H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
16-IPsec Digital Certificate Authentication Configuration Examples
H3C Routers
Introduction
The following information provides examples for configuring IPsec digital certificate authentication.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IPsec, IKE, and IKEv2.
Example: Configuring aggressive mode IKE with RSA signature authentication
This configuration example is not available when the device is operating in FIPS mode.
Establish an IPsec tunnel between Device A and Device B to secure data flows between the subnet of Host A (10.1.1.0/24) and the subnet of Host B (10.1.2.0/24).
·     Device A and Device B use IKE to negotiate IPsec SAs and use RSA signature authentication.
·     The IKE phase 1 negotiation uses the aggressive mode.
·     Device A acts as the initiator, and the subnet where Device A resides uses IP addresses dynamically allocated.
Figure 1 Network diagram
Procedures
Make sure the following tasks have been completed:
·     Device A has obtained CA certificate ca.cer and local certificate server1.pfx.
·     Device B has obtained CA certificate ca.cer and local certificate server2.pfx.
Configuring Device A
# Assign an IP address to each interface. (Details not shown.)
# Configure IPv4 advanced ACL 3101 to identify traffic from subnet 10.1.1.0/24 to subnet 10.1.2.0/24.
[DeviceA] acl advanced 3101
[DeviceA-acl-ipv4-adv-3101] rule permit ip source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
[DeviceA-acl-ipv4-adv-3101] quit
# Create an IPsec transform set named tran1.
[DeviceA] ipsec transform-set tran1
# Set the packet encapsulation mode to tunnel.
[DeviceA-ipsec-transform-set-tran1] encapsulation-mode tunnel
# Use the ESP protocol for the IPsec transform set.
[DeviceA-ipsec-transform-set-tran1] protocol esp
# Specify the encryption and authentication algorithms.
[DeviceA-ipsec-transform-set-tran1] esp encryption-algorithm des-cbc
[DeviceA-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[DeviceA-ipsec-transform-set-tran1] quit
# Create a PKI domain named domain1.
[DeviceA] pki domain domain1
[DeviceA-pki-domain-domain1] undo crl check enable
[DeviceA-pki-domain-domain1] quit
# Import CA certificate ca.cer and local certificate server1.pfx to the PKI domain.
[DeviceA] pki import domain domain1 der ca filename ca.cer
[DeviceA] pki import domain domain1 p12 local filename server1.pfx
# Configure a certificate-based access control policy named policy1.
[DeviceA] pki certificate access-control-policy policy1
[DeviceA-pki-cert-acp-policy1] rule 1 permit group1
[DeviceA-pki-cert-acp-policy1] quit
# Configure a certificate attribute rule.
[DeviceA] pki certificate attribute-group group1
[DeviceA-pki-cert-attribute-group-group1] attribute 1 subject-name dn ctn 1
[DeviceA-pki-cert-attribute-group-group1] quit
A peer certificate is valid only if it contains the specified string (1 in this example) in the DN attribute of the subject name field.
