgp] peer 2.2.2.9 connect-interface loopback 0
[UPE1-bgp] address-family vpnv4
[UPE1-bgp-vpnv4] peer 2.2.2.9 enable
# Allow the local AS number to appear in the AS-PATH attribute of routes, so as to receive the routes from UPE 2 in the same AS.
[UPE1-bgp-vpnv4] peer 2.2.2.9 allow-as-loop
[UPE1-bgp-vpnv4] quit
2.     Configure SPE 1:
# Configure VPN instance vpn1.
[SPE1] ip vpn-instance vpn1
[SPE1-vpn-instance-vpn1] route-distinguisher 100:1
[SPE1-vpn-instance-vpn1] vpn-target 100:1 both
[SPE1-vpn-instance-vpn1] quit
# Configure MP-EBGP peering with UPE 1, specify UPE 1 as a UPE, and create a BGP-VPN instance to redistribute VPN routes.
[SPE1] bgp 100
[SPE1-bgp] peer 1.1.1.9 as-number 200
[SPE1-bgp] peer 1.1.1.9 connect-interface loopback 0
[SPE1-bgp-vpnv4] peer 1.1.1.9 enable
[SPE1-bgp-vpnv4] peer 1.1.1.9 upe
[SPE1-bgp] ip vpn-instance vpn1
[SPE1-bgp-vpn1] quit
[SPE1-bgp] quit
3.     Configure UPE 2:
# Configure MP-EBGP peering with SPE 2.
[UPE2] bgp 200
[UPE2-bgp] peer 3.3.3.9 as-number 100
[UPE2-bgp] peer 3.3.3.9 connect-interface loopback 0
[UPE2-bgp] address-family vpnv4
[UPE2-bgp-vpnv4] peer 3.3.3.9 enable
# Allow the local AS number to appear in the AS-PATH attribute of routes, so as to receive the routes of UPE 1 in the same AS.
[UPE2-bgp-vpnv4] peer 3.3.3.9 allow-as-loop
[UPE2-bgp-vpnv4] quit
4.     Configure SPE 2:
[SPE2] ip vpn-instance vpn1
[SPE2-vpn-instance-vpn1] route-distinguisher 100:1
[SPE2-vpn-instance-vpn1] vpn-target 100:1 both
[SPE2-vpn-instance-vpn1] quit
# Configure MP-EBGP peering with UPE 2, specify UPE 2 as a UPE, and create a BGP-VPN instance to redistribute VPN routes.
[SPE2] bgp 100
[SPE2-bgp] peer 4.4.4.9 as-number 200
[SPE2-bgp] peer 4.4.4.9 connect-interface loopback 0
[SPE2-bgp-vpnv4] peer 4.4.4.9 enable
[SPE2-bgp-vpnv4] peer 4.4.4.9 upe
[SPE2-bgp] ip vpn-instance vpn1
[SPE2-bgp-vpn1] quit
[SPE2-bgp] quit
After the configuration is completed, execute the display bgp peer vpnv4 command on the SPE and UPE to verify that a BGP peer relationship has been established between the devices and is in Established state.
