- H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
- 01-Local 802.1X Authentication Configuration Examples
- 02-RADIUS-Based 802.1X Authentication Configuration Examples
- 03-AAA Configuration Examples
- 04-ACL Configuration Examples
- 05-MPLS over ADVPN Configuration Examples
- 06-ARP Attack Protection Configuration Examples
- 07-BFD Configuration Examples
- 08-Basic BGP Configuration Examples
- 09-BGP Route Attribute-Based Route Selection Configuration Examples
- 10-EAA Monitor Policy Configuration Examples
- 11-GRE with OSPF Configuration Examples
- 12-HoVPN Configuration Examples
- 13-IGMP Snooping Configuration Examples
- 14-IGMP Configuration Examples
- 15-IPsec Configuration Examples
- 16-IPsec Digital Certificate Authentication Configuration Examples
- 17-IPv6 IS-IS Configuration Examples
- 18-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 19-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 20-IS-IS Configuration Examples
- 21-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 22-L2TP over IPsec Configuration Examples
- 23-Multi-Instance L2TP Configuration Examples
- 24-L2TP Multidomain Access Configuration Examples
- 25-MPLS L3VPN Configuration Examples
- 26-MPLS OAM Configuration Examples
- 27-MPLS TE Configuration Examples
- 28-Basic MPLS Configuration Examples
- 29-NAT DNS Mapping Configuration Examples
- 30-NetStream Configuration Examples
- 31-NQA Configuration Examples
- 32-NTP Configuration Examples
- 33-OSPFv3 Configuration Examples
- 34-OSPF Configuration Examples
- 35-OSPF Multi-Process Configuration Examples
- 36-OSPF Multi-Instance Configuration Examples
- 37-Portal Configuration Examples
- 38-PPP Configuration Examples
- 39-RBAC Configuration Examples
- 40-RMON Configuration Examples
- 41-IPv4 NetStream Sampling Configuration Examples
- 42-SNMP Configuration Examples
- 43-SRv6 Configuration Examples
- 44-SSH Configuration Examples
- 45-Tcl Commands Configuration Examples
- 46-VLAN Configuration Examples
- 47-VRRP Configuration Examples
- 48-VXLAN over IPsec Configuration Examples
- 49-WLAN AC Configuration Examples
- 50-Small and Medium-Sized Store Configuration Examples
- 51-Cloudnet VPN Configuration Examples
- 52-Ethernet Link Aggregation Configuration Examples
- 53-Ethernet OAM Configuration Examples
- 54-Outbound Bidirectional NAT Configuration Examples
- 55-NAT Hairpin in C-S Mode Configuration Examples
- 56-Load Sharing NAT Server Configuration Examples
- 57-BIDIR-PIM Configuration Examples
- 58-Control Plane-Based QoS Policy Configuration Examples
- 59-Scheduling a Task Configuration Examples
- 60-Client-Initiated L2TP Tunnel Configuration Examples
- 61-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 62-Authorized ARP Configuration Examples
- 63-GTS Configuration Examples
- 64-Traffic Policing Configuration Examples
- 65-Traffic Accounting Configuration Examples
- 66-Mobile Communication Modem Management Configuration Examples
- 67-Port Isolation Configuration Examples
- 68-PBR Configuration Examples
- 69-TFTP Client Software Upgrade Configuration Examples
- 70-FTP Client Software Upgrade Configuration Examples
- 71-FTP Server Software Upgrade Configuration Examples
- 72-Routing Policy Configuration Examples
- 73-Software Upgrade from the BootWare Menu Configuration Examples
- 74-Mirroring Configuration Examples
| 61-LAC-Auto-Initiated L2TP Tunnel Configuration Examples | 79.33 KB |
Introduction
The following information provides LAC-auto-initiated L2TP tunnel configuration examples.
The following information applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of L2TP.
Example: Configuring an LAC-auto-initiated L2TP tunnel
As shown in Figure 1, Host accesses the network on the right of the LNS through an L2TP tunnel. Establish an LAC-auto-initiated L2TP tunnel between the LAC and LNS.
Analysis
To create an L2TP tunnel on the LNS after receiving a valid tunnel setup request from the LAC, enable tunnel authentication on both the LNS and LAC, and configure parameters such as PPP users and Virtual-Template interfaces.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
Procedures
Configuring the LNS
# Assign IP addresses to interfaces.
<LNS> system-view
[LNS] interface gigabitethernet 1/0/1
[LNS-GigabitEthernet1/0/1] ip address 10.1.0.1 255.255.255.0
[LNS-GigabitEthernet1/0/1] quit
[LNS] interface gigabitethernet 1/0/2
[LNS-GigabitEthernet1/0/2] ip address 3.3.3.2 255.255.255.0
[LNS-GigabitEthernet1/0/2] quit
# Configure a local user named pc of the network type, set the password to hello, and set the service type to PPP.
[LNS] local-user pc class network
[LNS-luser-network-pc] password simple hello
[LNS-luser-network-pc] service-type ppp
[LNS-luser-network-pc] quit
# Create VT interface 1, and assign IP address 192.168.0.20/24 to the VT interface. Configure the PPP authentication method as PAP on the VT interface, and specify the VT interface to allocate address 192.168.0.2 to the PPP user.