# Create an IKE profile named profile1.
[DeviceA] ike profile profile1
# Specify PKI domain domain1 for the IKE profile.
[DeviceA-ike-profile-profile1] certificate domain domain1
# Specify the IKE negotiation mode in phase 1 as the aggressive mode.
[DeviceA-ike-profile-profile1] exchange-mode aggressive
# Specify the DN in the local certificate as the local ID.
[DeviceA-ike-profile-profile1] local-identity dn
# Specify the DN in the peer's digital certificate as the peer ID for IKE profile matching.
[DeviceA-ike-profile-profile1] match remote certificate policy1
[DeviceA-ike-profile-profile1] quit
# Create an IKE proposal numbered 10.
[DeviceA] ike proposal 10
# Set the authentication algorithm to HMAC-MD5.
[DeviceA-ike-proposal-10] authentication-algorithm md5
# Specify the RSA authentication method.
[DeviceA-ike-proposal-10] authentication-method rsa-signature
[DeviceA-ike-proposal-10] quit
# Create an IKE-based IPsec policy entry. Specify the policy name as map1 and set the sequence number to 10.
[DeviceA] ipsec policy map1 10 isakmp
# Specify the remote IP address of the IPsec tunnel as 2.2.2.2.
[DeviceA-ipsec-policy-isakmp-map1-10] remote-address 2.2.2.2
# Specify IPsec transform set tran1 for the IPsec policy.
[DeviceA-ipsec-policy-isakmp-map1-10] transform-set tran1
# Specify ACL 3101 to identify the traffic to be protected.
[DeviceA-ipsec-policy-isakmp-map1-10] security acl 3101
# Specify IKE profile profile1 for the IPsec policy.
[DeviceA-ipsec-policy-isakmp-map1-10] ike-profile profile1
[DeviceA-ipsec-policy-isakmp-map1-10] quit
# Apply IPsec policy map1 to GigabitEthernet 0/0/1.
[DeviceA] interface gigabitethernet 0/0/1
[DeviceA-GigabitEthernet0/0/1] ipsec apply policy map1
[DeviceA-GigabitEthernet0/0/1] quit
# Configure a static route to the subnet where Host B resides. This example uses 1.1.1.2 as the next hop IP address.
[DeviceA] ip route-static 10.1.2.0 255.255.255.0 1.1.1.2
Configuring Device B
# Configure IPv4 advanced ACL 3101 to identify the traffic from subnet 10.1.2.0/ 24 to subnet 10.1.1.0/24.
[DeviceB] acl advanced 3101
[DeviceB-acl-ipv4-adv-3101] rule permit ip source 10.1.2.0 0.0.0.255 destination 10.1.1.0 0.0.0.255
[DeviceB-acl-ipv4-adv-3101] quit
[DeviceB] ipsec transform-set tran1
[DeviceB-ipsec-transform-set-tran1] encapsulation-mode tunnel
[DeviceB-ipsec-transform-set-tran1] protocol esp
[DeviceB-ipsec-transform-set-tran1] esp encryption-algorithm des-cbc
[DeviceB-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[DeviceB-ipsec-transform-set-tran1] quit
# Create a PKI domain named domain2.
[DeviceB] pki domain domain2
[DeviceB-pki-domain-domain2] undo crl check enable
[DeviceB-pki-domain-domain2] quit
# Import CA certificate ca.cer and local certificate server2.pfx to the PKI domain.
[DeviceB] pki import domain domain2 der ca filename ca.cer
[DeviceB] pki import domain domain2 p12 local filename server2.pfx
[DeviceB] pki certificate access-control-policy policy1
[DeviceB-pki-cert-acp-policy1] rule 1 permit group1
[DeviceB-pki-cert-acp-policy1] quit
[DeviceB] pki certificate attribute-group group1
[DeviceB-pki-cert-attribute-group-group1] attribute 1 subject-name dn ctn 1
[DeviceB-pki-cert-attribute-group-group1] quit
# Create an IKE profile named profile2.
[DeviceB] ike profile profile2
# Specify PKI domain domain2 for the IKE profile.
[DeviceB-ike-profile-profile2] certificate domain domain2
[DeviceB-ike-profile-profile2] exchange-mode aggressive
[DeviceB-ike-profile-profile2] local-identity dn
[DeviceB-ike-profile-profile2] match remote certificate policy1
[DeviceB-ike-profile-profile2] quit
[DeviceB] ike proposal 10
[DeviceB-ike-proposal-10] authentication-algorithm md5
[DeviceB-ike-proposal-10] authentication-method rsa-signature
[DeviceB-ike-proposal-10] quit
# Create an IPsec policy template entry. Specify the template name as template1 and set the sequence number to 1.
[DeviceB] ipsec policy-template template1 1
[DeviceB-ipsec-policy-template-template1-1] transform-set tran1
[DeviceB-ipsec-policy-template-template1-1] security acl 3101
# Specify IKE profile profile2 for the IPsec policy template.
[DeviceB-ipsec-policy-template-template1-1] ike-profile profile2
[DeviceB-ipsec-policy-template-template1-1] quit
# Create an IKE-based IPsec policy entry by using IPsec policy template template1. Specify the policy name as use1 and set the sequence number to 1.