Configuring UPEs to provide access to CEs
1.     Configure UPE 1:
# Configure VPN instance vpn1, allowing CE 1 to access UPE 1.
[UPE1] ip vpn-instance vpn1
[UPE1-vpn-instance-vpn1] route-distinguisher 100:1
[UPE1-vpn-instance-vpn1] vpn-target 100:1 both
[UPE1-vpn-instance-vpn1] quit
[UPE1] interface gigabitethernet 0/0/2
[UPE1-Gigabitethernet1/0/2] ip binding vpn-instance vpn1
[UPE1-Gigabitethernet1/0/2] ip address 10.1.1.2 24
[UPE1-Gigabitethernet1/0/2] quit
# Establish EBGP peering between UPE 1 and CE 1, and redistribute VPN routes into BGP.
[UPE1] bgp 200
[UPE1-bgp] ip vpn-instance vpn1
[UPE1-bgp-vpn1] peer 10.1.1.1 as-number 65410
[UPE1-bgp-vpn1] address-family ipv4 unicast
[UPE1-bgp-ipv4-vpn1] peer 10.1.1.1 enable
[UPE1-bgp-ipv4-vpn1] import-route direct
[UPE1-bgp-ipv4-vpn1] quit
[UPE1-bgp-vpn1] quit
2.     Configure CE 1:
# Assign an IP addresses to interface GigabitEthernet 1/0/2.
<CE1>system-view
[CE1] interface gigabitethernet 0/0/2
[CE1-GigabitEthernet0/0/2] ip address 10.1.1.1 255.255.255.0
[CE1-GigabitEthernet0/0/2] quit
# Establish EBGP peering with UPE 1, and redistribute direct routes into BGP.
[CE1] bgp 65410
[CE1-bgp] peer 10.1.1.2 as-number 200
[CE1-bgp] address-family ipv4 unicast
[CE1-bgp-ipv4] peer 10.1.1.2 enable
[CE1-bgp-ipv4] import-route direct
[CE1-bgp-ipv4] quit
[CE1-bgp] quit
3.     Configure UPE 2:
# Configure VPN instance vpn1, allowing CE 2 to access UPE 2.
[UPE2] ip vpn-instance vpn1
[UPE2-vpn-instance-vpn1] route-distinguisher 100:1
[UPE2-vpn-instance-vpn1] vpn-target 100:1 both
[UPE2-vpn-instance-vpn1] quit
[UPE2] interface gigabitethernet 0/0/2
[UPE2-GigabitEthernet0/0/2] ip binding vpn-instance vpn1
[UPE2-GigabitEthernet0/0/2] ip address 10.2.1.2 24
[UPE2-GigabitEthernet0/0/2] quit
# Establish EBGP peering with CE 2, and redistribute VPN routes into BGP.
[UPE2] bgp 200
[UPE2-bgp] ip vpn-instance vpn1
[UPE2-bgp-vpn1] peer 10.2.1.1 as-number 65420
[UPE2-bgp-vpn1] address-family ipv4 unicast
[UPE2-bgp-ipv4-vpn1] peer 10.2.1.1 enable
[UPE2-bgp-ipv4-vpn1] import-route direct
[UPE2-bgp-ipv4-vpn1] quit
[UPE2-bgp-vpn1] quit
4.     Configure CE 2:
<CE2>system-view
[CE2] interface gigabitethernet 0/0/2
[CE2-GigabitEthernet0/0/2] ip address 10.2.1.1 255.255.255.0
[CE2-GigabitEthernet0/0/2] quit
# Establish EBGP peering with UPE 2, and redistribute direct routes into BGP.
[CE2] bgp 65420
[CE2-bgp] peer 10.2.1.2 as-number 200
[CE2-bgp] address-family ipv4 unicast
[CE2-bgp-ipv4] peer 10.2.1.2 enable
[CE2-bgp-ipv4] import-route direct
[CE2-bgp-ipv4] quit
[CE2-bgp] quit
After the configuration is completed, execute the display bgp peer ipv4 command to verify that a BGP peer relationship has been established between the UPE and CE and is in Established state.
Configuring routing policies on SPEs to control route advertisement between VPNs
1.     Configure SPE 1:
# Configure a routing policy to permit routes of CE 2, and then apply the routing policy to the routes to be advertised to UPE 1.
[SPE1] ip prefix-list list1 index 10 permit 172.16.3.0 24
[SPE1] route-policy policy2 permit node 0
[SPE1-route-policy-policy2-0] if-match ip address prefix-list list1
[SPE1-route-policy-policy2-0] quit
[SPE1] bgp 100
[SPE1-bgp-vpnv4] peer 1.1.1.9 upe route-policy policy2 export
[SPE1-bgp] quit
2.     Configure SPE 2:
# Configure a routing policy to permit route 172.16.1.0/24 of CE 1, and then apply the routing policy to the routes to be advertised to UPE 2.
[SPE2] ip prefix-list list1 index 10 permit 172.16.1.0 24
[SPE2] route-policy policy2 permit node 0
[SPE2-route-policy-policy2-0] if-match ip address prefix-list list1
[SPE2-route-policy-policy2-0] quit
[SPE2] bgp 100
[SPE2-bgp-vpnv4] peer 4.4.4.9 upe route-policy policy2 export
[SPE2-bgp]quit
After the configuration is completed, verify that CE 1 has learned the route to subnet 172.16.3.0/24 of CE 2.
