H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
30-NetStream Configuration Examples
30-NetStream Configuration Examples 419.33 KB
H3C Routers
Copyright © 2024 H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides examples for configuring IPv4 NetStream and IPv6 NetStream.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
This document assumes that you have basic knowledge of NetStream.
Example: Configuring IPv4 NetStream
As shown in Figure 1, configure IPv4 NetStream on the gateway to monitor traffic and user behavior of internal users in the teaching areas.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
·     You must specify the destination UDP port for NetStream data export as the UDP port number of the NetStream server.
·     In this configuration example, the NetStream server runs on IMC PLAT 7.0 (E0202).
Procedures
Configuring the gateway
# Enable NetStream for incoming and outgoing traffic on GigabitEthernet 0/0/1.
<Gateway> system-view
[Gateway] interface gigabitethernet 0/0/1
[Gateway-GigabitEthernet0/0/1] ip netstream inbound
[Gateway-GigabitEthernet0/0/1] ip netstream outbound
[Gateway-GigabitEthernet0/0/1] quit
# Specify GigabitEthernet 0/0/2 as the source interface for NetStream data packets.
[Gateway] interface gigabitethernet 0/0/2
[Gateway-GigabitEthernet0/0/2] ip address 10.1.1.1 255.255.255.0
[Gateway-GigabitEthernet0/0/2] quit
[Gateway] ip netstream export source interface gigabitethernet 0/0/2
# Specify 10.1.1.2 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Gateway] ip netstream export host 10.1.1.2 5000
Configuring IMC
Adding a device
1.     Log in to IMC.
2.     Click the Service tab.
3.     From the left navigation pane, select Traffic Analysis and Audit > Settings.
4.     In the Guide to Quick Traffic Analysis And Audit Configuration area, click Device Management.
5.     Click Add.
Figure 2 Adding a device
Deploying the server configuration
1.     Click the Service tab.
2.     From the left navigation pane, select Traffic Analysis and Audit > Settings.
3.     On the Settings page that opens, click Server Management.
4.     Click the Modify icon for the NTA/UBA server.
5.     On the Server Configuration page shown in Figure 3, configure the server parameters and then click Deploy.
Figure 3 Deploying the server configuration
Adding a traffic analysis task
You can add multiple types of traffic analysis tasks. This example uses the interface traffic analysis task type.
To add an interface traffic analysis task:
3.     On the Settings page that opens, click Traffic Analysis Task Management.
4.     Click Add. The Select Task Type page opens.
5.     Select Interface and click Next. The Add Traffic Analysis Task page opens.
6.     Configure basic information and interface information, and then click OK.
Figure 4 Adding a traffic analysis task
1.     Display NetStream data export information.
[Gateway] display ip netstream export
IP export information:
  Flow source interface                           : GigabitEthernet0/0/2
  Flow destination VPN instance                   : Not specified
  Flow destination IP address (UDP)               : 10.1.1.2 (5000)
  Version 5 exported flow number                  : 8
  Version 5 exported UDP datagram number (failed) : 8 (0)
  Version 9 exported flow number                  : 0
  Version 9 exported UDP datagram number (failed) : 0 (0)
2.     Display the report of the interface traffic analysis task:
a.     Click the Service tab.
b.     From the left navigation pane, select Traffic Analysis and Audit > Interface Traffic Analysis Task. Use either of the following methods to access the report page of interface traffic analysis task Interface:
-     In the Summary List area, click the name of the interface traffic analysis task.
-     On the left navigation pane, move your mouse pointer to the shortcut menu icon next to Interface Traffic Analysis Task, and then select Interface from the menu.
Figure 5 Interface traffic analysis
Configuration files
interface GigabitEthernet0/0/2
interface GigabitEthernet0/0/1
 ip netstream export source interface GigabitEthernet0/0/2
Example: Configuring IPv6 NetStream
As shown in Figure 6, configure IPv6 NetStream on the gateway to monitor the network access traffic and behavior of internal users.
Figure 6 Network diagram
Procedures
# Assign IP address 22.1.1.2/24 to the NetStream server, and make sure the NetStream server and the gateway can reach each other. (Details not shown.)
# Enable IPv6 NetStream for incoming and outgoing traffic on GigabitEthernet 0/0/1.
[Gateway] interface GigabitEthernet 0/0/1
[Gateway-GigabitEthernet0/0/1] ipv6 netstream inbound
[Gateway-GigabitEthernet0/0/1] ipv6 netstream outbound
# Configure an IP address for GigabitEthernet 0/0/2.
[Gateway-GigabitEthernet0/0/2] ip address 20.1.1.1 255.255.255.0
# Specify GigabitEthernet 0/0/2 as the source interface for IPv6 NetStream aggregation data packets.
[Gateway] ipv6 netstream export source interface GigabitEthernet 0/0/2
# Specify 22.1.1.2 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Gateway] ipv6 netstream export host 22.1.1.2 5000
Configuring IMC
Adding a device
1.     Log in to IMC.
5.     Click Add.
Figure 7 Adding a device
5.     On the Server Configuration page shown in Figure 8, configure the server parameters and then click Deploy.
Figure 8 Deploying the server configuration
Figure 9 Adding a traffic analysis task
1.     Display IPv6 NetStream data export information.
[Gateway] display ipv6 netstream export
IPv6 export information:
  Flow destination IP address (UDP)               : 22.1.1.2 (5000)
Figure 10 Interface traffic analysis
Configuration files
 ipv6 netstream export source interface GigabitEthernet0/0/2
Related documentation
·     Network Management and Monitoring Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Network Management and Monitoring Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