[DeviceB] ipsec policy use1 1 isakmp template template1
# Apply IPsec policy use1 to GigabitEthernet 0/0/1.
[DeviceB] interface gigabitethernet 0/0/1
[DeviceB-GigabitEthernet0/0/1] ipsec apply policy use1
[DeviceB-GigabitEthernet0/0/1] quit
# Configure a static route to Host A. This example uses 2.2.2.1 as the next hop IP address.
[DeviceB] ip route-static 10.1.1.0 255.255.255.0 2.2.2.1
After above configuration, IKE negotiation is triggered between Device A and Device B when there is traffic between subnet 10.1.1.0/24 and subnet 10.1.2.0/24.
# Display the IKE proposal configuration on Device A and Device B.
[DeviceA] display ike proposal
 Priority Authentication Authentication Encryption  Diffie-Hellman Duration
              method       algorithm    algorithm       group      (seconds)
 10       RSA-SIG            MD5        DES-CBC     Group 1        86400
 default  PRE-SHARED-KEY     SHA1       DES-CBC     Group 1        86400
[DeviceB] display ike proposal
# Display the IKE SA on Device A.
[DeviceA] display ike sa
    Connection-ID   Remote                Flag         DOI
    1               2.2.2.2               RD           IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
# Display IPsec SA information on Device A.
[DeviceA] display ipsec sa
Interface: GigabitEthernet0/0/1
  IPsec policy: map1
  Sequence number: 10
  Mode: ISAKMP
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Path MTU: 1456
    Tunnel:
        local  address: 1.1.1.1
        remote address: 2.2.2.2
    Flow:
        sour addr: 10.1.1.0/255.255.255.0  port: 0  protocol: ip
        dest addr: 10.1.2.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 3264152513 (0xc28f03c1)
      Connection ID: 90194313219
      Transform set: ESP-ENCRYPT-DES-CBC ESP-AUTH-SHA1
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843200/3484
      Max received sequence-number:
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 738451674 (0x2c03e0da)
      Connection ID: 64424509441
      Max sent sequence-number:
      Status: Active
# Display information about the IKE SA and IPsec SA on Device B. (Details not shown.)
Example: Configuring GM main mode IKE with SM2-DE digital envelope authentication
Device A and Device B use IKE to negotiate IPsec SAs, use SM2-DE signature authentication, and use the GM main mode for phase 1 IKE negotiation.
Figure 2 Network diagram
Procedures
The SM1 algorithm is supported only if the following network data encryption modules are installed: SIC-CNDE, SIC-CNDE-SJK, SIC-4G-CNDE-SJK, SIC-D4G-CNDE-SJK, HMIM-CNDE-SJK