[CE1] display ip routing-table
Destinations : 25        Routes : 25
172.16.1.0/24       Direct 0    0            172.16.1.1      GE0/0/1
172.16.1.0/32       Direct 0    0            172.16.1.1      GE0/0/1
172.16.1.1/32       Direct 0    0            127.0.0.1       InLoop0
172.16.1.255/32     Direct 0    0            172.16.1.1      GE0/0/1
172.16.2.0/24       Direct 0    0            172.16.2.1      GE0/0/3
172.16.2.0/32       Direct 0    0            172.16.2.1      GE0/0/3
172.16.2.1/32       Direct 0    0            127.0.0.1       InLoop0
172.16.2.255/32     Direct 0    0            172.16.2.1      GE0/0/3
172.16.3.0/24       BGP    255  0            10.1.1.2        GE0/0/2
CE 2 has learned the route to subnet 172.16.1.0/24 of CE 1 but has not learned the route to subnet 172.16.2.0/24 of CE 1.
<CE2> display ip routing-table
Destinations : 21        Routes : 21
172.16.1.0/24       BGP    255  0            10.2.1.2        GE0/0/2
172.16.3.0/24       Direct 0    0            172.16.3.1      GE0/0/1
172.16.3.0/32       Direct 0    0            172.16.3.1      GE0/0/1
172.16.3.1/32       Direct 0    0            127.0.0.1       InLoop0
172.16.3.255/32     Direct 0    0            172.16.3.1      GE0/0/1
Subnet 172.16.1.0/24 of CE 1 can communicate with subnet 172.16.3.0/24 of CE 2. Subnet 172.16.2.0/24 of CE 1 cannot communicate with subnet 172.16.3.0/24 of CE 2.
Configuration files
·     CE 1:
interface GigabitEthernet0/0/1
 ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet0/0/2
 ip address 172.16.2.1 255.255.255.0
bgp 65410
  import-route direct
·     CE 2:
 ip address 172.16.3.1 255.255.255.0
bgp 65420
  import-route direct
·     UPE 1:
 vpn-target 100:1 import-extcommunity
 vpn-target 100:1 export-extcommunity
 mpls lsr-id 1.1.1.9
interface LoopBack0
 ip address 1.1.1.9 255.255.255.255
 ip address 172.1.1.1 255.255.255.0
 mpls enable
bgp 200
 peer 2.2.2.9 connect-interface LoopBack0
  import-route direct
  network 172.1.1.0 255.255.255.0
  peer 172.1.1.2 route-policy hope export
  peer 2.2.2.9 enable
  peer 2.2.2.9 allow-as-loop 1
   import-route direct
route-policy hope permit node 0
 apply mpls-label
·     SPE 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
 ip address 2.2.2.9 255.255.255.255
 ip address 172.1.1.2 255.255.255.0
 mpls enable
 ip address 180.1.1.1 255.255.255.0
 mpls enable
 mpls ldp enable
bgp 100
 peer 1.1.1.9 connect-interface LoopBack0
 peer 3.3.3.9 connect-interface LoopBack0
  peer 1.1.1.9 enable
  peer 1.1.1.9 upe
  peer 3.3.3.9 enable
 apply mpls-label
·     UPE 2:
 mpls lsr-id 4.4.4.9
interface LoopBack0
 ip address 4.4.4.9 255.255.255.255
 ip address 172.2.1.1 255.255.255.0
 mpls enable
 ip address 10.2.1.2 255.255.255.0
bgp 200
  peer 172.2.1.2 route-policy hope export
  peer 3.3.3.9 enable
  peer 3.3.3.9 allow-as-loop 1
   import-route direct
 apply mpls-label
·     SPE 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
 ip address 3.3.3.9 255.255.255.255
 ip address 172.2.1.2 255.255.255.0
 mpls enable
 ip address 180.1.1.2 255.255.255.0
 mpls enable
 mpls ldp enable
bgp 100
 router-id 3.3.3.9
 peer 4.4.4.9 connect-interface LoopBack0
  peer 2.2.2.9 enable
  peer 4.4.4.9 enable
  peer 4.4.4.9 upe
 apply mpls-label
Related documentation
·     MPLS Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     MPLS Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
·     Layer 3—IP Routing Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Layer 3—IP Routing Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