[LNS] interface virtual-template 1
[LNS-Virtual-Template1] ip address 192.168.0.20 255.255.255.0
[LNS-Virtual-Template1] ppp authentication-mode pap
[LNS-Virtual-Template1] remote address 192.168.0.2
[LNS-Virtual-Template1] quit
# Configure domain system to perform local authentication for the PPP user.
[LNS] domain system
[LNS-isp-system] authentication ppp local
[LNS-isp-system] quit
# Enable L2TP, and create L2TP group 1 in LNS mode.
[LNS] l2tp enable
[LNS] l2tp-group 1 mode lns
# Configure the local tunnel name as lns on the LNS and specify VT interface 1 for receiving calls from the peer named LAC.
[LNS-l2tp1] tunnel name lns
[LNS-l2tp1] allow l2tp virtual-template 1 remote lac
# Enable tunnel authentication, and set the tunnel authentication key to aabbcc.
[LNS-l2tp1] tunnel authentication
[LNS-l2tp1] tunnel password simple aabbcc
[LNS-l2tp1] quit
# Configure a private network route for accessing the LAC, so that the packets to the PPP user are forwarded through the L2TP tunnel.
[LNS] ip route-static 10.2.0.0 24 192.168.0.2
Configuring the LAC
# Enable L2TP.
<LAC> system-view
[LAC] l2tp enable
[LAC] interface gigabitethernet 1/0/1
[LAC-GigabitEthernet1/0/1] port link-mode route
[LAC-GigabitEthernet1/0/1] ip address 10.2.0.1 255.255.255.0
[LAC-GigabitEthernet1/0/1] quit
[LAC] interface gigabitethernet 1/0/2
[LAC-GigabitEthernet1/0/2] port link-mode route
[LAC-GigabitEthernet1/0/2] ip address 3.3.3.1 255.255.255.0
[LAC-GigabitEthernet1/0/2] quit
# Create L2TP group 1 in LAC mode.
[LAC] l2tp-group 1 mode lac
# Configure the local tunnel name as LAC, and specify LNS IP address 3.3.3.2.
[LAC-l2tp1] tunnel name lac
[LAC-l2tp1] lns-ip 3.3.3.2
[LAC-l2tp1] tunnel authentication
[LAC-l2tp1] tunnel password simple aabbcc
[LAC-l2tp1] quit
# Create interface virtual-PPP 1. On the interface, configure the PPP username as pc and password as hello, and configure the PPP authentication mode as PAP.
[LAC] interface Virtual-PPP 1
[LAC-Virtual-PPP1] ip address ppp-negotiate
[LAC-Virtual-PPP1] ppp pap local-user pc password simple hello
[LAC-Virtual-PPP1] quit
# Configure a private network route, so that the packets to the external network are forwarded through the L2TP tunnel.
[LAC] ip route-static 10.1.0.0 24 Virtual-PPP 1
# Trigger the LAC to initiate an L2TP tunnel setup request automatically, and use the tunnel parameters configured in L2TP group 1 when setting up the tunnel.
[LAC] interface Virtual-ppp1
[LAC-Virtual-PPP1] l2tp-auto-client l2tp-group 1
# On the LNS, execute the display l2tp session command to display the established L2TP sessions.
[LNS] display l2tp session
LocalSID RemoteSID LocalTID State
9400 1 36406 Established
# On the LNS, execute the display l2tp tunnel command to view the established L2TP tunnels.
[LNS] display l2tp tunnel
LocalTID RemoteTID State Sessions RemoteAddress RemotePort RemoteName
36406 13 Established 1 3.3.3.1 1701 lac
Configuration files
· LNS:
ip address 10.1.0.1 255.255.0.0
password cipher $c$3$tUCIDRzQtW17DGjt8zjletI9YfXQnNf3
service-type ppp
tunnel name lns
tunnel password cipher $c$3$B09LxThNxJFm5UL+stnd3gnPNLffshOzMg==
l2tp enable
· LAC:
interface Virtual-PPP1
ppp pap local-user pc password cipher $c$3$5VijMUTzyEreI02qAkTT3jliyHnJYg86
ip route-static 10.1.0.0 24 Virtual-PPP1
lns-ip 3.3.3.2
tunnel name lac
tunnel password cipher $c$3$ZQaYutqU2rIW/2+D+jaDn+5fsDtE3YXs6A==
l2tp enable
Related documentation
· Layer 2—WAN Access Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides (V9)
· Layer 2—WAN Access Command Reference in H3C MSR1000[2600][3600] Routers Command References (V9)