# Configure IPv4 advanced ACL 3101 to identify the traffic from subnet 10.1.1.0/ 24 to subnet 10.1.2.0/24.
[DeviceA-ipsec-transform-set-tran1] esp encryption-algorithm sm4-cbc
[DeviceA-ipsec-transform-set-tran1] esp authentication-algorithm sm3
# Set the authentication method to SM2-DE.
[DeviceA-ike-proposal-10] authentication-method sm2-de
# Set the authentication algorithm to SM3.
[DeviceA-ike-proposal-10] authentication-algorithm sm3
# Specify the encryption algorithm to SM4-CBC.
[DeviceA-ike-proposal-10] encryption-algorithm sm4-cbc
# Specify the phase 1 IKE negotiation mode as the GM main mode.
[DeviceA-ike-profile-profile1] exchange-mode gm-main
[DeviceA-ike-profile-profile1] proposal 10
# Configure the local ID as IP address 1.1.1.1.
[DeviceA-ike-profile-profile1] local-identity address 1.1.1.1
# Configure a peer ID with the identity type as IP address and the value as 2.2.2.2/16.
[DeviceA-ike-profile-profile1] match remote identity address 2.2.2.2 255.255.0.0
# Configure IPv4 advanced ACL 3101 to identify the traffic from subnet 10.1.2.0/24 to subnet 10.1.1.0/24.
[DeviceB-ipsec-transform-set-tran1] esp encryption-algorithm sm4-cbc
[DeviceB-ipsec-transform-set-tran1] esp authentication-algorithm sm3
[DeviceB-ike-proposal-10] authentication-method sm2-de
[DeviceB-ike-proposal-10] authentication-algorithm sm3
[DeviceB-ike-proposal-10] encryption-algorithm sm4-cbc
[DeviceB] ike profile profile1
[DeviceB-ike-profile-profile1] exchange-mode gm-main
[DeviceB-ike-profile-profile1] certificate domain domain2
[DeviceB-ike-profile-profile1] proposal 10
# Configure the local ID as IP address 2.2.2.2.
[DeviceB-ike-profile-profile1] local-identity address 2.2.2.2
# Configure a peer ID with the identity type as IP address and the value as 1.1.1.1/16.
[DeviceB-ike-profile-profile1] match remote identity address 1.1.1.1 255.255.0.0
[DeviceB-ike-profile-profile1] quit
# Create an IKE-based IPsec policy entry. Specify the policy name as use1 and set the sequence number to 10.
[DeviceB] ipsec policy use1 10 isakmp
# Specify the remote IP address of the IPsec tunnel as 1.1.1.1.
[DeviceB-ipsec-policy-isakmp-use1-10] remote-address 1.1.1.1
[DeviceB-ipsec-policy-isakmp-use1-10] security acl 3101
[DeviceB-ipsec-policy-isakmp-use1-10] transform-set tran1
[DeviceB-ipsec-policy-isakmp-use1-10] ike-profile profile1
[DeviceB-ipsec-policy-isakmp-use1-10] quit
10       SM2-DE             SM3         SM4-CBC         Group 1       86400
    1               2.2.2.2               RD           IPsec
Flags:
  IPsec policy: map1
  Sequence number: 10
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1456
    Tunnel:
    Flow:
    [Inbound ESP SAs]
      SPI: 1451246811 (0x568044db)
      Transform set: ESP-ENCRYPT-SM4-CBC ESP-AUTH-SM3
      Status: Active
    [Outbound ESP SAs]
      SPI: 2692887942 (0xa0823586)
      Status: Active
Example: Configuring IKEv2 with RSA signature authentication
·     Device A and Device B use IKEv2 to negotiate IPsec SAs.
·     Both Device A and Device B use RSA signature authentication.
