H3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR1000[2600][3600] Routers Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
69-TFTP Client Software Upgrade Configuration Examples
H3C Routers
Introduction
The following information provides an example for upgrading the software version of a centralized router through TFTP.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of TFTP.
Example: Using the device as a TFTP client to upgrade software
As shown in Figure 1, the host is connected to GigabitEthernet 0/0/1 of the router. The router acts as the TFTP client and the host acts as the TFTP server. Configure the network to realize software upgrade for the router through TFTP.
Figure 1 Network diagram
Analysis
For the router to use the new software version after reboot, specify the software image file to be used at the next boot as the main startup image file.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR2630E-X1 device.
When you configure the device as a TFTP client to upgrade software, follow these restrictions and guidelines:
·     If storage space on the device is not enough for the upgrade, use the delete /unreserved file-url command to delete unnecessary files before performing software upgrade.
·     Before rebooting the device to complete the upgrade, use the save command to save the running configuration.
Procedures
Configuring the host
# Assign IP address 192.168.100.14/24 to the host. Make sure the host and the router can reach each other. (Details not shown.)
# Start the TFTP server on the host and configure TFTP server settings such as the download path. This example uses the 3CDaemon TFTP server.
Figure 2 Configuring the TFTP server
Configuring the router
# Assign an IP address to GigabitEthernet 0/0/1 on the router.
<Router> system-view
[Router] interface gigabitethernet 0/0/1
[Router-GigabitEthernet0/0/1] ip address 192.168.100.66 255.255.255.0
[Router-GigabitEthernet0/0/1] quit
[Router] quit
# Verify that the router can ping the TFTP server.
<Router> ping 192.168.100.14
  PING 192.168.100.14: 56  data bytes, press CTRL_C to break
    Reply from 192.168.100.14: bytes=56 Sequence=0 ttl=128 time=2 ms
    Reply from 192.168.100.14: bytes=56 Sequence=1 ttl=128 time=1 ms
    Reply from 192.168.100.14: bytes=56 Sequence=2 ttl=128 time=1 ms
    Reply from 192.168.100.14: bytes=56 Sequence=3 ttl=128 time=1 ms
    Reply from 192.168.100.14: bytes=56 Sequence=4 ttl=128 time=1 ms
  --- 192.168.100.14 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 1/1/2 ms
# Download upgrade file test.ipe from the TFTP server to the router.
<Router> tftp 192.168.100.14 get test.ipe
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 58.7M  100 58.7M    0     0  1193k      0  0:00:50  0:00:50 --:--:-- 1127k
# Specify upgrade file test.ipe as the main startup image file for the router.
<Router> boot-loader file cfa0:/test.ipe main
Verifying the IPE file and the images.....Done.
H3C xxx images in IPE:
  test-cmw910-boot-r9141p16.bin
  test-cmw910-system-r9141p16.bin
This command will set the main startup software images. Continue? [Y/N]:y
Add images to the device.
Decompressing file test-cmw910-boot-r9141p16.bin to flash:/test-cmw910-boot-r9141p16.bin.........Done.
Decompressing file test-cmw910-system-r9141p16.bin to flash:/test-cmw910-system-r9141p16.bin.................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on the device.
# Specify upgrade file test-old.ipe as the backup startup image file for the router.
<Router> boot-loader file cfa0:/test-old.ipe backup
This command will set the backup startup software images. Continue? [Y/N]:y
The images that have passed all examinations will be used as the backup startup
software images at the next reboot.
# Reboot the device.
<Router> reboot
# Use the display version command to display system version information after device reboot.
<Router> display version
H3C Comware Software, Version 9.1.063, Release 9141P16
Copyright (c) 2004-2023 New H3C Technologies Co., Ltd. All rights reserved.
H3C xxx uptime is 0 weeks, 0 days, 6 hours, 54 minutes
Last reboot reason : Power on
Boot image: flash:/test-cmw910-boot-r9141p16.bin
Boot image version: 9.1.063, Release 9141P16
Compiled Mar 10 2023 15:00:00
System image: flash:/test-cmw910-system-r9141p16.bin
System image version: 9.1.063, Release 9141P16
# Display the current software images and startup software images on the router.
<Router> display boot-loader
Software images on the device:
Current software images:
Main startup software images:
Backup startup software images:
  flash:/test-cmw910-boot-r9141p14.bin
  flash:/test-cmw910-system-r9141p14.bin
Configuration files
interface GigabitEthernet0/0/1
 port link-mode route
Related documentation
·     Fundamentals Configuration Guide in H3C MSR1000[2600][3600] Routers Configuration Guides(V9)
·     Fundamentals Command Reference in H3C MSR1000[2600][3600] Routers Command References(V9)