Figure 3 Network diagram
Procedures
# Define an ACL to identify traffic from subnet 10.1.1.0/24 to subnet 10.1.2.0/24.
# Create an IKEv2 profile named profile1.
[DeviceA] ikev2 profile profile1
# Specify the local authentication method as RSA signature authentication.
[DeviceA-ikev2-profile-profile1] authentication-method local rsa-signature
# Specify the remote authentication method as RSA signature authentication.
[DeviceA-ikev2-profile-profile1] authentication-method remote rsa-signature
[DeviceA-ikev2-profile-profile1] certificate domain domain1
[DeviceA-ikev2-profile-profile1] identity local dn
[DeviceA-ikev2-profile-profile1] match remote certificate policy1
[DeviceA-ikev2-profile-profile1] quit
# Create an IKEv2 proposal numbered 10.
[DeviceA] ikev2 proposal 10
# Set the integrity protection algorithm to HMAC-MD5.
[DeviceA-ikev2-proposal-10] integrity md5
# Set the encryption algorithm to 3DES.
[DeviceA-ikev2-proposal-10] encryption 3des-cbc
# Specify the DH group as Group 1.
[DeviceA-ikev2-proposal-10] dh group1
# Set the PRF algorithm to HMAC-MD5.
[DeviceA-ikev2-proposal-10] prf md5
[DeviceA-ikev2-proposal-10] quit
# Create an IKEv2 policy named 1.
[DeviceA] ikev2 policy 1
# Specify IKEv2 proposal 10 for the IKEv2 policy.
[DeviceA-ikev2-policy-1] proposal 10
[DeviceA-ikev2-policy-1] quit
# Create an IKEv2-based IPsec policy entry. Specify the policy name as map1 and set the sequence number to 10.
# Specify IKEv2 profile profile1 for the IPsec policy.
[DeviceA-ipsec-policy-isakmp-map1-10] ikev2-profile profile1
# Create an IKEv2 profile named profile2.
[DeviceB] ikev2 profile profile2
[DeviceB-ikev2-profile-profile2] authentication-method local rsa-signature
[DeviceB-ikev2-profile-profile2] authentication-method remote rsa-signature
[DeviceB-ikev2-profile-profile2] identity local dn
[DeviceB-ikev2-profile-profile2] match remote certificate policy1
[DeviceB-ikev2-profile-profile2] quit
[DeviceB] ikev2 proposal 10
[DeviceB-ikev2-proposal-10] integrity md5
[DeviceB-ikev2-proposal-10] encryption 3des-cbc
[DeviceB-ikev2-proposal-10] dh group1
[DeviceB-ikev2-proposal-10] prf md5
[DeviceB-ikev2-proposal-10] quit
[DeviceB] ikev2 policy 1
[DeviceB-ikev2-policy-1] proposal 10
[DeviceB-ikev2-policy-1] quit
[DeviceB-ipsec-policy-template-template1-1] remote-address 1.1.1.1
# Specify IKEv2 profile profile2 for the IPsec policy template.
[DeviceB-ipsec-policy-template-template1-1] ikev2-profile profile2
# Apply IPsec policy use1 to GigabitEthernet0/0/1.
After above configuration, IKEv2 negotiation is triggered between Device A and Device B when there is traffic between subnet 10.1.1.0/24 and subnet 10.1.2.0/24.
# Display the IKEv2 proposal configuration on Device A and Device B.
[DeviceA] display ikev2 proposal 10
IKEv2 proposal : 10
  Encryption : 3DES-CBC
  Integrity : MD5
  PRF : MD5
  DH Group : MODP768/Group1
[DeviceB] display ikev2 proposal 10
IKEv2 proposal : 10
  Integrity : MD5
  PRF : MD5
# Display the IKEv2 policy configuration on Device A and Device B.
[DeviceA] display ikev2 policy 1
IKEv2 policy : 1
  Priority: 100
  Match Local : any
  Match VRF : public
  Proposal : 10
[DeviceB] display ikev2 policy 1
IKEv2 policy : 1
  Priority: 100
  Match Local : any
  Match VRF : public
  Proposal : 10
# Display the IKEv2 SA on Device A.
[DeviceA] display ikev2 sa
Tunnel ID   Local                       Remote                      Status
  1        1.1.1.1/500                  2.2.2.2/500                  EST
Status:
IN-NEGO: Negotiating, EST: Established, DEL:Deleting
  IPsec policy: map1
  Sequence number: 10
  Mode: ISAKMP
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1456
    Tunnel:
    Flow:
    [Inbound ESP SAs]
      Connection ID: 141733920771
      Status: Active
    [Outbound ESP SAs]
      Connection ID: 141733920770
      Status: Active
# Display information about the IKEv2 SA, and IPsec SA on Device B. (Details not shown.)
